Re: Melksham to Bristol Parkway - no fare, mis-advertised, mis-sold, not corrected
In "Fare's Fair" [378562/32392/4]
Posted by ChrisB at 17:24, 22nd August 2026
Round the rhubarb loop - not from Melksham I meant
In "Fare's Fair" [378561/32392/4]
Posted by grahame at 15:50, 22nd August 2026
By 'reliably', I meant throughout the day, regularly. Say at least every hour?
Ah - right.  So that means you can never reliably travel in either direction from Melksham, with gaps up to 2 hours 40 minutes, and only once a day in one direction only do two trains run at better than your definition.
It makes a huge difference to the users or potential users.   I have just turned up (elsewhere) for a service that runs every 30 minutes, knowing I can get a train soon - and I did; catching up from the train.  I am now working out how to get home - and the last leg is the interesting one.
In "Fare's Fair" [378560/32392/4]
Posted by ChrisB at 15:40, 22nd August 2026
Re: GWR IEP buffet trolley drinks question
In "Across the West" [378557/32395/26]
Posted by ChrisB at 15:09, 22nd August 2026
yup, that's them!
Re: NPPF revisions - more homes can be built near stations?
In "Looking forward - the next 2, 5, 10 and 20 years" [378556/32385/40]
Posted by REVUpminster at 15:02, 22nd August 2026
Isn't that what this planning change is all about; more housing.
As for infrastructure move the crossing to Coleford junction to make a dual track and not two single tracks. It should have been done when the original Okehampton was improved. It would benefit Barnstaple travellers as well.
Isn't Newton St Cyres already ear marked for housing? Yeoford, Crediton, Newton St Cyres will all come under the new Greater Exeter.
In "Across the West" [378555/32395/26]
Posted by Mark A at 14:40, 22nd August 2026
Ah, possibly Lakeland Dairies.
https://lakelanddairies.com/food-service/international-business/milk-butter-portions
In "Looking forward - the next 2, 5, 10 and 20 years" [378554/32385/40]
Posted by IndustryInsider at 13:41, 22nd August 2026
Yeoford has second platform that only needs re-instating. GWR would probably quote £10m.
I've lost all faith in GWR in the southwest unless someone else is paying.
Why would GWR be asked to quote on the second platform reinstatement at Yeoford?
Anyway, having visited Yeoford I really can't see how this is ever likely to happen.  There's not much of a problem reinstating the platform itself, but I am sure the residents of a small, lovely and charming sleepy village would object strongly to a load more housing being plonked in a place that sits in a natural valley.  The tight winding roads in and around the station would then see more traffic and to turn it into a place which is the size to justify a service every 30-minutes to Crediton and Exeter and an hourly service to Okehampton would need hundreds of new houses completely destroying the character of the small village.
None of the narrow roads without footpaths leading to the station can be easily widened and I'm sure modern planning regulations would insist on expensive upgrades to ensure pedestrian safety immediately around the station.
As you mention, the pathing is very tight between Exeter and Crediton and with the Okehampton service having a little as 5 minutes turnaround, so there would need to be further infrastructure improvements to support the 3-4 minutes additional time the line would be occupied between Crediton and Okehampton per hour if the train was to stop in each direction.
I'd estimate at least £25m.  Money that would be much better spent elsewhere.
In "TransWilts line - Swindon, Chippenham, Melksham, Trowbridge, Westbury, Salisbury" [378553/31359/18]
Posted by TaplowGreen at 13:09, 22nd August 2026
Cancellations to services between Swindon and Westbury via Melksham
Due to a fault with the signalling system between Swindon and Bristol Temple Meads some lines are blocked. Disruption is expected until 16:00 22/08.
Train services between Swindon and Westbury via Melksham will be cancelled.
In "Fare's Fair" [378551/32392/4]
Posted by grahame at 13:03, 22nd August 2026
[Can you reliability travel via Rhubarb Loop?]
More so than many other services - the 07:04 from Bath Spa to Filton Abbey Wood has run on 19 out of the last 20 days (so 5% cancellation rate) and has averaged just a 3 minute late arrival.
In "Shorter journeys in Plymouth and Cornwall" [378550/28556/25]
Posted by REVUpminster at 13:00, 22nd August 2026
175003 has been entrusted with Newquay today. It is the most reliable train.
On Thursday it completed its full passenger diagram starting at 0655 Exeter and finishing there at 2237.
Also running backwards and forwards between Exeter and Plymouth was 175006+175115 completing 500 miles with no incidents. It wasn't in passenger service just mileage accumulation.
At Exeter it coupled up with 175003 in a 2+3+2 and returned to Laira as 5P28. The first 7 car formation.
It was planned to repeat it on Friday but cancelled due to staff shortages.
In "Looking forward - the next 2, 5, 10 and 20 years" [378549/32385/40]
Posted by REVUpminster at 12:44, 22nd August 2026
I've also thought housing could be developed at Yeoford. Trains every half an hour, roads are terrible. It would need track infrastructure improvements which GWR wouldn't do unless someone else pays. Maybe the new GBR would?
Not so much track as a second platform?
The only think we know about the "real" next GBR generation is that we don't know what it will bring ...
Paignton station since the fire which still hasn't fully opened platform 2 for nine car trains. Supposed to be next week. The ticket hall and booking office don't look to be open for weeks. The damage was smoke related. The frontage has been boarded up across the car park. The toilets on platform 2 in a shed further along have been open when staff are present. There is a new back door fire escape to the staff accommodation that has been installed since the fire. The repairers don't work weekends; no urgency.
On a Saturday the toilets close at 1630 and the staff all go by 1700; yet that station is still busy. All the tour trains and their has been one virtually every Saturday and some midweek all depart about 1730. Because they cannot stop in platform 2 to pick up (11 coaches and a diesel at each end) Paignton has lost a lot of business.
In "Shorter journeys in Plymouth and Cornwall" [378548/28556/25]
Posted by TonyN at 11:55, 22nd August 2026
Due to more trains than usual needing repairs at the same time between Truro and Falmouth Docks fewer trains are able to run.
Train services running to and from these stations may be cancelled. Disruption is expected until the end of the day.
One of the trains that operates the Truro to Falmouth Docks service has developed a fault that needs mechanical attention. We do have another train that is operating the service, which means we can only operate half of the service for the rest of today.
If you are wanting to travel to Falmouth, please check your journey and if there is not a service, we recommend take a local bus, where your ticket can be used at no extra cost.
Same again today......
.......one of the options on offer is "Consider postponing your journey until our service returns to normal" - extremely helpful - if anyone has a crystal ball handy!
Use the ferry from Malpas to Falmouth its more reliable.
In "Across the West" [378547/32395/26]
Posted by ChrisB at 11:50, 22nd August 2026
SEmi-skimmed UHT Dairy it is - but I can't remember the brand....
In "Across the West" [378546/32395/26]
Posted by Mark A at 11:37, 22nd August 2026
The sachets of 'Milk' (can't recall if it's actually dairy, but no matter, it's effective) - can anyone recall what it is and where it's available retail?
In "Fare's Fair" [378545/32392/4]
Posted by ChrisB at 11:01, 22nd August 2026
Distance - By actual service train.
In "Looking forward - the next 2, 5, 10 and 20 years" [378543/32385/40]
Posted by grahame at 08:26, 22nd August 2026
BTP Officers referred to to Watchdog over Levy case
In "The Wider Picture in the United Kingdom" [378542/32394/51]
Posted by TaplowGreen at 08:23, 22nd August 2026
Catalogue of errors with awful consequences.
https://www.bbc.co.uk/news/articles/cn4n55g2dejo
In "Shorter journeys in Plymouth and Cornwall" [378541/28556/25]
Posted by TaplowGreen at 08:06, 22nd August 2026
In "Looking forward - the next 2, 5, 10 and 20 years" [378540/32385/40]
Posted by REVUpminster at 07:27, 22nd August 2026
Torbay Council have proposals to develop Paignton Station and car park, the short term car park opposite, and the bus station into flats. A new multi-story car park would be built out of site behind the library in Station Lane. The are plans for flats at Victoria Square within a stones throw of the station and is a temporary car park now.
Re: Espresso - undiluted monthly compendia
In "News, Help and Assistance" [378539/22974/29]
Posted by grahame at 05:10, 22nd August 2026
Already liked by Western Pathfinder, Chris from Nailsea
After being quietly suspended for a while during a denial of service attack, I am re-enabling the espresso facility. I have also automate the default so that it becomes month-to-date without me having to go in and change it manually at the start of each month; I still have to remember on 1st January each year to update the year!
This is not a facility that gets huge use, nor would I expect it to be - but if you want to find out what we were talking about  in (say) March 2012, it will help.
Espresso now has an https wrapper which will help ensure that members don't get lots of security warnings in their browser when they use it, and may also help our search engine and AI feed visibility. I will be keeping an eye open just in case it generates significant server loads.  And I will be adding back the facility to navigate around it better too.
In "Looking forward - the next 2, 5, 10 and 20 years" [378537/32385/40]
Posted by grahame at 04:48, 22nd August 2026
Houses without requiring planning consent
They'd still need planning consent in consideration of other issues, would they not, as the following extract from NPPF says:
These should be approved, unless the benefits of doing so would be substantially outweighed by any adverse effects, when assessed against the national decision-making policies in this Framework
The NPPF is, I think, trying to say: "Developments outside settlement boundaries are usually a bad thing, but if there's a useful railway station nearby, we can say that the development is actually OK".
What I'm having trouble in deciding is whether or not the "Top 80 GVA" rule is actually doing anything useful.
I would agree.
With (any) development there will be positive and negative factors and planning discussions result not in a "100% yes" or "100% no" agreed outcome.   The various elements of the NPPF we're talking about help swing some of the factors - give extra weight to some of the elements and perhaps substantial weight that makes a difference in some cases.
I see that the Conservative-elected, Reform-representing MP for Bedwyn and Pewsey is making the local press concerning the NPPF for those two stations and the Wiltshire Gazette article has a picture of an IET at a rural-looking Bedwyn station. But then as I read the maps, Bedwyn is just outside a top 80 area.  Those are potentially an interesting watch from the sidelines.
Across the South West, most of our MPs represent parties who are not part of the government - Conservative, Liberal Democrat, Reform and Green - and they have the luxury of being able to represent their electorate without facing the hard national consequences where difficult choices which are in the country's intrerest but not in the interest of the views of their electorate, and you might expect pushback from a wide variety of places.  As I understand it, these "station rules" are only one element, and factors like building on flood plains (and railways tend to follow rivers) are still significant to put it mildly.
The "Top 80" rule does help exclude places like Lelant Saltings - there might a station there, it might be practical to stop 2 trains an hour each way, and there might be unused close to the station - but the question to be asked is "travel to WHAT work?"
In "Fare's Fair" [378536/32392/4]
Posted by grahame at 04:16, 22nd August 2026
Which route is shorter?
Journey time shorter - via Swindon.
Normally least changes on scheduled passenger trains - via Swindon (1 change)
Physical distance shorter - via Thingley Junction and the Rhubarb Loop
https://my.railmiles.me/mileage-engine/
Distance:
31mi 0ch
Route:
Melksham, Thingley Jn, Bathampton Jn, Bath Spa, Oldfield Park, Twerton, Keynsham, North Somerset Jn, Dr Day's Jn, Lawrence Hill, Stapleton Road, Narroways Hill Jn, Ashley Down, Horfield Junction, Filton Abbey Wood, Filton Jn, Bristol Parkway
or add these who
Distance:
22mi 70ch
Route:
Melksham, Thingley Jn, Thingley East Junction, Chippenham, Dauntsey, Wootton Bassett Jn, Rushey Platt, Swindon
plus
Distance:
34mi 39ch
Route:
Swindon, Rushey Platt, Wootton Bassett Jn, Little Somerford, Hullavington, Badminton, Chipping Sodbury, Westerleigh Jn, Bristol Parkway
and subtract 2 x Wooton Bassett to Swindon
Distance:
5mi 49ch
Route:
Re: What might have been - Westbury to Brussels and Swindon to Paris
In "Campaigns for new and improved services" [378535/27805/28]
Posted by grahame at 03:34, 22nd August 2026
The "trains is other liveries" website had a photoshopped picture of a 153 at Blaenau Ffestiniog in Nightstar livery and one wonders what traffic from there to the other end of the route - perhaps Venlo - might have been ... but yet ...
http://25kv.uk/fictitiousliveries.php
Re: Wilts & Berks Canal - merged posts, ongoing developments and discussion
In "Heritage railways, Railtours, buses, canals, steamships and other public transport based attractions" [378534/28863/47]
Posted by grahame at 03:29, 22nd August 2026
**J. F. Pownall has entered the chat**
https://www.nature.com/articles/149467a0
Abstract
IN a booklet entitled “The Projected Grand Contour Canal” (Birmingham: Cotterell and Co., 2s.), Mr. J. F. Pownall describes his ideas of a waterway linking together the main ports of England and accessible to coasting vessels up to 1,500 tons displacement, as well as canal barges. He points out. that in the main watersheds of England, the lowest cols are at approximately 300 ft. As a result, he plans this canal to follow as near as possible the 310 ft. contour, which would obviate canal locks, with their delay and cost of upkeep, and necessitate only a few tunnels. Already some two hundred miles of existing canals lie at about 300 ft. ; others are at lower levels. These might be linked by lifts, which have the advantage over locks in that they do not lose water in operation.
Re: New station at North Filton - now named as 'Bristol Brabazon' - ongoing discussion
In "Bristol and Bath (WECA, now WEMCA)" [378533/24927/21]
Posted by IndustryInsider at 23:49, 21st August 2026
I’m told that rains actually go some way along the Henbury line before reversing, rather than turning at Filton Abbeywood.
They go a short way onto the Filton Chord so that they're in behind BL2052 signal to shunt back into Filton Abbey Wood.
