Left 29 minutes late at 14:47. At least it is running.
14:18 Westbury to Swindon due 15:01
14:18 Westbury to Swindon due 15:01 will be starting late from Westbury.
This is due to this train being late from the depot.
15:14 Swindon to Westbury due 15:58 will be starting late from Swindon.
This is due to a late running train being in front of this one.
| Re: Bristol Temple Meads - station, facilities, incidents and events (merged posts) In "Bristol and Bath (WECA, now WEMCA)" [379140/10737/21] Posted by Phantom at 12:56, 4th September 2026 | ![]() |
In terms of usage, it is also quite handy for gigs at the prospect building.
Excellent point - it will make those last trains home slightly easier to catch
| Re: Same word - different meanings - public transport context In "Portsmouth to Cardiff" [379138/32449/20] Posted by stuving at 12:49, 4th September 2026 | ![]() |
7. Passenger v Customer
Reeks of consultant speak. If they are called passengers it reminds everybody what the object of the exercise is. Had similar situation in the health service, they are patients and want a medical issue sorted.
Customer tends lean towards a sales opportunity, coffee shops on stations, over-priced branches of M&S in hospitals.
One of the fixed ideas behind privatisation was that BR was run, by engineering and operations, for its own benefit and convenience not the passengers'. I remember hearing one of the privatisers explaining at the time that they had designed the process with minimal barriers to entry (capital both as money and owning equipment), so a group of outsiders could bid for a franchise.
The idea was to bring in people from a retail background, where (it is said) the customer is king and always right. The switch to "customer" was meant to reflect this change of ethos of those running the TOCs, which should start to recognise that they were customer-facing.
Of course that totally misses some important differences. With competent logistics (which you can hire in) to maintain stock levels, you can retail stuff out of your stock room that was manufactured ages ago. It stays as made, with no involvement of the manufacturers until it's been bought and taken (or sent) home.
You can't retail a rail journey that way. You have to keep manufacturing the journey after it's been sold, and while it's going on, until it has finally been consumed. So the manufacturing staff (both engineering and operations) need to be involved throughout. This makes life more difficult, but can't be wished out of relevance.
| Re: A bit out in the sticks In "Railway History and related topics" [379137/32108/55] Posted by Marlburian at 10:21, 4th September 2026 Already liked by Mark A | ![]() |
I guess that freight ceasing in 1966 applied to other stations on the DN & S, and Churn just happened to be included. There might have been some agricultural traffic, though in 1943 a siding installed for the benefit of Churn Farm was removed as part of the wartime doubling. C W Judge in An Historical Survey ... of the line says that the station was closed to goods traffic then.
In the past fifty years I've explored most of the line between Upton and Winchester, but for some reason not the bit between Upton and Didcot - until yesterday. It's now a well-surfaced path for cyclists, walkers and horse-riders. One or two stretches of embankment have been reduced to allow sloping access paths, there are several bridges to peer over and the concrete base of what I guess may have been a platelayers' hut.
| Re: Noble (?) failures In "Railway History and related topics" [379136/32454/55] Posted by Mark A at 10:07, 4th September 2026 | ![]() |
OK, I'll bite. The APT was failed by a country that was in fundamentally unserious mode concerning the train and I suspect that many other aspects of railway travel benefitted from the research that produced it. Also, to engineer that tilt mechanism in a purely analogue way. If the trains running on the GWML now were a descendent of the ATP I suspect that everyone would be rather happier with the ambience of the passenger compartments than they are.
| Re: Imber Bus Day - merged topics, ongoing events and discussion here In "Buses and other ways to travel" [379135/17260/5] Posted by CyclingSid at 10:00, 4th September 2026 Already liked by Mark A | ![]() |
British army told to stop non-essential training exercises to save money
Unfortunate timing with Trump reviewing the situation with the Falklands, followed by the Argentinians rising to the bait.
| Re: Noble (?) failures In "Railway History and related topics" [379133/32454/55] Posted by CyclingSid at 09:51, 4th September 2026 | ![]() |
Should this be titled like the recent awards; Ignoble failures?
An unusual set of circumstances led to some extended delays around the single line overnight.
Both sleeper services were routed via Melksham and both were running late. The Up sleeper lost half an hour coming through Cornwall while the Down service was delayed by 50 minutes due to an incident east of Swindon. The pair usually cross in Somerset. This morning it was between Trowbridge and Westbury.
However behind the westbound sleeper was a queue of trains at Chippenham waiting for the single line to clear. A couple of them had been allowed to run early at previous points in their journey. The closure of the line through Chipping Sodbury for overnight engineering work also added to the pressure. The second in the queue was just waiting for the one in front to take the single line before it could continue towards Bath Spa.
The up sleeper was delayed on the approach to Bradford Junction for 45 minutes while a pair of trains used the single line. The message on Journeycheck suggested it had been delayed by a late running train in front. I suppose it was - by the down sleeper!
In all it took nearly three hours for the congestion to clear as other trains joined the queues at both ends. The worst delay I have seen was a freight train which approached Chippenham 12 minutes early but was 83 minutes late by the time it got to Trowbridge.
In the middle of the night perhaps it doesn't matter so much - but it shows what a knife-edge capacity along the single line is on at times.
| Re: Imber Bus Day - merged topics, ongoing events and discussion here In "Buses and other ways to travel" [379131/17260/5] Posted by Marlburian at 09:19, 4th September 2026 | ![]() |
I can't see Imber being returned to civilian habitation as it remains a useful training facility, although, ironically, the army had to construct the nearby "village" on Copehill Down (complete with railway siding and vehicles) to better replicate the sort of buildings, including cellars, that the British Army might have to fight in in Europe).
(And something would need to be done about the poor mobile-phone reception!)
In recent years I've become conscious of the increased use of the central ranges north of Larkhill. (Imber is in the western ranges.) Time was when one could go there on a Sunday and be reasonably sure that they were not being used and one could access the rights-of-way. But on several occasions in the past few years the Salisbury Plain Training Area website has shown no artillery firing taking place, only for me to drive down and find the red flags were up and there were army vehicles whizzing around. A year or two ago the flags were down, so I trudged up the old Salisbury-Devizes road for two miles from Bustard, only to find a barrier was down across it.
Recently the SPTA website has tweaked its guidance, but still does not indicate military use other than firing.
No doubt one might be fairly safe in assuming that the army takes Christmas Day and adjacent dates off, but on most winter days the Plain is not particularly inviting.
| Re: Same word - different meanings - public transport context In "Portsmouth to Cardiff" [379130/32449/20] Posted by bobm at 07:33, 4th September 2026 | ![]() |
As has been said… frequently.
| Re: 2 of 3 - rail related but no trains In "The Lighter Side" [379129/32435/30] Posted by grahame at 06:11, 4th September 2026 | ![]() |
B5 looks to be in France, from the 'Sor' or 'Sort' as the beginning of the possible word 'Sortie' on the sign at the top right of the picture.
There's also the "Pictish symbol signs"! I think that station is La-Bastide-St-Laurent-les-Bains.
Very, very close - you are just two stations along the line. At Langogne we stopped for a crew change, then at La-Bastide-St-Laurent-les-Bains to pass the train coming the other way.
Here is La Bastide:
| Re: Imber Bus Day - merged topics, ongoing events and discussion here In "Buses and other ways to travel" [379128/17260/5] Posted by grahame at 05:58, 4th September 2026 | ![]() |
Imber could be re-opened, then?
The Army has been told to stop "non-essential" training exercises to save money, according to a defence source.
A defence source said the plans mean not doing what he called "nice to have training" - like large live fire exercises and rehearsing platoon attacks in UK training areas like Salisbury Plain in Wiltshire and Sennybridge in Wales.
This worries me. Not the re-opening of Imber which (if any senior politicians or cool servants have been up there on the 23A) has well connected public transport and housing and a church that could be brought up to modern standards to form the hub of a new town. But also with political decisions taking the opportunism of short(er) term money saving even in a sphere they are apparently committed too. Could money be saved by mothballing the Badminton and Langport cutoffs, with London to the West and South Wales routed via Gloucester, via Bath Spa, and via Honiton?
| Re: Same word - different meanings - public transport context In "Portsmouth to Cardiff" [379127/32449/20] Posted by grahame at 05:49, 4th September 2026 | ![]() |
The two words - which are not the same, but which do rile me, when they are misused - are 'regular' and 'frequent'. Regular could be 'once every one hundred years', whereas frequent could be 'every few minutes', for example.
Indeed - we had a regular train service from Swindon to Westbury from December 2006 to December 2013 - it ran about every 12 hours. It has improved since then, but to this day we remain in search of a frequent service, for example as suggested by the Bath and Wiltshire Metro which would run every 30 minutes, though perhaps not completely regular because there might be a gap from 00:30 to 04:30 midweek.
| Noble (?) failures In "Railway History and related topics" [379126/32454/55] Posted by grahame at 05:31, 4th September 2026 | ![]() |
Key Facts
Name Origin: Named after Edsel Ford, the son of founder Henry Ford and former president of the company.
The Launch: Debuted on September 4, 1957 (known as "E-Day"), following a massive, highly publicized hype and teaser campaign.
Unique Features: Famous for its polarizing vertical "horse-collar" grille, rolling-dome speedometer, and the Teletouch push-button automatic transmission located right in the center of the steering wheel.
Models Offered: Included upscale models like the Citation and Corsair, as well as lower-priced choices like the Pacer and Ranger.
The Failure: Became a legendary corporate failure due to poor timing during an economic recession, quality control issues on shared assembly lines, and a design that public consumers largely disliked. Ford lost hundreds of millions of dollars before discontinuing the brand in November 1959
https://en.wikipedia.org/wiki/Edsel
There have been some noble (and nit so noble) failures in the railway world, and some of them are associated with great engineers who had other magnificnent successes but these cases results were not as planned:
Leader
Drumm Electric Train
Bideford, Westward Ho! and Appledore
4DD trains
Brighton and Rottingdean Seashore Electric Railway
Advanced Passenger Train
Waterloo and Whitehall Railway
Class 769 trains
Brill Branch
Cardiff Railway (Treforest)
| Re: Same word - different meanings - public transport context In "Portsmouth to Cardiff" [379125/32449/20] Posted by bobm at 03:12, 4th September 2026 | ![]() |
…and staying on topic, there is regular coffee.
| Re: 'Surveillance pricing'. In "Fare's Fair" [379124/32345/4] Posted by 1st fan at 02:51, 4th September 2026 | ![]() |
Covers EWR-LHR (Premium Economy) US$376.00
Carrier-imposed surcharge (YQ) US$560.00
Carrier-imposed surcharge (YR) US$22.00
Looks like a case of the tail wagging the dog. $588 out of $991. Nearly 60% of what you're asked to pay is in this "surcharge" bucket ...
Normally it’s to get money out of the people paying using airline points for their ticket. So the ticket price of $376 is what you pay for with the points, then on top of that you have to pay the surcharge in cash. So essentially with the points you’re getting a 30% discount, which to my mind makes the points less attractive than if you can pay for the whole thing in points. There is something on BA in Europe where you can essentially pay for most of it in points.
| Re: Cornwall's history - Trelawney, Trevithick, the miners and many others In "Railway History and related topics" [379123/32030/55] Posted by Chris from Nailsea at 01:19, 4th September 2026 | ![]() |
Actually, having been encouraged by two of my fellow admins here on the Coffee Shop forum, I'm now inclined to
From YouTube, see https://youtube.com/shorts/miwshkCqxHU?is=_g_LdAXh3gqjiZFt - and sorry if it's portrait rather than landscape format (or vice versa) - but that's just how it is on YouTube.
| Re: Imber Bus Day - merged topics, ongoing events and discussion here In "Buses and other ways to travel" [379121/17260/5] Posted by Chris from Nailsea at 00:15, 4th September 2026 | ![]() |
It will continue to train soldiers preparing to be deployed or on deployments - such as units sent to Estonia, the Falklands or Cyprus. But units back in the UK and who are not preparing for a specific deployment have been told to cut back on collective training exercises due to financial pressures.
It comes as Prime Minister Andy Burnham faces pressure to increase spending on defence. The government is increasing defence spending to 2.5% of national income by next year, but is under growing pressure to reach a target of 3% by the end of the decade.
| Re: 2 of 3 - rail related but no trains In "The Lighter Side" [379120/32435/30] Posted by Chris from Nailsea at 23:43, 3rd September 2026 | ![]() |
Easy for you to pronounce, stuving.
| Re: 2 of 3 - rail related but no trains In "The Lighter Side" [379119/32435/30] Posted by stuving at 23:35, 3rd September 2026 | ![]() |
| Re: Same word - different meanings - public transport context In "Portsmouth to Cardiff" [379117/32449/20] Posted by Chris from Nailsea at 22:45, 3rd September 2026 | ![]() |
This image is a fictional representation of us singing in the Coffee Shop
A couple of points from me, if I may?
That is not the admin team here on the Coffee Shop forum.
17:50 Gloucester to Salisbury due 20:06 has been delayed at Trowbridge and is now 27 minutes late.
This is due to trespassers on the railway.
| Re: Newquay Line - services, incidents and improvements (merged posts) In "Shorter journeys in Plymouth and Cornwall" [379115/19772/25] Posted by Mark A at 19:34, 3rd September 2026 | ![]() |
I'm going to sound like a complete fossil - I recall a notice on the, er, left luggage office at Teddington Station, a list of items that was positively Edwardian, I think I recall 'Gramophone' and am sure I recall 'Pair of sculls' but can't remember if the notice distinguished between those and oars. Perhaps 'Primus stove (must first be emptied of fuel)'. The last begs a question - when the railways were still accepting accompanied motorbikes carried in the guards van on long distance passenger services, but insisted that the fuel tanks be empty, what did the travelling motorcyclist do with the excess fuel?
I read that GWR advises that it does not carry surfboards to Newquay. Don't anyone suggest to the Swiss they stop transporting skis.... in pairs...and ski poles!
The Portuguese even make a feature of it on the lines out of Lisbon:
https://www.surfertoday.com/surfing/portuguese-railways-are-surfer-friendly
