| Re: North Cotswold line delays and cancellations - 2025 In "London to the Cotswolds" [368658/29711/14] Posted by Witham Bobby at 14:35, 27th November 2025 | ![]() |
27.11.2025
11:52 London Paddington to Hereford due 14:44 was terminated at Worcester Shrub Hill.
It will no longer call at Worcester Foregate Street, Malvern Link, Great Malvern, Colwall, Ledbury and Hereford.
This is due to a safety inspection of the track.
Last Updated:27/11/2025 14:21
15:18 Hereford to London Paddington due 18:29 will be started from Worcester Shrub Hill.
It will no longer call at Hereford, Ledbury, Colwall, Great Malvern, Malvern Link and Worcester Foregate Street.
Last Updated:27/11/2025 14:20
Is there a GW service that fails to reach it's intended end of journey as often as 1W02?
| Re: Problems with IET trains from April 2021 In "Across the West" [368657/24934/26] Posted by matth1j at 14:01, 27th November 2025 | ![]() |
Any suggestions why it's happening now - what's changed?
| Re: Problems with IET trains from April 2021 In "Across the West" [368656/24934/26] Posted by bradshaw at 13:59, 27th November 2025 | ![]() |
Reports appearing that GWR IETs are having problems with the fuel pumps on the Generating Units.
This is affecting numerous units
https://x.com/cmpd_date/status/1993100923288404229?s=61&t=VlafMC5gF9tidw36b1Y8JQ
https://x.com/gordondudman/status/1994021321836032219?s=61&t=VlafMC5gF9tidw36b1Y8JQ
https://x.com/chimewhistle/status/1993707713839485201?s=61&t=VlafMC5gF9tidw36b1Y8JQ
| Re: Re-opening the Cowley branch to passenger traffic In "London to Didcot, Oxford and Banbury" [368655/27074/9] Posted by Noggin at 13:53, 27th November 2025 | ![]() |
With apologies for continuing the thread drift (does this warrant its own topic? Not sure...) Cheltenham Road Viaduct does look to be reasonably capacious (see Google Maps image). Clause 18 of The Great Western and Midland Railways (Clifton and Bristol) Act of 1871 implies that part or all of the line was originally built to broad guage, so I suspect they at least allowed for this - even though the iron spans of the bridge were cast in Derby, which suggests the contract may have been let by the Midland.
Apologies too for thread drift. AFAIK Cheltenham Road Viaduct is double-track as-built (standard not broad gauge). Assuming it's structurally sound, the problem is that if you redouble, you have to rebuild Montpelier and Redland stations which will mean lifts etc. and I suspect £10m+ each by the time you are done (not to mention they are tight sites very close to housing). IIRC, there is a plan being progressed by WECA and NR to redouble up to (St Andrews?) tunnel east of Montpelier Station with a revised junction onto the mainline which would give a significant capacity uplift for less money and minimal disruption.
| Re: 175s to GWR In "Across the West" [368654/28982/26] Posted by eightonedee at 13:25, 27th November 2025 | ![]() |
There's no spares although talk of TFW 150s coming.
If so, let's hope TFW looked after them better than the 175s. Or are they coming for cannibalising for spares?
| Re: Re-opening the Cowley branch to passenger traffic In "London to Didcot, Oxford and Banbury" [368653/27074/9] Posted by Chris from Nailsea at 11:59, 27th November 2025 | ![]() |
It probably does: I'll look into that this afternoon. CfN.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 In "TransWilts line" [368652/29726/18] Posted by grahame at 11:43, 27th November 2025 Already liked by Mark A | ![]() |
What's your suggestion then? Don't cancel it until being sure around an hour from time of service?
No
Don't mention it at all (until it doesn't set off from origin, just to be ultra-sure?
No
(Don't cancel it in the first place would be obvious suggestion, but sometimes it has to happen)
No - none of the above. For all my negative responses, good serious discussions with GWR 10 days ago on how to deal with these circumstances. I do agree that cancellations shouldn't happen in the first place. If on-the-day announced cancellations including "false" ones could be reduced from the 14% they were early this month prior to the GWR meeting, the problem would be far less. Better to treat the disease rather than the symptoms, though the worst effects of the symptoms need to be looked after.
| Re: Bath and Wiltshire Metro In "TransWilts line" [368651/30454/18] Posted by John D at 11:03, 27th November 2025 | ![]() |
Just playing with AI (Gemini), asking about this sort of thing, and it mentioned that proposed improvements include reinstating the unused platform at Chippenham (nearest the main building), as well as Westbury. That was news to me - has it got it right? I've probably just missed it.
Broadly, yes ...
It will be interesting to see if it can fit, since the track on the Bristol-bound platform was slewed over somewhat and the platform widened. Also to see how they deal with the ticket barrier halfway down the platform and the recent construct which I believe helps shield the barriers and staff from the elements.
Personally speaking, I would be attracted by an Arnos Grove type layout with the local trains in the centre, able to exit both ends onto and from either line. Long enough to put a freight out of the way in an emergency.
I would guess it would be cheaper to reopen half the platform, as a bay facing Melksham, than create a loop.
Wouldn't be as flexible as three platforms where centre one is used for reversing trains, or as a long reversible freight loop.
At the moment the crossovers at Thingley Junction don't allow trains to depart for Melksham and Bath as parallel moves (actually it can be done, but I think the mainline train needs to continue wrong normal line to Bathampton currently, so can only happen if nothing is coming from Bath for about 15 minutes)
| Full and standing 27 November 2025 In "London to the Cotswolds" [368650/31160/14] Posted by Witham Bobby at 11:03, 27th November 2025 | ![]() |
Facilities on the 09:52 London Paddington to Hereford due 12:46.
This is due to overcrowding.
Service full and standing. First class not available.
Last Updated:27/11/2025 10:00
Five cars, according to RTT. As I type this, the train is approaching its Oxford stop. Hopefully, the passenger load will thin out a bit, and the journey over The Cotswolds will be less uncomfortable
Crowded with people fleeing Rachel's budget?
| Re: 175s to GWR In "Across the West" [368649/28982/26] Posted by REVUpminster at 09:50, 27th November 2025 | ![]() |
Modern Railways says that the Castles are definitely finished, and any lack of 175s will be made up with 150s
15 150s in use today. There's no spares although talk of TFW 150s coming.Strangely on the Devon metro today there are no 158s. Seven turbos (one 2 car) operating. One two car 150 cancelled from Paignton. Two 150s being used on the busiest train from Barnstaple.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 In "TransWilts line" [368648/29726/18] Posted by ChrisB at 09:42, 27th November 2025 | ![]() |
| Re: 175s to GWR In "Across the West" [368647/28982/26] Posted by ChrisB at 09:21, 27th November 2025 | ![]() |
| Re: Re-opening the Cowley branch to passenger traffic In "London to Didcot, Oxford and Banbury" [368646/27074/9] Posted by Red Squirrel at 09:17, 27th November 2025 | ![]() |
| Re: 175s to GWR In "Across the West" [368645/28982/26] Posted by bradshaw at 09:16, 27th November 2025 | ![]() |
Comments on Twitter/X about the 175s
Senior GW source says nothing has been decided yet,but says that a "hush-hush" working group has been set up for that purpose.They also said that GW will not officially acknowledge its existence! Obviously, with two weeks until new timetable, a decision will have to be made soon.
https://x.com/chimewhistle/status/1993967812826518010?s=61&t=VlafMC5gF9tidw36b1Y8JQ
Being used for driver training is a lot different from entering passenger service. GW source tells me they are in a "terrible state", saying that only the bare minimum maintenance and exams were carried out, once it was known that they were coming off lease from ATW.
https://x.com/chimewhistle/status/1993964158002274622?s=61&t=VlafMC5gF9tidw36b1Y8JQ From senior source at GWR "There is no chance at all of the 175s coming in the West Country any time soon".
https://x.com/chimewhistle/status/1993810490515190092?s=61&t=VlafMC5gF9tidw36b1Y8JQ| Re: GWR Train / Bus integration - WWRUG, 26th November 2025, Trowbridge. All welcome In "Diary - what's happening when?" [368644/30844/34] Posted by grahame at 08:23, 27th November 2025 | ![]() |
Excellent meeting and networking last night
Slide set shared for members at https://www.firstgreatwestern.info/mirror/GWR_Transport_Integration_WWRUG_261125.pdf
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 In "TransWilts line" [368643/29726/18] Posted by grahame at 08:03, 27th November 2025 Already liked by Mark A | ![]() |
Last night I travelled on the 21:22 from Trowbridge to Melksham after the West Wiltshire Rail User Group meeting. That was the same train that I caught home from the previous meeting which was in September, but that night the train had been announced as cancelled on JourneyCheck and other systems and only re-instated late on. 15 passengers when we left Trowbridge last night - not a lot, but three times the five passengers on that day in September. So evidence confirming that JourneyCheck and the various electronic systems do reach people and send them away, and that phantom cancellations really do damage the customer base. I understand that trains cancelled and re-instated do not show up on industry stats so presumably the TOC is not sanctioned for poor performance in any way.
| Re: Holding GWR to account - service reliability In "TransWilts line" [368642/31113/18] Posted by TaplowGreen at 07:57, 27th November 2025 | ![]() |
Of course it does, TG. That's the way the TUPE regulations work.
Then I guess it comes back to the question I asked over a year ago and has never been answered.....what positive differences can customers expect post nationalisation?
When the service collapses the sentiment here is often "don't blame GWR, it's the DfT who pull the strings"
So what'll change for the better?
Nothing! It’ll get worse, far worse.
When the service collapses it’ll be because of “14 years of Tory austerity”
Yep, I would imagine that "line against enquiry" has already been drafted and is ready to be issued to all concerned!
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 In "TransWilts line" [368641/29726/18] Posted by grahame at 07:51, 27th November 2025 | ![]() |
05:11 Gloucester to Southampton Central due 08:09
05:11 Gloucester to Southampton Central due 08:09 will be terminated at Salisbury.
It will no longer call at Romsey and Southampton Central.
| Re: North Dorset Railway Trust - Shillingstone In "Campaigns for new and improved services" [368640/23009/28] Posted by grahame at 23:09, 26th November 2025 Already liked by Western Pathfinder | ![]() |
https://www.bbc.co.uk/news/articles/cvgr73ep9l7o
First locomotive crosses bridge since 1966 closure
Volunteers rebuilding a section of railway ripped up in the 1960s are celebrating after witnessing a locomotive cross the station bridge for the first time in nearly 60 years.
Shillingstone station in Dorset closed in 1966 but, in 2005, a group of locals took on the lease and began restoration work, initially opening a museum and cafe.
In July, North Dorset Railway completed a four-year project to double the length of the track to half a mile (0.8km), with the aim of one day offering brake van rides to museum visitors.
On Saturday, volunteers braved the rain to see the Hudswell Clarke diesel cross the newly renovated bridge over Bere Marsh.
| Re: Bath and Wiltshire Metro In "TransWilts line" [368639/30454/18] Posted by grahame at 22:00, 26th November 2025 Already liked by Andy E, Oxonhutch, Witham Bobby | ![]() |
Broadly, yes ...
| Re: Bath and Wiltshire Metro In "TransWilts line" [368638/30454/18] Posted by matth1j at 17:06, 26th November 2025 | ![]() |
According to AI:
The reinstatement of a disused platform at Chippenham station is a critical component of the Bath & Wiltshire Metro proposal, even though the station already has two operational platforms (Platform 1 for westbound services and Platform 2 for eastbound services).
The goal is to increase the operational flexibility and capacity of the entire rail corridor, especially for the local services coming from the Melksham/Trowbridge line.
Here is how the reinstatement fits into the plan:
1. What Platform is Being Reinstated?
Chippenham used to have a third platform (often referred to historically as the original Down Platform, now disused).
Location: This disused platform is the one immediately next to the main station building on the south side, which currently serves as a sort of concourse/access area.
Why it was removed: It was taken out of use in 1976 and the track was slewed (moved) to the south side of the island platform (Platform 1) to allow the new, longer High Speed Trains (HSTs) to be fully accommodated on the island platform.
2. The Purpose of Reinstatement (Platform 3 / Down Local)
The return of this platform is essential for the proposed increase in local service frequency:
Segregation of Services: The Great Western Main Line (GWML), which runs through Chippenham, is a high-speed route used by frequent long-distance services to and from London Paddington and Bristol/South Wales. The TransWilts services (the local Metro service) share these main lines.
Preventing Bottlenecks: With only two operational platforms, if a local Metro train terminates at Chippenham or has a scheduled longer stop, it holds up the main line, causing delays to the high-speed intercity services.
Dedicated Local Platform: Reinstating the third platform (let's call it the Down Local Platform for simplicity) would allow the new, more frequent Metro services (the two-trains-per-hour service) to use a dedicated platform. This would:
Increase Reliability: The local service could run independently, without waiting for a gap in the main line traffic, greatly improving reliability.
Increase Capacity: It frees up the main line platforms (1 and 2) for the high-speed services, increasing the overall throughput of the station.
In essence, while the Melksham Passing Loop unlocks the capacity between Trowbridge and Chippenham, the reinstatement of a platform at Chippenham unlocks the capacity at the station itself, allowing the increased number of trains to turn around, terminate, or stop without disrupting the main high-speed traffic.
| Re: Bath and Wiltshire Metro In "TransWilts line" [368637/30454/18] Posted by matth1j at 17:01, 26th November 2025 | ![]() |
| Re: Re-opening the Cowley branch to passenger traffic In "London to Didcot, Oxford and Banbury" [368636/27074/9] Posted by Chris from Nailsea at 16:48, 26th November 2025 Already liked by johnneyw | ![]() |
Pleasingly, I'm hard pushed to think of any, save perhaps the railway arch over the A38 Gloucester Road (or is it Cheltenham Road there?)
It is Cheltenham Road there - hence the term 'Cheltenham Road arches'.
The A38 northbound doesn't become Gloucester Road until the junction with Zetland Road.
CfN (used to live in Kingsdown)
Briefing issued - mirror for members at https://www.firstgreatwestern.info/mirror/D052025_251126_Dean_Forest_Railway.pdf
Important safety messages
This accident demonstrates the importance of heritage railway staff and volunteers:
* only undertaking safety-critical tasks for which they have been trained and
assessed as competent
* being aware of any loading gauge restrictions when transporting large or
unusual loads by train.
This accident also underlines the importance of heritage railways undertaking
appropriate risk assessments for their activities and implementing effective
controls.
Summary of the accident
At around 10:55 on Thursday 14 August 2025, part of a 360-degree excavator being
transported on a train struck the footbridge which carries a public footpath over the
Dean Forest Railway at St Mary’s Halt station, Lydney, Gloucestershire. The train
was travelling at around 10 mph (16 km/h) when the accident occurred. The
footbridge collapsed as a result of the collision, with parts of it falling onto the station
platform and the moving train.
There were no injuries caused by the accident. No pedestrians were using the
footbridge when the accident occurred, and the railway was not open to the public.
The train, operated by Dean Forest Railway volunteer staff, was transporting an
excavator owned by the railway from Lydney Junction to Whitecroft, a distance of
around 3 miles. The train consisted of a class 08 diesel-electric shunting locomotive
propelling two 4-wheel well wagons and a bogie brake van, which was at the leading
end. The excavator was on the wagon nearest the locomotive, but the train driver
was unable to see it as the locomotive’s driving cab was at the rear.
controls.
| Re: North Cotswold line delays and cancellations - 2025 In "London to the Cotswolds" [368634/29711/14] Posted by charles_uk at 14:22, 26th November 2025 | ![]() |
Earlier 1P26 1059 Great Malvern to London Paddington was cancelled between Oxford and London Paddington due to unknown cause (ZW)
13:50 London Paddington to Great Malvern due 16:15 will be started from Oxford.
It will no longer call at London Paddington and Reading.
13:18 Hereford to London Paddington due 16:24 has been cancelled.
The service following the cancellation from Hereford (15:18 Worcester Foregate Street to London Paddington) is a five car short-formation. On the other hand, the truncated services from/to Great Malvern were nine coaches vice five so swings and roundabouts.
| Re: Re-opening the Cowley branch to passenger traffic In "London to Didcot, Oxford and Banbury" [368633/27074/9] Posted by johnneyw at 14:20, 26th November 2025 | ![]() |
Thanks all; very useful.
There a some lines around Bristol (and Wiltshire!) which could benefit from re-doubling, and I have always assumed that if an alignment once had two tracks it should be piossible to re-double it without needing to acquire land.
I can see now that this may not always be the case -although thanks to Brunel, we may have more wiggle room than some!
I've been having a ponder over any problem points for redoubling on The Beach Line, a line that I'm reasonably familiar with and which is relatively short but which may need additional passing loops for a more "metro like" frequency.
Pleasingly, I'm hard pushed to think of any, save perhaps the railway arch over the A38 Gloucester Road (or is it Cheltenham Road there?). Could there be gauge or weight restriction issues there?
| Re: Holding GWR to account - service reliability In "TransWilts line" [368631/31113/18] Posted by a-driver at 12:25, 26th November 2025 Already liked by Phil, TaplowGreen | ![]() |
| Re: Holding GWR to account - service reliability In "TransWilts line" [368630/31113/18] Posted by grahame at 12:04, 26th November 2025 Already liked by Mark A | ![]() |
An update on this story at https://grahamellis.uk/blog1791.html
Last night (25.11.2026), I attended Melksham Town Council's Economic Development and Planning meeting to speak to the agenda item 13 - asking the Town Council to add their support to the MTUG request / campaign to get GWR to run the current timetabled service more reliably. Delighted that they added their support, unanimously, and with some very kind words for the work we do at MTUG.
We now have both Melksham Town and Melksham Without, and our MP, fully on board with the call - a not just making the cal but pressing with us for fixing. All six public transport providers have helped by proofing / approving a Melksham timetable booklet ready for the December Timetable change, and we are looking to all raise the bar in partnership on reliability, friendliness and use of all public transport services.
Found this on Facebook post by Cllr Mike Bell
WHY DOES WINTERSTOKE BRIDGE REPLACEMENT TAKE 18 MONTHS❓
Why is the Winterstoke Bridge Replacement Scheme going to take approx 18 months? Here’s the full detailed answer from the contractor courtesy of my colleague Cllr Ciarán Cronnelly - Weston super Mare.
Matt Whale, Octavius:
"The biggest engineering challenge on the Winterstoke Road Bridge is the ground conditions, with Weston-super-Mare being situated on the alluvium of the Somerset Levels, this fenland is the second largest in England and is characterised by low-lying land prone to flooding, the alluvium is deep, extremely soft, and unstable in nature. The poor ground conditions are the main reason the existing structure has failed albeit it was only ever supposed to be a temporary structure and it was never designed to carry modern traffic flows or weights.
The ground conditions are also a major reason (the main reason) why we cannot install a new bridge by lifting it in as a complete unit, nor by constructing it off-line and sliding it into position using SPMTs. Much of the new bridge structure sits below ground level and must be supported on 24 no. 1.2m diameter steel-cased bored concrete piles, each drilled to a depth of 35m to reach stable Mercia Mudstone.
With a 60m span and a weight of over 2000 tonnes, a bridge of this scale would simply sink without piling, and so would any heavy lifting or sliding equipment required to install it. Prefabrication and sliding options are therefore ruled out.
Even if the bridge could be built off-line, we would still need to install the piled substructure first and the ground conditions dictate that this is a slow and highly controlled process. The piles are so large, and the soil so challenging, that we are using the smallest rig capable of achieving both the required depth and diameter, meaning progress is limited to approximately one pile every other day, all being carried out in a small area adjacent to a live railway line.
The work above takes considerable time, and we have many other challenges to factor in as well:
1) Spatial constraints and proximity to businesses and properties – when the original bridge was built it was surrounded by fields, rhynes and a flak tower and not the built-up area you see today.
2) A large drainage culvert and water course (Rhyne) underneath the existing bridge – A high water table adds to the difficult ground condition challenges and must be carefully managed.
3) The 100mph Bristol to Exeter Mainline to which the project team or NSC don’t have any control over - Work over the railway line can only be carried out when there are no passenger and freight trains running and these types of closures usually must be booked months, sometimes years in advance, and the operational window is small.
If Network Rail and Train Operators did agree to diversions or daytime closures the project would be expected to pay out £millions due to compensation payments to cover the Train Operator Companies (TOCs) and the Feight Operator Companies (FOCs) loss of income, as well as passenger compensation for delays potentially all the way up to London and beyond.
Delays on this section of mainline can affect the rolling stock all over the country causing further delay and compensation, Trains are unable to be diverted around Weston-super-Mare due to this being the Bristol to Exeter Mainline and having two tracks, the loop line into Weston is a single bi-directional line.
The railway track itself below the bridge is also susceptible to the poor ground conditions with heave or ‘lifting’ expected once the old bridge is removed, this must be carefully managed as the slightest twist or fault in track alignment can potentially derail a train travelling at 100mph.
We are also very mindful to keep the community connected with a temporary footbridge which also serves a secondary purpose to ensure uninterrupted service supplies when the old bridge is removed with BT, City Fibre, gas and watermains currently crossing it, supplying businesses and hundreds of private properties.
This is a significant engineering challenge, and the design also must consider the poor ground conditions, pedestrians, trains, and utilities.
No records of the existing bridge exist (not surprising being built by the MOD during the war) and partial demolition of the bridge while keeping a section open to traffic is not feasible, as the bridge is too small and the construction techniques used in 1941 do not allow for this approach.
When you consider the all of the above we have significant limits on what we can do, the plant and equipment we can use and the timeframes we do it in, Octavius and our specialist supply chain have the capability and expertise to carry out rapid infrastructure replacement using complex offline techniques and I have been fortunate enough to deliver a number of them, but sadly this scheme is not suited to those techniques due to the challenges I have mentioned above, you would be hard pushed to find anyone globally that could undertake this particular scheme any differently."
