Re: Hot weather - changes for 13th August 2026
In "Across the West" [378185/32358/26]
Posted by Chris from Nailsea at 14:26, 13th August 2026
Hmm.  From the BBC live:
Temperatures top 36C in England as amber extreme heat warning expanded
In "TransWilts line - Swindon, Chippenham, Melksham, Trowbridge, Westbury, Salisbury" [378184/31359/18]
Posted by grahame at 14:26, 13th August 2026
The service now cancelled for the rest of the day with the exception of the through services to and from the Stroud Valley.
So it would seem
Has the reason turned into an excuse??
In "TransWilts line - Swindon, Chippenham, Melksham, Trowbridge, Westbury, Salisbury" [378183/31359/18]
Posted by grahame at 14:21, 13th August 2026
14:18 Westbury to Swindon due 15:01
15:14 Swindon to Westbury due 15:58 will be cancelled.
I would have thought that with the Bristol - Salisbury service canned for the day, there would have been been stand in available.  Granted - there wasn't a train available at short notice for the train 2 hours earlier, but by this time ...
17:45 Swindon to Westbury due 18:26 will be cancelled.
I would have thought that with the Bristol - Salisbury service canned for the day, there would have been been stand in available.  Granted - there wasn't a train available at short notice for the train 2 hours earlier, nor for the one 4 hours earlier ... but by this time ...
Looks like someone's still not looking outside the box!
If there's a fault on this train, use another.  There should be plenty of spares today NOT running from Bristol to Salisbury!
In "TransWilts line - Swindon, Chippenham, Melksham, Trowbridge, Westbury, Salisbury" [378182/31359/18]
Posted by bobm at 14:17, 13th August 2026
In "TransWilts line - Swindon, Chippenham, Melksham, Trowbridge, Westbury, Salisbury" [378181/31359/18]
Posted by grahame at 14:15, 13th August 2026
In "TransWilts line - Swindon, Chippenham, Melksham, Trowbridge, Westbury, Salisbury" [378180/31359/18]
Posted by grahame at 14:13, 13th August 2026
Re: Solar eclipse 12/08/2026
In "Across the West" [378179/32340/26]
Posted by JayMac at 14:10, 13th August 2026
My phone's camera does have full manual settings so I dialled the exposure right down, set ISO to 50 and shutter down to 1/5000. Even with those settings I couldn't prevent blown out images. So I also used several ND filters. Ones from my old drone that I stuck over the phone's camera lens, held in place with sticky tape! Stacked ND1000+ND256+ND64. Still only managed one half decent shot.
Thinning in hot weather
In "Portsmouth to Cardiff" [378178/32361/20]
Posted by grahame at 13:16, 13th August 2026
Cancellations to services between Bath Spa and Salisbury
Due to forecasted severe weather between Bath Spa and Salisbury fewer trains are able to run on all lines.
The heatwave continues with forecast temperatures expected to potentially hit 38 degrees Celsius today. To minimise disruption, some train services have been taken out of the timetable.
The hourly Bristol Temple Meads to Salisbury service will not run today. However, customers can still make their journey on the Cardiff Central to Portsmouth Harbour service, which will call additionally at Freshford and Avoncliff.
Concerns / cuts understood.   But if the CDF->PMH service is planned / announced to fill in at Freshford and Avoncliff, why not at Dilton Marsh too?    What happens there?  Are we told anywhere?
In "Across the West" [378177/31163/26]
Posted by TaplowGreen at 13:02, 13th August 2026
Journeycheck doesn't seem to be awake to this one - from National Rail.............
Elizabeth line between Shenfield and Heathrow Terminal 5, and also between between Abbey Wood and Heathrow Terminal 4 / Maidenhead / Reading
A failure of the electricity supply between London Paddington and Heathrow Terminals / Reading means all lines are disrupted. As a result, trains will be cancelled, delayed by up to 60 minutes or revised.
Major disruption is expected until 15:00.
In "Across the West" [378176/31163/26]
Posted by grahame at 12:55, 13th August 2026
Already liked by JohnM
The day that rail industry people, as part of disruption information, stop mansplaining components will be a good day. It' a really bizarre practice.
I'm inclined to disagree, Mark - it's not there for you, me and other Coffee Shop members who know these things.  It's there for the other people - many of whom are bright - who have other skills and knowledge that fill their brains in preference to "points", "overhead electrics", and "staff".  From an IT viewpoint, having the explanations come up as rollovers might be worth them considering.
In "Across the West" [378175/31163/26]
Posted by ChrisB at 12:51, 13th August 2026
Why should it?
Nothing to do with GWR where any fault can be pinned. It's climate change & network Rail infrastructure. GWR are the affected customer.
In "TransWilts line - Swindon, Chippenham, Melksham, Trowbridge, Westbury, Salisbury" [378174/31359/18]
Posted by grahame at 12:47, 13th August 2026
I came on to the Coffee Shop a few minutes ago to record / summarise yesterday's performance or lack thereof ... but find myself again reporting on new cancellations.
12:17 Westbury to Swindon due 13:01
13:14 Swindon to Westbury due 13:57
13:14 Swindon to Westbury due 13:57 will be cancelled.
For the record, from yesterday ... train summary. Only replacement flagged to be provided was a late pair of buses.
In "Across the West" [378173/31163/26]
Posted by Mark A at 12:41, 13th August 2026
*snip*
*snip*
In "Across the West" [378172/32340/26]
Posted by Mark A at 12:31, 13th August 2026
That last photo... a drop of cloud really helps. Sorry about your 1999 absence.
In "Across the West" [378171/32340/26]
Posted by Mark A at 12:29, 13th August 2026
Liking those. Your phone seems very good at either not producing, or its suppressing, lens flare which in the case of a direct photo of the sun, the flare can actually be good at recording the sun's disk itself.
Re: Online buying pitfalls
In "Fare's Fair" [378170/32356/4]
Posted by Mark A at 12:27, 13th August 2026
To be fair, the BRfares purchasing site is lightning-fast, informative and avoids the annoyances of e.g. the National Rail site and others. It's not straying into advance purchase travel territory though.
In "Across the West" [378169/32358/26]
Posted by TaplowGreen at 12:11, 13th August 2026
Sharing for GWR and Network Rail
Ahead of tomorrow's (Thursday 13 August) anticipated hot weather and the accompanying amber weather warning, our teams are working together to ensure the vast majority of planned services operate as usual. We are advising customers to check before they travel and carry water, and we're very grateful for their patience and understanding during this period.
We are also planning some reductions in service to help minimise further disruption and reduce the stress on rail infrastructure in the extreme heat. This includes:
* In the Thames Valley, we anticipate changes to our stopping services between London and Reading/Didcot Parkway, with trains not calling at Slough, Maidenhead and Twyford.
* Services between Truro and Falmouth will be reduced to hourly from half-hourly.
* The Okehampton branch will not operate, with replacement buses running instead. Services on the Barnstaple line will run as usual.
* The local stopping service between Bristol and Salisbury will not run. Cardiff/Bristol-Portsmouth services will continue to run as usual
* The shuttle service between Bristol Temple Meads and Filton Abbey Wood will not run. Tickets will be valid on local bus services.
More information is available on our dedicated webpage at www.gwr.com/weather, and we've also issued a joint media release which you can read here: https://news.gwr.com/news/gwr-and-network-rail-advise-customers-to-check-before-travelling-as-new-amber-weather-warning-issued
Any help you can give to make your networks aware would be much appreciated, and as ever if there's anything we can do to help, please don't hesitate to get in touch.
According to the Met Office the temperature in Truro is currently 24 degrees, expected to reach a maximum of 25 degrees today.
Does this really constitute "extreme heat"?
In "Across the West" [378168/32340/26]
Posted by Mark A at 11:54, 13th August 2026
An eclipse of some sort would now have a 'tick' against it on my bucket list if I actually had one. Agreed that it didn't score particularly highly on the spectacular scale. The expected Sound Of Silence was completely ruined by Gulls & Magpies, which creatures frequently invade our peace and quiet around here.
We were on the lower slopes of Mount Teide in Tenerife for the 1999 eclipse but had no idea it was happening. Didn't matter because most of the island was shrouded in thick cloud.
That reminds me of Plymouth - the total eclipse arrived and the various seabirds that had been flying around blithely taking no notice of the evidence in front of their own eyes that something was about to happen. Complete panic and a series of rather hairy dives as they ran for cover and safety.
In "Fare's Fair" [378167/32356/4]
Posted by JohnM at 11:15, 13th August 2026
Looking at the BRFares website, it's good to see they don't waste their efforts on presenting a nice looking UI
Re: Interesting "What3Words"
In "The Lighter Side" [378166/32322/30]
Posted by grahame at 11:04, 13th August 2026
Already liked by Mark A, GBM
///kicks.irritable.shop ... somewhat amused because of what you can buy there, how annoyed you can get when you can't find the product you want, and the action you are tempted to take when the machine is out or order.
Topic drift ...
BrilliantPeacock4284
SilverWolf6121
CuriousHamster1843
ResilientCaribou791
DynamicSeal940
EmeraldStrawberry4929
EmpatheticFalcon2062
BrilliantKangaroo5708
Some of the "nicknames" seen on current social media posts where people select to have an alter-ego in groups they are members of.   I'm concerned at people posting with their own names and also with nicknames in a group and find myself wondering "why?".  Having said which, Coffee Shop member names in essence are nicknames / handles.  I guess my concern is people having multiple personalities in a group, and using the two supposedly unlinked to setup phishing traps. Hence our "one name/account only" policy here, with a handful of exceptions where good cause is demonstrated.
It may surprise readers ... I am personally accepting of anonymous posting where there is reason on such groups - such as where a surprise holiday is being researched.
Anyway - to end the aside, Facebook is now giving group admins the ability to turn off posting under nicknames; that will put paid to any discussions of meeting up with Dynamic Seal when on a visit to Budapest, just to discover later that you've set up a clandestine liaison with your own wife.  Example fictstious.
In "Fare's Fair" [378165/32356/4]
Posted by Trowres at 10:03, 13th August 2026
As I understand it - and I have not looked in detail - BRFares is unlikely to be able to offer quotaed fares on specific trains such as Advance fares.
That is correct.
In "Across the West" [378164/32340/26]
Posted by bobm at 08:49, 13th August 2026
Already liked by Mark A, GBM, johnneyw, JayMac
With its view of the western horizon, I chose Weston-super-Mare to view the event.
Although it did get noticeably busier as we neared the time of the maximum eclipse it was by no means crowded and plenty of seats available.  I opted not to take a tripod with me so the shots were all handheld, although there were others there who were clearly making a production number out of it.
I did hear some reports of people's views elsewhere being obscured by cloud.   At Weston there were just a few towards the end.
From around Europe - some lessons for Melksham and other towns?
In "TransWilts line - Swindon, Chippenham, Melksham, Trowbridge, Westbury, Salisbury" [378163/32360/18]
Posted by grahame at 08:35, 13th August 2026
I have blogged 24 picture with brief titles at https://grahamellis.uk/blog2051.html showing things I noticed.  Many are transport related, so sharing here. Although no longer a Town Councillor, I retain an interest in transport, environment and planning.   And I thank goodness that I have been able to let others pick up entertainment, parks, dog exercise, splash features, and food and drink and am now purely a user / consumer of those.
In "Across the West" [378162/31163/26]
Posted by TaplowGreen at 08:33, 13th August 2026
Due to severe weather between London Paddington and Reading fewer trains are able to run on some lines.
The extreme heat that is forecast for today can lead to an increase in points failures.
To reduce the risk of this happening, a number of points will be set for one route and not moved, protecting the route to and from London Paddington.
In "Across the West" [378161/32358/26]
Posted by grahame at 08:20, 13th August 2026
As far as I can see - not quite as usual.  The cancellation of the local services withdraws almost all services (certainly daytime ones) at Avoncliff, Dilton Marsh and Freshford.   Correct in the circumstances, the Cardiff to Portsmouth trains will be making extra calls at  Avoncliff and Frsehford.  However, it appear that they are not calling at Dilton Marsh - at least according to JourneyCheck.  Which is an oddly unbalanced decision, considering that the walking area catchment of Dilton Marsh probably exceeds the walking area catchment of Freshford and Avoncliff combined.
In "Across the West" [378160/31163/26]
Posted by Bob_Blakey at 08:09, 13th August 2026
.....Looks like it was brought under control before it caused thousands of pounds worth of improvements.
Similarly the joke about the fallout from the long predicted massive Cumbre Vieja (La Palma) rockslide; 'A tsunami hit Plymouth yesterday, causing an estimated £15 million worth of improvements."
In "Across the West" [378159/32340/26]
Posted by Bob_Blakey at 07:43, 13th August 2026
In "Across the West" [378158/32340/26]
Posted by GBM at 07:12, 13th August 2026
Posting here from my desk in the South-facing study in our house in Nailsea, I can say that I was very underwhelmed at this eclipse.
I noticed a slight reduction in the exterior daylight, and there were just a few squawking birds flying about - but that was about it, really.
Yes, underwhelming here as well.
A bit less sun, cooler.  Then dusk!
Agree with Marlburian as well.
In "Fare's Fair" [378157/32356/4]
Posted by grahame at 06:19, 13th August 2026
It appears, Hafren, that BRFares.com now offers that "buy a ticket now" functionality. I haven't tried it yet.
I noted that too as a potential solution to a problem I have had buying online - where I have known the ticket I need, but struggled to find a train to which it applies.  That may sound odd - but if I want to go from - say A to C with a break of journey in B, I may well know (because I'm a sad geek) the best fare, but there may not be any specific / individual train and connections that would normally offer it on the routing I want because it's always quicker direct from A to C, not going via B.
Re: Railway Accident Photography
In "Railway History and related topics" [378156/32353/55]
Posted by JayMac at 00:27, 13th August 2026
Me too!
The old timetables particularly.
