| Re: Person struck by train 1st August 2026 Devon In "Shorter journeys in Devon - Central, North and South" [377658/32302/24] Posted by GBM at 14:28, 1st August 2026 | ![]() |
11:35 London Paddington to Newquay due 16:45
Facilities on the 11:35 London Paddington to Newquay due 16:45.
This is due to the emergency services dealing with an incident earlier today.
Catering is not available.
| Re: Person struck by train 1st August 2026 Devon In "Shorter journeys in Devon - Central, North and South" [377657/32302/24] Posted by GBM at 14:26, 1st August 2026 | ![]() |
As a consequence no doubt.
Won't be a pleasant experience......
10:02 London Paddington to Penzance due 15:09
Facilities on the 10:02 London Paddington to Penzance due 15:09.
Service full and standing.
Neither will thisWon't be a pleasant experience......
12:03 London Paddington to Penzance due 17:08
12:03 London Paddington to Penzance due 17:08 will be starting late from London Paddington.
Will be formed of 5 coaches instead of 10.
| Re: Buses in Bristol will no longer stop in Broadmead shopping area - 30 Aug 2026 In "Bristol and Bath (WECA, now WEMCA)" [377656/32284/21] Posted by WelshBluebird at 14:19, 1st August 2026 | ![]() |
At the risk of sounding facetious or cynical, may I suggest that the buses are being cleared out of the way, to allow for Helen and Andy's mass transit system ie trams to be installed ?
I'd wager that the complete? removal or buses from Union Street and Horsefair is mainly to ease the redevelopment of Broadmead and The Galleries - particularly the old Debenhams building.
As for trams, extrapolating from the WECA strategy document, they are thinking of a three line tram system - Airport to TM, TM to Cribbs/Brabazon/Parkway and TM to Keynsham/Bath via A4. Mind you, I can't really see how they can do any of that other than with a lot of mixed road running, but that's another matter.
On that basis, TM to Stokes Croft is Victoria Street, Wine Street, Union Street, Haymarket and I would also lay money on the Bear Pit being filled in with HM Gov cash as Sheffield did when they built their system. So an almost completely pedestrianised Broadmead.
There are two elements to the changes.
The Horsefair is being pedestrianised. That means anything that currently uses it (most of the buses headed east basically) needs to move to using Fairfax Street instead.
Separately Union Street is being made into a bus only two way street with much better access to and from the Haymarket. These works again require services thst currently use it to be moved until the works are done.
As it happens yes the longer term plan for Union Street is for it to form part of a "rapid transit" cross city route. But from what I've read that just sounds like more Metrobus style services rather than trams sadly.
And in terms of The Galleries work I must expect that the work when it eventually happens will impact Fairfax Street so I suspect some of the routes will need to temporarily move to that reopened two way Union Street.
| Re: Buses in Bristol will no longer stop in Broadmead shopping area - 30 Aug 2026 In "Bristol and Bath (WECA, now WEMCA)" [377655/32284/21] Posted by WelshBluebird at 14:14, 1st August 2026 | ![]() |
Map with changes in routes and stops at https://travelwest.info/bus/broadmead-bus-changes/
This is pretty radical stuff - I really get the point that busses need to move more quickly around the city centre, but having the inbound and outbound routes diverge so far seems really user-unfriendly - particularly for tourists and occasional bus users. This is particularly the case with the number 1 and 2.
A lot of these routes have been doing that for years though, with the inbound services going via Bond Street and the outbound services snaking through Broadmead. E.g. the 45.
If people who use the other routes are able to handle it then so can people who use the 1 and 2. Especially as the longer term plans are to bring back at the the number 2 to Union Street when the works are done.
| Re: Person struck by train 1st August 2026 Devon In "Shorter journeys in Devon - Central, North and South" [377654/32302/24] Posted by TaplowGreen at 13:21, 1st August 2026 | ![]() |
| OTD - On This Day, 1 August (1925) - Wantage Tramway closed to passengers In "Railway History and related topics" [377653/32305/55] Posted by Chris from Nailsea at 13:06, 1st August 2026 | ![]() |
From Wikipedia:
The Wantage Tramway Company was a two-mile tramway that carried passengers and freight between the Oxfordshire town of Wantage and Wantage Road Station on the Great Western Main Line in England.
Formed in 1873 to link Wantage Road station with its terminus at Mill Street, Wantage the line was built parallel to what was then the Besselsleigh Turnpike, and now the A338.
The tramway closed to passengers in 1925 and to goods traffic in 1945.
| Re: Network Rail press release: passengers and luggage In "The Wider Picture in the United Kingdom" [377652/32295/51] Posted by grahame at 12:48, 1st August 2026 | ![]() |
**snip**
... but then grahame woke up.
Ah, to the reverie I'd just added a through platform at Chippenham and started Graham's bucolic train at Calne.
Makes sense. With calls at Black Hound and Stanley Bridge.
| Re: Off peak ticket, travel involves a connection, peak time services In "Fare's Fair" [377651/32304/4] Posted by Mark A at 12:47, 1st August 2026 | ![]() |
Thanks, both. That's all sensible.
| Re: Network Rail press release: passengers and luggage In "The Wider Picture in the United Kingdom" [377650/32295/51] Posted by Mark A at 12:45, 1st August 2026 | ![]() |
**snip**
| Re: Off peak ticket, travel involves a connection, peak time services In "Fare's Fair" [377649/32304/4] Posted by grahame at 12:40, 1st August 2026 | ![]() |
I am reading the question a little differnt to ChrisB - hence my answer is a little different.
If you are travelling on an off peak ticket and a National Rail service goes wrong such that your connection, or one of a series of connections, drops you into the peak then you are allowed to travel on the first available peak train rather than having to wait for the peak to be over. Whether or not that's written into the conditions of travel or is somewhere else or is an unwritten rule, I know not.
If the error is yours such that the miss the last off peak train, or the connecting service that fails is not a national network one, I dont think the dispensation applies - so if you are delayed from Chesham or Brussels or Ryde, tough?
| Re: Off peak ticket, travel involves a connection, peak time services In "Fare's Fair" [377648/32304/4] Posted by ChrisB at 12:26, 1st August 2026 | ![]() |
Hmm. There are different answers for different scenarios.
If your train is late, you have to wait for it unfortunately.
If it is cancelled, you can travel on the service afterwards, and indeed, if you are aware early enough, the train before.
If you are on multiple connections, If any train is late, you have to still travel on it & catch the next available service(s) of later connections. If you suffer a cancellation, the above applies to that journey & later connections can be made as you arrive for them.
| Off peak ticket, travel involves a connection, peak time services In "Fare's Fair" [377647/32304/4] Posted by Mark A at 12:18, 1st August 2026 | ![]() |
In the scenario that someone's travelling on an off-peak ticket and their intended train is cancelled/runs late resulting in the next train available is a peak time departure, do terms and conditions allow them to travel on the peak time service?
This might also involve a cross-London journey, where their inbound train is late/cancelled and they find themselves at a London terminal after the evening peak is under way.
I can just imagine ... a little bay platform at Chippenham, people connecting into it from the London express, and calling at Lacock, Melksham, Staverton, Trowbridge, White Horse and Westbury ... overtaken there by the international express from South Wales to the Solent, and carrying on Frome, Witham, Bruton, Castle Cary - further connections - Queen's Camel, Yeovil Pen Mill, connection with another similar train headed for Exeter, then Thornford, Yetminster, Chetnole, Eversholt, Cattistock, Maiden Newton, Grimstone, Dorchester, Upwey and Weymouth.
| Re: Person struck by train 1st August 2026 Devon In "Shorter journeys in Devon - Central, North and South" [377645/32302/24] Posted by Chris from Nailsea at 11:16, 1st August 2026 Already liked by GBM | ![]() |
With thanks to TaplowGreen and GBM for posting, I've merged both topics here, for clarity.
| Re: Flooding incident near Taff’s Well 30/07/2026 In "Railway History and related topics" [377644/32300/55] Posted by Chris from Nailsea at 11:13, 1st August 2026 | ![]() |
This event as it was looks to have been very much on a scale that posed a risk to life - I'm surprised it's not higher profile in the news. Given slightly different geography, this would have resulted in collapsed buildings full of mine debris, something that has terrible resonances in the South Wales valleys.
Indeed: see https://www.firstgreatwestern.info/coffeeshop/index.php?topic=31667.0
| Re: Walking - and the right to roam. In "Active travel: Cyclists and walkers, including how the railways deal with them" [377643/32293/50] Posted by Marlburian at 10:16, 1st August 2026 | ![]() |
Some landowners do allow public access to their private land and paths, often closing the latter for one day a year to prevent claims that continuous access might lead to legal claims that they become fully public.
From the Savernake Estate website: "Though it is private property, the Forest's owners permit extensive public access. However, visitors are asked to note that there are NO vehicular rights of way, nor any public footpaths, anywhere in the Forest. To maintain its private status (especially to prevent the creation of vehicular rights of way) Savernake Forest's roads have to be shut on one day a year - usually the first working day of each year - in a joint operation by the Savernake Estate and their tenants the Forestry Commission. On that one day every road into the Forest is physically barriered and all cars are turned away ... Pedestrians may walk where they like, though they are asked to respect the few signs protecting the various groups of private houses scattered through the Forest."
(OK, this relates to vehicular access, but the same principal is applied elsewhere to pedestrian use.)
| Re: Network Rail press release: passengers and luggage In "The Wider Picture in the United Kingdom" [377642/32295/51] Posted by grahame at 10:16, 1st August 2026 | ![]() |
[snip] Many of the old stations though are decrepit / falling apart, and so I can't give you a totally rosy story. The train manager checks and sells tickets and it would be a challenge, I suspect, to travel without paying here!
And no sooner had I posted that than ...
Revenue Protection in action. The train manager(ess) had requested a young couple to alight with her at Zwickau and they stood dutifully behind her as the train pulled in. But as the doors opened they dashed off along the train. The train manageress indicated their movement to three revenue protection colleagues waiting on the platform, and they scuttled along the the next door. When I got off, the manageress and her colleagues were in discussion on the platform with the young people, and after the train had left I saw them waling across the main station concourse with the thee revenue folks around them rather like one sees a cluster of nay ships around a convoy in films. I have no idea what rule(s) these young people had broken, nor whether or not they were known regular transgressors, but it did provide a reminder that even a country with open stations - free from barriers - has teeth to catch up with those whom they suspect are not following the rules.
| Re: Network Rail press release: passengers and luggage In "The Wider Picture in the United Kingdom" [377641/32295/51] Posted by TaplowGreen at 09:52, 1st August 2026 | ![]() |
The DfT having happily specc'd a train interior intended for the morning commuter run inbound from Reading - conveniently overlooking that the trains would also serve everywhere from Penzance to Pembroke, the result is a situation of frequent low level (and not so low level) conflict.
Indeed - and I am struck in so much of my continental travel as to just what a variety of things people have with them and how space is provided for the most part for ... so much. Luggage, push chairs and buggies, bicycles, mobility aids, and even the single carriage local trains we travelled on yesterday - 2 bicycles, two pushchairs - one with a baby and one an enormous double unit, one mobility device, luggage in the form of big hard-shelled cased and packs - and we all made room for each other and there was space for us to adjust and be pleasant about it as we pootled along the main line between major stations, stopping at intermediate villages as and when someone had pressed the "request stop" button or was wanting to join. The trains were modern, had fully accessible loos and level boarding, and were pleasantly busy. Running for the most part every hour, on single track lines they had the odd pause while we waited for another - or a freight - coming the other way. Many of the old stations though are decrepit / falling apart, and so I can't give you a totally rosy story. The train manager checks and sells tickets and it would be a challenge, I suspect, to travel without paying here!
Timely example this morning!
| Re: Person hit by a train 1 August In "Shorter journeys in Devon - Central, North and South" [377640/32302/24] Posted by GBM at 09:19, 1st August 2026 | ![]() |
Note to Mods.
TG and I posted at similar times.
My post is at https://www.firstgreatwestern.info/coffeeshop/index.php?topic=32303.0
| Person struck by train 1st August 2026 Devon In "Shorter journeys in Devon - Central, North and South" [377639/32302/24] Posted by GBM at 09:13, 1st August 2026 | ![]() |
Cancellations to services between Exeter St Davids and Newton Abbot
Due to the emergency services dealing with an incident between Exeter St Davids and Newton Abbot the line is blocked.
Train services running through these stations may be cancelled, delayed or revised. Disruption is expected until 10:00 01/08.
Thoughts with all involved.
Not sure if it's
1J74 0641 Plymouth to London Paddington at Exeter St Thomas
or
2F08 0710 Paignton to Exmouth at Starcross
| Person struck by train 1st August 2026 Devon In "Shorter journeys in Devon - Central, North and South" [377638/32302/24] Posted by TaplowGreen at 09:10, 1st August 2026 | ![]() |
https://www.plymouthherald.co.uk/news/local-news/person-hit-train-between-exeter-11088285?utm_source=linkCopy&utm_medium=social&utm_campaign=sharebar
Between Exeter and Newton Abbott, a number of services to/from Devon and Cornwall being cancelled or starting/finishing short.
| Re: Network Rail press release: passengers and luggage In "The Wider Picture in the United Kingdom" [377637/32295/51] Posted by grahame at 07:09, 1st August 2026 | ![]() |
| Re: East West Rail Timetable In "Chiltern Railways services" [377636/29004/44] Posted by anthony215 at 23:33, 31st July 2026 | ![]() |
According to the latest Oxford Clarion we may have a solution to the problem of 'guards' on trains:
"Chiltern is now advertising for Customer Service Inspectors to work from its Bletchley depot, the base for East West Rail services. The inspectors will perform guard-like duties such as “provide a high level of customer care on trains”, “take part in revenue protection activities on trains”, “perform on-train announcing”, and “take action to rectify or report faults”.
The train doors will still be operated by drivers, not guards, so services could run without a second staff member in exceptional circumstances – as is common south of London. An internal Government document says that issues at Winslow station will not obstruct entry to service, and that the trains have been upgraded to support ‘Superpower mode’, which improves acceleration, to meet the tight timetable. With Chiltern due to be nationalised on 20 September, a December start date for the Oxford–Milton Keynes service is now widely expected."
https://oxfordclarion.uk/clarion-weekend-31-july-2026/
I don't know whether this is a coincidence but I have noticed more class 196 trains at Oxford in recent weeks.
Oh if those 196s are anything like our class 197s sports mode is good but they drink diesel and ad blue
| Re: Flooding incident near Taff’s Well 30/07/2026 In "Railway History and related topics" [377635/32300/55] Posted by Red Squirrel at 22:52, 31st July 2026 Already liked by Mark A | ![]() |
I have made a little tweak to the subject line - it’s Taff’s Well, not Taff Wells
| Re: Getting to the airport - an advert for public transport! In "Buses and other ways to travel" [377634/32285/5] Posted by LiskeardRich at 22:47, 31st July 2026 | ![]() |
https://www.bbc.co.uk/news/articles/cp8ez2dx032o?at_ptr_name=facebook_page&at_link_origin=BBC_BedsHertsBucks&at_campaign_type=owned&at_bbc_team=editorial&at_format=link&at_medium=social&at_campaign=Social_Flow&at_link_id=E87F5A26-8CEC-11F1-919F-B27202F0E840&at_link_type=web_link&fbclid=IwdGRleATZ9p9wZG9mBWV4dG4DYWVtAjExAHNydGMGYXBwX2lkCjY2Mjg1NjgzNzkAAR7MadO-slTsiSMd0Cxfn_2lVuoRv_NrcYCFKQyW3xKxfkBGi3U6Mi9iRqq0rQ_aem_GalezK-ZDRhegjAlEEF-cg
Airport funds free bus travel to reduce congestion
Two people stand beside a large bus outside London Luton Airport. One person is showing something on a smartphone screen while the other person, who is carrying a backpack and holding the handle of a wheeled suitcase, looks at the device.
IMAGE SOURCE, LONDON LUTON AIRPORT
Image caption,
Passengers need to show a valid printed or digital boarding pass for a flight from London Luton Airport to the driver to qualify for free travel next month
ByMatthew Lockwood
Bedfordshire, Hertfordshire and Buckinghamshire
Published
9 hours ago
Holidaymakers travelling to one of the UK's busiest airports are being encouraged to leave their cars at home.
London Luton Airport (LLA) said it is funding free bus travel to the terminal from locations in Bedfordshire, Hertfordshire and Buckinghamshire during August, in a bid to reduce congestion and help families save money.
It is expecting its busiest August ever, with 1.9 million passengers - a 5% increase on last year.
Alberto Martin, chief executive of LLA, said: "This initiative demonstrates our commitment to reinvesting in transport options that benefit both our passengers and the communities we serve."
Some of the services taking part in the month-long scheme, external will run 24 hours a day.
LLA said the initiative complements the Department for Transport's free summer bus travel, external scheme for children aged five to 15 in England.
| Re: 14 coach IET In "Across the West" [377633/32299/26] Posted by bobm at 22:19, 31st July 2026 | ![]() |
There seems to have been an issue in recent days with coach allocations.
The GWR app has variously shown 18 and 14 coach formations which have then translated to other systems.
| Cannington Viaduct visit weekend In "Railway History and related topics" [377632/32301/55] Posted by Mark A at 22:07, 31st July 2026 Already liked by Western Pathfinder | ![]() |
Travelling from London to Axminster with cycles on... I think it was... what were they called, those... £5?... awaydays for Network Southeast season ticket holders... we could have done with this viaduct and indeed the entire branch, either as a railway or a shared-use path, the route to Lyme being hilly. We made it to Lyme though, and thankfully made it back for the return train too.
Anyway for the viaduct, a weekend of open days, more here.
https://fortheloveofarailway.co.uk/viaduct
| Re: Network Rail press release: passengers and luggage In "The Wider Picture in the United Kingdom" [377631/32295/51] Posted by Ralph Ayres at 21:33, 31st July 2026 | ![]() |
NR's blurb isn't very well worded (and who do they expect will see it?). One bullet point just seems to ban anything over 1 metre but elsewhere it says "You may bring a large item (more than 1 metre in any dimension), but only if you are able to carry it without assistance" with no actual size limit. Even the latest Conditions of Travel (ooh, just out, dated 30th July 2026) only have maximum dimensions - smaller than many suitcases - for a few specific items which seems unfair on musicians and furniture restorers in particular. I've also got a surfboard which is only 80cm long and takes up next to no space but is specifically banned because someone at RDG thinks all surfboards are like the ones on Baywatch!
TfL incidentally do have a 2 metre general limit in their Conditions of Carriage which seems sensible, particularly for true tube stock.
| Re: Network Rail press release: passengers and luggage In "The Wider Picture in the United Kingdom" [377630/32295/51] Posted by Chris from Nailsea at 21:25, 31st July 2026 Already liked by TaplowGreen | ![]() |
I guess in the old days the Guard's van came in handy in these circumstances?
Another yellow card to TG for encouraging the learned member for Minehead.
| Re: Flooding incident near Taff’s Well 30/07/2026 In "Railway History and related topics" [377629/32300/55] Posted by Mark A at 20:59, 31st July 2026 | ![]() |
Also, 'other mines are available'.
Look at an aerial photo of the present day quarry and locate at about ten o'clock relative to the deep excavation, the 'Island' of greenery atop unexcavated ground and connected by vegetation to the quarry lip. That's 'Garth Shaft' or 'Little Garth' "Worked since medieval times. Reopened and extensively modified for ammunition storage 1939-1945" The current quarriers not keen to approach it it seems.
https://buddlepit.co.uk/mine-explorer/Database/MineDetails.html?id=uaX1J5QJ6Kxt9PL6m3dw0g==
