Re: Passport required from next month for UK to Ireland travel.
In "The Wider Picture in the United Kingdom" [378841/32422/51]
Posted by eightonedee at 20:51, 28th August 2026
Is it being "awkward" to not have need for a passport's primary purpose and also not want the cost of acquiring one?
Sorry Jaymac, but in the emerging brave new world it's also awkward to want to use your bank account or buy a train ticket unless you have also paid to acquire a smartphone or a PC/laptop and associated internet services even if you have no other use for them or have positively decided you don't want one....
Traintracker Live: live train movements across Europe
In "The Wider Picture Overseas" [378840/32427/52]
Posted by Mark A at 20:48, 28th August 2026
Re: Neasden - huge waste facility fire shuts Tube and train lines - 28 August 2026
In "The Wider Picture in the United Kingdom" [378839/32426/51]
Posted by ChrisB at 20:36, 28th August 2026
Or rechargeable batteries at least.....
In "TransWilts line - Swindon, Chippenham, Melksham, Trowbridge, Westbury, Salisbury" [378838/31359/18]
Posted by TaplowGreen at 19:59, 28th August 2026
20:06 Westbury to Cheltenham Spa due 22:06
20:06 Westbury to Cheltenham Spa due 22:06 will be started from Swindon.
It will no longer call at Westbury, Trowbridge, Melksham and Chippenham.
21:16 Westbury to Swindon due 21:58 will be cancelled.
In "TransWilts line - Swindon, Chippenham, Melksham, Trowbridge, Westbury, Salisbury" [378837/31359/18]
Posted by grahame at 19:58, 28th August 2026
Re: Railways but no trains - 1 of 3
In "The Lighter Side" [378836/32425/30]
Posted by grahame at 19:56, 28th August 2026
Here are the correct ones
0 Paddington - stuving
3 Arbroath - broooklea
5 York - Chris from Nailsea
6 Marlow - Mark A
14 Prague hlavní nádraží  - DR7835
But these are not
10 - not Swansea
11 - not Fishguard
13 - not Swindon
In "The Lighter Side" [378835/32425/30]
Posted by PrestburyRoad at 19:08, 28th August 2026
10. A guess - a memento of the copper works in Swansea
Re: Imber Bus Day - merged topics, ongoing events and discussion here
In "Buses and other ways to travel" [378834/17260/5]
Posted by Clan Line at 19:04, 28th August 2026
"Warminster Journal"
In "The Lighter Side" [378833/32425/30]
Posted by JayMac at 19:02, 28th August 2026
13. Swindon?
Re: Gatwick Airport - facilities, improvements and incidents - merged posts, ongoing discussion
In "Buses and other ways to travel" [378831/20849/5]
Posted by Chris from Nailsea at 18:11, 28th August 2026
Gatwick Airport faced water outage after main burst
Gatwick Airport passengers were left without water after a main burst in a nearby field.
SES Water said that it located a burst main in Horley, with parts of the airport left without water as a result.
A spokesperson for the airport confirmed that the issue had affected water supply in both terminals and was under investigation by SES Water. The water company said it had begun to restore supply.
Flights remained unaffected by the disruption, the airport added.
In "The Lighter Side" [378830/32425/30]
Posted by stuving at 18:10, 28th August 2026
0 is at Paddington - specifically on the linking walkway in front of the Paddington Square building. Quite what it links, or will, I'm not sure; it mainly seems to block off Tanner Lane (what was London Street) where the change in ground level is now incompatible with it continuing.
In "The Wider Picture in the United Kingdom" [378829/32426/51]
Posted by Mark A at 18:10, 28th August 2026
Only a week or so since the one at Bermondsey burned - and for the second time. If this relates to disposable vapes, they're... imposing costs on us all.
In "The Lighter Side" [378828/32425/30]
Posted by TonyN at 18:01, 28th August 2026
11. Fishguard harbour
Re: Derailment, Wickford,14th August 2026
In "The Wider Picture in the United Kingdom" [378827/32365/51]
Posted by Chris from Nailsea at 18:00, 28th August 2026
... particularly if the on-board toilet facility is not available...
In "The Lighter Side" [378826/32425/30]
Posted by DR7835 at 17:37, 28th August 2026
14: Czech Republic; The eye-catching "classic" entrance hall to Praha hlavní nádraží /Prague Main Station. (Admittedly the background does give a bit of a clue!).
In "The Wider Picture in the United Kingdom" [378825/32426/51]
Posted by Chris from Nailsea at 17:33, 28th August 2026
Huge waste facility fire shuts Tube and train lines
A large fire has broken out at a waste facility close to Wembley Stadium in north-west London, shutting Tube and train lines in the area.
The London Fire Brigade (LFB) said 125 firefighters were tackling the blaze at an industrial estate on Hannah Close in Neasden, with the smoke plumes visible from miles away in central London.
The LFB was alerted just after 11:30 BST and has deployed 20 fire engines to the scene. Residents have been warned to keep their windows and doors shut because of the huge amount of smoke.
Transport for London (TfL) said the entire Metropolitan line has been suspended as a result, while the Jubilee line has been part shut between Willesden Green and Wembley Park.
Rail services to and from London Marylebone are also being delayed or cancelled due to train lines to Aylesbury being blocked, National Rail said.
In "The Lighter Side" [378824/32425/30]
Posted by Chris from Nailsea at 17:11, 28th August 2026
5.  York Station (UK), but without the tale of the fox - see also https://www.firstgreatwestern.info/coffeeshop/index.php?topic=29110.0
In "The Wider Picture in the United Kingdom" [378822/32422/51]
Posted by TaplowGreen at 16:07, 28th August 2026
Further information - Stena also applying the new "rule" too.
From TimeOut
Taking a boat from the UK to Ireland this autumn? Double-check that your passport is in date because it’ll soon be the only ID that’ll allow you to make the journey.
At the moment, multiple forms of photo ID (like bus passes, work ID cards and international student cards) are accepted on the ferry journey between Britain and Ireland. But from late September onwards, passengers will need a valid passport, regardless of age or nationality.
Stena Line and Irish Ferries confirmed that passengers on the Holyhead to Dublin and Fishguard to Rosslare services must soon show a passport on departure – no other form of ID will be allowed. The change comes from UK Border Force rules concerning the ‘accuracy and integrity of passenger data before boarding’ and will take effect from Monday September 28.
However, if you’re using Stena Line for services via Belfast, Liverpool, Cairnryan or Heysham, then any form of photo ID is still fine. There are also still no passport checks between Northern Ireland and the Republic of Ireland.
Despite the new rule, the UK, Ireland, the Isle of Man and the Channel Islands are all still part of the Common Travel Area, which means that citizens aren’t legally required to show a passport to travel freely between each place. However, Aer Lingus (as of February this year) and Ryanair both demand that passengers going between Ireland and Great Britain must present a passport at departure, not any other photo identification. The lesson? It’s just best to pack your passport for any journey over to the Emerald Isle.
Yet from https://www.gov.uk/government/publications/common-travel-area/common-travel-area-accessible?
British and Irish citizens travelling to GB via Ireland are not required to present a passport as evidence of identity and nationality. British and Irish citizens may present any other document(s) that satisfactorily establishes their nationality and identity
"The lesson? It’s just best to pack your passport for any journey over to the Emerald Isle"
Amen.
Re: 2 car trains (again)
In "Portsmouth to Cardiff" [378821/32239/20]
Posted by TaplowGreen at 16:05, 28th August 2026
I haven’t heard anything about 158s personally.
Here’s more on the Class 175 plan - which explains why less have been in service lately:
“A recovery plan is being put in place which will centre around a dedicated technical investigation team, with specialists from GWR and our industry partners Alstom and Angel.
New processes will also be introduced with enhanced pre-service checks and ensuring the trains complete a significant amount of miles without a fault occurring before they are able to go into passenger service.”
But the facts are that the 175s were fairly fragile with TfW and are from the same family as the 180s which were fairly fragile when with FGW.  Having been in storage for a year or two won’t have helped.
So I think just about reliable enough is the best we can wish for!
Don't worry, it'll all be fine once it's renationalised under GBR
In "The Lighter Side" [378820/32425/30]
Posted by Mark A at 15:58, 28th August 2026
6, Marlow?
In "The Lighter Side" [378819/32425/30]
Posted by brooklea at 15:53, 28th August 2026
3. Arbroath
Re: Holiday home in Torquay (Torre) anyone? - be aware of train noise
In "Shorter journeys in Devon - Central, North and South" [378818/24457/24]
Posted by RichardB at 14:52, 28th August 2026
I see bidding got to £57,000 but that didn't meet the reserve so it was unsold.  Will be interesting to see what happens from here.
In "The Lighter Side" [378817/32425/30]
Posted by grahame at 14:49, 28th August 2026
Pictures taken by ... myself on my travels .. showing the great variety that are railways.  I have lots of pictures with trains in them, but this series - over three days does not feature trains.  Just at or near railway stations.  For the UK ones, can you tell me the station; for the overseas ones, can you tell me the country and there's a bonus for the actual place.
0.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
In "The Wider Picture in the United Kingdom" [378816/32365/51]
Posted by JohnM at 14:37, 28th August 2026
77mph (decreasing) for 1.5 miles in a carriage not running on rails must be pretty scary.
In "London to the Cotswolds" [378815/31371/14]
Posted by ray951 at 14:13, 28th August 2026
Already liked by Witham Bobby, rogerw, eightonedee
17:04 Didcot Parkway to Evesham due 18:23 will be cancelled.
Last Updated:28/08/2026 11:34
18:51 Evesham to Oxford due 19:50 will be cancelled.
Last Updated:28/08/2026 11:35
Is this now the least likely to run as advertised service on the GW network?  Why is it even in the timetable?  They could just add it as a special excursion on the days when they can be a*s*d to run it
35% cancellation in the last 4 weeks.
1636 Oxford  - Didcot also on 35% over the last 4 weeks which of course then forms the 1704 DID to Evesham.
As we all know since electrification was cancelled GWR has not had enough diesel trains. Cancelling the half complete electrification to Oxford was one of the most stupid decisions made. Thanks Chris Grayling, who has plenty of form with stupid decisions.
In "The Wider Picture in the United Kingdom" [378814/32422/51]
Posted by Western Pathfinder at 13:36, 28th August 2026
Just a short note .please check your drivers license,whilst you may be entitled to drive until well into the future,the photo card does need to be renewed and the picture updated every so often 10 years at this time.
In "London to the Cotswolds" [378813/31371/14]
Posted by ChrisB at 12:59, 28th August 2026
Probably the most popular train on the Evesham-Oxford section!
Certainly in term time.
In "London to the Cotswolds" [378812/31371/14]
Posted by Witham Bobby at 12:55, 28th August 2026
Already liked by JohnM
In "The Wider Picture in the United Kingdom" [378811/32422/51]
Posted by ChrisB at 12:36, 28th August 2026
That latter paragraph is a currently, now option without referring to end September. It will surely be updated nearer the time.
