| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by CyclingSid at 08:36, 3rd February 2025 | ![]() ![]() ![]() |
Incidentally, since when were OS grid coordinates called X and Y?[/i]
Presumably when the GIS user reads what is on their screen. Thankfully it is not Lat and Long to six digit accuracy. I assume they reference the centre (centroid) of the structures.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by Chris from Nailsea at 00:17, 3rd February 2025 | ![]() ![]() ![]() |
My excellent geography teacher, Mr Stoyle at Plymstock School over 50 years ago, would have a fit if he could see that!
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 00:01, 3rd February 2025 | ![]() ![]() ![]() |
Wokingham had the only mechanical signal box for miles around, which is now disused. And if you were wondering what was planned for it, this is the answer (text from the letter of notification):
Notice of intention to demolish redundant railway signal box located to the south side of Barkham Road, Wokingham, Berkshire (X:480601 Y:168594) known as ‘Wokingham Signal Box’, as well as the operational equipment building situated behind (X:480605 Y:168581).
As set out above, I am writing to notify you of Network Rail Infrastructure Limited’s (Network Rail) intention to undertake works to demolish a redundant signal box at the above location. The adjacent operational equipment building will also be removed as part of the demolition works and the area of ground will be cleared and made safe afterwards. Both buildings are shown edged in red on the photograph included in Figure 1 below.
The signal box and adjacent building are situated alongside the railway line and south-west of the Level Crossing on Barkham Road, as denoted with a red outline on the Site Location Plan enclosed within this letter. The demolition is required as both buildings area now redundant as they are no longer operational following the conclusion of the Feltham re-signalling programme.
The footbridge immediately south of Wokingham Station, on the opposite side of the Level Crossing and Barkham Road, is Grade II listed, however the signal box and adjacent building do not fall within its curtilage. The site is also not located within a Conservation Area.....
They do not actually say why they need to remove it. I presume it's just that any disused building incurs maintenance and security charges, as well as a risk of liability for injury to intruders, so they routinely plan for removal. If someone comes up with a compelling reason for retention, then maybe ...
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 16:22, 24th May 2024 | ![]() ![]() ![]() |
When are they going to complete the new bridge? Or is that the purpose of the latest planned closure?
It'll now be late summer!
Explanation on the bridge/foot crossing thread with previous pictures etc.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by CyclingSid at 07:09, 17th May 2024 | ![]() ![]() ![]() |
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 00:14, 3rd March 2024 | ![]() ![]() ![]() |
“Can anyone explain the relevance of the first photo to a resignalling project?”
The pic of what looks like bank stabilization works does seem irrelevant; probably another example of Network Rail’s Media Contractors’ Reputation Management efforts or should it be mismanagement efforts ?!
True, if that is slope stabilisation work, it does not seem to fit even the track replacement work in the project. But then apart from the two staff recorded at Wokingham Station, the other scenes in the video are not related to the recent work. The level crossing being renewed is Mays crossing in Datchet, and the overhead view is of Wood Lane crossing at Isleworth - done ages ago.
For a resignalling project, it did seem a bit odd for 1 km of track replacement to be included. But replacing Wokingham Junction did make sense as resignalling, not just using the blockade for another job. It would not make sense to replace it and to do the motorisation as separate steps.
And while it's not obvious how to measure the single track length of a junction, that one is likely to come out as is over 800m. Then there are the two crossovers worked by ground frames, at Bracknell and Blackwater, which have been motorised - and may have been replaced in the process.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 22:56, 2nd March 2024 | ![]() ![]() ![]() |
When I went to have a look on Monday (19th) afternoon, there was a guy with a video camera on a tripod. He turned out to be one of the Basingstoke signallers who does the level crossings! He was promising shorter barrier-down times, suggesting there was a new block, or least a distant signal, on the approach from Crowthorne (though I'm not convinced of that).
I would expect the ROC to be quicker than a local signaller, resetting the route for the next train using the lever frame before crossing the box to press the button, especially with ARS. Crossings now have their own signaller, and I was surprised to see that they use a box with lights and switches per crossing, not a patch of a screen.
I didn't gather whether this video was for familiarisation and briefing purposes, or whether he was being a railway enthusiast (which he obviously was). I've now found the video on YouTube, where he calls himself M-Train. So if you like watching level crossings operating, he has more like this ...
https://youtu.be/7sCDrGmJ5Yw
He said the emergency number goes to the relevant signaller, and they get a lot of non-emergency stuff: complaints and insults mainly. I'm surprised there isn't an operator to screen calls in this sort of urban area.
We both thought one of the zigzags (the far one in the video) was rather low - perhaps to improve the sighting for drivers? Well, a driver's eye view doesn't support that, what it really shows is how dense the thicket of signs and posts is there.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 22:47, 2nd March 2024 | ![]() ![]() ![]() |
Yellow and white line painting seems to wear very quickly. Is that because of economy and they put down the thinnest layer. I know ones in London which have survived for ages, but I can also feel them when I go over them on the bike.
The main factor is, I'm sure, that there are three main ways of applying these markings (that I've seen used here - and many more I've not). Paint is obviously likely to wear off, and most notably so on plastic surfaces like the level crossing boards (have you tried painting drainpipes?).
Then there's the gloop - officially it's a thermoplastic resin - which forms a thick solid layer. This will eventually break up like the road itself, but does seem more durable. I see cold gloop is now available, and lasts even better.
When the Wokingham crossing and junction were rearranged in 2015, some of the white lines at the junction were applied as sticky shapes. The process involved preheating the road with as gas torch, then rolling them down. It did not work, and they got lifted up, and stuck down on other markings - which looked really bad, and pretty confusing.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by CyclingSid at 07:08, 2nd March 2024 | ![]() ![]() ![]() |
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 00:19, 2nd March 2024 | ![]() ![]() ![]() |
Here's how to paint, or rather repaint, a level crossing - not exactly a modern automated process.
First you mark out the lines with a chalky string (p1). I didn't see any careful measuring, so I think they had a plan or image of the crossing, with the pattern drawn onto it. They did some of the white lines and the yellow lines at the ends with hot gloop while I was away. I was told by one of the main contractor's guys that the yellow gloop does not stick to the Strail plastic panels in the centre, but not why the white stuff does.
Putting gloop down obviously involves a degree of skill, using what I gather is called a drawbox (p2). Those Strail panels were done with roll-on paint, following masking with sticky tape (p3). Supposedly that does adhere - but in the final view, from Monday, it's already wearing off (p4).
On Sunday, they were installing new trespass guards after all; they are some kind of rigid plastic and are screwed down. And I was told, about that fencing, that they now had to make all the 1.4s into 1.6s. I take it that means the standard they work to now says six-foot high fencing is needed all round it.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 23:45, 1st March 2024 | ![]() ![]() ![]() |
I don't think this crossing was, in fact, ever likely to become am object detection one. The guide (Level crossings: a guide for managers, designers and operators) says of CB-ODs:
This type of crossing may be suitable at sites where road traffic flows freely, road lay-out is simple and there is no significant history of misuse. Risk assessment should, in particular, consider how the risks from blocking-back of road traffic and high or problematic pedestrian usage will be controlled.
The station crossing was never going to meet that description; even the Star Lane one, which might, has gone to MCB (CCTV) as well.
However, that guide has been withdrawn by ORR, and "replaced" by Principles for managing level crossing safety, which is guidance for doing risk assessments. I don't see that as a replacement, and I'm not convinced it's helpful (a topic to return to, probably.)
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 23:37, 1st March 2024 | ![]() ![]() ![]() |
My posts on Monday 19th's reopening got held up; here's the catchup (in parts). The reopening was left until after a final proving train had run - which I heard go past - a turbo to Guildford and back between 1 and 3 am. (This was also able to rescue a dead Turbo, stuck in Guldford P6/7 since before the blockade.) There was also a swap of the SWR train stuck in Reading for a new one, proving the other line.
So here's the junction after all the clearing up, and the crossing which currently has barriers that meet exactly in a straight line (for how long?). We now have the yodel alarms instead of bells, but they are surprisingly quiet. Direct phones to the signallers are no longer fitted; I guess it now makes little difference. The phone number to call is on the small signs, but the standard NR signboard for the track access point also gives it - and one for the ECR too.
The point about the the big signs facing the track is just that - it's an odd place to put them. But there is an issue with names: is it reasonable to expect the public to use "railway names", which are often different to what anyone else would say, historical, or just wrong. Here, a lot of locals would call this the station crossing because they know there is at least one other crossing in Wokingham. And while you need to see one of the small signs to get the number to call the signallers, and that has the official name, a lot of calls come in via other routes (e.g. 999).
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by bobm at 20:53, 21st February 2024 | ![]() ![]() ![]() |
Problems yesterday, although not down to the infrastructure, after the guard on a Reading bound train was assaulted at Wokingham station and the offender then fled across the tracks.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 20:33, 21st February 2024 | ![]() ![]() ![]() |
SWR were showing the delay as at "a level crossing near Wokingham", and there are only two, both rebuilt last week. There were several orange minders at the station one when I was going for a train to Reading at 1 pm, so it was probably that one. Fortunately by that time trains had just started coming through again, in a bunch of those that had been waiting. I got one not visible on the CIS, since it had been told to run non-stop to Reading, though it did call.
And it had all been going so well .... for two days, anyway.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by GBM at 13:50, 21st February 2024 | ![]() ![]() ![]() |
Cancellations to services at Wokingham
Due to a fault with barriers at a level crossing at Wokingham trains have to run at reduced speed on all lines.
Train services running through this station may be cancelled or delayed. Disruption is expected until 15:00 21/02.
There is a fault with lowering barriers at a road crossing at Wokingham. Network Rail staff are on site and looking to resolve the issue. Whilst this takes place trains will continue to run but at a reduced speed in the area.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by Oxonhutch at 14:24, 19th February 2024 | ![]() ![]() ![]() |
Though at least the signal numbering allows them to be inserted at a later date.
Along with the third rail?
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by IndustryInsider at 14:14, 19th February 2024 | ![]() ![]() ![]() |
Perhaps a slight shame that the l-o-n-g sections through Sandhurst and Crowthorne didn't get an extra signal section added to reduce headways? Though at least the signal numbering allows them to be inserted at a later date.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by AMLAG at 13:25, 19th February 2024 | ![]() ![]() ![]() |
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by IndustryInsider at 12:51, 19th February 2024 | ![]() ![]() ![]() |
We already had new-fangled electric light signals! There must be some detailed changes to the signals layout, though I've not spotted any to check for in updated maps. Signalmaps does not show signal numbers, but it has changed the crossing from MCB to MCB-CCTV, following its up (or down, or sideways) -grade.
Yes, but the feed from the previous Train Describer was not able to show their status.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 12:36, 19th February 2024 | ![]() ![]() ![]() |
Signalmaps, for one, has been updated to show nice colour lights, routes set and platform occupation already:
https://signalmaps.co.uk/#feltham:2074
OTT does have the new BEFnnnn numbers - correctly, for the couple I know.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by bobm at 12:04, 19th February 2024 | ![]() ![]() ![]() |
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by IndustryInsider at 11:04, 19th February 2024 | ![]() ![]() ![]() |
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by paul7575 at 10:51, 19th February 2024 | ![]() ![]() ![]() |
Here’s the NR press release. Can anyone explain the relevance of the first photo to a resignalling project?
From Saturday 10 to Sunday 18 February, Network Rail completed the final phase of the resignalling work in the Wokingham area as part of the five-year £375m programme of work to bring the 1970s signalling equipment up to modern standards.
During the most recent nine-day closure, engineers worked around the clock to install 43 new signals (traffic lights for the railway), as well as upgrade two level crossings at Wokingham station and Easthampstead Road (Star Lane) and renew a double railway junction at Wokingham.
Now complete, customers will benefit from a modern digitalised signalling system that will help improve train performance, increase future capacity, result in fewer delays, and enhance the safety of level crossings.
As part of the five-year programme, Network Rail moved control of the signalling equipment between Feltham and Wokingham and transferred it to Basingstoke, into the Rail Operating Centre (ROC), as well as upgraded 16 level crossings and installed 500 pieces of signalling equipment, which covers 80 miles of railway across Feltham, Hounslow, Shepperton, Twickenham, Windsor & Eton Riverside and Wokingham.
https://www.networkrailmediacentre.co.uk/news/network-rail-completes-final-phase-of-gbp-375m-investment-to-install-state-of-the-art-signalling-system-which-will-improve-the-reliability-of-the-line-between-feltham-and-wokingham
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by ellendune at 08:15, 18th February 2024 | ![]() ![]() ![]() |
And on that yellow-railed cabinet patio there is now a name board for the crossing. For some reason.
If someone is reporting an incident at the crossing then you want them to use the right name. It may be obvious in this case, but consistency is important.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 00:23, 18th February 2024 | ![]() ![]() ![]() |
By yesterday (Friday) the orange crowds had mostly dispersed, apart from at the level crossing and some signalling work. The testing of the new signalling is not a very visible process.
During the week, as well as the track replacement at the junction, the level crossing was also removed and new equipment put in. This involved taking out the old concrete bases and pouring new ones in plywood boxes in very nearly the same place. Some more, slightly smaller, precast cubic bases were dropped in to hold the posts for new wigwags (p2).
A lot of new fencing has gone in all round the barrier machines, along the road and beside the track too. There it will close the side of the trespass guards (arris rails) - those were not removed until yesterday, which seems a bit odd. They have been put to one side, so presumably will be put back not renewed. And on that yellow-railed cabinet patio there is now a name board for the crossing. For some reason.
Today's main job was painting the crossing; more complicated than it sounds. That didn't finish until after the daylight had gone, so I'll show it when I've got a decent picture.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 22:38, 15th February 2024 | ![]() ![]() ![]() |
Still a lot of work going on today, though most of the big bits are done. I was surprised to see signals being erected only now; it must be about time to start testing the new kit. A bloke who was labelled Atkins told me that the level crossing will not have object detection. I wonder whether the reliability of CCTV alone has been reassessed as better than it was before.
The track has, I think, been welded and stressed through the junction, along the straight direction - all I can see. For one thing, I can't now see any adjustment switches on the station side. There was one on the left, alongside the crossover switch on the right. And the insulated joints are still in place, but bypassed by bonding.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 20:20, 14th February 2024 | ![]() ![]() ![]() |
It's hard to see how true the track is now, there are so many people working on it, but it certainly looks better. A tamper did turn up late last night - or something bigger; I could only see a part of it sitting on the level crossing. My guess is it was an on-track finishing machine; that can straighten rails laterally (lining) too.
Exactly what all these small machines are doing I can't work out, but I'd expect cutting ends to leave the right gap, drilling holes for various reasons, and eventually stressing for when the final welds go in. After that comes grinding and other finishing, but no doubt there's more to it than I can think of. Track clips were being undone within the station this afternoon, which presumably relates to re-stressing. However, I'd expect that unclipping to be done after stress is applied.
On the other hand, the old junction was protected from rail stress by adjustment switches on all six tracks. I can't make out if the same is true now - partly because of all the bodies in the way. I did wonder if the insulated joints close to the level crossing would be replaced or removed now, as the down-side one at least is worn (i.e. loud ker-thump noises as a train runs in). With axle counters being used, IRJs are not needed, unless perhaps a few track circuits are retained for static detection.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by Electric train at 07:25, 14th February 2024 | ![]() ![]() ![]() |
The junction is in obvious need of a visit from the tamper, and not just because the view exaggerates the wiggliness. The wiggles in the vertical direction are exactly what tampers are meant for, but is there enough spring force in the rails to straighten them in the horizontal plane as well, when lifted and shaken?
There may be some work left to be done with RRV's to dress and line up the rails. The new track will not have been stressed and finally welded yet this will allow the Tamper to iron out wiggles; once stressed and welded there will be at least one Tamper run booked in a few weeks after the line is reopened
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 23:52, 13th February 2024 | ![]() ![]() ![]() |
Over Sunday/Monday night that remaining track (the Up Main) has been torn up and replaced by new ballast (and the last rodding has gone too). By yesterday morning, that Kirow crane was back and already a lot of the temporary track has been taken out (p1). By the time I got back it was well after dark, but in the fuzzy pictures I got did suggest all the new track was in place. So I missed all the fun! Though this gang of RRVS having a rest may have found it more like hard work (p2).
By midday today most of the debris had been cleared up (p3), and by late afternoon it was all remarkably clean (p4). The junction is in obvious need of a visit from the tamper, and not just because the view exaggerates the wiggliness. The wiggles in the vertical direction are exactly what tampers are meant for, but is there enough spring force in the rails to straighten them in the horizontal plane as well, when lifted and shaken?
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by Electric train at 07:00, 12th February 2024 | ![]() ![]() ![]() |
By late afternoon, a section of new track has been put in, with two new motorised switches. But perhaps that should be called plain line, since the left-hand rail is continuous through places there should be a rail crossing. Less than twenty minutes later (photo 2), a slab of that new track has been hoicked out and now plain line is being laid round to the left, towards Bracknell, via a new track crossing on the other track.
Looking at how much track is still stacked up waiting to be used, it does seem that much of the track so far laid is temporary. So it seems the current method is to bring in an engineering train on one track, and rip out the rest, and replace the ballast with fresh. The final track panels are laid where possible, i.e. where remaining the old track is not in the way. In the gaps, temporary track panels are put down. to allow the remaining old track to be removed with a train alongside. Once all the new ballast is in place, even full-width track panels can be swapped in or out by crane from either end.
Close examination of the two big track panels in the foreground shows that the wider one, on top, fits just after the farther incomplete switch, and the one underneath comes after that. So there is a lot of temporary plain line where those panels will eventually be. The view from the footbridge at the station is of course highly foreshortened, disguising how long those panels are.
Normal practice on twin track is to use an adjacent one for engineering train(s) for scrap / waste and new ballast etc
When those large panels go in place it be done with Kirow rail cranes
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 23:54, 11th February 2024 | ![]() ![]() ![]() |
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 23:59, 10th February 2024 | ![]() ![]() ![]() |
As expected, Team Orange got really stuck in last night, tearing up the track. First to go was the point rodding, or at least part of it (photo 1). Next we see the junction being taken out and dug up, one piece at a time so as to allow trains and the rail crane to be used. In the background, track panels are being unloaded from the tilting transporter wagons.
To get a better view I had to find another vantage point to replace the demolished footbridge: on top of the car park, through a fine steel mesh. From there you can see Colas's Kirow crane, and a whole IKEA kit of track panels (I hope someone's got the instruction leaflet!). Tilting transporters can manage panels 3.7 m wide, but those in the foreground are a lot wider than that; how did they get here? Finally (photo 4), a little later, it's time to put in the new ballast and fit the first panel.
There's a lot of bits of rail to be joined there. If it's all done by thermit welding, those living on the houses by the line will enjoy a big firework display (though its timing may be a bit antisocial).
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by IndustryInsider at 14:40, 6th February 2024 | ![]() ![]() ![]() |
With the siding now electrified, does that count as the first step towards infill electrification to Aldershot South Junction?
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by Electric train at 11:06, 6th February 2024 | ![]() ![]() ![]() |
The gap in the third rail is rather odd, though.
If you mean the gaps by the switches (points) there are 2 reasons I can think of, first they look like HW point machines the drive rods protrude out and there is a risk of contact with the conrail forming a high impedance fault path also no conrail makes it easier to maintain the point ends and heater | Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 00:39, 6th February 2024 | ![]() ![]() ![]() |
The track was all in place and ready for this morning's first ECS at 5 am, in fact well before that. The points are clipped, so the bits of missing rail are not an issue. The gap in the third rail is rather odd, though. The curves on that siding entrance have been eased a little, by shifting the points towards the station.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 10:30, 4th February 2024 | ![]() ![]() ![]() |
And the signallers have announced their departure.
Great pictures, thank you
One more week to go, and then after the big switch-over it all goes to Basingstoke.
The last big change was introducing the colour light signals. I'm not sure when Wokingham's were done, but it must have been roughly when the Feltham box was switched on in 1974, replacing 45 mechanical boxes. That took three years to put in, so not so different from the latest resignalling. Wokingham box was already capable of working to Reading, Ascot, and North Camp at night (because there are no junctions that need operating), and had been with with semaphore signals.
When this box was built in 1933, it followed a lot of complaints from local councillors etc. about the length of crossing gate closures. They had been operated by the station's only porter who also collected tickets, and the new "mechanised" gates would have a capstan in the signal box. There was something indicated as "SB" on the maps before this, but perhaps it was only a cabin hidng a ground frame.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by GBM at 09:22, 4th February 2024 | ![]() ![]() ![]() |
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 23:05, 3rd February 2024 | ![]() ![]() ![]() |
As expected, the heavy mob turned up to start work last weekend, at midnight on Friday. Since then they've been ripping out the old crossing stuff, and digging - still more - holes to fill with concrete. There was also some work being done on the track at the junction, though there can't be a lot they could do then since it's still in use until next weekend. Most of the work has been beside the track, but fenced off.
NR were lucky enough to find a dormant building site next door, and borrowed it for storing things. Big things, such as at least five big RRVs, most of then the caterpillar ones (ORRVs?). And on a couple of nights, with no work going, a low loader has turned up to remove or deliver one of those.
There is a picture put on line by NR of a crossing crossing the crossing, which is a bit of a puzzle. It's not been installed, indeed the junction replacement can't logically be done until the 9-day blockade. So where have they hidden it? Most likely on a bit of spare land at the junction, which I can't currently look at as the footbridge (Tan Hill) has been demolished.
And last night a couple of big trains turned up after midnight, and something noisy ensued. Today you could see that a bit of track has been ripped up, - though it will have to be be replaced by Monday. Closer examination shows this is the entrance to the siding. This is out of use for the duration, so a new switch can be put in with no signalling system to work it.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by oxviem at 11:49, 25th January 2024 | ![]() ![]() ![]() |
My understanding is Wokingham box controls(ed) two level crossings - one immediately by the station and one further away via CCTV. So perhaps the number reflects the numbers that are controlled by the signaling boxes being lost rather than their specific locations
Though given these are by the station and Star Lane - perhaps someone has confused the number of carriageways/track crossed to the number of level crossings.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 10:01, 25th January 2024 | ![]() ![]() ![]() |
and presumably Reading to Guilford, if they are closing the station level crossing
https://www.bbc.co.uk/news/uk-england-berkshire-68073195
Don't understand the two level crossings at Wokingham station, or Star Lane. Not sure the second image has any direct relevance to the story headline.
The second picture is lifted from NR's web page on the Feltham and Wokingham Resignalling project, and the area it shows was done in phase 1. So it is relevant to the reason for the closures and bustitutes.
Quite what original text was mangled so as to double the number of crossings is not at all clear. And it does not help to talk about closing a level crossing and give two different date ranges (for the station one). The road at the crossing is indeed closing this weekend, but the trains keep running for another two weeks before the railway closes as well for nine days. It's easy to get confused if those two types of closure are not distinguished clearly.
I guess they are removing the old crossing in its entirety to build a new one, within the time available between trains, so it takes a long time. But it's hard to see that's not possible within the same nine days as all the signals per se. Curing time for concrete plinths?
PS: the main thread for this resignalling is on the SWR board.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by CyclingSid at 07:28, 25th January 2024 | ![]() ![]() ![]() |
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by bobm at 18:55, 4th January 2024 | ![]() ![]() ![]() |
More details of the replacement services from GWR here - https://www.gwr.com/-/media/gwr-sc-website/files/travel-information/travel-updates/planned-engineering/2023/Rail-improvement-work-on-the-North-Downs-line-Saturday-10-to-Sunday-18-February-2024.pdf
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 18:44, 4th January 2024 | ![]() ![]() ![]() |
The NR page "Feltham and Wokingham re-signalling programme" has had a new bit dropped into it, that says:
Saturday 10 to Sunday 18 February – Reading to Bracknell and Guildford
In February 2024 engineers will work around the clock during a 9-day closure to turn on signals we previously installed in the Wokingham area. The closure extends from Reading to Ascot on Sunday 11, Saturday 17 and Sunday 18 February and from Guildford to Aldershot on Sunday 18 February.
Information about rail replacement buses
Saturday 10 February – buses running from Reading to Bracknell and Guildford.
Sunday 11 February – buses running from Reading to Ascot and Guildford.
Monday 12 to Friday 16 February – buses running from Reading to Bracknell and Guildford.
Saturday 17 February (before 19:30) – buses running from Reading to Bracknell and Guildford.
Saturday 17 February (after 19:30) – buses running from Reading to Ascot and Guildford.
Sunday 18 February – buses running from Reading to Ascot and Guildford Buses running from Aldershot to Guildford.
So the end is indeed nigh for my local signallers. Elsewhere, level crossings have been switched to CCTV control from the ROC before the signals are switched over, but I haven't seen anything about that here. Nor have I seen any OD sensors (radar/IR), which I think are still part of the plan. It may be that this last one is being done at the same time as everything else.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 20:42, 13th February 2023 | ![]() ![]() ![]() |
But today, there's a striking absence of any work being done, and no road closure over the crossing. And I have found no source of information on this.
There is work on the station platform, and at the junction, though it's not the major level crossing work that was "promised". And the change of plan is in the EAS, which has a change date of 2/2/23. I guess this will now have to happen later:
WOKINGHAM LC WILL BE CLOSED TO ROAD
TRAFFIC FROM 0200 TO 0600 MONDAY AND 2200
FRIDAY TO 0400 SATURDAY
STAR LANE LC WILL BE CLOSED TO ROAD
TRAFFIC FROM 2300 SUNDAY 12TH TO 2200
FRIDAY 17TH
FRIDAY 17TH
NR and WBC have been confusing people by the way they declare road closure times. This was the case for the second of the roadside sign9 above), and for the Star Lane crossing closure (from the WBC travel Facebook listing):
The closure will be in place on Star Lane level crossing from 12 – 17 February, 11pm – 10pm. This is to allow Network Rail to carry out Transport Authority works at level crossing.
The wording is NR's, I think, where someone seems to think those mean the same thing!
But it leads to the question:
11pm-10pm?
So it’s open for an hour a day?
Or is that 10am?
If the latter, they’ve got it closed at rush hour during the week the railway isn’t running trains, so car usage will be even higher than normal.
Or is that 10am?
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 15:18, 13th February 2023 | ![]() ![]() ![]() |
One bit of signalling that's already gone in at the station is new AWS magnets - pretty green ones. But today, there's a striking absence of any work being done, and no road closure over the crossing. And I have found no source of information on this.
IIRC green AWS magnets are the version used in DC third rail traction areas. I think they’re stronger than the yellow versions used elsewhere?That's right. The field strength as specified is not much higher, but is sensed higher up (193 mm vs 150* mm). So two receivers, or a dual one, are needed for trains running in both DC and non-dc areas. The old ones that have just been replaced would also have been high strength ones, just not colour coded like these new Vortok ones.
*PS: the two heights were 193 mm and 115 mm, but since 2012 both receiver types are specified at a range of heights. The traction-related fields to be ignored are not specified numerically.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by paul7575 at 14:36, 13th February 2023 | ![]() ![]() ![]() |
IIRC green AWS magnets are the version used in DC third rail traction areas. I think they’re stronger than the yellow versions used elsewhere?| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 12:55, 13th February 2023 | ![]() ![]() ![]() |
The final signal before the crossing is down on the right, an old one, and what's that inverted triangle beyond it? It looks like the back of a warning sign, perhaps for marauding leaves. Is anything else that shape?
That's a warning board for the PSR of 30mph that applies through Wokingham station. You can just about make out the AWS magnet beyond it, which of course you don't get with adhesion warning boards. Here's one from the other side (but not that one!): https://railsimroutes.net/driversguide/images/psr_warn_2.jpg
That does make sense, even if most drivers have slowed down well before they get there. Having found out that the warning is meant to be about 1 km in advance for a 70-30 speed reduction, my initial reaction was "that sign can't be far enough away". But it can! For one thing the viewpoint on the footbridge is 220 m from the PSR change, and then a bit of zoom and foreshortening does the rest. The signal in the distance showing a green aspect is 1.7 km from the footbridge, so the warning sign is indeed 780 m away.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by IndustryInsider at 11:50, 13th February 2023 | ![]() ![]() ![]() |
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by Electric train at 07:08, 13th February 2023 | ![]() ![]() ![]() |
Yeah I thought it was for cabling. As you say it looks more like for water or sewerage!
UTX (Under Track Crossing) the Track Engineer requires UTX to be typically greater that 2.5 meters below track base level (track base is from the bottom of the ballast)
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by CyclingSid at 06:58, 13th February 2023 | ![]() ![]() ![]() |
I wondered what the "South Western Railways replacement" bus through Reading was as I came to work this morning.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 00:24, 13th February 2023 | ![]() ![]() ![]() |
The work two weekends ago showed what that patio was really for: high-rise tin beehives. And these were not empty cabinets to be populated out in situ; they arrived with ID labels and all their contents fitted and wired up. In the picture, the one still dangling is for the level crossing controls, and the one in front of it the crossing power supply.
Along the line to Reading, there are several new signals (I see straight posts are so out of fashion!), some with mini-patios of their own. None of the station signals has been done yet, but some posts and handrails are in place nearby. Looking towards Crowthorne, there's a cranked post on the right this side of the existing signal, but maybe not by enough to shorten the long drag up to the crossing. On the left, that's a new signal and it's a straight post!
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 20:18, 12th February 2023 | ![]() ![]() ![]() |
Well, we're all getting ready for next week's unusual work on our level crossing. Unusual in that it's Monday-Friday, closing road and railway, and not including either weekend. Apparently it's timed to coincide with half-term - you don't think they have left those weekends clear for holiday travel via Gatwick do you?
But I'm now wondering if it is really going to happen, and where to look for definitive information. (Note that the road closure is separate from the railway one, and not always included in NR's information.) The TRO was announced in the local papers (with diversion routes), and was in one.network, but it's now vanished. The closure of Star Lane crossing is still shown, but with no diversion route. And the council has no web page listing TROs - only Star Lane is on their Facebook page. I guess we'll find out later tonight.
Railway closures are publicised in several ways, and the local news media picked up on this one (so they do read TROs!). But most of us would never look unless we see one of those yellow signs by the roadside. So I was a very surprised to see this sign on 15th January: "Road closed 11.00pm Sat 28th Jan-10.00pm Fri 17th Feb". It took four days to correct that to "11.00pm-11.00pm/Fri 27th -Sun 29th Jan/11.00pm-10.00pm/Sun 12th-Fri 17th Feb". The TRO came out the same day. The sign vanished a week ago.
I also got another "Dear railway neighbour" letter to add to my large collection, and that had both the right dates in a table, and the scaremongering ones in its heading. Maybe that's what the first sign was based on. I suspect a lot of users of the crossing (most of whom are not railway neighbours) are in for a big surprise tomorrow, including some driving HGVs for which the diversion is very long. If it gets signposted, that is ...
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 20:10, 21st January 2023 | ![]() ![]() ![]() |
The contractors working on this sort of resignalling programme are getting quite keen to publicise it (and themselves). Since they have to explain what the whole project is, often it sounds as if they are doing more that is the case. Here the civils are (they say) the work of Global Rail Construction, and the signalling per se by Atkins (aka SNC-Lavalin) "supported" by RT Infrastructure Solutions (i.e. they provide extra labour).
So far most of what we've seen here is the civils, including that UTX. GRCL say they had to do 16 of those, and 16 under roads, in one possession. However, I wonder about that as someone is out there right now digging a trench across Barkham Road at the level crossing. After breaking up the surface, the digging is being done by a bloke with a high-pressure hose and a big s(p)oil-sucker truck - plus lots of people standing around looking into the hole.
GRCL claim 26 location case hard standings, with walkways and handrails. We have one of those too, opposite the signal box. When they started that, I did wonder why the signallers needed a patio so much it was worth doing if there was no space next to their box. I also wondered why you'd build a patio with a hypocaust. But now we know it's all about grey boxes and conduit runs. Or it will be - so far it's only been used for dumping bent barrier arms.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 19:41, 21st January 2023 | ![]() ![]() ![]() |
Made by the same companies as for drainage too. So are the "pipes" that run under the tracks, but they too have got more sophisticated, being divided into several separate channels. | Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by IndustryInsider at 18:46, 21st January 2023 | ![]() ![]() ![]() |
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 17:12, 21st January 2023 | ![]() ![]() ![]() |
My initial though was that those plastic cylinders look like the manifolds that sit under drain covers leading down to inspection chambers. These were big enough to provide manholes. But there's no sense in having a drain there, and that pipe sitting across the tracks must be a red herring.
It turns out they are called UTX chambers, and that running wires under the track is another area of railway infrastructure that's got bigger (and more expensive) and one hopes better too. The first of two later pictures suggests that, and, when I zoom the original image right in, that marker post even has "electric cables" written on it.
Oddly, that marker vanished in later tidying up, and it does look as if the cables had to be put in before the civils work was finished. The same is true behind the left-hand one, where the cables have to run along the nearside of the line towards Crowthorne. There was a conduit built across to join the old lineside conduit, and now a new one is being installed. All the trees and bushes have gone too.
All of this is of course for the Feltham and Wokingham resignalling project. The Feltham part is largely done, but Wokingham's area will take until next year. There is one effect so far that passengers might notice - and I don't imagine they'll be pleased. Even as a manual box Wokingham could have had remote control of distant points, but it in the past this wasn't done for the crossovers at Bracknell and Blackwater. They remained with ground frames, and kept locked except for engineering works.
The Bracknell crossover is now controlled from the Wessex Rail Operating Centre (Basingstoke), so it can be used for routinely reversing trains. And from last December three evening trains do that, and no longer Run to Wokingham and Reading. The last two trains do still run through, but L-2 and L-6 terminate and run ECS to Staines, while L-4 runs there in service. For trains from Reading to Ascot, just one (L-2) has been lost.
Now, it was already possible to terminate and reverse trains at Wokingham - but I don't think that was ever part of the service pattern. (With no printed timetables to collect, I can't be sure.) Some complaints are starting to appear, but it's a bit odd for the Bracknell MP to be involved.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by IndustryInsider at 21:43, 20th January 2023 | ![]() ![]() ![]() |
For cabling going under the tracks isn’t it?
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by Surrey 455 at 19:53, 20th January 2023 | ![]() ![]() ![]() |
Drainage?
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 18:54, 20th January 2023 | ![]() ![]() ![]() |
What were these guys up to, do you think? The pictures (during and after) aren't new - they date from two years ago, when work on the upgraded (now residing) siding began. But what's the purpose of whatever they built underground?
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by IndustryInsider at 12:45, 10th January 2023 | ![]() ![]() ![]() |
A Class 701 that SWT don't want, SE Trains have taken some but I think they are finding it cheaper to refurb 465/6's
I think you're getting 701s and 707s mixed up, as well as SWT and SWR.
Mind you, whether SWR really want 701s now is open to debate given the time taken to introduce them and the reduction in the core SWR commuter market since they were ordered.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by Bmblbzzz at 12:40, 10th January 2023 | ![]() ![]() ![]() |
Graffiti can be art. Perhaps it's subjective as to when it becomes art*, but unwanted spraying over windows, etc, is vandalism.
*The 'What is art?' thread can found over there >>> First post, Cave Hunter, 01/01/-9999
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by Electric train at 09:58, 10th January 2023 | ![]() ![]() ![]() |
I noticed coming through Wokingham this morning there was a graffitied train in the siding. Is that the same one?
Yes, it's been there all along. SWR must be really short of space. But after the first bit of painting on each side I've seen no more. So maybe the signal box really is a deterrent.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 09:09, 10th January 2023 | ![]() ![]() ![]() |
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by bobm at 09:01, 10th January 2023 | ![]() ![]() ![]() |
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by Fourbee at 10:17, 27th December 2022 | ![]() ![]() ![]() |
I was literally just about to post at least GWR let them practise on 769s, not brand new 701s.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by IndustryInsider at 10:11, 27th December 2022 | ![]() ![]() ![]() |
Oh dear. Still, it’s a testing time for graffiti artists due to price rises. Maybe it would have been a better idea to stable some 769s there and hand out some free crayons?
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 23:31, 26th December 2022 | ![]() ![]() ![]() |
I did question why this long access platform was built at our siding. Well, now we know! It's a working platform for the local freelance paint contractors to work from*.
You might also ponder why, having picked an out-of-depot siding that is monitored - overlooked by a signal box staffed 24/7 - they put a train there on the only day (or two) of the year when the box is closed.
* and at such very affordable rates, too.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by CyclingSid at 06:52, 5th May 2022 | ![]() ![]() ![]() |
Went up over the new Waterloo Road bridge which is open, didn't go further (having just done a circuit of Bracknell). The Easthampstead Road crossing had a massive tail back, so I assume that the Waterloo Road project isn't finished.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 20:02, 3rd February 2022 | ![]() ![]() ![]() |
Note the date ... so it's nearly five years on, and the local papers (as well as the borough) announce that the road and bridge have been granted planning approval (no. 172934).
Since approval, work on this bridge and a little bit of linking road has proceeded with very little reporting. Apart from none of us going out much, it's probably relevant that it was hard to get there - no road access. But it did open on 24th January, as unreported in the local paper.
As built, it replaces the level crossing in Waterloo Road, which was already closed for the new junction (roundabout) to be built but that will now be permanent. However, that's not a route of any use to me going to or from home, so it'd need a special visit to get there. Another bit of de facto ring road is planned that would make it more useful, but that has not even got to the full planning application stage.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by Electric train at 08:07, 4th December 2021 | ![]() ![]() ![]() |
The same question occurred to me on Tuesday when I noted to patina of rust on the rails when I passed it on the way to Guildford!
It is posible the siding is for perturbation, and as turnback use during engineering possessions also as a cripple siding
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 18:41, 3rd December 2021 | ![]() ![]() ![]() |
Has anyone seen anything using this siding in anger yet?
The only thing I can recall seeing parked there is the odd RHTT.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by bobm at 18:15, 3rd December 2021 | ![]() ![]() ![]() |
It has been used a couple of times in connection with rolling stock failures.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by eightonedee at 18:04, 3rd December 2021 | ![]() ![]() ![]() |
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by IndustryInsider at 14:02, 3rd December 2021 | ![]() ![]() ![]() |
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by Electric train at 07:13, 21st May 2021 | ![]() ![]() ![]() |
Here is what a proper siding, and the walking route to it, looks like these days. The new fence seems to have been a bit of an afterthought, and wasn't finished when AmcoGiffen took their site office away (they are still doing some sort of landscaping to it). And a bit of work was going on today; by the look of it some of those lights needed redoing. Given how many there are, it wouldn't be a big fraction of them.
By the way, I'm not really suggesting that improving safety isn't worthwhile - just that it has a cost, and in this case it contributes only marginally to operational performance.
The fence has more to do with crime reduction than public safety, when trains are berthed in the siding there is a high risk of graffiti. It will not have been an after though it would have been part of the formal design for the siding, it is also likely that boundary fence reinforcement has or will be carried out elsewhere
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 22:54, 20th May 2021 | ![]() ![]() ![]() |
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by IndustryInsider at 01:34, 20th May 2021 | ![]() ![]() ![]() |
Good to see it open, it's a 15mph siding, so probably just taking it cautiously.
Regarding a proper berth for it, you may well see one when the area is resignalled (2024?) but not before.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 00:07, 20th May 2021 | ![]() ![]() ![]() |
Today (Wednesday 19th) the siding finally opened to receive guests - a few days after other hospitality venues. I've got some pictures, which will have to wait until tomorrow. They show what crew access to a siding looks like now, under the latest agreement with ASLEF.
The visitor was a pair of 707s, running as 5Z41 from Waterloo and then, after lunch, as 5Y68 to Wimbledon Park Depot Sidings. It ran as if for training, calling like a passenger service (until reversing at Twickenham), which does seem odd for 707s. It came out of the siding at walking pace, which might be standard practice or it might be because it was the first test use.
From now on there is a late afternoon Q path in the WTT, from Staines Up Loop to Reading, for reasons that are hardly clear. But no operational use has yet been timetabled. Both Traksy and OTT showed the siding before his, but neither has a berth in it even now - the departing train just appeared from nowhere in Wokingham P2.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by Electric train at 08:35, 29th March 2021 | ![]() ![]() ![]() |
More, slow, progress, with this siding but still many bits to complete. And you do wonder if this new super-high build standard is really called for.
Those platforms are indeed one long and one short. I presume the requirement is to park a train and leave it to be recrewed later, so the requirement is to walk through and check the whole train (unless it arrived ECS). However, I'm still not sure how that matches what they've built.
The latest new bits are all those lights. Most of the path is done, assuming those black and yellow covers are for underground ducts only and gravel is OK for the rest. And no doubt, this being The Railway, that colour choice means something. Quite a bit has been done to tidy up the earth slope beyond the path, with boarding which I guess is a permanent retaining wall. Surprisingly, the raised cable ducting has been kept at the same height but moved from in front to behind the supports!
And you can just see that the third rail has been fitted with guard boards. That does seem a bit of an odd thing to do if it is for safety of the crews of trains using the siding. But is there another reason? Like not allowing a shorting bar to be used in the siding? Or perhaps because the running lines right next door don't form part of a third-rail railway at all?
Its an ORR requirement for guard boarding to be fitted in stabling sidings. The platforms are to reduce the slips trips and falls for the train crew to access and egress the train, there will be a walkway and I suspect there will be lighting as well
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 00:15, 29th March 2021 | ![]() ![]() ![]() |
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 00:15, 15th March 2021 | ![]() ![]() ![]() |
I've always expected some preparation for resignalling to be included, but if so it's not visible.
Network Rail now have a web page about the Feltham and Wokingham resignalling. This gives the following commissioning schedule:
From 2021 onwards, we are set to commission new signalling in the following areas on the following dates:
Phase one: Strawberry Hill and Twickenham – Easter 2021
Phase two: Virginia Water and Ascot – Easter 2022*
Phase three: Windsor and Staines – August 2023
Phase four: Feltham and Kew Bridge – August 2023
Phase five: Wokingham – March 2024
*To be confirmed
*To be confirmed
So Wokingham - where the points are mechanical, though the signals aren't - is to be done last. The first date I saw for its completion (implying the closure of the signal box) was 2017, though the whole programme had already been delayed before that was set. Still, that's quite quick compared to some bits of work ...
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by IndustryInsider at 00:15, 12th March 2021 | ![]() ![]() ![]() |
From the limited evidence in the picture, it looks like a longer platform nearby and a shorter one down at the end. That would give access to the cabs at both ends of a single unit, and the far cab of a second unit coupled to it, but not to the other cab of that unit. There's no sign of a third platform for that, though.
You only really need a platform in the middle as the two cabs at each end of a 2x5 car train can be reached by walking through the train, so I'm not sure why the far platform is being constructed? Not that there's too many 5-car sets being constructed as part of the Class 701 build anyway, so the majority of trains will be formed of the 10-car sets where a driver wouldn't need to leave the train to change ends.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 00:03, 12th March 2021 | ![]() ![]() ![]() |
Work on and around the siding has continued for the last two months. For one week there was a team of twenty working, but mostly it's been about five. And all that work has, as far as its visible outcome, been on the yellow walking route and what it leads to. I've always expected some preparation for resignalling to be included, but if so it's not visible.
Part of the route is laid on a concrete base (as in the previous photos), but further on it spans an existing cable duct and presumably keeps that accessible. It's not all yellow, and not finished yet, but it will have lights. And, at the end, you can see that there will be two mini-platforms. No doubt they will have steps at the end ... and those yellow railings at the back? Taller lights? And ... a name? Perhaps not.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by IndustryInsider at 00:53, 15th January 2021 | ![]() ![]() ![]() |
Good to see the 3rd rail extend all the way to the end - plenty of room for a 10-car unit.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 23:34, 14th January 2021 | ![]() ![]() ![]() |
Up at The Signallers' Shed, even more progress - it's finished.
Most activity since mid-December has been between the shed and the siding. I thought this would be preparation for the resignalling (and recontrol of the points), but there's no sign of any new grey or yellow boxes (just some less hidden by the undergrowth). But now it's becoming clearer what they have been building: it's a Yellow
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 23:32, 14th January 2021 | ![]() ![]() ![]() |
There has been some progress on the siding, done overnight with no big possessions needed. First we had ballast tipped on top and conductor rail left at the side, then a tamp, and finally the insulators and third rail were fitted. You'll see that it's still isolated - very safely indeed (I can't even see the bit of rail for that gap).
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 23:55, 2nd December 2020 | ![]() ![]() ![]() |
You have rail! It was delivered quietly, with no possession, early on Sunday morning. I didn't even hear all those fishplate joints being done up! Next step, presumably, is a visit from a tiny tamper - one is due on 13th. So maybe it is a Christmas present after all.
But no progress on the new shed roof.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by Electric train at 07:05, 19th November 2020 | ![]() ![]() ![]() |
I thought on the latest third rail sleepers the holes actually contained threaded inserts? Will have to look at some more closely...
Concrete screws are used now, they do not require and insert, a steel bolt that screw that threads direct into concrete driven in with an impact wrench set to the right torque.
Well, the concrete castings are - they have the fixing holes for chairs - but there are none with chairs fitted. I'd have thought that these days they'd have to be factory fitted - you can't just clip them down using those holes can you? ared unfit for DMU habitation and longer is better. Unless it is foreseen that there will be multiple failures of 769s, even of just one engine, so they have to be pulled out of service ...
If the pots were factory fitted they would not survive the delivery and placement process, also modern plastic pots are in 2 bits, the top half sits inside the lower half, there is are stepped adjustments in the mouldings so shimming is no (mostly) longer required
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by paul7575 at 21:14, 18th November 2020 | ![]() ![]() ![]() |
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 23:00, 17th November 2020 | ![]() ![]() ![]() |
Excuse my eyeballs, but I can't make out sufficient detail, are those sleepers suitable for third rail?
Well, the concrete castings are - they have the fixing holes for chairs - but there are none with chairs fitted. I'd have thought that these days they'd have to be factory fitted - you can't just clip them down using those holes can you? I can't make out any maker's name, but they do have a number - 5894 - on one end. Oddly, they have all been laid with that number on the same (east) side but the chair fixing holes are a random mixture of that side and the other. I can't imagine how they get manufactured that way.
Here's a full resolution clip from that photo, so you can see what I mean.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by Electric train at 21:11, 17th November 2020 | ![]() ![]() ![]() |
Osborne were given a new framework contract in December 2018, announced together with Murphy & Sons and BAM Nuttall (for Anglia and South Eastern). These are for CP6, and the announcement was for Southern region, though how Anglia fits into that is a mystery. Presumably the work planned within the routes will stay that way and to start with only top management will change.
That was how Infrastructure Projects was structured prior to the Putting Passengers First reorg. IP was structured into their own regions in 2012, supposedly it was more efficient! but had no accountability to the Routes who funded the projects
IP is now called Capital Delivery who are now part of the NR Regions and are part of the Region Managing Director structure so better accountability.
Most building maintenance work is carried out by Works Delivery which tend to carryout smaller cost projects such as heavy maintenance where as CD carry out the multi million ? projects. Works Delivery do such projects as sidings renewals as well
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 20:42, 17th November 2020 | ![]() ![]() ![]() |
Geoffrey Osborne were given a framework contract for "One-team Wessex", a multi-functionak framework for infrastructure projects, running from 2014-1018. But that wasn't as an independent prime contractor; they set up a design and project management office jointly with NR at Waterloo. I never saw anyone labelled as "Osborne", so it may be that the subcontracting process was kept with NR.
What I did see, at the end of 2018, was a huddle of small vans (too small for a PW crew plus tools) by our level crossing, with a bigger Network Rail (NR) one. There was a bunch of figures in shiny new HiVis on the track near the junction, looking at it. The vans were liveried Cleshar, SERC, and Ganymede - all contractors who do work in the track, though not on the same scale.
The only reason I could think of for all three to be there was some kind of on-site bidders' conference; the modern style is that any answer to one has to be copied to all so they might as well all look and ask together. No secrets! But what work was planned? This was after the last bent points got straightened, and during 2019 I saw Cleshar vehicles only a couple of times, and yes for work on that junction.
Edit: VickiS - Clarifying Acronym
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 20:03, 17th November 2020 | ![]() ![]() ![]() |
The building next to the box at Wokingham is the relay room. Apparently earlier this week the work caused a leak in the roof and various electrical components were doused in water.
It looks a lot of scaffolding if the work is just to relay the roofing felt. Which would be a bit ironic, of course.
After a very serious incident 2 years ago where a technician received electrical burns in a traction power substation, the flash over was caused by water ingress into the build' a survey of all operational buildings containing operational electrical were surveyed. A plan is being worked through to repair building roofs in a number of types / age of buildings its been decided to remove to old roofing and renew it with a modern system.
I saw these joists had been fitted by Sunday, and did wonder if they were for a roof or floor. You can't really see how deep they are, and in any case a roof probably has to be strong enough for a couple of dozen teenagers to climb on it and jump up and down.
While it would seem odd for the new recontrolled signals to need a lot of heavy kit, the junction will need several point motors and it takes more than a supply of digits to make them dance. So there may be a need for more space somewhere, unless the whole removal/replacement is done in one operation.
I found that the latest (June 2019 - presumably also the last) Wessex Route Strategic Plan has dates for major disruptive works for all CP6, i.e. out to 2023/24. This lists two 9-day blockades for Wokingham Feltham Re-signalling Commissioning and Wokingham S&C - both for the Winter Half-term (eh?).
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by Electric train at 20:03, 17th November 2020 | ![]() ![]() ![]() |
All the moulds on the production line will all be orientated in the same direction, if i remember correctly there are 10 sleepers per mould. Sleepers tend to come pre clipped, for third rail there will be 4 holes on each side to anchor the pot, these holes are onl6 12mm dia and may be plugged to prevent unused ones filling with water and potential freeze cracking the sleeper end
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 19:46, 17th November 2020 | ![]() ![]() ![]() |
But if it's not to be electric, it does remove the only obvious use for a siding. Based on pre-Covid plans, of course, SWR should be moving up to 4 tph all day, so if there's a hold-up on the Reading side they can rapidly end up with too many trains in one place. If a driver is missing (out of hours, for example) or the capacity for returning trains towards Waterloo is a limitation, a parking place would be a good idea.
But if it's not SWR's trains, it's hard to see why it needed lengthening - unless the track was now so rough it had been declared unfit for DMU habitation and longer is better. Unless it is foreseen that there will be multiple failures of 769s, even of just one engine, so they have to be pulled out of service ...
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by ellendune at 08:16, 17th November 2020 | ![]() ![]() ![]() |
NR was required by DfT and ORR to reduce costs by the use of Framework Contractors, each Route tendered out the Framework. These contracts were multi discipline the Framework contractor then employing sub Framework contractors / suppliers.
These Framework and subs are in the main from large National companies.
Is it cheaper, more efficient etc ............... who knows!
I am very skeptical about cost savings from frameworks contracts as they currently operate. They certainly reduce the clients management costs, but in many cases the levels of sub-contracts can be significant. So you have the tier 1 contractor subcontracting to a tier 2 to a tier 3 etc.. Each contractor takes a cut and communication gets lost so I have seen requirements in the original contract watered down or lost by the 3rd tier as the price has been committed by the main contractor and each tier needs to pay for its cut!
Perhaps it is because the contracts are trying to be too much of a good thing.
In these systems smaller contractors only get a bite of the cake by working for their larger rivals. This leads to a situation similar to the supermarkets and farmers where the smaller contractors are screwed down on price (and do sometimes therefore do a bad job) to pay for the margins of those in between.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by Electric train at 07:15, 17th November 2020 | ![]() ![]() ![]() |
it may not be an electrified siding in which case no need for third rail sleepers
The first point is that the contractor is not a small local one, but AMCO-Giffen of Barnsley - second level, behind the really big boys. The current activity was a bloke on a mini 'dozer (and RRV one), who had two helpers to stand watching and wave their arms. There was another one too, sitting peering at his phone.
Network Rail (NR) was required by DfT and ORR to reduce costs by the use of Framework Contractors, each Route tendered out the Framework. These contracts were multi discipline the Framework contractor then employing sub Framework contractors / suppliers.
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by CyclingSid at 06:55, 17th November 2020 | ![]() ![]() ![]() |
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 19:14, 16th November 2020 | ![]() ![]() ![]() |
Another weekend, another mob of track workers out - in the rain, this time. About ten certainly working on the siding on Sunday, but there were at least twice as many from other contractors so probably doing other stuff. As you can see, yesterday we got some sleepers, and by today (last pic) they run the full length. Still about ten people doing the usual vital work: watching the sleepers, moving long bits of wood from place to place, etc. ...
| Re: Wokingham station - improvements, resignalling and siding - merged posts Posted by stuving at 15:43, 12th November 2020 | ![]() ![]() ![]() |
If it's not for EMUs then it maybe it is for DMUs, 769s? Or would they have fitted in with the previous length?
I'm sure it was easily long enough, though I can't find a picture of where the marker was. This year's TPR has its length as 8 cars, which agrees with what I estimated as 150 m (ish).
