| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 10:51, 15th June 2026 | ![]() ![]() ![]() |
| Re: Class 175s to Great Western Railway (GWR) Posted by GBM at 09:35, 15th June 2026 | ![]() ![]() ![]() |
https://www.youtube.com/watch?v=S0YO9ZzSpZA
First 175 into Paignton
Video link says it is private, so can't view it!First 175 into Paignton
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 08:54, 15th June 2026 | ![]() ![]() ![]() |
First 175 into Paignton.
I did not use hyperlink. May work now.
| Re: Class 175s to Great Western Railway (GWR) Posted by JohnM at 08:19, 1st June 2026 | ![]() ![]() ![]() |
Yeah the 175s avoid the cooked sewage problem, but there is a stale urine smell on some units, probably linked to their storage.
Don't know if this ties in with your observations (and it might just be making stuff up, wouldn't be the first time...):My previous breakdown missed a specific flaw that is very real for the Class 175s.
They absolutely do have their own distinct effluent tank smell issue, and it comes down to a different design vulnerability than the Voyagers.
On the Class 175s, the problem is caused by the underfloor air conditioning condenser units. Unlike the Voyagers (which sucked air in from under the chassis), the 175s have their fresh air intakes on the roof. However, their air conditioning condensers—which handle the heat exchange process—are located on the underframe.
Because of how Alstom tightly packed the underframe components, these condenser units sit directly adjacent to the toilet retention tank breather vents. When the train is in motion, the aerodynamic pull around the underframe creates a pressure differential. The air con condensers end up pulling the vented air directly from the effluent tanks and circulating it through the cooling systems. The result is a highly localized, distinct sewage odor that regularly sweeps through the passenger saloons, especially when the toilets are heavily used or the tanks are near capacity.
It turns out both fleets suffer from toilet odor issues, just via entirely different engineering headaches—Bombardier cooked the sewage from the exhaust, while Alstom's layout caused the cooling system to accidentally draft from the tank vents.
| Re: Class 175s to Great Western Railway (GWR) Posted by plymothian at 14:56, 30th May 2026 | ![]() ![]() ![]() |
| Re: Class 175s to Great Western Railway (GWR) Posted by JohnM at 15:58, 29th May 2026 | ![]() ![]() ![]() |
175s use a similar effluent system to Voyagers; the waste is stored in an upright tank behind the toilet rather than slung below and some stink as bad.
AI's view...The Voyager "Boiled Sewage" Flaw
The severe odor issues on the Voyagers came down to an incredibly unfortunate layout of the underfloor components, combined with a bad choice of location for the climate control system:
Why the Class 175 Avoided This
While the Class 175s were designed and built at roughly the same time (late 1990s to early 2000s), they were manufactured by Alstom, whereas the Voyagers were built by Bombardier.
Alstom's packaging layout underneath the Class 175 frames was entirely different. The effluent tanks were isolated cleanly from the engine exhausts, and the air conditioning pods were mounted on the roof rather than drawing air from beneath the chassis. Because of this, the 175s generally smell like a normal train inside—their underfloor issues were strictly mechanical and flammable, rather than olfactory.
- The Heating Problem: On the Voyagers, some of the engine exhaust piping was routed directly alongside or underneath the Controlled Emission Toilet (CET) retention tanks. In the summer—or when the engines were working hard—the extreme heat from the exhausts effectively "cooked" the raw sewage inside the tanks, causing intense gas build-up and a foul stench.
- The Intake Problem: To make matters worse, the fresh-air intake vents for the passenger saloon’s air conditioning system were located under the chassis, right in the vicinity of those heated effluent tanks.
- The Result: The air conditioning system regularly sucked in the escaping sewage fumes and actively pumped a concentrated aroma of warm, stale urine and sulfur directly into the passenger cabins, particularly around the vestibules.
| Re: Class 175s to Great Western Railway (GWR) Posted by TaplowGreen at 12:52, 29th May 2026 | ![]() ![]() ![]() |
So whilst you can't polish a turd, you can store them on board the train.
| Re: Class 175s to Great Western Railway (GWR) Posted by plymothian at 12:50, 29th May 2026 | ![]() ![]() ![]() |
| Re: Class 175s to Great Western Railway (GWR) Posted by trainbuff at 23:24, 28th May 2026 | ![]() ![]() ![]() |
You can't polish a turd: Voyagers are crap.
That's only my personal opinion, based on experience, by the way: not an official view from the Coffee Shop forum. CfN.
:- But you can roll it in glitter!
Edit note: Quote mark correction, for clarity. CfN.
| Re: Class 175s to Great Western Railway (GWR) Posted by trainbuff at 23:23, 28th May 2026 | ![]() ![]() ![]() |
20 mins later boarded my first refurbed XC Voyager... reasonable enough but they still seem not to have sorted out that unpleasant air in the carriages containing the WCs.
They are what they are
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 20:14, 28th May 2026 | ![]() ![]() ![]() |
175116 to Laira today. Delayed for 70 mins near Acton Wells but arrived 8 minutes early at Laira
Ely :3: 175005/008, 175104 (175008 is in two halves)
Wolverton :9 : 175004, 175102/103/105/106/107/108/109/110
Laira : 14: 175002/007/009, 175114 ex Ely; 175001/003/006/011, 175101/111/112/113/115/116 ex Wolverton
Long Rock : 1 : 175010 ex Ely
as of 28 May 2026
| Re: Class 175s to Great Western Railway (GWR) Posted by Chris from Nailsea at 00:43, 20th May 2026 | ![]() ![]() ![]() |
| Re: Class 175s to Great Western Railway (GWR) Posted by johnneyw at 23:36, 19th May 2026 | ![]() ![]() ![]() |
Saw my first 175 in GWR territory today at Totnes station just as I arrived at about 13.30. It was Exeter bound and running about 8 minutes late. 20 mins later boarded my first refurbed XC Voyager... reasonable enough but they still seem not to have sorted out that unpleasant air in the carriages containing the WCs.
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 18:23, 15th May 2026 | ![]() ![]() ![]() |
175113 at the third attempt to Laira today.
Wolverton :10 : 175004, 175102/103/105/106/107/108/109/110/116
Laira : 13: 175002/007/009, 175114 ex Ely; 175001/003/006/011, 175101/111/112/113/115 ex Wolverton
as of 15 May 2026
| Re: Class 175s to Great Western Railway (GWR) Posted by IndustryInsider at 10:57, 1st May 2026 | ![]() ![]() ![]() |
Five daily diagrams on Weekdays and Saturdays then.
Getting there...
| Re: Class 175s to Great Western Railway (GWR) Posted by plymothian at 09:55, 1st May 2026 | ![]() ![]() ![]() |
175 services from 17 May
Sundays
2C06 0845 Plymouth to Penzance
2E13 1149 Penzance to Exeter St Davids
2C32 1527 Exeter St Davids to Penzance
2P28 1915 Penzance to Plymouth
2C20 1032 Plymouth to Penzance
2E17 1349 Penzance to Exeter St Davids
2P36 1708 Exeter St Davids to Plymouth
2N08 1012 Par to Newquay
2N09 1118 Newquay to Par
2N16 1438 Par to Newquay
2N19 1552 Newquay to Par
2N22 1715 Par to Newquay
2N23 1816 Newquay to Par
2N26 1935 Par to Newquay
2N27 2029 Newquay to Par
Monday-Friday
2C00 0533 Plymouth to Penzance
2E06 0743 Penzance to Exeter St Davids
2C20 1127 Exeter St Davids to Penzance
2P20 1515 Penzance to Plymouth
2P05 0808 Liskeard to Plymouth
2C11 1014 Plymouth to Penzance
2P16 1315 Penzance to Plymouth
2C26 1339 Plymouth to Penzance
2P21 1552 Penzance to Plymouth
2C05 0655 Exeter St Davids to Penzance
2E11 1050 Penzance to Exeter St Davids
2C32 1528 Exeter St Davids to Penzance
2E28 1915 Penzance to Exeter St Davids
2E04 0849 Plymouth to Exeter St Davids
2C18 1027 Exeter St Davids to Penzance
2P17 1350 Penzance to Plymouth
2C31 1556 Plymouth to Penzance
2P27 1850 Penzance to Plymouth
2N02 0707 Par to Newquay
2N03 0822 Newquay to Par
2N06 0916 Par to Newquay
2N07 1028 Newquay to Par
2N10 1121 Par to Newquay
2N11 1217 Newquay to Par
2N14 1316 Par to Newquay
2N15 1428 Newquay to Par
2N18 1515 Par to Newquay
2N19 1618 Newquay to Par
2N22 1717 Par to Newquay
2N23 1822 Newquay to Par
2N26 1916 Par to Newquay
2N27 2028 Newquay to Par
Saturdays
2C05 0515 Plymouth to Penzance
2P10 0740 Penzance to Plymouth
2C49 1242 Plymouth to Penzance
2P24 1515 Penzance to Plymouth
2C42 0800 Exeter St Davids to Penzance
2P18 1150 Penzance to Plymouth
2C53 1443 Plymouth to Penzance
2P30 1715 Penzance to Plymouth
2E12 0850 Penzance to Exeter St Davids
2C51 1219 Exeter St Davids to Penzance
2P26 1550 Penzance to Plymouth
2C40 0807 Plymouth to Penzance
2E16 1039 Penzance to Exeter St Davids
2P56 1422 Exeter St Davids to Plymouth
2C57 1638 Plymouth to Penzance
2P95 1930 Penzance to Plymouth
2N02 0703 Par to Newquay
2N03 0812 Newquay to Par
2N06 0905 Par to Newquay
2N07 1010 Newquay to Par
2N10 1130 Par to Newquay
2N11 1231 Newquay to Par
2N14 1338 Par to Newquay
2N15 1447 Newquay to Par
2N20 1622 Par to Newquay
2N21 1740 Newquay to Par
2N24 1834 Par to Newquay
2N25 1938 Newquay to Par
2N28 2032 Par to Newquay
2P97 2124 Newquay to Plymouth
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 10:00, 16th April 2026 | ![]() ![]() ![]() |
175109 dragged from Ely today; 175115 to Laira last Monday/Tuesday after being stopped overnight at Westbury to fix a fault.
Wolverton :11 : 175004, 175102/103/105/106/107/108/109/110/113/116
Laira : 12: 175002/007/009, 175114 ex Ely; 175001/003/006/011, 175101/111/112/115 ex Wolverton
as of 16 April 2026
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 11:31, 30th March 2026 | ![]() ![]() ![]() |
The first 3 car in passenger service. Not one that has been through Wolverton.
https://www.realtimetrains.co.uk/service/gb-nr:P22967/2026-03-30/detailed#allox_id=0
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 13:46, 27th March 2026 | ![]() ![]() ![]() |
175103 and 175105 dragged from Ely today; the ones I presume should have come last Friday
Ely : 4: 175005/008, 175104/109 (175008 is in two halves)
Wolverton :11 : 175004, 175102/103/105/106/107/108/110/113/115/116
Laira : 11: 175002/007/009, 175114 ex Ely; 175001/003/006/011, 175101/111/112 ex Wolverton
as of 27 March 2026
https://www.youtube.com/watch?v=SXoiW3fW4yc
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 19:18, 20th March 2026 | ![]() ![]() ![]() |
Ely Mif 6: 175005/008, 175103/104/105/109 (175008 is in two halves)
Wolverton : 9 : 175004, 175102/106/107/108/110/113/115/116
Laira : 11: 175002/007/009, 175114; 175001/003/006/011, 175101/111/112 are refurbished
I think this is it as of 20 March 2026
| Re: Class 175s to Great Western Railway (GWR) Posted by a-driver at 11:08, 20th March 2026 | ![]() ![]() ![]() |
175111 arrived at Wolverton 9th October, so has taken 5.5 months.
If another unit arriving today from Ely takes the same duration, will reappear in September
And these would have been considered to be in the best condition!
The move from Ely has been cancelled though.
| Re: Class 175s to Great Western Railway (GWR) Posted by John D at 09:18, 20th March 2026 | ![]() ![]() ![]() |
Should be 175111 with another two 3-cars pencilled in for April.
There’s also a move in the system for Ely to Wolverton so potentially another 175 to attempt to get working!
| Re: Class 175s to Great Western Railway (GWR) Posted by a-driver at 06:32, 20th March 2026 | ![]() ![]() ![]() |
| Re: Class 175s to Great Western Railway (GWR) Posted by John D at 09:17, 19th March 2026 | ![]() ![]() ![]() |
There is a path for another class delivery from Wolverton tomorrow (Friday), 4 weeks after last one.
https://www.realtimetrains.co.uk/service/gb-nr:K63327/2026-03-20/detailed
I think 6 units are still stored at Ely, and haven't even got to Wolverton yet, and Wolverton often seems to have them about 4 months
| Re: Class 175s to Great Western Railway (GWR) Posted by Bob_Blakey at 14:16, 17th March 2026 | ![]() ![]() ![]() |
Out on the bike this morning passed 175002, immediately north of Starcross, exhibiting an impressive turn of speed. As above running to time on the 2C20 EXD > PNZ.
| Re: Class 175s to Great Western Railway (GWR) Posted by a-driver at 05:27, 16th March 2026 | ![]() ![]() ![]() |
There is intention to add another 175 in to passenger service from 16 March to run Plymouth - Penzance - Exeter St Davids - Penzance - Plymouth as there are now 6 serviceable sets that can run in passenger service. However 175006 broke down again today with a bogie fault and 5Z13 training run was cancelled as a result.
ETA, the diagram will be
2C00 05.33 Plymouth - Penzance
2E06 07.45 Penzance - Exeter St Davids
2C20 11.27 Exeter St Davids - Penzance
2P20 1515 Penzance - Plymouth
175002 on it this morning.
| Re: Class 175s to Great Western Railway (GWR) Posted by plymothian at 09:52, 10th March 2026 | ![]() ![]() ![]() |
| Re: Class 175s to Great Western Railway (GWR) Posted by Pb_devon at 08:25, 4th March 2026 | ![]() ![]() ![]() |
Long article in the latest Rail magazine 1056 of an interview with GWR Programme Director Barry Milsom about the 175 delays.
In summary, outside storage for years has caused damage requiring repair, plus other issues.
| Re: Class 175s to Great Western Railway (GWR) Posted by bobm at 15:48, 27th February 2026 | ![]() ![]() ![]() |
Same with the 10:56 from Chippenham to London Paddington this morning. Journeycheck suggested it was a 5 car rather than a 9. I was in coach H.
| Re: Class 175s to Great Western Railway (GWR) Posted by IndustryInsider at 12:07, 27th February 2026 | ![]() ![]() ![]() |
07:12 Plymouth to Penzance due 09:19
09:50 Penzance to Plymouth due 11:47
12:18 Plymouth to Penzance due 14:14
14:50 Penzance to Plymouth due 16:45
17:00 Plymouth to Liskeard due 17:37
All cancelled due to "more trains than usual needing repairs at the same time" - more problems with these "new" trains?
Booked for a 4-car Class 150.
Another spin of the famous JourneyCheck 'AM reality is PM fantasy' wheel - with the last three all now reinstated...using a 2-car 150.
| Re: Class 175s to Great Western Railway (GWR) Posted by grahame at 08:57, 27th February 2026 | ![]() ![]() ![]() |
With Barnstaple, Okehampton and Exmouth all running again ... and I suspect this week that in these days of specialisation there are trains in Plymouth that need to get to Exeter for repair but can't because the line from Totnes to Plymouth is closed for engineering works, and the old alternative from Bere Alston to Okehampton has been closed for much longer.
| Re: Class 175s to Great Western Railway (GWR) Posted by GBM at 08:30, 27th February 2026 | ![]() ![]() ![]() |
RTT not showing a 175, but 150'type.09:50 Penzance to Plymouth due 11:47
| Re: Class 175s to Great Western Railway (GWR) Posted by TaplowGreen at 08:00, 27th February 2026 | ![]() ![]() ![]() |
| Re: Class 175s to Great Western Railway (GWR) Posted by plymothian at 08:37, 25th February 2026 | ![]() ![]() ![]() |
There are issues coupling more than 2 units together, therefore VSTP diagrams are splitting the moves to/from Laira into 2 separate ones, 5Z10 and 5Z11 this morning.
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 07:37, 25th February 2026 | ![]() ![]() ![]() |
In other news 175002 visited Newquay yesterday.
And it's due to do so again today. 175001+175007 again working in tandem as well.It's also reported the three units came out of Laira together although not supported by Realtime trains and were meant to go back together this evening although it did not seem to happen yesterday when both trains ended alongside each other in platform 7 and 8.
| Re: Class 175s to Great Western Railway (GWR) Posted by plymothian at 07:27, 25th February 2026 | ![]() ![]() ![]() |
| Re: Class 175s to Great Western Railway (GWR) Posted by a-driver at 12:45, 23rd February 2026 | ![]() ![]() ![]() |
5Z13 shows 175011 allocated from Par, and RTT has reports of it from Par to (so far) St Germans. How it got to Par, and why it's not showing on Traksy, is another matter.
It has just popped up at Wivelscombe on Traksy. But how it's already got past Saltash on camera, I have no idea.
Just to tidy up, and correct my mistakes:
- REVUpminster's webcam of 175011picture was on 5Z33, 1100 Plymouth-Par, coming off the bridge at 11:13.
- so that answers my question about how it got to Par
- it was also seen in the Saltash webcam on 5Z13 at 12:51, on the way back to Plymouth (arr. 1259).
Which leaves outstanding the question of when it first got back from its enforced holiday at Liskeard to Plymouth. If I had to guess (which I don't, obviously) I'd say it was coupled to 175007, but not mentioned in despatches.
An interesting signal problem is how. On London Underground signalling; as the points cannot be guaranteed, because a train is occupying the approach section, to be locked they would have to be scotched and clipped and hand signalled into the platform or the trains moved towards Liskard past signal LD20, the points on the branch scotched and clipped then the normal signal interlocking can take effect and the trains moved onto the main line.
All fully signalled with shunt signals. No need for anything to be clipped and scotched.
On the undergound as some who might have to do it we were taught to say scotched and clipped as the scotch goes in first in case the points move as you try to put the clip on. The trainer would also say don't put the clip on over the rail. It's been done!
I'm not quite sure I get you!
if you go from Liskeard platform on the mainline towards the branch, you'd be signalled by a shunt signal - LD17. Speed is 5mph. Once the train drops in clear of LD20 on the branch, LD17 can be returned to danger and the points on the mainline can be returned to normal - mainline route.
Coming off the branch, the points will be reversed and LD20 can then be cleared in to the platform as far as LD11 which is Penzance end of the platform.
If you were to use another unit to rescue the failed sets, you could still clear LD17 from the platform but because you will not drop in clear of LD20 you would need authorisation from the signaller to change direction and return to the platform. The points would remain locked in position.
The only time you wouldn't potentially need to clip and scotch the points is if the move was a passenger carrying move.
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 09:19, 23rd February 2026 | ![]() ![]() ![]() |
| Re: Class 175s to Great Western Railway (GWR) Posted by a-driver at 16:29, 22nd February 2026 | ![]() ![]() ![]() |
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 17:10, 20th February 2026 | ![]() ![]() ![]() |
Wolverton : 10 : 175004, 175102/106/107/108/110/111/113/115/116
Laira : 10: 175002/007/009, 175114; 175001/003/006/011, 175101/112 are refurbished
175002 and 175114 have been at Laira over a year.
175112 arrived at Laira from Wolverton today about 87 minutes early.
Updated 20 February 2026. I have had to correct a previous post but I think this is right.
175001+175007 are doing the Plymouth-Penzance-Plymouth run today together.
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 09:19, 14th February 2026 | ![]() ![]() ![]() |
| Re: Class 175s to Great Western Railway (GWR) Posted by stuving at 22:26, 13th February 2026 | ![]() ![]() ![]() |
| Re: Class 175s to Great Western Railway (GWR) Posted by Richard Fairhurst at 16:25, 13th February 2026 | ![]() ![]() ![]() |
| Re: Class 175s to Great Western Railway (GWR) Posted by TaplowGreen at 15:30, 13th February 2026 | ![]() ![]() ![]() |
Looks like the 175s are coming to Laira plus the two simulators. The 158s at Exeter to go to Bristol.
GWR to get all the class 175s. It be great to see them in service they are good units.
This hasn't aged very well.
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 14:58, 13th February 2026 | ![]() ![]() ![]() |
175011 is back at Laira somehow??
It is out an about and due to do the 1340 Plymouth - Penzance. I did a snip of the train at Saltash. It may not appear here.
The 1340 was cancelled and only 175001 seems to be running round. GWR service gone to pot.
| Re: Class 175s to Great Western Railway (GWR) Posted by stuving at 12:46, 13th February 2026 | ![]() ![]() ![]() |
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 11:45, 13th February 2026 | ![]() ![]() ![]() |
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 18:21, 12th February 2026 | ![]() ![]() ![]() |
After all that, what an anti-climax!
https://www.realtimetrains.co.uk/service/gb-nr:V75372/2026-02-12/detailed
Al sorted out in situ (by someone who knows about these things, apparently) and then scoot back to Plymouth in half an hour. Its buddy 011 was meant to follow an hour later (5Z15), but for some reason ... now what's happened there?
011 due to leave Liskeard as 5Z15 at 1945 using an existing path showing cancelled at the moment. It wasn't going to be sent via Penzance.https://www.realtimetrains.co.uk/service/gb-nr:V75372/2026-02-12/detailed
https://www.realtimetrains.co.uk/service/gb-nr:V75376/2026-02-12/detailed
| Re: Class 175s to Great Western Railway (GWR) Posted by stuving at 17:56, 12th February 2026 | ![]() ![]() ![]() |
All sorted out in situ (by someone who knows about these things, apparently) and then scoot back to Plymouth in half an hour. Its buddy 011 was meant to follow an hour later (5Z15), but for some reason ... now what's happened there?
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 19:06, 11th February 2026 | ![]() ![]() ![]() |
If they can separate the trains maybe 175011 can return faster?
This is a job for Saltash cams at 0208 if I can stay awake. Don't trust the timings.
175009 failed today out on the public run.
Recovering the trains was cancelled. Luckily I forgot and didn't stay up.
| Re: Class 175s to Great Western Railway (GWR) Posted by stuving at 11:41, 11th February 2026 | ![]() ![]() ![]() |
ANother forum is saying 5mph.... those timings certainly look painful!
I assume the '33' is some code in the timing load – looks like RTT can't match it against its list of timing load tokens, so it's misreading as a speed, perhaps. Similar to when the IET timings first appeared - IIRC the code for Class 800 DMU didn't make sense to RTT (or to whatever source it uses) so it parsed it as diesel loco with 800t trailing load.
Pathing and planning speed are two separate parameters. Here, for example, is what RTT has for a goods working (not VSTP) which ran yesterday -
Pathed as Diesel locomotive, trailing load 600 tonnes
Planned for 60mph max
For most passenger stock at the moment the pathing information does not include a speed, that's implied by the class.
This is the text for the planned recovery of the 175s tonight -
Pathed as Class 150/153/155/156 DMU
Planned for 33mph max
Obviously the scheduled timings were not derived from either the maximum speed for planning purposes or the pathing category!
That "33 mph" is common on RTT for VSTP (labelled VST) movements, for example this for a light loco running Bescot to Arpley yesterday -
The point, as I understand it, is that VSTPs are different. Everything else goes through standard processing to become part of the current timetable, at least at the start of each day. Details may be altered later (becoming VAR entries), but no new entries can be inserted into the timetable. VSTP items are provided separately so that they can be added to e.g. displayed outputs at a late stage in their production. The process that formats them for the industry data feed is separate from that for the main timetable.
So yes - that speed is provided in m/s, and should converted if required in mi/hr as 75. Other apps on line get it right, e.g. Liverail, or Live Train Times. The last divides the information differently, but for tonight's sick 175 movement includes:
Train Info
Operated By GWR
Timed For 75mph
Power Type DMU
Timing Load Sprinter
Operated By GWR
Timed For 75mph
Power Type DMU
| Re: Class 175s to Great Western Railway (GWR) Posted by grahame at 10:06, 11th February 2026 | ![]() ![]() ![]() |
Watch Journeycheck tomorrow morning - "this train has been delayed because of a slower train in front of it" for early services from Penzance to Plymouth.
| Re: Class 175s to Great Western Railway (GWR) Posted by Hafren at 00:12, 11th February 2026 | ![]() ![]() ![]() |
| Re: Class 175s to Great Western Railway (GWR) Posted by stuving at 22:24, 10th February 2026 | ![]() ![]() ![]() |
Plan to remove the failed units tomorrow night.
8X75. - Maximum speed 33 m.p.h. 23:20 at Liskeard to 04:15 at Laira. On skids? Man walking in front with red flag?
That would be too fast for skates, wouldn't it? But it's actually a "feature" of RTT's reporting of VSTP services: in the data the 33 is meant to be m/s but it hasn't been converted, which would give 75 mi/hr.
| Re: Class 175s to Great Western Railway (GWR) Posted by grahame at 21:38, 10th February 2026 | ![]() ![]() ![]() |
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 20:54, 10th February 2026 | ![]() ![]() ![]() |
https://www.realtimetrains.co.uk/service/gb-nr:53806/2026-02-11/detailed
Today has been a good day with 175001+175003 in tandem on training run to Newton Abbot-Penzance-Plymouth before 175001 made up the one passenger diagram to Penzance and back.
175009 also did a couple of training runs.
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 21:39, 6th February 2026 | ![]() ![]() ![]() |
The move from Wolverton to Laira was cancelled for the second time which has been the norm.
175002 and 175011 are parked up on the Looe branch until they fix the problem.
| Re: Class 175s to Great Western Railway (GWR) Posted by JayMac at 21:39, 5th February 2026 | ![]() ![]() ![]() |
172002 had brakes locked on at Liskeard. This fault a couple days after it had door interlock issues, also at Liskeard
Today the rescue unit sent wrong road from Plymouth was coupled up to 175002 and the brake problem transferred to the new unit.
Subsequent major disruption in Cornwall.
| Re: Class 175s to Great Western Railway (GWR) Posted by a-driver at 21:08, 5th February 2026 | ![]() ![]() ![]() |
Failed 175 only recently disappeared from Traksy - not sure where the unit has gone.
Dumped in the Yard at Liskeard
| Re: Class 175s to Great Western Railway (GWR) Posted by Southernman at 20:45, 5th February 2026 | ![]() ![]() ![]() |
Failed 175 only recently disappeared from Traksy - not sure where the unit has gone. The 17.50 Penzance - Paddington is formed of 150238 (2 car). Lost 30 minutes or so en-route to Plymouth but still going on! Lost no more time to Totnes. How far will it reach before being relieved of its long distance outing? Or maybe there was a swap of trains at Plymouth?
Presumably off the Falmouth branch shuttle but good bit of initiative!
| Re: Class 175s to Great Western Railway (GWR) Posted by GBM at 15:51, 5th February 2026 | ![]() ![]() ![]() |
2C26 1340 Plymouth to Penzance (175002 to Liskeard) sat down at Liskeard and sulking.
Due to a broken down train at Liskeard disruption is expected until 16:00 05/02.
Train services between Plymouth and Penzance may be cancelled or delayed.
A train has broken down at Liskeard, blocking the line towards Penzance.
Our engineers are working with the crew on the train to find the cause of the fault. We are currently unable to run trains from Plymouth towards Penzance. This will also begin to affect services from Penzance towards Plymouth, as trains will not be in the right place.
2C27 1255 Exeter St Davids to Menheniot Signal Dm260 now sitting at said signal for an hour now.
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 20:53, 4th February 2026 | ![]() ![]() ![]() |
https://www.realtimetrains.co.uk/service/gb-nr:K61700/2026-02-06/detailed
Another go from Wolverton. Very late in the day.
| Re: Class 175s to Great Western Railway (GWR) Posted by plymothian at 19:01, 4th February 2026 | ![]() ![]() ![]() |
175007 was in public service today.
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 17:29, 30th January 2026 | ![]() ![]() ![]() |
Planned 175004 and 175110 dragged to Wolverton today but the planned move from Wolverton to Laira was cancelled.
Wolverton : 11 : 175004, 175102/106/107/108/110/111/112/113/115/116
Laira : 8: 175002/007/009, 175114; 175001/003/006/011, 175101 are refurbished.
Updated 30 January 2026
https://www.youtube.com/watch?v=xOCFBzYBXjY
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 18:50, 26th January 2026 | ![]() ![]() ![]() |
Have we got any green ones yet?
As these are a stop gap, very unlikely to be repainted and the future of regional liveries is up in the air with the possible new GBR livery.| Re: Class 175s to Great Western Railway (GWR) Posted by Noggin at 11:04, 26th January 2026 | ![]() ![]() ![]() |
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 09:14, 26th January 2026 | ![]() ![]() ![]() |
175002 un-refurbished being used on a training run then to make up passenger 1340 to Penzance. 175001 refurbished also out training.
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 16:58, 24th January 2026 | ![]() ![]() ![]() |
175101 yesterday stopping for no one at Newton Abbot. It is impressive.
https://www.youtube.com/shorts/WWT4932_b40
Passing West Drayton
https://www.youtube.com/watch?v=5X6ICpRYwlw
| Re: Class 175s to Great Western Railway (GWR) Posted by Chris from Nailsea at 22:58, 23rd January 2026 | ![]() ![]() ![]() |
Did I see a 175 at Saltash this afternoon?
That, or you may need to update your medication.
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 22:43, 23rd January 2026 | ![]() ![]() ![]() |
175001 been to Newton Abbot and Penzance175007 had a couple of runs to Lostwithel and back first then Par and back
| Re: Class 175s to Great Western Railway (GWR) Posted by Red Squirrel at 20:35, 23rd January 2026 | ![]() ![]() ![]() |
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 18:05, 23rd January 2026 | ![]() ![]() ![]() |
The timings show how good this train is. Just needs to be able to carry passengers.
Ely Mif :8: 175004/005/008, 175103/104/105/109/110 (175008 is in two halves)
Wolverton : 9 : 175102/106/107/108/111/112/113/115/116
Laira : 9: 175002/007/009, 175114; 175001/003/006/011, 175101 are refurbished.
Updated 23 January 2026
| Re: Class 175s to Great Western Railway (GWR) Posted by TonyK at 17:12, 23rd January 2026 | ![]() ![]() ![]() |
It made Tavistock Junction 94 early, but has either stopped there or delayed the announcement of its triumphal entry into Laira.
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 14:35, 23rd January 2026 | ![]() ![]() ![]() |
A 3 car 175, maybe more, has left Wolverton. Hopefully catch it at Dawlishcam at 17.38 although is often early.
Reported as 175101
If it does not stop at Taunton it will 100 minutes early. Green all the way.
| Re: Class 175s to Great Western Railway (GWR) Posted by a-driver at 13:35, 23rd January 2026 | ![]() ![]() ![]() |
Reported as 175101
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 12:09, 23rd January 2026 | ![]() ![]() ![]() |
| Re: Class 175s to Great Western Railway (GWR) Posted by John D at 12:07, 23rd January 2026 | ![]() ![]() ![]() |
Delivery of a 175 (or maybe more than one unit coupled together) is currently happening, left Wolverton few minutes early
https://www.realtimetrains.co.uk/service/gb-nr:K60250/2026-01-23/detailed
| Re: Class 175s to Great Western Railway (GWR) Posted by TonyK at 17:14, 22nd January 2026 | ![]() ![]() ![]() |
175001 (paired with 009), the only unit that can run in public traffic, was terminated on its training run at Liskeard as the windscreen spontaneously cracked in 2 places.
Liskeard and Saltash?
| Re: Class 175s to Great Western Railway (GWR) Posted by ChrisB at 16:53, 22nd January 2026 | ![]() ![]() ![]() |
Can they seriously close with just two months notice?
| Re: Class 175s to Great Western Railway (GWR) Posted by bradshaw at 10:10, 22nd January 2026 | ![]() ![]() ![]() |
Rumour on X that Papworth sidings, Ely are closing in March
https://x.com/trainlifegb/status/2014057725278212412?s=61&t=VlafMC5gF9tidw36b1Y8JQ
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 09:08, 22nd January 2026 | ![]() ![]() ![]() |
Today, 175001 refurbished and 175007 unrefurbished out on training runs with 175001 expected to take up the passenger service at 1340. These two, out of eight, trains seem to be the only trains used in public service.
| Re: Class 175s to Great Western Railway (GWR) Posted by John D at 13:40, 21st January 2026 | ![]() ![]() ![]() |
Looks like another unit (hopefully more than one unit) is scheduled from Wolverton to Laira on Friday.
Last couple of scheduled deliveries were cancelled, so will this one actually happen
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 15:59, 17th January 2026 | ![]() ![]() ![]() |
175007 out in public use today on 2C49 12.42 Plymouth - Penzance and 2P24 15.15 Penzance - Plymouth
And it's an un-refurbished unit. On another site, water from the air condition unit coming down the windows inside.| Re: Class 175s to Great Western Railway (GWR) Posted by plymothian at 13:26, 17th January 2026 | ![]() ![]() ![]() |
| Re: Class 175s to Great Western Railway (GWR) Posted by John D at 17:27, 16th January 2026 | ![]() ![]() ![]() |
Nothing from Wolverton in the past two hours. Maybe they have gone to get some clear cello tape. Perhaps the tide is in at Dawlish when the train is due?| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 13:40, 16th January 2026 | ![]() ![]() ![]() |
Nothing from Wolverton in the past two hours. Maybe they have gone to get some clear cello tape. Perhaps the tide is in at Dawlish when the train is due?| Re: Class 175s to Great Western Railway (GWR) Posted by plymothian at 10:03, 16th January 2026 | ![]() ![]() ![]() |
| Re: Class 175s to Great Western Railway (GWR) Posted by Richard Fairhurst at 07:47, 16th January 2026 | ![]() ![]() ![]() |
It does make you wonder how they were maintained towards the end of their time in Wales
I think that's reasonably well known - the maintenance contract was taken away from Alstom (who built the trains) and given to CAF (who built their replacements), and CAF were either uninterested or unknowledgeable. There was a series of Adelante-like fires in 2023.
| Re: Class 175s to Great Western Railway (GWR) Posted by Timmer at 07:36, 16th January 2026 | ![]() ![]() ![]() |
Something seriously wrong with these trains.
Even by railway standards, the entry into service of these existing trains is happening at glacial pace. It does make you wonder how they were maintained towards the end of their time in Wales and the length of time they were stored outside has played a part.| Re: Class 175s to Great Western Railway (GWR) Posted by Red Squirrel at 23:44, 15th January 2026 | ![]() ![]() ![]() |
You may well be right, but let's hope not. When the 165/6's came to Bristol they were plagued with reliability issues while the local maintenance teams got the hang of them. Now they're not too bad, given their age and unsuitability for short-stop metro-style services.
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 22:10, 15th January 2026 | ![]() ![]() ![]() |
175003 did not run but 175001 took it's place. So a second of four has still not run in public service. Something seriously wrong with these trains.
See what tomorrows delivery from Wolverton is.
https://www.realtimetrains.co.uk/service/gb-nr:K60141/2026-01-16/detailed
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 09:40, 15th January 2026 | ![]() ![]() ![]() |
Late start. Let's hope they are in condition for passenger service. Got the weekend to fix them. Yesterday 175001 ran a training run but was replaced by a 150 for the 1340 Plymouth- Penzance and back. Not one of the other three refurbished units at Laira has run in passenger service AFAIK.
It certainly feels like a slow (re)start of the class. And January and February being the slow time of year, a 2 coach 150 on train from Penzance or 2 St Ives will have adequate capacity whereas come Easter, if the weather in nice, 2x158 or an IET or an HST would have been needed.
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 09:34, 15th January 2026 | ![]() ![]() ![]() |
175003, one of the refurbished, is planned to operate the 1340 Plymouth Penzance today.
| Re: Class 175s to Great Western Railway (GWR) Posted by grahame at 08:59, 15th January 2026 | ![]() ![]() ![]() |
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 07:28, 15th January 2026 | ![]() ![]() ![]() |
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 20:36, 13th January 2026 | ![]() ![]() ![]() |
The seventeen hour drag from Ely to Long Rock took place today; reportedly 175010.
So I think this is the situation. 175001 is the only train in passenger service and that had a door failure that should have been fixable but it was taken out of service. Back working today.
Wolverton : 10 : 175101/102/106/107/108/111/112/113/115/116
Laira : 8: 175002/007/009, 175114; 175001/003/006/011 are refurbished.
Updated 13 January 2026
| Re: Class 175s to Great Western Railway (GWR) Posted by TonyK at 23:07, 12th January 2026 | ![]() ![]() ![]() |
https://www.realtimetrains.co.uk/service/gb-nr:K49768/2026-01-09/detailed
175s coming from Wolverton today, hopefully. A 150 from Wolverton to Exeter was cancelled yesterday.
But will the trains be in serviceable condition. Of the four previous refurbished units; only 175001 has been used in passenger service.
The drag from Ely to Penzance is now scheduled for next week. Is it to do the work that Wolverton should be doing?
1945hrs Train did not run today
Still in Wolverton, I think, as of CoP 12 Jamuary.
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 10:56, 9th January 2026 | ![]() ![]() ![]() |
| Re: Class 175s to Great Western Railway (GWR) Posted by REVUpminster at 15:10, 6th January 2026 | ![]() ![]() ![]() |
175001 doing it's passenger run to Penzance and back. 1340 off Plymouth. It did a training run to Penzance coupled with 175009 beforehand. 175009 went back to Laira at 1340.
175001 seems to be the only train they trust in passenger service despite three other refurbished units at Laira. It was cancelled yesterday due to a fire alarm.
Today a planned drag from Ely to Penzance was cancelled due to locomotive failure. It was to be repaired at Longrock?
Stock shortages in the southwest are really bad this week with shortforms despite Looe and St Ives having a bus service this week.
| Re: Class 175s to Great Western Railway (GWR) Posted by Chris from Nailsea at 14:19, 18th December 2025 | ![]() ![]() ![]() |
A couple of recent posts here have indeed been split off, moved and merged with our ongoing Portishead reopening topic.
See https://www.firstgreatwestern.info/coffeeshop/index.php?topic=231.msg369669#msg369669
