3.7.2025 (Thursday) 10:20 - All running AOK
In "TransWilts line" [362894/29726/18]
Posted by matth1j at 10:17, 3rd July 2025
Real Time Trains makes rather better predictions
I tend to use National Rail for checking for delays etc., and on the odd occasion I've tried RTT I've found it's not showing the problems being reported by the National Rail app. Like on Monday, while NR showed the diversion via Bristol Parkway and a delay, RTT didn't.
So while RTT is great for history, I'm sticking with NR for predictions.
Re: Vivarail chosen for fast charging trial on the Greenford branch
In "Across the West" [362893/26034/26]
Posted by Ralph Ayres at 10:11, 3rd July 2025
Would it be over-pessimistic of me to think that despite the success of this trial, it may still be several years before we actually see any of these in regular service on GWR?  Infrastructure, training, certification, contracts and more still to do, and nothing ever seems to happen quickly.  Might still beat HS2 opening though!
In "TransWilts line" [362892/29726/18]
Posted by bobm at 10:08, 3rd July 2025
I don't disagree with the message, my point was as orange on cream I didn't spot it.   It was only when I went to quote the message and it was black on white that I saw it.
In "Across the West" [362891/26034/26]
Posted by Mark A at 10:02, 3rd July 2025
He says charging takes 4 minutes (2:30 in the video), but not how often it needs that; at every stop?
I think he based the 4 mins on the Greenford round trip.   The battery charge on the train never normally exceeds 80%, that's to do with battery life.
The charger is quick around 800 Volts at several hundred Amps, the train BMS (Battery Management System) controls the charge rate and the train uses 2 sets charging rails each set of rails has its own shore side battery bank
The 80% figure caught my eye, I've an app on the phone that monitors state of charge and makes a small fuss when the phone's charging and a set level of charge is reached to allow the user to stop charging it.
80% advised but this can be set to any value.
The app also tracks battery degradation, and indicates that up to 80% is efficient from that perspective, and that it's the 80 to 100% segment that causes the majority of wear to the battery. I'd been wondering about this with respect to electric vehicles and their owners' thirst for range.
In "TransWilts line" [362890/29726/18]
Posted by grahame at 07:46, 3rd July 2025
Until just now when I went to quote Graham's message did I spot his postscript about solving the root cause - clearly (pardon the pun) my eyesight isn't up to seeing that colour against the background.
My naughty little postscript in orange was supposed to point out that [they/we] are treating the symptoms and not the cause / disease - easing the pain when what is needed is action to fix the causes as far as possible.
My guesstimate is that 75% of the problems are fixable at source. Whilst that would cost money to do, it would also bring about a huge saving on the work stress of those who are trying to ease the pain, a big saving on delay/repay, and a boost to confidence in the system so that people who are wary about using the train because of its unreliability would (re)turn to rail.
I am disappointed that these fixings at source have not been done - it almost defies logic that they have not. I do have indications that much background work has been done so "they" know what to do.  Perhaps they are waiting for GBR for it to be a flagship policy of improvements once the government takes over the TOCs?
In "TransWilts line" [362889/29726/18]
Posted by grahame at 06:41, 3rd July 2025
I have spent a bit of time trying to find the specifics of the cancellation and reinstatement of these services without success.
However it seems GWR are in a bit of a no win situation when it comes to cases like this.   When the services were cancelled it was in the earnest belief that they would not run.   They could have delayed the announcement but then run the risk of being criticised for making it even more short notice.  Control and the rosters staff are eternal optimists and always hope they can pull something out of the hat and run a service.  So work continues behind the scenes to rescue a service or reduce a shortform until they run out of all options.   If they waited until they reached that point there would be a rash of last minute cancellations/alterations.   The current situation is not ideal, but personally if there are going to be cancellations I'd rather know as early as possible, even if it is later reinstated.
Thanks so much for that Bob - I have to agree that leaving it to the last minute is NOT the way to go.  And indeed the very good and often successful work of those involved to getting a service back, which is appreciated, leads to them being criticised for a false "the xx:xx train is cancelled" but it ends up running.   The very last thing  I would want encourage is a mentality that says "once a cancellation is broadcast, it is never re-instated".
I guess that a sizeable minority of cancellations are reversed - if only there was a tag line that could be added "but we are still trying to find a way of running it"; my understanding is that's a systemic problem - the options available don't include that ...
As for this morning's service from Gloucester, the confusing messages are down to the way the automated system works.  Once it went off its booked route at Standish Junction the system lost it and so defaulted to delayed.   It was only when it approached Swindon and picked up its planned route that the system started to update again.
Again - a systemic option.   Journeycheck assumes once delayed, always delayed.  It is often "hilariously" wrong on certain trains such as the sleeper ... and the very train in question in this thread - the 05:11 from Gloucester to Southampton can be as much as 20 minutes late as it passes Standish Junction, projected as 08:30 rather than 08:09 into Southampton and yet arrive there on time.   Real Time Trains makes rather better predictions, by various methods like taking the time that trains sit at intermediate stations (Swindon, Salisbury and a little at Westbury on the 05:11) and trimming then back as it predicts.  In reality, once a train is significantly delayed, it comes down to a complex mesh of factors such as platform availability at Westbury which can add significantly to the delay, together with factors already mentioned like timetabled intermediate dwells, and it's pretty unpredictable by current algorithms as to whether the delay is recovered, maintained, or gets worse.
In "Across the West" [362888/26034/26]
Posted by Electric train at 06:05, 3rd July 2025
Already liked by Mark A, PrestburyRoad
In "Across the West" [362887/26034/26]
Posted by grahame at 06:04, 3rd July 2025
No - less than that.   On the Greenford Branch, charging is once an hour at West Ealing - enough for calls at three intermediate stops (which they did make) to Greenford and then the same three stops on the way back. Total running time perhaps 40 minutes.
In "Across the West" [362886/26034/26]
Posted by matth1j at 21:57, 2nd July 2025
In "Across the West" [362885/26034/26]
Posted by BBM at 19:51, 2nd July 2025
YouTuber Jago Hazzard was invited to this week's test:
https://www.youtube.com/watch?v=4qeK3182aPQ
Re: Welfare Reform bill protest at Liverpool Lime Street - July 2025
In "Across the West" [362884/30430/26]
Posted by Chris from Nailsea at 19:44, 2nd July 2025
In the interests of context and ease of future reference, I have expanded the heading of this topic and moved it here.
As ever, I hope this helps.
In "Across the West" [362883/30430/26]
Posted by Western Pathfinder at 19:10, 2nd July 2025
Thankyou Phantom for your post ,which throws a very clear light on a situation that many of us have fortunately no experience of.
In "Across the West" [362882/29650/26]
In "TransWilts line" [362881/29726/18]
Posted by bobm at 18:16, 2nd July 2025
In "Across the West" [362880/26034/26]
Posted by Electric train at 18:04, 2nd July 2025
It looks like the trails have convinced GWR that the system works and can be applied to various routes according to this BBC news article.
https://www.bbc.co.uk/news/articles/c3355ll0krxo
I think they were convinced a while back, I have had one visit and a few meeting as part of my day job with the NR Technical Authority Engineers to look at items in the safety case and how the lineside and track mounted equipment is to be maintained NR staff competencies etc
Re: "Off on my travels again"
In "The Lighter Side" [362879/30432/30]
Posted by stuving at 17:25, 2nd July 2025
And standing on the balcony of our hotel room, look back in angers
Angers - I didn't recognise that as somewhere I've ever been. However, it turns out that I did stop for lunch in Angers in 1992. At the gare d'Angers St Laud, as it happens - though I think not the present structure, seen in your picture. I don't have a photo, nor any memory of the event after 30 years. But then I don't remember what I had for lunch last week (not a "senior" issue; I never could).
In "TransWilts line" [362878/29726/18]
Posted by matth1j at 17:11, 2nd July 2025
Yeah I appreciate that. As Graham says it would better/great if they fixed the root cause.
As for this morning's service from Gloucester ... Once it went off its booked route at Standish Junction the system lost it and so defaulted to delayed.
Thanks - I can understand that, although I'm fairly sure that it was showing as 'on time' at least for a short time on the National Rail app when the route included Bristol Parkway (which I assume corresponds to 'went off its booked route' - might have misunderstood).
In "TransWilts line" [362876/29726/18]
Posted by bobm at 16:52, 2nd July 2025
Already liked by matth1j, Mark A, Timmer
In "Across the West" [362875/29650/26]
In "The Lighter Side" [362874/30432/30]
Posted by chuffed at 16:31, 2nd July 2025
Looks as if John Osborne has just left it.....
In "TransWilts line" [362873/29726/18]
Posted by grahame at 16:26, 2nd July 2025
True, although that's 6.5 hours in the future so perhaps it allows them a bit more freedom.
Part of my frustration is that the information systems have just green and red lights.  I know that in the end it runs or it doesn't, but a "This train may be cancelled" or "this train may be delayed" warning with "please check back in an hour" might do wonders.
Better still - have enough of the right people available at the might time in the right place and don't have to cancel, or say you're cancelling, so many trains!
In "TransWilts line" [362872/29726/18]
Posted by matth1j at 16:07, 2nd July 2025
FRUSTRATION ... I know that things have to be moved around during the day sometimes, but flagging up trains as cancelled, letting people know that they won't be able to get home anything like as easily as normal ... and then saying "just kidding" or "we didn't really mean that" is enough to put people off using the train!
Not like this morning's early Gloucester-Southampton (which I mentioned above - apologies for the repetition). I normally leave the house at ~6:05 to catch the 6:32 Melksham departure, and at that time it was showing as 'delayed' (after previously being 'on time', and 'delayed' before that). So I went from the front door back to my room and got my laptop out to start working, planning on catching one of the later services.
Then at ~6:15 I refreshed the web page and it had gone back to 'on time' Laptop back in rucksack, dash downstairs and jog most of the 1.6 miles to the station. Where it was now showing as 15 minutes late
In "The Lighter Side" [362871/30432/30]
Posted by grahame at 15:52, 2nd July 2025
Well, fancy that! St Malo! With the fortified old town (intra muros) in the background.
Now in Angers ...
Re: 30 cancellations on the North Downs this morning
In "North Downs Line" [362870/30321/16]
Posted by grahame at 15:43, 2nd July 2025
Cancelled - "more trains than usual needing repairs at the same time"
09:54 Reading to Gatwick Airport due 11:25
11:29 Gatwick Airport to Reading due 12:57
13:24 Reading to Gatwick Airport due 14:55
14:59 Gatwick Airport to Reading due 16:28
16:50 Reading to Gatwick Airport due 18:25
18:29 Gatwick Airport to Reading due 19:57
20:22 Reading to Gatwick Airport due 21:57
22:01 Gatwick Airport to Reading due 23:21
Looking carefully - that's all just one train ...
In "TransWilts line" [362869/29726/18]
Posted by grahame at 15:41, 2nd July 2025
This is due to a shortage of train crew
Twenty minutes later - reinstated.
In "TransWilts line" [362868/29726/18]
Posted by bobm at 14:42, 2nd July 2025
In "TransWilts line" [362867/29726/18]
Posted by grahame at 14:32, 2nd July 2025
21:16 Westbury to Swindon due 21:59
Realtime Tickets
In "The Wider Picture in the United Kingdom" [362866/30433/51]
Posted by Mark A at 13:01, 2nd July 2025
Realtimetrains, that helps you know where your train is, has now been joined by Realtimetickets, which will sell you a ticket for it. It also allows you to do things like set a starting point and a budget for a day trip and the site will suggest destinations.
https://www.realtimetickets.co.uk/
In "North Downs Line" [362865/30321/16]
Posted by ray951 at 12:06, 2nd July 2025
Not surprisingly it is the same on the Didcot - Banbury trains today with a lot of cancellations.
In "The Lighter Side" [362864/30432/30]
Posted by stuving at 12:03, 2nd July 2025
