Re: Lifts at Swindon
In "London to the West" [379228/32287/12]
Posted by ChrisB at 16:49, 6th September 2026
Has this been fixed? Journeycheck seems to think so as it is no longer mentioned there as a problem at Swndon station
In "Across the West" [379227/31163/26]
Posted by TaplowGreen at 15:25, 6th September 2026
Alterations to services between Reading and Didcot Parkway
Due to a safety inspection of the track between Reading and Didcot Parkway some lines are blocked.
Train services running to and from these stations will be diverted. Pangbourne will not be served. Disruption is expected until 18:00 06/09.
We have had a report of a defect on some lines in the Reading area. Trains may not be able to run over the affected line until it has been inspected or may have to run at reduced speed.
Re: 2 car trains (again)
In "Portsmouth to Cardiff" [379226/32239/20]
Posted by WelshBluebird at 15:01, 6th September 2026
A 6 car (or even a 5 or 4 car) would have been appreciated yesterday once the 8.30 service from Cardiff considering the football (Cardiff away to Portsmouth). Only got 3 carriages in the end that was likely standing room only all the way through (certainly was from Temple Meads).
Re: Sunday 23/08/26 - No Crosscountry services
In "Cross Country services" [379225/32397/43]
Posted by GBM at 13:26, 6th September 2026
https://www.bbc.co.uk/news/articles/c8xkgkqjdqro
CrossCountry cancels trains due to driver shortage  (6th September 2026)
35 minutes ago
A number of CrossCountry rail services have been cancelled on Sunday due to a shortage of train drivers.
Services heading out of Birmingham to Reading, Newcastle, Nottingham will no longer run, as well as services into the city from Nottingham, Newcastle, Paignton, Bournemouth, Nottingham, Manchester Piccadilly and Bristol Temple Meads.
..........continues...........
In "Across the West" [379224/31163/26]
Posted by GBM at 13:24, 6th September 2026
https://www.bbc.co.uk/news/articles/cnvl1r1080go
Heathrow Airport train services resume after trackside fire disruption
Ewan Somerville
Published
5 September 2026
Updated 7 hours ago
Trains to and from Heathrow Airport were halted after a trackside grass fire caused delays and cancellations.
National Rail said there was a "major disruption" to services following the incident which began shortly after 16:00 BST.
.................continues............
In "Across the West" [379223/31163/26]
Posted by TaplowGreen at 12:59, 6th September 2026
From National Rail.....
Elizabeth line between Abbey Wood and Heathrow Terminal 4 / Maidenhead / Reading, and between Shenfield and Heathrow Terminal 5
All Great Western Railway trains to / from London Paddington
All Heathrow Express trains between London Paddington and Heathrow Terminals
A fault with the signalling system between London Paddington and Ealing Broadway means trains have to run at a reduced speed on all lines. As a result, trains may be delayed by up to 30 minutes or revised.
Disruption is expected until 16:30.
In "TransWilts line - Swindon, Chippenham, Melksham, Trowbridge, Westbury, Salisbury" [379222/31359/18]
Posted by grahame at 11:16, 6th September 2026
Yes ridiculous chaos for the Weymouth services yesterday. On Journey Check there were a number of bus/taxi replacements shown (and in some detail). It will be interesting to know what actually operated (ie train or bus) each service in the end.
However, as per many previous comments these late changes are of no use to the average customer trying to plan their day.
Here's what ran (trains) in the end - from Real Time Trains, Weymouth via Yeovil Pen Mill
What the log does NOT tell us is how many services were advertised as cancelled and then re-instated, nor about any buses or taxis provided.   It does tell us how long, or otherwise, each train was.
Re: How well travelled are YOU?
In "Introductions and chat" [379221/32458/1]
Posted by GBM at 10:55, 6th September 2026
Many countries!
Fortunate to have done a short spell in the Merchant Navy (didn't want to, but that's another story).
4 different ships, mostly eastern part of the world (from the UK point of view), and never went Stateside.
Stateside was a family holiday just before Covid.
My health unfortunately is limiting my mobility somewhat, so perhaps cruises for a while.
In "TransWilts line - Swindon, Chippenham, Melksham, Trowbridge, Westbury, Salisbury" [379220/31359/18]
Posted by WSW Frome at 10:44, 6th September 2026
Re: 9th October 2026 - TravelWatch SouthWest, Taunton
In "Diary - what's happening when?" [379219/32460/34]
Posted by grahame at 10:22, 6th September 2026
I shall be there, in my electric powerchair....
And I'm sure we can get you all charged up during the day - both electrically and about socially necessary bus services!
In "Diary - what's happening when?" [379218/32460/34]
Posted by ChrisB at 09:48, 6th September 2026
In "Portsmouth to Cardiff" [379217/32239/20]
Posted by grahame at 09:27, 6th September 2026
Looks like today's 1F09 09:18 Cardiff - Portsmouth is just a 2car 158
And its subsequent 1F20 13:09 Portsmouth - Cardiff and 1F29 17:25 Cardiff - Portsmouth are same 2car unit
Meanwhile realtime trains is suggesting 1F11 10:25 Cardiff - Portsmouth (why 67 minutes, not an hour later) is a 6car, along with its return 1F24 14:09 Portsmouth - Cardiff
Is the 67 minutes rather than 60 because that earlier train also calls at Keynsham and Oldfield Park and needs to be on-the-clockface through the more crowded Solent areas?
2 car then 6 car suggests to me 1 x 158 and 2 x 166 and a lack of compatabity means they can't balance better as a 3 car and 5 car.   Not clever - do you remember those more compatible times when a 142, 143, 150, 153 and 158 could all couple up?
In "TransWilts line - Swindon, Chippenham, Melksham, Trowbridge, Westbury, Salisbury" [379216/31359/18]
Posted by grahame at 09:20, 6th September 2026
09:08 Swindon to Westbury due 09:49
09:08 Swindon to Westbury due 09:49 will be starting late from Swindon.
This is due to engineering works not being finished on time.
The 08:06 Warminster to Swindon was delayed 15 minutes at Westbury too; ironically, the reported delay on Journeycheck has turned out to be only 6 minutes.
No great harm done even by the 15 minute delay for passengers headed onward to London - just a shorter wait at Swindon for the Paddington train.
Edit to add - no connection failure at Chippenham off the up train either - just a shorter wait there.
In "Portsmouth to Cardiff" [379215/32239/20]
Posted by John D at 09:09, 6th September 2026
In "TransWilts line - Swindon, Chippenham, Melksham, Trowbridge, Westbury, Salisbury" [379214/31359/18]
Posted by TaplowGreen at 09:01, 6th September 2026
In "Introductions and chat" [379213/32458/1]
Posted by Clan Line at 08:51, 6th September 2026
and Denmark.
Ooops - missed that one !
In "Introductions and chat" [379212/32458/1]
Posted by Chris from Nailsea at 08:45, 6th September 2026
Some time later, when looking at spreadsheets showing my generally excellent number of phone calls taken on my team's UK helpline, a manager asked ' what happened for the dip in that April?'
Going further off topic, is a large number of calls to a helpline a measure of success or a sign there is a problem with the product?   I am involved with one and managers get very exercised when the number of calls or emails rises (as they tend to seasonally).
In my case, it was a measure of success.  My team at that time was 'Marketing Technical Services': we answered queries about changes in legislation and taxation, particularly around the end of the tax year (5 April). The more calls we took, the better it worked in terms of our helping the sales team to promote the use of our particular financial services company.
In "Introductions and chat" [379211/32458/1]
Posted by bobm at 08:27, 6th September 2026
Re: Noble (?) failures
In "Railway History and related topics" [379210/32454/55]
Posted by grahame at 08:10, 6th September 2026
On dates - I, too, find it very hard to pin things down to years or even groups of years.
On Brunel's pneumatic railway and whether it was a "noble failure" it probably was - but I had already listed the Waterloo and Whitehall railway which would have been pneumatic, and I considered the Crystal Palace [upper] experiments and the mail rail (I think it was) link to Euston.   There was no real science to the things on the list, except to have a bit of variety.  Only one battery train, ignoring the Aberdeen to Braemar, for example.
In "Introductions and chat" [379209/32458/1]
Posted by grahame at 08:01, 6th September 2026
Another large factor in stopping many US citizens travelling abroad is the paucity of paid holiday in most American workplaces coupled with the American work ethic.
In UK/Europe it is easy to take (say) 3 weeks (paid !) holiday in one go - in most American jobs you would probably have to take unpaid leave to do this. ...
Back in April 2003 (I think) I took a pre-arranged three week paid holiday (out of my contractual five weeks entitlement) from my employer at that time.
As a former UK employer, we simply had a team that was large enough to cope with holiday leave absences (and medical and occasional compassionate ones too) ut that did increase the cost of employment.  But then in the UK, even in our hospitality business where the USA standard is based on significant tipping, we looked to pay a decent base wage and the (very occasional) tips that came in were pooled for a shared Christmas box, shared out based on the number of hours each of the team members (not the directors) had worked in the year.   Different culture, and what - to me - feels far more equitable, social, caring; perhaps I am going to much to the left in my political thinking here, but I would find it hard to vote to the right as my parents did in a national or regional election.
In Chris's case, as one of a team where others pick up while someone's on leave it works well and the measured stats of individual team members when on vacation provide a useful and comforting "control" that emphasises their worth at other times.   Where a role is unique to one person (dangerous) either the job stops while they're away - and for the training courses I gave that was reasonable, with no need for anything in the calendar those weeks, as training was scheduled a year ahead (public courses) and typically 8 to 12 weeks for private ones.   Neither Lisa not I really take vacations where we switch off; whilst not physically around in the UK, we have done some memorable work (including volunteers) from all sorts of places and do to this day.
In "Railway History and related topics" [379208/32454/55]
Posted by Mark A at 07:51, 6th September 2026
Thanks for this - that's pinned it down a bit. Note to former self: did you notice your friends keeping diaries? Yes. So do the same yourself.
In "Introductions and chat" [379207/32458/1]
Posted by Chris from Nailsea at 03:03, 6th September 2026
I simply said, 'I was out in South Africa for three weeks'.  He rather ruefully acknowledged that was a reasonable explanation.
In "Across the West" [379206/31163/26]
Posted by Chris from Nailsea at 02:34, 6th September 2026
In other words, you're on your own.
Hmm.
As an admin on this forum, I must be impartial.  However, that becomes increasingly difficult, when I read such posts.
Can the railways really not offer at least some more constructive suggestions as to possible alternative travel arrangements, when they apparently can't cope themselves?
Re: Bristol Temple Meads - station, facilities, incidents and events (merged posts)
In "Bristol and Bath (WECA, now WEMCA)" [379204/10737/21]
Posted by johnneyw at 23:36, 5th September 2026
Me too. I wonder whether it’s better to be inside or outside?
I'll have a return ticket from Nailsea & Backwell, so I will be able to do either.  I'd suggest the ceremony will probably be outside, as the weather forecast is for 'bright and sunny', and there's more room outdoors for those attending, rather than trying to cram everyone inside into the concourse.
I shall be wearing a Coffee Shop badge for identification, just in case anyone here wants to approach me, and I will hopefully be in company with my esteemed admin colleague here, Red Squirrel.  For a squirrel, he is remarkably tall, when he stands up on his hind legs, so you can't miss him.
Look forward to seeing some of you there.  CfN.
Well unless the strange quirks of life intervene, I intend to turn up outside there.
For easy identification regarding other Coffee Shop members, I considered wearing my giant green chicken costume but I doubt it would be ready with the dry cleaners by then...oh well, jeans and polo shirt it is then.
In "Introductions and chat" [379203/32458/1]
Posted by ellendune at 23:19, 5th September 2026
12
In "Diary - what's happening when?" [379202/32460/34]
Posted by Chris from Nailsea at 23:13, 5th September 2026
I have registered - it's free, and fairly easy to do (that qualified comment is only due to Eventbrite, not TWSW).
The venue, at Firepool Centre, Taunton, is very easy to find: it's just a slight slope down from Taunton station and a traffic light controlled pedestrian crossing of Trenchard Way.  If anyone does need assistance with mobility access, that can be arranged - please do just let us know.  The venue itself is very modern, all on the ground floor, with the appropriate facilities.
I look forward to meeting some of our Coffee Shop members (and indeed guests).
In "Bristol and Bath (WECA, now WEMCA)" [379201/10737/21]
Posted by Chris from Nailsea at 22:53, 5th September 2026
In "Introductions and chat" [379200/32458/1]
Posted by grahame at 22:11, 5th September 2026
In UK/Europe it is easy to take (say) 3 weeks (paid !) holiday in one go - in most American jobs you would probably have to take unpaid leave to do this. This has two effects: 1. Loss of money. 2. Gives the impression (rightly or wrongly) that you don't care about your employer and the wonderful job that he has kindly given you !
Indeed - it was very interesting when Lisa and I were courting, with her job in Naples (Florida).  That's where we both learned to work remotely even in the early days of the Internet.
In "Railway History and related topics" [379199/32454/55]
Posted by JayMac at 21:48, 5th September 2026
On a canal trip in one of the skiffs, 1971(?), it was a morning, we saw an APT at speed, I think just north of Leighton Buzzard, the train looking suitably futuristic, really shifting - and for good measure, leaning into a curve.
Unlikely to have been 1971. The APT-E (Experimental gas turbine) didn't begin testing until 1972. APT-P (Prototype 25kV electric Class 370) First ran in 1978.
