In "TransWilts line - Swindon, Chippenham, Melksham, Trowbridge, Westbury, Salisbury" [376735/31359/18]
Posted by IndustryInsider at 23:23, 5th July 2026
Not a great start to the week with the first two trains cancelled, but after that everything ran through Melksham to give a 98.28% reliability score for the week.
Re: Disruption to train services between Reading and London - ongoing discussion
In "London to Reading" [376734/26735/7]
Posted by Chris from Nailsea at 22:21, 5th July 2026
I have been noted for occasionally writing a load of tosh on the Coffee Shop forum ...
In "London to Reading" [376733/26735/7]
Posted by grahame at 22:18, 5th July 2026
Suggesting the forum owner is writing a load of tosh is hardly likely to be a good career move.
It's AOK by invite, mind you.
One other thing to consider is trackside maintenance.  A more intensive service and changes to what can and cannot be done on or adjacent to a live line makes track access more difficult.
Yes - I had intended that to be a part of / subtext of point no.5 and perhaps should have been more specific.
In "London to Reading" [376732/26735/7]
Posted by bobm at 21:35, 5th July 2026
Re: BBC article Warleigh Weir Swimming and rail crossing
In "Portsmouth to Cardiff" [376731/32195/20]
Posted by PhilWakely at 20:47, 5th July 2026
I was there a few years ago. Whilst I was there, a chap crossed the line with a loose, young labrador dog.  The dog was clearly out of control as it ran off down the track. The chap called out frantically for the dog to return - sadly, the next thing I heard was a thump as a unit passed.
In "London to Reading" [376730/26735/7]
Posted by grahame at 19:23, 5th July 2026
So the question, to which I don't believe we the customers have ever received a full and frank answer from Network Rail, is 'Why is the railway infrastructure between London Paddington & Reading, and more particularly it seems to me between Paddington & Slough, so horrendously unreliable?'
Answers on a very large postcard.
This may be of some interest - although not much information was forthcoming...............
https://www.firstgreatwestern.info/coffeeshop/index.php?topic=29248.0
I am going to risk a summary - on just a medium sized postcard of some of the elements as I understand them:
1. Electrification to Airport Junction was done relatively 'light' with equipment designed, tested as tolerances for a relatively light electric unit running at up to 90 mph every 15 minutes rather that much longer and heavier trains, some running at higher speeds every 5 minutes on 2 lines each way.
2. There are 30 different models of points and motors across Network Rail, and no fewer than 15 of them may be found on the stretch from Paddington to Reading.  This brings a spares issue, and a knowledge issue with onsite staff not building up a daily knowledge of just one or two types, so that fixes are not routine daily jobs
3. Reduced infrastructure maintenance of the old embankments and cuttings and trackbed lead to things like slips and wetness  and earthwork decay, and that is not helped by climate changes - more extremes of weather that push the whole shooting match towards the limits of operation, and where it tends to wear/age more quickly, on more occasions
4. The lack of steam engines throwing out smoke and soot makes for a cleaner line side, which means that plants / greenery grows far more and is likely to impinge on the railway
5. The UK' modern health and safety regimes require far more caution as to how things run when there is a potential problem, and a ganger can't go out and just tweak something or bang home a rail clip that's a bit loose any more between trains.  And trains aren't allowed to run in "it'll probably hold out" track mode.
There's potentially a load of tosh in what I write - I welcome comments on the above to put me right, or to add other items.
In "London to Reading" [376729/26735/7]
Posted by broadgage at 19:18, 5th July 2026
Modern batteries need very little maintenance, and diesel engines less than in the past.
A seldom used battery should last half the life of the train.
I would design for battery operation at about  a half of normal speed to keep costs down.
I also believe that all new trains should be fitted with opening windows for hot weather air conditioning failures. Electrically  locked to prevent needless opening.
In "London to Reading" [376728/26735/7]
Posted by grahame at 19:00, 5th July 2026
This only underlines my long held view that ALL new electric trains should be fitted with a battery or diesel engine, so as to permit continued operation when the wires come down.
Consideration should be given to retrofitting batteries to existing electric trains.
Yes but ...
Batteries and diesel engines require maintenance, and are only going to help when the knitting is not physically blocking / fouling or has the slightest possibility of fouling the tracks on which the trains will run.   You are in effect suggesting everything should be bi-mode with the added complications of things like control systems that are going to be needed whether the backup engines are 280 horsepower or 2800 horsepower, and set up to allow 125 mph running or 25 mph running.  You may save a bit if you have to be stationary to switch modes.
In "London to Reading" [376727/26735/7]
Posted by broadgage at 18:34, 5th July 2026
Re: Andy Burnham and buses: article from the Guardian.
In "Looking forward - the next 2, 5, 10 and 20 years" [376726/32149/40]
Posted by grahame at 14:54, 5th July 2026
“You go from deregulation to regaining public control, it’s just unbelievable what becomes possible,” said Andy Burnham.
https://www.theguardian.com/politics/2026/jul/05/burnham-uk-transport-bee-network-manchester-buses-rail
Should - as seems probably - Andy Burnham become PM in coming weeks, he certainly comes to the role with a more active prior involvement with public transport than Keir Starmer has even had.   It will be interesting to see if the model he has used in Manchester is mapped wider, or if other issues such as "Ooze gonna pay for it" and a need for him to put his defence of the realm on his agenda where a defence of Manchester from Liverpool was unnecessary.
Mark Hopwood noted on Thursday how many PMs, SoSs and Rail Ministers have come and gone since he took up the reins at FGW/GWR and I wonder if we'll see changes in the DfT's ministers before the end of this month,
In "Looking forward - the next 2, 5, 10 and 20 years" [376725/32149/40]
Posted by Mark A at 13:29, 5th July 2026
Re: Two East Midlands Railway trains collide near Bedford, 19th June 2026
In "The Wider Picture in the United Kingdom" [376724/32151/51]
Posted by Chris from Nailsea at 12:59, 5th July 2026
BBC presenter back on air after train crash injury
BBC Radio London presenter Jo Good has returned to her show two weeks after suffering four fractures to her face in the Bedfordshire train crash.
The crash near Elstow, near Bedford on 19 June killed East Midlands Railway driver Shaun Burton and left 162 people injured, with 102 – including Good – needing hospital treatment.
Speaking on her Late Night Jo show on Friday night, Good, shared her experience and also thanked the emergency services and a train guard who managed the evacuation.
Good had been travelling back from an event in Market Harborough to London St Pancras when her carriage was hit from behind by the London-bound express train, causing it to partially roll.
After her return to air, Sara David, editor of BBC Radio London said: "We are so relieved to have Jo back on air doing what she does best. All of the team at Radio London and her listeners have been wishing her well. We are so utterly grateful she's okay."
When the collision happened, Good was thrown from her seat and hit her face, causing the fractures.
Recalling the immediate aftermath, she told listeners: "In movies, there's always screaming and high drama. There wasn't any. It was silent actually, people in the deepest shock."
She said her phone and those belonging to other passengers began sending out messages saying "you have been in a crash" along with a siren.
Good described being on the floor of the carriage with items landing on her before a "very, very, very brave guard" arrived to manage the evacuation.
Because the carriage had partially rolled in a remote location, passengers faced a jump down when disembarking and had to wait in a nearby field, she said.
In "South Western services" [376723/25368/42]
Posted by Clan Line at 11:56, 5th July 2026
https://www.wiltshiretimes.co.uk/news/26251226.push-wiltshire-towns-london-train-link-progresses/
In "TransWilts line - Swindon, Chippenham, Melksham, Trowbridge, Westbury, Salisbury" [376722/31359/18]
Posted by grahame at 11:34, 5th July 2026
14:04 Frome to Swindon due 14:57
14:04 Frome to Swindon due 14:57 will be cancelled.
15:44 Swindon to Frome due 16:38
15:44 Swindon to Frome due 16:38 will be cancelled.
Much of that now appears to be uncancelled - hope not too many people were put off! Now down to:
14:04 Frome to Swindon due 14:57 will be started from Westbury.
It will no longer call at Frome.
Weymouth - day trip from Melksham, 4th July 2026.
In "Introductions and chat" [376721/32204/1]
Posted by grahame at 10:59, 5th July 2026
Already liked by Chris from Nailsea, Mark A
Weymouth - day trip from Melksham, 4th July 2026.  I went along quietly to see how we are doing 15 years after the first "modern times" (= last 20 years) through service - the experimental service with local sponsorship, with the first Sunday morning Heart of Wessex train starting back from Swindon rather than from Westbury for seven Sundays.  At that time, we had been asked to jump five hurdles for us to be taken seriously with our requests for an improved service at Melksham which had just 2 trains each way per day, running at times that a train wasn't needed for use elsewhere and, frankly, was equally super-off-peak on our line too. Southbound at 06:35 and 19:19, northbound at 07:20 and 19:50 as I recall.
The request was to prove we had the community "ear" and could get people to use trains in Melksham.  Hard one to prove with the weekday trains at near-useless hours, the Saturday service weird (08:00 and 15:30 northbound, 15:00 and 21:30 southbound) and two Sunday service northbound at around 18:00 and 20:00 and nothing southbound as FGW had been told to run two trains from Westbury to Swindon and no requirement in the other direction.  By sponsoring the early southbound Sunday service, we (Melksham Railway Development Group, Wiltshire Association of Chambers of Commerce) provided the option of  a day trip from Melksham to Weymouth and back.  Fares were such that it was a good price, and in those days some free car parking at Melksham Station was available.
Local press helped us no end, as did early social media, BBC local radio, and other networks.  People wanted to enquire by phone and we had fabulous help from a couple of ladies based with the Chambers of Commerce for the purpose (thank you Ann Marie and Vicki) in answering those and assuring people of the way it worked and joined up.  And even in those early days, we appreciated the importance of other traffic too - it's not just about Melksham.   Our train offered a seamless day out in Weymouth from Swindon and Chippenham too, and the "empty" train from Westbury to Swindon to form the service was not run empty - it took passengers, allowing residents of Westbury and Trowbridge to "escape" early on a Sunday morning as the train ran well before any other trains from those station too.
Outcome?  Huge success - we chose to promote different Sundays "hard" in Melksham, in Chippenham and in Swindon, to some extent based on people going for a one-off promotion and also based on our promotional resources. Lots of users, lots of people hearing about the line and our requests for an all day, every day, useful service.  Lots of people having a wonderful day out. I can recall standing at Weymouth station as people came back from all the things they had been doing there directing people to the train; it was five carriages, dividing in those days at Westbury with part going on to Bristol and the other part providing that weird Sunday service I have mentioned above via Melksham to Swindon.  Short platform as various stations - including Melksham in those days - meant that there were no fewer than five different sets of instructions as to which carriage to travel in.
We learned a lot about people and travel that summer. We learned how weather-dependent people's days out were. We learned just how much people wanted, needed and would use train services and connections - side-spray from the main journey if you like.  We had two problems during the season.  On one Sunday, so many people came along that the 3 car train in the morning worked, but the 2 car back from Westbury in the evening was overfull and there was a need to use "Plan B" of asking Chippenham / Swindon passengers to change at Bath and to use taxis for a final few who still could not fit from Westbury.  And we got complaints and criticism after the event for "poor promotion" from people who only heard about the trains after the season had finished; I didn't see it that way - as I explained multiple times, we could have done more but that would have been irresponsible as we would have brought out and then disappointed far more people than we could manage.
So - 15 years later - how was yesterday?
The now-summer-Saturdays "Weymouth Wizard" from Melksham picked up 27 passenger (and 9 people got off) with 119 on the train on its journey on via Trowbridge. There are 262 passenger seats on that train, so everyone was comfortably seated. As we headed south, we picked up more people along the way, with some standing from Yeovil though there were also a handful of seats not taken. My estimate would be between 300 and 320 on the train.    The train left Melksham on time at 09:09 and was on time at Dorchester, where we waited for a late-running train from London which was allowed to go first.  We the stopped at the site of Upwey Wishing Well Halt for a couple of minutes while that London train did its business at the current Upwey station and we followed it in (we did not stop at Upwey) some ten minutes late - arriving at 11:18 rather than the scheduled 11:08. No-one seemed to mind the 10 minute delay.
There is so much to DO in Weymouth!  I have shared some pictures here and leave each of them to paint 1000 words.
The direct return train does not leave until 19:38 and after exhausting myself walking around some old favourites and some new sites, and refreshing my photo-library, I stopped for a meal and for a recharge of my, my laptop's and my phone's batteries before heading back to the station.
The train had sat in the Jersey Sidings all day (that name coming from the days of boat trains for the Channel Islands) and as it was a sunny day, it was rather hot when we got on; AC soon sorted that. I estimate that there were around 200 people on board - lower than on arrival, as there are other return options for most stations, and setting of home at 19:38 is rather late for many.  There were still 72 people on the train when we left Trowbridge.  We rolled into Melksham some 15 minutes late, having waited until later than we should at Yeovil for a train from London coming off the single line to Castle Cary, and then a further wait before we went onto the single line from Trowbridge through Melksham that runs on to Chippenham. 25 people got off in Melksham, and 3 more got on.  Three cars picking up people off the train after their day out; no-one had parked their own car for the day.  No taxis called.  Everyone else was walking home or in the case of one adult group to The Bear.
That's my "journey report" and as is my habit, I ask what I learned from the day.
* I learned that our level of promotion still needs to be tailored to meet the capacity of the train.  Ideally, an extra 2 carriage unit should be attached on the way down at Westbury and that would allow us to market the service properly from Swindon / Chippenham / Melksham rather than being muted.  We really must be responsible and not cause problems south of Yeovil!
* I learned that we are very much a network - more perhaps than we have been - with people using our trains and all the trains to get around.  I met four people I know 'from Melksham while walking around Weymouth. All of them used the train to get to Weymouth - but different trains; some were on holiday for a few days, some parked at Westbury.   And so many other making different / shorter journeys on those trains.  Both run through Melksham on Saturdays all year, though not onwards to/from Weymouth come the Autumn.
* I confirmed the importance - and failures at times - of customer information at *any* station.  Weymouth station building is locked shut long before the train sets off to return, and is accessed through the rear gates. Signage does not tell you this but fortunately there are enough people around to tell you.  And the in-train display saying "next station Chippenham" as we left Trowbridge caused - err - a degree of concern.
So this is 15 years on from that first run - what would I like to see 15 more years on?
* Trains long (and reliable) enough for us and the community to be able to encourage people to use them without us having to hold back for so much of the time.
* Trains calling at Melksham at least once an hour in each direction.  Quite apart from "through train" issues that would allow other sensible connections every day without long waits / changes at Westbury
* Trains from Swindon to routinely carry on to Weymouth beyond Westbury every 2 hours, with the second train from Swindon I have mentioned just above carrying on to Southampton.  At Westbury, cross-platform 2-way connections with Bristol to Salisbury and beyond, and Bristol to Weymouth services running on the other hour so giving Swindon / Chippenham / Melksham passengers hourly good-connection links to Weymouth and to Salisbury and beyond.
* A bus connection from Melksham Station into and out of the Weymouth and all other trains to serve those residential and growing parts of Melksham that are not close to the station.
Disruption Reading - Westbury
In "London to Kennet Valley" [376720/32203/8]
Posted by John D at 09:19, 5th July 2026
Problems with singnalling near Hungerford, disruption now extended to Monday evening
Due to a fault with the signalling system between Westbury and Reading fewer trains are able to run on some lines.
Impact:
Train services running to and from these stations may be delayed by up to 20 minutes. Disruption is expected until the end of the day on 06/07/26.
https://www.gwr.com/travel-information/travel-updates/live-network-updates
In "TransWilts line - Swindon, Chippenham, Melksham, Trowbridge, Westbury, Salisbury" [376719/31359/18]
Posted by TaplowGreen at 08:55, 5th July 2026
In "Across the West" [376718/28982/26]
Posted by TaplowGreen at 08:54, 5th July 2026
Will GBR keep the management on in December?
Why wouldn’t they?
I have sympathy for ‘the management’ as they have inherited an already unreliable fleet which needed much TLC to offer up OK levels of reliability with TfW and which was left to fester for a year or two in sidings.
A far worse decision from ‘the management’ would have been to chuck them out in service at a rate of knots, and watch them screw up the main line by failing on a daily basis.
Or another poor decision would have been to take the Class 175s over a much more reliable unit…but the 175s were all that was on offer.
I'm not so sure.
I wonder if GWR and their senior management presented their CVs for consideration, listing their "achievements" whilst at the controls, how would they stack up against (for example) a new team with fresher ideas and (for example) a more customer driven culture?
For sure they've had to deal with issues such as these ageing hand-me-downs, but if you look at the relative "newness" of much of the fleet (800 series, Electrostars etc) and all the opportunities they had to deal with historic issues when more was within their control, perhaps history may not be quite so forgiving.
Maybe, as with the onset of GBR, it's just time for a change all round.
No-one's irreplaceable, after all.
That said, other than a new colour scheme, I foresee very little (positive) change under GBR - I remember the excitement on these pages when it was first announced several years ago, and having asked the well informed people here at the time what real positive difference it would make to customers, I'm still waiting for an answer.............that's not a reflection on any forum members by the way, more on reality!
Perhaps the experience with the 175s are a metaphor for the future.
Same management, same problems is my prediction. Time will tell!
An extremely plausible outcome! (and admirably succinct compared to me!)
In "London to Reading" [376717/26735/7]
Posted by TaplowGreen at 08:51, 5th July 2026
In "Across the West" [376716/31163/26]
Posted by GBM at 08:11, 5th July 2026
Alterations to services between Westbury and Reading
Train services running to and from these stations may be delayed or diverted. Some stations between Westbury and Reading will not be served. Disruption is expected until 08:00 04/07.
"Disruption is expected until the end of the day on 06/07/26" (!)
Train services running to and from these stations may be delayed by up to 20 minutes or diverted. Some stations between Westbury and Reading will not be served. Disruption is expected until the end of the day on 06/07/26.
There is a fault with the signalling system in the Hungerford area.
We can run our trains via an alternative route between Melksham and Hullavington. This will extend journey times.
Last Updated:04/07/2026 16:04
((Issued yesterday!))
In "London to Reading" [376715/26735/7]
Posted by Bob_Blakey at 07:46, 5th July 2026
In "London to Reading" [376714/26735/7]
Posted by broadgage at 22:01, 4th July 2026
I expect Coffee Shop member 'TaplowGreen' will be keeping an eye on it.
And also broadgage.
In "Across the West" [376713/28982/26]
Posted by IndustryInsider at 19:28, 4th July 2026
Already liked by TaplowGreen
Why wouldn’t they?
I'm not so sure.
Time will tell!
In "Across the West" [376712/31163/26]
Posted by TaplowGreen at 18:09, 4th July 2026
Re: Server slow ...
In "News, Help and Assistance" [376711/30293/29]
Posted by grahame at 16:10, 4th July 2026
The number on line peaked at 8771 earlier today.  That’s a rather unwelcome new record for the most on line at anyone time in the forum’s history.
Indeed ... and I found a common theme in many of the excess visitors and diverted them away ... for a couple of minutes until I realised that I fell into the common theme too and I had diverted myself away.
I am looking for other themes / patterns ... watch this space.
In "Across the West" [376710/28982/26]
Posted by TaplowGreen at 16:09, 4th July 2026
Why wouldn’t they?
I'm not so sure.
Re: Server slow ...
In "News, Help and Assistance" [376709/30293/29]
Posted by bobm at 14:27, 4th July 2026
Re: Weather updates from across the UK and implications for infrastructure - 2026
In "The Wider Picture in the United Kingdom" [376708/31355/51]
Posted by Chris from Nailsea at 10:23, 4th July 2026
UK temperatures forecast to exceed 30C as another heatwave imminent
Parts of the UK are set to heat up from this weekend, with forecasters warning that temperatures could exceed 30C.
For some areas this will mark the third heatwave of the year.
Highs could reach 33C for southern and south-eastern England with 30C possible as far north as South Yorkshire. It will be cooler in the west.
While this latest hot spell is not expected to be as intense as the record-breaking heatwave in late June, it looks set to last significantly longer, potentially into the middle of the month.
Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion
In "London to the West" [376707/31911/12]
Posted by Mark A at 09:52, 4th July 2026
Several empty stock moves but anything for (sleepy) passengers before the 07:40?
Re: GWR Community Rail and Stakeholder conference - 2.7.2026 - Summary report
In "Across the West" [376706/32196/26]
Posted by grahame at 08:34, 4th July 2026
Slide set - for Coffee shop members and thanks to GWR at:
https://www.firstgreatwestern.info/mirror/GWR_crcof26.pdf
