Two rail workers killed in collision with train, near Port Talbot - Wed 3 July 2019
9.5.2025 (Friday) 15:42 - All running AOK
Re: Two rail workers killed in collision with train, near Port Talbot - Wed 3 July 2019
Posted by ChrisB at 21:29, 16th February 2025
Fine to be paid by the taxpayer.
By way of less improvement spend in the period
Posted by Electric train at 11:00, 16th February 2025
When NR is fined it is actual loss of capital that the company no longer has available, NR is still obligated to its CP7 renewals, levels of maintenance etc therefore the £3.75m has to be found by internal cost cutting / savings, NR cannot go back to the ORR / DfT and ask can we have more money.
Posted by TaplowGreen at 10:48, 15th February 2025
Posted by Chris from Nailsea at 09:11, 15th February 2025
Network Rail fined £4m after workers killed by train
Rail workers Gareth Delbridge and Michael Lewis died when a train crashed into them while they were on a job in July 2019
Network Rail has been fined nearly £4m after two workers were struck and killed by a train following safety failures.
Gareth Delbridge, 64, and Michael "Spike" Lewis, 58, were hit by a Great Western Railway train travelling from Swansea to London Paddington in July 2019.
The two men had been working for Network Rail at Margam, near Port Talbot, at the time and a third track worker also came close to being hit, with a previous report describing him as "severely traumatised".
Network Rail said it continued to "transform the safety of our workforce" following "the tragic deaths".
At Swansea Crown Court on Friday, Recorder Christian Jowett fined Network Rail £3.75m, saying the company had failed to put in place proper measures to protect the workers.  The judge said issues surrounding safety policy had been known for some time and the firm had failed to make improvements.
Network Rail previously admitted its role in the men's deaths.
The court heard that, in the absence of technological solutions, the only protection workers had was a lookout, which Mr Jowett described as the "lowest level of protection".
"Visibility towards Port Talbot at the site was restricted due to a curve in the track, so the need for two lookouts was identified, with four men carrying out the work," he said.  "But what happened was the group split into two, one to carry out the maintenance work and the other to carry out [other] work - no one was available to be the second distant lookout.  The task was noisy because of the type of machine being used."
The judge said none of the workers were aware of the approaching train "until it was too late".
Issues surrounding Network Rail's track safety policy had been known since 2017, but the judge said by 2019 the steps taken had "not resolved the concerns".
Mr Jowett said the policy - called Standard 19 - for how track work should be carried out was "substantially based on a number of unsuccessful initiatives since 2014", following previous deaths in 2011 and 2012.  "I find that Network Rail therefore must have had a good understanding of why these initiatives failed," he said.  "However, I also find that it didn't learn from these experiences because the design and rollout of Standard 19 repeated a number of mistakes and introduced further mistakes."
Contrary to its own policy, Network Rail did not consider it necessary for the rollout of Standard 19 to be delivered by qualified trainers, with the amount of training reduced from eight hours to two and a half, with a video, "which may have added further confusion".
The judge also said track workers had narrowly avoided being struck by trains in July 2018 and April 2019, and in December 2018 the regulator indicated that it was "minded to serve improvement notices".
Nick Millington, route director at Network Rail Wales and Borders, said the "tragic" deaths of Mr Delbridge and Mr Lewis "should never have happened on our railway".  "Since this tragedy, we have continued to transform the safety of our workforce through the development of new technology and planning tools, which have almost entirely eliminated the need to work on the railway when trains are running," he said. "Today's judgement reinforces why safety must always be our first consideration, and we will continue to do all we can to make our railways the safest they can be."
Mark Phillips, chief executive of the independent organisation Rail Safety and Standards Board, said the incident was a "catalyst to completely rethink track worker safety".
Posted by Electric train at 07:44, 14th February 2021
From my experience as a passenger passing works for nearly two decades - aren't the works at night usually lit by temporary site lighting at a low level that seems to illuminate track works quite well?
The portable / mobile lighting provides both task lighting (200 Lux plus) and general illumination 10 / 20 Lux).  The one thing that fixed lighting on columns cannot provide easily in task lighting portable / mobile is able to provide the task lighting.
On electrified routes, it should be possible to provide night time work lighting affixed to the OHLE gantries. A permanent installation but only turned on when needed. This would greatly reduce the risk of trips and falls.
In extreme weather it might be worth turning on the lights in order that the infrastructure and surroundings may be kept under close observation.
Lighting will need a voltage significantly below 50/25kV. This will require a step down power supply which essentially means an additional low voltage power supply in parallel with the traction power.  This would be an additional cost with the only offset being that it could presumably be supported on the OLE infrastructure. The cost would therefore be significant.  Far better to take power from the 650V signalling power supply where that is present.
The 650V signalling supplies generally do not have the capacity to provide site lighting loads.  Signalling Power Supplies are also a safety critical system using them for general supplies would pose a risk to the safety critical system.  Also the transitory nature of track works means the cost of modifying the 650V system against the times it would be used probably would not have the cost saving benefit.
NR are trialling portable tower lighting with LED lights that are battery powered that have sola / wind generation which means at night they run on battery during the day when not in use the sola and wind charge the batteries, they also have a small generator to charge the batteries.  The great thing about these is they are silent at night, the generator only runs is need during the day
Posted by ellendune at 22:18, 13th February 2021
Posted by eightonedee at 18:52, 13th February 2021
Posted by Electric train at 17:23, 13th February 2021
Whilst it sounds like a good idea there are a number of issues.
OLE structures on the GW am 100 metres apart, therefore quite powerful lighting would be required, this could be hazardous to train drivers on adjacent open lines.
The OLE structures are not high enough with the 100 metre spacing and would cause shadows in the middle area which would increase the slips trips and fall hazards
Where fixed light has been installed at junctions, even with correct direction of the light fittings and shielding complaints from lineside neighbours due to the light pollution almost renders them useless.
The maintenance of the lights is problematical.
The reason I am sceptical .................. it has already been tried on the West Coast Mainline at a number of junctions and was remove quite quickly because of the issues above and few more.
With battery and LED technology we have today site lighting is easier to deal with.
Most staff slip trips and falls are actually getting in and out of the van or off loading the vans and walking down access stairs and paths to the line side
Posted by broadgage at 11:49, 13th February 2021
Posted by Electric train at 18:32, 13th November 2020
A quote from the recommendations of the report with potentially far reaching consequences:
10 The intent of this recommendation is to explore ways of reducing the risk
to staff who work on or near the track by creating more opportunity for
safe access to the track when trains are not running.
Network Rail, in consultation with the Department for Transport, relevant
transport authorities, ORR and other railway stakeholders, should
investigate ways of optimising the balance between the need to operate
train services and the need to enable safe access to the track for routine
maintenance tasks. Options for consideration should include:
a) the provision of gaps in the train service, during daylight off-peak
hours, to enable timely and safe access for maintenance staff
b) greater use of alternative routes or bidirectional lines to achieve the
above
c) increased availability and utilisation of weekend and night time
possessions for cyclical maintenance tasks.
Any reasonably practicable measures that are identified should then be
implemented in accordance with a timebound plan (paragraph 359b).
There is a big drive to do more work on nights, however there are knock on effects, some are.
There has been an increase in slip, trip, fall injuries to staff due to night work (apparently is dark at night ....... who knew!! )
Less staff available during to day to react to faults and failures
Increased complaints from lineside neighbours due to noise and light pollution from the work lights
Passengers may see a reduction in late night services
Posted by ellendune at 23:38, 12th November 2020
Should and must have different meanings in this context. there are no musts in this quote, so only a sugestion to change anything.
Hence potentially
Posted by MVR S&T at 23:26, 12th November 2020
Posted by ellendune at 23:04, 12th November 2020
above
Posted by didcotdean at 11:42, 12th November 2020
The RAIB published its report on this today here.
"The accident occurred because the three track workers were working on a line that was open to traffic, without the presence of formally appointed lookouts to warn them of approaching trains. They were carrying out a maintenance activity which they did not know to be unnecessary. All three workers were almost certainly wearing ear defenders, because one of them was using a noisy power tool, and all had become focused on the task they were undertaking. None of them was aware that the train was approaching until it was too late for them to move to a position of safety. Subsequent acoustic measurements have shown that they would not have been able to hear the train?s warning horn.
"The system of work that the controller of site safety had proposed to implement before the work began was not adopted, and the alternative arrangements became progressively less safe as the work proceeded that morning and created conditions that made an accident much more likely."
Posted by grahame at 08:09, 3rd July 2020
From The TSSA
TSSA Remembering Margam
3 July 2020
Today marks the first anniversary of the tragic deaths of two Network Rail (NR) maintenance workers at Margam, near Port Talbot in South Wales.
Gareth Delbridge (who was 64) and Michael "Spike" Lewis (aged 58) were hit by the train travelling from Swansea to London Paddington. Our thoughts remain with their family and friends - they are gone but not forgotten.
Our union will always commemorate the dead, whilst also doing, all we can to fight for the living.
Over the past twelve months we have seen progress when it comes to keeping people safe going about their work on the tracks. Our union has been very vocal in continuing to press NR for improvements in the area of track safety.
We learned – via a report from the Rail Accidents Investigation Branch - there were no formally appointed lookouts at the site where the two rail workers were hit and killed. Our union will always put your safety first and we welcomed NR establishing a safety taskforce in the wake of the deaths at Margam.
We have taken an active role working with the taskforce and are now seeing downward trends in the use of unassisted lookouts, increased use of methods of protection whilst works takes place, and more technology to drive safer solutions in our working environments.
However still more needs to be delivered to reach our collective goals - such as speeding up the roll-out of Track Circuit Operating Devices (TCODS) – a simple, cheap and effective means of providing protection to those working on the track by activating track circuits to show the track section being worked on; not relying solely on the signaller for protection.
Progress is being made but there is much still to do. We know a train nearly hit a track worker in Bedfordshire last month. The incident involved the train – travelling from London Euston to Liverpool Lime Street – passing dangerously close to the worker at Leighton Buzzard.
We know NR is working on long-term improvements but risks to track workers remain too high, with too many near misses. Together we must keep pushing for ever greater progress to save lives.
So, we will continue to work with employers to ensure incidents like Margam are reduced to zero while at the same time making our concerns clear on NR’s so-called ‘Putting Passengers First’ reorganisation and the regional devolution of safety management this entails.
Posted by grahame at 08:06, 3rd July 2020
A year ago today ... Gareth Delbridge, 64,  and Michael "Spike" Lewis, died when they were hit by a train while working on the track near Margam when systems and colleagues should have kept them safe.
From the BBC
Network Rail: 'Serious failings' led to Margam deaths, says victim's family
Two rail workers were killed by a train due to "serious failings" by their employer, according to one victim's family.
Gareth Delbridge, 64, from Kenfig Hill, and Michael "Spike" Lewis, 58, from North Cornelly, died near Margam, Port Talbot, on 3 July 2019.
Mr Delbridge's son-in-law said Network Rail's current working practices "aren't fit for purpose".
The company said it is working to "improve safety on the railway".
Investigations by Network Rail found Mr Delbridge and Mr Lewis had been using a tool with a petrol engine and wearing ear defenders, meaning they did not hear the approaching train, which was travelling from Swansea to London Paddington.
The report said six staff working on the line had separated of their own accord into groups of three, which meant there was no official lookout.
It also said the Port Talbot depot's management's "habitual ways of working had normalised behaviour which was inherently non-compliant with company and group standards."
'Archaic'
Mr Delbridge's son-in-law, Adrian Grant, from Porthcawl, said it was "unacceptable" for the report to blame individuals.
"These were very experienced men who went out to work that day and never returned home," he said.
"If that can happen to these men it says to me there are some very serious failings within an organisation. They didn't go to work for this to happen.
"For an organisation to put out a final investigation report blaming people working on the track is unacceptable."
Bill Kelly, Network Rail's route director for Wales and Borders, said colleagues were taking part in a two-minute silence on the anniversary of the tragedy, which "remains at the forefront of our minds".
"The safety of our colleagues and passengers remains our absolute priority and our safety task force, comprising of more than 100 people, has been set up to further improve safety on the railway," he added.
Calling the company's working practices "archaic", Mr Grant has called for the company to protect those working on tracks who are "putting their lives at risk".
"They've got men with flags and whistles or horns in front of locomotives travelling at 120 mph," he said.
"There's no lessons learnt by saying person A or person B did something wrong that day. What needs to be learnt is about the fundamentals of what went wrong."
Posted by Electric train at 19:23, 22nd April 2020
A further incident with workers on a live line not being (properly) alerted to an approaching train. Fortunately in this case, the track workers concerned were alerted by the train's horn and able to jump clear.
I will leave the experts to draw appropriate parallels between Margam and Kirtlebridge - but I am posting the above in the "Margam thread" as a reminder of the critical importance of getting systems right for every situation where there is work on the track.
Sadly, Another - this from an email announcing that the RAIB is looking into it.
At around 10:52 hrs on 8 April 2020, a track worker was struck and fatally injured by a passenger train on the West Coast Main Line near to the village of Roade. The track worker was part of a group that were undertaking civil engineering work at the location. At the time of the accident the line was open to traffic.
The train was travelling from Northampton to London (Euston), at around 90 mph (145 km/h) when its driver saw the track worker on the line ahead, sounded the train horn and applied the emergency brakes.
Sadly the another loss of life of someone working on an operational railway; however the work activity, the number of persons involved and staff protection method are completely different to Margam
Posted by grahame at 11:23, 22nd April 2020
Posted by ellendune at 19:23, 16th April 2020
There are similar issues with roadworks, hence the greater use of road closure to carry out work. The same issues as listed by EE arise there.
Posted by Electric train at 13:08, 16th April 2020
ET. Personally, speaking from the point of view of having worked lineside for over 50-years now, is that fundamental problem won't be addressed.  That is, too much paperwork to fill in and too much to read and brief out before going lineside.  Peoples natural tendency is that if it gets too complex they will take short cuts, as the 'its too difficult' syndrome cuts in.  I'm not prejudging this was the case in the latest incident, but from the initial RAIB notice of investigation it certainly looks that way.
If you move to RED ZONE working only that will make the situation even worse, and it will probably be impossible to implement.  We might as well give up running trains altogether if that happens.  Working on a live railway always has been, and always will be a hazardous process, and you cannot eliminate all Risk.
So my messge is: Make it all simpler and straightforward for people to implement, not more complex.
While agree with all that you have said, like you I've worked lineside for 45 years most of it on 125 railways.  In those 4 plus decades a number of things have changed.
There are more faster trains operating
The noise level of the trains is lower
Vegetation is more of an issue today.
But the key issue is the experience of the staff and in particular their local knowledge.
There is less and less equipment in the 4ft or within the 2 meter zone that requires access, HS1 for instance does not allow access even to most its lineside while trains are running.
Could in a Court of Law demonstrate beyond all reasonable doubt that the work in a red zone could not reasonable done in a different way or time
Posted by SandTEngineer at 08:26, 16th April 2020
Posted by Electric train at 07:04, 16th April 2020
https://www.bbc.co.uk/news/uk-scotland-south-scotland-52270656
A train travelling at 125mph almost struck three track workers after a breakdown in communications, rail accident investigators have concluded.
The workers jumped clear less than one second before the train passed them on the West Coast main line in November.
The Rail Accident Investigation Branch report said one of the lookouts had not known he was meant to raise the alarm.
It said the lookout team had used "informal language" rather than following the proper protocols.
A radio-based lookout-operated warning system was being used because of the high train speeds and the curved track south of Kirtlebridge in Dumfries and Galloway.
These are my personal thoughts; what in the industry is called Red Zone Working (ie undertaking work on open lines or within 2m) could well be prohibited.
I feel initially this prohibition will be for anywhere any of the lines has a line speed is over 60mph.   This would mean any work would require a possession of the line or ESR to carry out work.
I also feel if NR does not introduce this its self the ORR will impose it under its Health and Safety at Work Act powers
Posted by grahame at 11:16, 15th April 2020
Posted by stuving at 15:03, 6th December 2019
RAIB have released an interim report. I guess this covers much the same narrative information as the network Rail one did. The preliminary conclusions are:
60 The accident occurred because the three track workers were working on a line that was open to traffic, and without the presence of formally appointed lookouts to warn them of approaching trains. All three workers were almost certainly wearing ear defenders, because TW3 was using a noisy power tool, as instructed. All three were focused on the task they were undertaking. None of them was aware that a train was approaching them, until it was too late to move to a position of safety.
61 Working on an open line without a formally appointed lookout meant that no single individual stood apart from the work activity at the points with the sole responsibility of providing a warning when trains approached. The absence of a lookout with no involvement in the work activity removed a vital safety barrier.
62 The planning paperwork for the work on 9577B points indicated that the work was to start at 12:30 hrs, to coincide with the planned blockage of the up main line. However, witness evidence suggests that there was a widespread belief at the local maintenance depot that there was no need to wait for the planned line blockage in the afternoon, and a general lack of understanding as to how the planning paperwork should be interpreted.
63 The system of work that the COSS had proposed to implement before the work began was not adopted, and the alternative arrangements became progressively less safe as the work proceeded that morning.
64 These factors had created conditions that made an accident much more likely.
Posted by grahame at 14:42, 19th November 2019
From The BBC
Families of two rail workers who died after being hit by a train have said every day is "a living nightmare".
They want changes in rail line working conditions after Gareth Delbridge, 64, and Michael "Spike" Lewis, 58, were killed by a passenger train on 3 July near Margam in Port Talbot.
Mr Delbridge's son-in-law Adrian Grant said the families were awaiting the conclusions of three inquiries.
An initial report said there was "no safe system in place".
Early investigations found Mr Delbridge, from Kenfig Hill, Bridgend, and Mr Lewis, from nearby North Cornelly, had been using a tool with a petrol engine and wearing ear defenders, meaning they did not hear the train, which was travelling from Swansea to London Paddington.
A third worker was treated for shock but was not injured.
I recommend that forum members read the full article which is much longer than the quote above.  It clearly draws from the interim report mentioned above, and from which key parties have already been briefed to ensure that the systemic failures which have already been identified are dealt with such that this "cannot happen again".
Posted by grahame at 09:00, 9th October 2019
As there was so much reporting of a "published" document, I asked Network Rail for a link or copy.  Their response:
Dear Mr Ellis,
Thank you for contacting us about the interim report that was shared with Network Rail colleagues this week about the tragic events of Margam. We are aware of a number of media outlets reporting on this but wish to express that this report is only the initial stage of the investigation and once the final report has been concluded, we will be sharing the findings with not only our colleagues but with the concerned public.
The final report is expected to be concluded within the coming months.
Kind Regards,
Community Relations
I am now better informed on the interim investigations - finding out in detail what went wrong and crucially making sure that lessons are learned to ensure they don't happen again.   Good to report that such lessons, and briefings, are very much in progress (or have happened already) even prior to the full report.   Critical is that safety is paramount and planned and that it's not just down to good fortune that these are exceptionally rare occurrences.
Posted by grahame at 15:54, 2nd October 2019
But I can't find it on the Network Rail website, nor though search engines.   Have Network Rail published this as in "made it public readable" (and if so, where?) or have they sent out copies to selected outlets?   Has anyone got either a URL or a copy of the source document??
I assumed NR had "published" it in the sense of giving it, and more likely presenting it, to invited journalists. That's still pretty common for all kinds of organisation; sometimes followed by being put on line, sometimes not. It's not easy to see on NR's web site whether they have anywhere to put such publications - they certainly don't like providing links to help you find find such specific items.
Dear Mr Ellis,
Kind Regards,
Community Relations
Posted by SandTEngineer at 09:38, 2nd October 2019
A bit more detail here: https://www.railengineer.co.uk/2019/09/30/interim-report-on-port-talbot-track-worker-fatalities-reveals-there-was-no-safe-system-of-work-in-place/
Posted by stuving at 09:30, 2nd October 2019
Posted by grahame at 01:33, 2nd October 2019
There is no report on the RAIB website, which currently states that it is investigating.
Various further news stories such as Wales Online
https://www.walesonline.co.uk/news/wales-news/network-rail-port-talbot-deaths-17009796
Network Rail has now published an interim report of its initial findings into what happened. It found that a person looking out for approaching trains, known as a distant lookout, had not been deployed that morning.
Posted by bradshaw at 18:00, 1st October 2019
Posted by grahame at 17:43, 1st October 2019
From that ...
There was "no safe system in place" when two rail workers were hit and killed by a train in July, an initial report has found.
Gareth Delbridge, 64, and Michael "Spike" Lewis, 58, died on 3 July after being struck near Margam, Port Talbot.
A Network Rail and Great Western Railway probe said six staff were working on the line and separated of their own accord into groups of three.
This meant there was no official lookout.
Article continues ...
Interesting to see this quoted at a Network Rail / GWR report, rather that a government / DfT and RAIB one - I'm not sure of the metrics and have not picked up any links direct to the report - just seeing it as yet via the BBC.
The TSSA (via this link) have picked it up though ...
TSSA Response - Interim Report Into Margam Deaths
1 October 2019
TSSA General Secretary, Manuel Cortes, has issued a warning about rail safety and leadership after an initial report into the deaths of two workers who were hit by a train in July.
The Network Rail report says there was ‘no safe system in place’ when Gareth Delbridge and Michael ‘Spike’ Lewis died on 3rd July after being struck near Margam, Port Talbot.
Responding to the interim report, published on 30th September, Manuel Cortes, said:
"The report clearly demonstrates that senior management at Network Rail have failed to provide the necessary leadership and direction to ensure that those working on the track are able to do so without fear of losing their lives.
"Margam is the tip of the iceberg - we know there have been frequent near miss incidents involving track workers right across the country, both before and after Margam.
“For several years our union has warned of the weaknesses in the processes that are supposed to protect track workers. Sadly, so far, we have seen little progress in improving this situation.
"The rail safety enforcement body - the Office of Road and Rail - must also accept some responsibility; it knew of the problems but failed to take decisive action until Margam.
Posted by broadgage at 12:41, 1st October 2019
Posted by JayMac at 16:56, 19th July 2019
Since this tragic incident NR has mandated that a senior maintenance engineer must give approval at the work planning stage all work activities that require track workers to wear ear defenders when lines are open to traffic.  This level of approval is way way above supervisor or depot manager level
It's good to know that Network Rail have quickly addressed this specific issue. Unfortunately it is shutting the stable door...
Posted by Electric train at 15:09, 19th July 2019
From the Rail Accident Investigation Branch
At around 09:52 hrs on Wednesday 3 July 2019, two track workers were struck and fatally injured by a passenger train at Margam East Junction on the South Wales Main Line. A third track worker came very close to being struck. These three workers were part of a group of six staff, who were undertaking scheduled track maintenance on lines that were still open to traffic.
The train, which was travelling from Swansea to London Paddington, was approaching Margam on the up line at around 73 mph (117 km/h). Its driver saw three track workers walking away from him on the adjacent line and, beyond them, three more track workers on the line ahead of his train. He sounded the train horn and applied the emergency brakes. The track workers walking on the adjacent line became aware of the train approaching and tried to warn their colleagues as the train passed them.
The three track workers on the up line were working on a set of points, using a petrol-engined tool for loosening and tightening large nuts. Consequently, at least one of the workers was wearing ear defenders. CCTV images taken from a camera at the front of the train suggest that the workers did not become aware of the train until it was very close to them. By this time, it was travelling at around 50 mph (80 km/h).
The RAIB’s investigation will identify the sequence of events that led to the accident and consider:
* what might have influenced the actions of those on site
* the protection arrangements that were in place
* the planning of the work and the implementation of Network Rail’s standard for keeping people safe on or near the line
* any relevant underlying management or organisational factors
Putting the context in place, they add
Our investigation is independent of any investigation by the railway industry, the British Transport Police or by the industry’s regulator, the Office of Rail and Road.
We will publish our findings, including any recommendations to improve safety, at the conclusion of our investigation. This report will be available on our website.
Thank you Graham, this explains the work they were involved in.
Posted by grahame at 10:20, 19th July 2019
Posted by Chris from Nailsea at 00:39, 10th July 2019
Overwhelmingly, a sad day and I very much hope we can learn lessons quickly. My thoughts are with the families of the deceased and their Network Rail colleagues.
Thank you for posting your personal comments here, Mark.
Posted by Electric train at 19:49, 9th July 2019
Network Rail have asked that all railway employees join Network Rail in a minute silence at 10am Wednesday 10th July as a mark of respect to our two fellow railway employees, Gareth Denbridge and Michael Lewis who both tragically lost their lives a week ago whilst working on the line at Port Talbot.
Network Rail wish to invite all to join them in observing the minutes silence for Gareth, Michael and their loved ones.
Many thanks.
Posted by jamestheredengine at 15:14, 6th July 2019
A few footnotes from my experience of the disruption surrounding this sad incident:
1) Given what's been said about the replacement bus operation (and quite how rammed those Bridgend/Maesteg stoppers are at the best of times), I definitely feel I made the right call in going up to Merthyr for the X75, rather than changing at Central and Bridgend. It was a very pleasant, fast ride down the Vale of Neath that could only be improved by running more than three times a day (and with steel wheels on steel rails of course).
2) No-one asked the company operating the X75 to accept rail tickets (so I had to pay £6 up front) – to be fair, I'd anticipated this would probably happen – but the railway staff were brilliant. Got a smile from the Taff Vale guard who understood exactly what I was doing. And the guys in the ticket office at Neath were their usual helpful selves and provided me with a claim form and stamped a bit of paper to point out to customer service that this was to do with the disruption.
3) Pleasantly surprised that both the Capitals United and the train half an hour later ran the following morning. Ended up on the later of the two as I worked out I probably didn't need to rush.
4) Good to see that the "do not travel; use your tickets tomorrow" advice went up – this saves so much hassle – managed to use the return half of Wednesday's First Class excess on the Thursday night (rather later than usual – 2344 from Cardiff – thanks to my reprobate colleagues abducting me to the local Wetherspoon's and force-feeding me gin and bubbly to celebrate my birthday).
Posted by MarkHopwood at 07:14, 6th July 2019
Thank you for positive comments about GWR colleagues on board the train who seem to have managed a challenging situation well.
We have some lessons to learn about provision of buses and how that works jointly with TfW.
Posted by grahame at 20:36, 5th July 2019
Statement from Network Rail Media Centre
Media release dated today, 5th July.
Thursday 4 July 2019:
Andrew Haines, chief executive of Network Rail said: “Many of us are still reeling from the shock of the tragedy in South Wales yesterday when our colleagues, Gareth Delbridge and Michael Lewis died after being struck by a train. Gareth and Mike were extremely well respected and experienced members of the Port Talbot track team - together they have given over 84 years’ service to the railway and they will be missed.  Today I have been to South Wales to offer support to my colleagues, the families, as well as to the BTP and RAIB investigations.
“We have also appointed an independent investigator who will be joined by trade unions and industry partners to form the investigation team.
“This is a heart-breaking reminder of how dangerous it can be to work on the railway and highlights to us all the importance of challenging anything that seems unsafe.”
Wednesday 3 July 2019:
Bill Kelly, route director, Network Rail Wales, said: “We are shocked and distressed to confirm that two members of our team lost their lives today in an accident involving a train. We do not know the details behind this dreadful accident and we are fully cooperating with the British Transport Police and Rail Accident Investigation Branch. Our thoughts are with the families of our colleagues and our members of staff who will be affected by this tragic loss, and we will provide all the support we can.”
Posted by Electric train at 10:38, 5th July 2019
Hmm.  As an Administrator on this forum, I'm going to step in here.
The early reference to the wearing of ear defenders by the two sadly deceased rail track workers was unfortunate, and has led to some speculation here, and elsewhere.
The Rail Accident Investigation Branch immediately sent three of their inspectors to South Wales to investigate this 'serious incident'.  To me, that means there is probably much more to this very sad event than we yet know.
May I therefore request that there be no further speculation regarding this incident, until we see the conclusions of the official RAIB investigation.
Our thoughts and commiserations are with the family and friends of the deceased.
Chris, I do not wish to add to the speculation to whether they were or wearing not wearing ear defenders.
I wish to clarify however there are certain activities undertaken by track workers that necessitate the wearing of PPE that may impede their ability to hear or see the approach of trains, there are well developed working practices in these circumstance.
As a working rail professional with over 40 years of experience and who still often finds himself working on the track this incident is very sobering and has deeply touched all college's
Posted by Chris from Nailsea at 21:30, 4th July 2019
Thank you for posting that very constructive and detailed update, Hafren.
Posted by Hafren at 21:16, 4th July 2019
Some general thoughts on the day (without going into the incident itself).
Vibe from passengers throughout, and reflected in news reports, is that GWR et al did things right. Train crew and later a GWR manager and BTP officer made frequent announcements and regularly passed through checking on passengers and ensuring there was no confusion. Some people were clearly off to special events etc (as expected on a mid-morning intercity journey) but accepted the situation. (Apart from one who had a flight to catch!) Being directly in the situation of course helps people to feel it's not just another delay, but there was a definite human touch which left people with a positive view of 'the railway' despite the huge delay. Passengers were told to claim full refund - I wonder if that includes season tickets which IIRC aren't routinely covered by GWR Delay Repay yet. However, although usually I'm claiming for a delay as soon as the journey's over, as it is part of the operator's contractual responsibility to offer compensation, I'm not entirely comfortable with claiming in these circumstances.
As reported here many times, information provision during more usual forms of disruption is variable, and quite frankly PA announcements sometimes aren't enough. Going through the train makes all the difference. Dodgy PA, outside noise, passengers talking, perhaps someone hard of hearing can all mean messages don't get through - there have been times when I've only just made out announcements about short platforms, terminating short etc because I've been anticipating them and pick out enough words to know what's being said. On this occasion there was no doubt that passengers felt as informed as they could be in a naturally confusing situation.
A huge effort from staff who were working in nasty circumstances (and would have seen a lot more than the passengers) but made clear that passenger welfare was a priority.
Journeycheck not entirely helpful e.g. confirming how many buses were booked but not really confirming the service pattern.
The evening was a bit weaker. Cardiff Central displays showed nothing useful apart from cancellations and short workings. Given that entire screens are taken up with 'special' notices about unattended luggage etc, there's plenty of room for a summary like "Passengers for Swansea and West Wales change at Bridgend for coaches". I was basically left wondering if I should go to platform and wait for an announcement, or to the replacement bus pickup point. Therefore gateline staff are left to answer this - fine at 6.30pm but they would have been bombarded earlier. Passengers from London trains also didn't seem to know if they should go to the back for buses or take local connection to Bridgend.
On arrival at Bridgend, no staff immediately visible, and a multitude of coaches - so it was a case of picking one and asking the driver. One non-stop to Swansea and another for intermediate stations (not sure how Swanline was covered). Also one to (I think) Llanelli and Carmarthen to give West Wales passengers a head start. I think the this was because I was in a flight of 3 trains, and staff only seemed to direct passengers when the next one arrived. (Maesteg stopper, then a 6 car non-stop extra, which in reality would have been stopping behind the stopper, then the GWR Carmarthen which ran as far as Bridgend.) Passengers for the west had no idea there was a separate bus for them and naturally assumed they had to join the Swansea bus, and then had to move. It's understandable that staff availability would have been limited by then. Perhaps an information board could have been put up by that point. As it turns out, those would have been the last trains affected by the blockade.
Some from the first of the 3 trains were a bit annoyed when told the bus would wait for the next trains - perhaps they didn't realise they were literally minutes apart! They'd probably have been happier not being told and wouldn't have noticed the shortish wait! People don't like to think about the big picture sometimes...!
First news reports came from passengers and highlights how much speculation goes into early reports. Rather publish quickly and be first than wait for things to be corroborated. For example I suspect the idea that 3 were hit came from a natural interpretation of the plural.
The significance of having crew on both sets in a 10 car was made very clear. Passenger actions could have been a lot less calm and manageable had they not felt such a staff presence. I wonder how it would have been on a DOO train - in fact the news not so long ago of a Networker in South London tells us it could have been much more chaotic. I suppose DOO routes are often suburban and therefore backup shouldn't be far off, but in the meantime the driver is alone, and is often the person most affected by events. On the semi-DOO type routes that have 'commercial' grade staff I wonder if they could reassure passengers with the authority that someone of 'Guard' grade has, as someone who directly deals with train safety as the bread and butter of their role. Being a 2x5 formation also meant evacuation was effectively in two stages.
Very different from the more usual fatalities, in some of the specifics and in the level of response. Naturally there was more to investigate, given that this was a 'workplace' incident rather than someone who shouldn't really have been there.
I was impressed to see a full service running out of Swansea this morning. Historically it's more or less guaranteed after disruption that the 7.59 is cancelled or (post-HST) short-formed. It looks like only the first two of the trains that end the day at Swansea ended up being blocked, and it looks like at least one ran empty to Swansea when the line reopened. (Not sure if any Cheltenhams still run empty to/from Swansea overnight in these IET days which would have contributed to the balance.)
Posted by grahame at 16:26, 4th July 2019
The BBC has named the men who died on the railway near Margam yesterday and has published a tribute to them.
Tributes have been paid to the two railway workers who died after being hit by a train on Wednesday.
Gareth Delbridge, 64, from Kenfig Hill and Michael "Spike" Lewis, 58, from North Cornelly, were hit by the Swansea to Paddington train near Margam.
Posted by grahame at 14:21, 4th July 2019
From Gov.uk
Fatal accident at Margam
Investigation into a fatal accident at Margam, near Port Talbot, South Wales, 3 July 2019.
At around 09:52 hrs on Wednesday 3 July 2019, two track workers were struck by a passenger train and fatally injured at Margam. A third track worker, who was very close to being struck, was treated for shock.
We will provide further details of what happened, and of our investigation, in the coming weeks.
Updated to me because
You’re getting this email because you subscribed to immediate updates to ‘Rail Accident Investigation Branch’ on GOV.​UK.
and I will of course follow up with anything further.
Posted by Chris from Nailsea at 23:56, 3rd July 2019
Posted by REVUpminster at 23:06, 3rd July 2019
Should not be working a job requiring ear defenders. How would they hear any warning from lookouts? When I worked on the underground we were not allowed to wear coats with hoods in case your hearing was impaired if tempted by the weather to use the hood.
Posted by jamestheredengine at 22:42, 3rd July 2019
Lines have re-opened so looks like the last few services of the day will run through to their destinations.
There goes my evil plan to work from home tomorrow! I'm expecting that it'll be one of those not enough trains in Swansea mornings with lots of cancellations, but they really have done a brilliant job to get the railway working again so quickly.
Posted by bobm at 22:34, 3rd July 2019
Terrible day for the railway and it’s family of workers.
If I may say so. I think that sums up the feeling of many tonight.
Posted by Incider at 22:05, 3rd July 2019
I was saddened to see the pixilated drone picture of the accident site and the premature BTP comments about ear-defenders. At this stage information should be for HMRI and the BTP families' liason officers.
Without speculating further, it appears that the IET stopped in 6 car lengths - remarkable presence of mind by the shocked driver.
Ear-defenders may prompt reference to the Methley Junction accident of 1987 IIRR.
Two good men lost.
OTC
 I have dealt with too many suicide aftermaths to have much sympathy for those that choose to end it that way, but to go to work and not come home, because of an accident, which will undoubtedly have been caused by an error or mistake on someone’s part, is truly tragic and will affect many people for a long time.
Regarding the stopping in 6 car lengths, that would be remarkable given the speed the train was doing when the driver put the brake into emergency.
Posted by broadgage at 21:39, 3rd July 2019
Moving on from the tragic accident itself and considering the aftermath, TPTB are in my view to be commended and thanked for re-opening the line on the same day.
After some previous incidents, I have felt that line closures were unduly prolonged.
And yes I know that it was tragic, but closing the line for three days does not make it any less tragic than closing for part of one day, full marks for opening tonight.
Investigations will be detailed, as should be after lives have been lost, but such investigations do not require a prolonged line closure.
Posted by onthecushions at 21:33, 3rd July 2019
Two good men lost.
OTC
Posted by bobm at 21:06, 3rd July 2019
Most of the messages attributed the problems to “a person hit by a train” - but I did see one public message describing it as “a serious incident”
Posted by JayMac at 21:03, 3rd July 2019
Not everyone had heard or read the news by mid afternoon. I overheard someone at Paddington saying, "another selfish suicide" after a PA announcement saying a Swansea service was terminating at Cardiff "due to a person hit by a train."
I put them right and got a rather insincere, "Oh, thanks."
Posted by bobm at 20:38, 3rd July 2019
Posted by grahame at 19:18, 3rd July 2019
Noting the various thoughts and speculation. The BTP and RAIB are deeply into their work; as GWR's statement says "they seek to understand the circumstances which led to this tragic accident" and there is significance in those words - confirming it as a tragic accident.
The headline speculations we've seen are just some elements of what the specialists are looking into, and I look forward to the outcomes being shared in due course so that this tragic accident is never repeated.    In the meantime, thoughts with family and friends of those who were fatally injured, and with the very wide rail community who have been effected. That's  from 'seismic shock' level but spreading out afar too.
Posted by Bob_Blakey at 19:00, 3rd July 2019
LBC also reporting  the 'Ear Defenders' statement but without the obvious qualification that in such a scenario lookouts would (?should) have been posted and therefore, I suspect, giving Joe Public a rather distorted impression of this very sad incident.
When I first heard this news I am afraid that I was not as surprised as perhaps I should have been given that recent RAIB bulletins have contained a number of 'near miss' reports.
Posted by martyjon at 18:15, 3rd July 2019
Condolences to all concerned from me.
BBC R4 news at 18.00 carried a verbal statement from a BTP spokesperson that the two fatalities were wearing ear defenders at the time of the incident.
Posted by jamestheredengine at 18:10, 3rd July 2019
Ouch. Poor sods. Think I'm going to try heading up to Merthyr later and getting the last X75 of the day down the Vale of Neath, as I imagine it'll not be fun trying to head directly west from Cardiff when they find some rail replacement buses.
GWR Journey Check says there are 2 x double buses operating between Cardiff and Swansea.    TFW have sourced buses also.
I needed to head north from Cathays just after 3 for my rather pleasant attempt to emulate the Vale of Neath Railway to work; but good to know that they finally found some buses to fight their way through Cardiff traffic.
Posted by bobm at 17:45, 3rd July 2019
Statement from GWR
Everyone at GWR is incredibly saddened to learn that two railway colleagues lost their lives this morning, when they were struck by the 0929 service from Swansea to London Paddington.
We have offered our full assistance to the British Transport Police, the Rail Accident Investigation Branch, and Network Rail as they seek to understand the circumstances which led to this tragic accident.
We would like to take the time to thank members of the railway community and emergency services who were involved in looking after our customers and colleagues on the train following the incident, and in getting them safely onto alternative transport.
Our deepest condolences and thoughts at this incredibly difficult time are with the families, friends and colleagues of those who lost their lives.”
Posted by a-driver at 17:42, 3rd July 2019
Speculation elsewhere suggests that the signalman didn't know they were there.
AFAIK they don’t always need to.
Still, desperately sad incident.  I find it absolutely disgusting when the likes of Sky publish pictures from the scene with an area blurred out. Where’s the dignity and respect for those men and all concerned with the incident?
Posted by TaplowGreen at 17:15, 3rd July 2019
Posted by grahame at 17:02, 3rd July 2019
Many online sources covering the story.  The Wales Online link is being updated as things become clearer, and with reactions.
https://www.walesonline.co.uk/news/wales-news/train-port-talbot-bridgend-gwr-16523315
https://metro.co.uk/2019/07/03/two-rail-workers-dead-hit-train-10107789/
Posted by phile at 14:45, 3rd July 2019
Posted by broadgage at 14:20, 3rd July 2019
Tragic ,my condolences to all involved especially the driver.
"liked" not of course because I like the news, but because I agree with the sentiments expressed re sympathy with all involved, and with the driver in particular.
Posted by grahame at 13:54, 3rd July 2019
BTP Statement - http://media.btp.police.uk/r/16549/statement__incident_on_the_railway_near_port_talb
Statement: Incident on the railway near Port Talbot - Wales
Update at 11.50am
Shortly before 10am today (03/07), officers from British Transport Police were called to the railway close to Port Talbot in South Wales, following a report of a train striking persons on the tracks.
Paramedics from the Welsh Ambulance Service are also on scene, very sadly two persons have been pronounced dead at the scene.
Media reports suggest that three persons were struck by a train. Our enquiries have only identified two people who were struck. A third person was treated for shock at the scene, they were not injured.
Superintendent Andy Morgan from British Transport Police, said: “We are making a number of urgent enquiries to understand exactly what happened in the moments leading to this fatal collision.
“Very sadly two people have died and my officers are now working to identify them and ensure that their families are supported at this incredibly difficult time.”
The Rail Accident Investigation Branch have been notified.
Posted by Western Pathfinder at 13:24, 3rd July 2019
Posted by jamestheredengine at 12:41, 3rd July 2019
Posted by broadgage at 12:10, 3rd July 2019
Here is a later report that is more accurate and in more detail.
Includes a picture of the scene, which I appreciate that some might consider inappropriate, but as it is from a reputable and publicly available news site I see no harm in posting.
https://www.bbc.co.uk/news/uk-wales-48854010
Posted by broadgage at 11:20, 3rd July 2019
Indeed, very sad.
The earlier report to which I referred made no reference to any loss of life, but yes, later reports state two fatalities.
I am sure that the bereaved and injured are in our thoughts.
Posted by Hafren at 11:18, 3rd July 2019
On the affected train. Emergency services advised they won't be handing over for at least 2 hours. Crew being very visible and informative despite being clearly a bit shaken.
Posted by BBM at 11:11, 3rd July 2019
Just seen the following tweet from PA media: https://twitter.com/PA/status/1146359427529936902
#Breaking Two people have died after being struck by a train on railway tracks near Port Talbot in South Wales, British Transport Police say
(My thoughts to everyone involved with this very tragic incident.)
Posted by broadgage at 11:08, 3rd July 2019
Early reports state that three rail workers struck. Please be aware that this is "breaking news" and liable to be revised as more detailed reports become available.
