30.4.2025 (Wednesday) 12:56 - All running AOK
Posted by grahame at 18:04, 29th April 2025
It's in "Oh no - not AGAIN" territory ...  known as being a risky train. I will look at putting some numbers on it some time.
This train has run 89 times in the last six months, in which there have been 130 weekdays.  28 of those days it was cancelled because of planned engineering, 2 because it was Christmas / Boxing Day.   So 100 "should" have run. 11% cancellation rate - a very high percentage for a weekday.
Here's the proof, and comparison to other services:
Because of the very thin service, any cancellation is serious.
Posted by grahame at 17:52, 29th April 2025
Posted by grahame at 16:21, 29th April 2025
Only 2 trains in GWR area cancelled through lack of crew ... guess where
Cancelled as the guard for those services is booked to arrive at Westbury on the 1C77 10:35 Paddington to Exeter St Davids service which is currently being diverted via Swindon. Not the first time that problems or delays with 1C77 see the Swindon services cancelled.
For the record, the points failure at Westbury yesterday caused the cancellation of the 2M28 15:15 Swindon to Westbury and 2M21 16:23 Westbury to Swindon services. The unit stayed in the bay platform at Swindon and became the 17:35 departure to Westbury.
Posted by RA at 12:14, 29th April 2025
Posted by grahame at 11:50, 29th April 2025
Posted by grahame at 06:16, 29th April 2025
Facilities on the 05:11 Gloucester to Southampton Central due 08:09.
17:50 Gloucester to Salisbury due 20:06 was terminated at Westbury.
Posted by bobm at 15:47, 27th April 2025
and some additional information.
14:22 Frome to Swindon due 15:34
We're sorry for the disruption to your journey.
Taxis have been arranged leaving Westbury at 14:47 calling at Trowbridge (14:59), Melksham (15:12) and Chippenham (15:29 arrival). Change at Chippenham for Swindon. The taxi company is Bath Taxis.
Road transport pick up/drop off points can be found on the information poster at stations or online at nre.co.uk/stations
Posted by TaplowGreen at 09:30, 27th April 2025
14:22 Frome to Swindon due 15:34 will be terminated at Westbury.
It will no longer call at Trowbridge, Melksham, Chippenham and Swindon.
15:44 Swindon to Frome due 16:38 will be cancelled.
16:43 Frome to Swindon due 17:34
16:43 Frome to Swindon due 17:34 will be started from Westbury.
It will no longer call at Frome.
Posted by grahame at 06:13, 27th April 2025
18:11 Castle Cary to Swindon due 19:33
19:43 Swindon to Westbury due 20:25
19:43 Swindon to Westbury due 20:25 will be cancelled.
Posted by Mark A at 19:38, 26th April 2025
The lineside fire related disruption bit Bath rugby going home time, a bit of a queue outside the station and at least one bus driver being generous to people travelling back to places that suddenly had no train service. The bus station wasn't quite coping with the volume of people some of which were displaced from the trains and some *waves at the bus to Wells* definitely weren't.
Posted by grahame at 18:17, 26th April 2025
17:35 Swindon to Westbury due 18:18
17:35 Swindon to Westbury due 18:18 is being delayed between Swindon and Chippenham and is now expected to be 15 minutes late.
This is due to a fire next to the track earlier today.
Posted by TaplowGreen at 16:30, 25th April 2025
Unless these IETs stop at roughly the same time as timetabled services however (and I doubt they'd be advertised given the necessarily ad hoc nature), wouldn't they largely find an empty platform at Melksham due to people having drifted off/not expected to find a train stopping at a given time?
I suppose some hardy souls may hang around in the hope of something stopping!
It needs to be used carefully and is far more relevant during planned engineering works.   Today's disruption turned out to be over almost before it began, with a handful of long distance expresses running via Swindon rather than Newbury, and as far as I can tell the biggest service disruption was a four hour gap each way on trains between Westbury an Swindon.
Agreed re: engineering works, a proper "timetable" could be put in place and advertised.
Posted by grahame at 16:05, 25th April 2025
Posted by TaplowGreen at 15:53, 25th April 2025
Journey check looking good today - flagging up just two cancellations across the whole GWR area.   Guess where
This is due to a safety inspection of the track.
OK - so I notice a day when we are the only cancellations ... but this is not a unique occurrence!
Cancellations to services between Westbury and Swindon via Melksham
Due to a safety inspection of the track at Pewsey the line towards Reading is closed. Disruption is expected until 13:00 25/04.
Train services between Westbury and Swindon via Melksham have been cancelled.
Due to a safety inspection of the track, all train services between Westbury, Melksham and Swindon are cancelled.
Customers travelling between Westbury, Trowbridge, Chippenham and Swindon are advised to change at Bath Spa.
Melksham is not being served by trains for the time being. Road transport is being organised.
((A section of track between Westbury and Pewsey is being examined for a possible defect. As a precaution we are not currently running trains along this stretch. This affects services to London Paddington from Devon and Cornwall. Where possible trains will divert, taking an alternative, slightly longer route. Where this is not possible, train services may be terminated at short notice.))
Typical "because of a problem on another line we're cancelling the trains on your line".
Hopefully, we have a better solution for the future ...only yesterday, I was photographing the new Stop boards for IETs at Melksham, and a train manager was telling me how they've had a circular around telling staff that the long distance trains can stop here.  Ideal for the sort of thing we have going on today? If the none-stop Taunton to Reading services run via Bristol and Bath, the semi-fast can run via Westbury and serve Trowbridge and Melksham in addition to Castle Cary and Westbury.  But it will take a bit of getting used to - oy, anyone in GWR reading this
Posted by grahame at 12:16, 25th April 2025
Posted by GBM at 12:05, 25th April 2025
Posted by grahame at 11:18, 25th April 2025
Posted by IndustryInsider at 08:09, 25th April 2025
A driver was allocated to it and they arrived on time from Fratton on 2V52.
Doesn’t mean the RTT code is wrong (short notice illness etc.), but codes on RTT are unofficial and on JourneyCheck are ‘official’…but with a pinch of salt!
Posted by grahame at 07:09, 25th April 2025
05:11 Gloucester to Southampton Central due 08:09 will be terminated at Westbury.
It will no longer call at Dilton Marsh, Warminster, Salisbury, Romsey and Southampton Central.
Interesting to note that Real Time Trains shows an on time arrival at Westbury and reports
This service was cancelled between Westbury and Southampton Central due to an issue with the train crew (TH).
So which is it - perhaps the fault on the train was that there was no-one to drive it  .
P.S. There is routinely a crew change at Westbury on this service
Posted by grahame at 06:55, 25th April 2025
Posted by bobm at 19:18, 24th April 2025
I see Melksham now has IET stop boards on the platform.
Presumably IETs can now stop there which will come in handy when they’re diverted for whatever reason.
..and here they are
Posted by grahame at 16:12, 24th April 2025
15:15 Swindon to Westbury due 15:59 is being delayed between Chippenham and Melksham and is now expected to be 12 minutes late.
Posted by TaplowGreen at 13:49, 22nd April 2025
15:15 Swindon to Westbury due 15:59 will be cancelled.
Posted by grahame at 11:38, 22nd April 2025
A week is a long time in politics ... a quarter hour is a long time in a train service. 20:02, 20:10 and 20:14
Posted by grahame at 08:49, 22nd April 2025
I ended up getting home last night at around 21:15 when I had planned to be home around 19:30 (very last minute cancellation ) and then - plan B - at around 20:45 (another very last minute cancellation).
I made a thought out but quick decision in Trowbridge to take a taxi that was sitting on the rank; there are NOT always taxis there, and I've had to wait up to 90 minutes during the evening before.  I spoke to both the help point gentleman and a lady at GWR, and both told me that the final train could not be guaranteed but at the time of speaking it was still showing as running.  That would have got me home at 22:00 if it ran.
Having had two trains cancelled in succession on my, in both instances at or after the time they were due to leave, and seeing a taxi available - pragmatic decision.  There was no fall back bus via Bath as it was a Bank Holiday bus service, and I was disinclined to take up the GWR suggestion to wait over an hour to see if that final train ran, and if it didn't then set about finding a taxi.
"Small beer" perhaps in yesterday's chaos across the GWR area, but cancellations - especially ones that are very late in the day, and advise which is not customer supportive (saving them money over customer's time / comfort / peace of mind) really don't help promote the railway.   And cancellations because of a faulty train, and because of a lack of available crew, are not the sort of reasons that well up mounds of sympathy in the same way that a passenger being taken ill on a train does.
Posted by grahame at 21:56, 21st April 2025
20:06 Westbury to Cheltenham Spa due 22:05
20:06 Westbury to Cheltenham Spa due 22:05 has been cancelled.
This is due to train crew being delayed.
The 17:50 from Gloucester via Melksham was cancelled at 18:05 (the train sitting in the platform with passengers in it waiting to go - so I did not get into Melksham at 19:09 as per plan "A"
I took the 18:10 from Gloucester which also runs via Trowbridge to Westbury (via Bristol, this one) with the intent of changing into the 20:12 from Trowbridge back to Melksham - however that was cancelled at very late notice (about 5 past so I did not get to Melksham at 20:21 which was plan "B"
The help point told me that I should wait for the 21:22 train which would bring ne into Melksham at 21:32 - plan C.   As far as he knew it would run but he couldn't promise anything.   He suggested I call GWR if I wanted to be more certain.  I did, but they were unable to give me any re-assurance.  They told me to wait and see if it ran - and if it was cancelled, I should then take a taxis and try and claim for it.    They were unable to explain why they only told the public that they had no staff for the 20:12 a couple of minutes before it was due ...
Posted by grahame at 19:26, 21st April 2025
17:50 Gloucester to Salisbury via Swindon:
This service is cancelled.
This service was cancelled due to a problem with the train (M8).
Very late cancellation - hasn't made it to JourneyCheck.
Oh - it's just appeared on the map
17:50 Gloucester to Salisbury due 20:06 has been cancelled.
Last Updated:21/04/2025 19:20
What, if anything, would delay / repay get me on an FOSW for a delay of 72 minutes (projected). No, I probably won't bother - pragmatism over principle!
Posted by grahame at 18:57, 21st April 2025
Posted by grahame at 16:15, 21st April 2025
15:15 Swindon to Westbury due 15:59 will be started from Chippenham.
It will no longer call at Swindon.
It will be delayed at Chippenham and is expected to be 9 minutes late.
This is due to a passenger being taken ill on this train.
Posted by grahame at 09:54, 20th April 2025
Over running engineering works have also done for the first service from Swindon to London Paddington (starts Didcot Parkway) and first westbound service to Bristol and Exeter St Davids (starts Bristol Temple Meads).
Oh dear ...  From Swindon to London, there's an 08:00 bus (change Reading) and an 09:40 train ... first train to Westbury now 2 hours after that. Passenger volumes are of course very different, but it's also a reminder of just how serious cancelling even one train on an infrequent service is.
Nearly 4 hours to wait for public transport home to Melksham now if you miss the 17:44 (and on a Sunday, the evening buses from Bath don't run so even those of us in "the know" would struggle)
Posted by bobm at 09:24, 20th April 2025
Posted by grahame at 08:58, 20th April 2025
Oh goodie - 4 out of 14 (28% cancellation rate) not calling at Melksham on what's probably going to be the first really busy Sunday of the year. Just taken a look at the two morning cancellations and there's nothing helpful there about buses or taxis - just an offer to give you your money back ...
Posted by TaplowGreen at 08:44, 20th April 2025
08:06 Warminster to Swindon due 09:02
08:06 Warminster to Swindon due 09:02 was terminated at Westbury.
This is due to engineering works not being finished on time.
09:08 Swindon to Westbury due 09:49
09:08 Swindon to Westbury due 09:49 will be cancelled.
Posted by grahame at 04:33, 20th April 2025
11:41 Swindon to Weymouth due 13:53
11:41 Swindon to Weymouth due 13:53 will be terminated at Westbury.
It will no longer call at Bruton, Castle Cary, Yeovil Pen Mill, Thornford, Yetminster, Chetnole, Maiden Newton, Dorchester West, Upwey and Weymouth.
18:11 Castle Cary to Swindon due 19:33 will be terminated at Westbury.
Stay-at-home Sunday for me then ... on an 8 out of 15 FOSW ticket and Sundays have the advantage of the early start being allowed, but I'me replanning for this to be a day of rest.   Yes, I know that evening round trip might get re-instated but there's no comfortable "Plan B" for Sunday evenings
Damage already done - day planned and planned without a return to Melksham on those trains, comment made in public at https://www.passenger.chat/t30162.html and onto Facebook.
Posted by grahame at 08:45, 18th April 2025
At around 08:45, re-instated, I notice.
Posted by grahame at 02:24, 18th April 2025
Posted by grahame at 14:25, 17th April 2025
13:14 Swindon to Westbury due 13:57 has been delayed at Swindon and is now 20 minutes late.
14:18 Westbury to Swindon due 15:00 will be starting late from Westbury and is expected to be 5 minutes late.
Posted by grahame at 07:59, 17th April 2025
Happy with that ... and if it weren't school holidays that would be very welcome indeed beyond Swindon
Posted by grahame at 10:47, 16th April 2025
Yes - for passenger purposes.    When planned works or an emergency stoppage take place between Westbury and Reading, trains to / from the South West get diverted either via Bristol Temple Meads or via Melksham.  The very long distance expresses often go via Bristol, but the semi-fasts always go via Melksham so that a service can be maintained from Castle Cary and Westbury into Reading and London, and they'll be able to call at Trowbridge, Melksham and Chippenham and reduce the need for some of the rail replacement buses and taxis.
Posted by matth1j at 10:31, 16th April 2025
Probably a daft question... I can only imagine that they'd want to stop at a specific point relative to the platform (on a single track line) to allow passengers on/off. But under what circumstances would they do that?
Posted by grahame at 08:17, 16th April 2025
I understand that is the plan  - I understand that there's a need to do some sort of final check out of the system / test stop perhaps and fill in risk assessment paperwork perhaps so I am not counting my chickens, but clearly with it being programmed into the units and also having the stop boards in place it's coming into place.
Posted by a-driver at 07:28, 16th April 2025
Posted by grahame at 17:26, 15th April 2025
20:14 Swindon to Westbury due 20:57
Facilities on the 22:31 Swindon to Westbury due 23:12.
Posted by grahame at 08:09, 14th April 2025
07:45 Westbury to Swindon due 08:34
08:45 Swindon to Westbury due 09:26
08:45 Swindon to Westbury due 09:26 will be cancelled.
Posted by grahame at 06:17, 14th April 2025
20:38 Westbury to Swindon due 21:23 will be cancelled.
I wonder whether they had the crew?  We only ever get one reason and, somewhat uncharitably, I sometimes wonder if we are told the reason for cancellation that brings the least criticism onto the operator.
Posted by TaplowGreen at 19:33, 13th April 2025
Posted by grahame at 18:12, 13th April 2025
18:11 Castle Cary to Swindon due 19:33 will be cancelled.
and now - not surprised ...
Last Updated:13/04/2025 17:45
... only surprise is that they cancelled the up service and lunchtime, but left the return service running until 4 hours later
Posted by grahame at 13:15, 13th April 2025
Posted by grahame at 17:48, 10th April 2025
17:50 Gloucester to Salisbury due 20:06 will be reinstated and will now run as scheduled.
Last Updated:10/04/2025 17:34
Posted by grahame at 19:27, 6th April 2025
Ah yes - added after my original post (and I admit I had changed my plans for today overnight and hadn't checked back this morning)
Taxis have been arranged leaving Swindon at 19:43 calling at Chippenham (20:14), Melksham (20:32), Trowbridge (20:45) and Westbury (20:57 arrival). Please see the Information Poster at the station for the road transport pick up/drop off point or visit nre.co.uk/stations.
The taxi company is Cross Street Cars.
Last Updated:06/04/2025 07:58
Posted by bobm at 19:12, 6th April 2025
Posted by JayMac at 18:42, 6th April 2025
Someone's got acorns for brains.
Posted by Chris from Nailsea at 18:28, 6th April 2025
https://www.railadvent.co.uk/2025/04/plans-discussed-for-a-metro-system-for-bath-and-wiltshire.html
His name is Dan Okey, not Dan Oakey, and it's Okehampton, not Oakhampton: more examples of shoddy journalism - perhaps using autocorrect, without bothering to make sure it is in fact correct.
Posted by TonyK at 15:50, 6th April 2025
Luckily, the Wiltshire Metro will sort all this lot out.
Posted by grahame at 15:08, 6th April 2025
13:42 Swindon to Weymouth due 15:53
13:42 Swindon to Weymouth due 15:53 will no longer call at Frome.
It has been delayed between Chippenham and Melksham and is now 16 minutes late.
Posted by grahame at 17:26, 5th April 2025
Sun, 6 April 18:11 Castle Cary to Swindon due 19:33
Sun, 6 April 19:43 Swindon to Westbury due 20:25
Sun, 6 April 20:38 Westbury to Swindon due 21:23
Sun, 6 April 21:34 Swindon to Westbury due 22:16
06/04/25 21:34 Swindon to Westbury due 22:16 will be cancelled.
Posted by grahame at 20:34, 4th April 2025
20:14 Swindon to Westbury due 20:57 will be starting late from Swindon and is expected to be 15 minutes late.
This is due to congestion.
Posted by grahame at 20:48, 1st April 2025
Posted by grahame at 07:09, 1st April 2025
20:06 Westbury to Cheltenham Spa due 22:05 will be cancelled.
Posted by grahame at 06:34, 1st April 2025
17:50 Gloucester to Salisbury due 20:06 will be terminated at Swindon.
It will no longer call at Chippenham, Melksham, Trowbridge, Westbury, Dilton Marsh, Warminster and Salisbury.
Posted by grahame at 17:07, 30th March 2025
16:43 Frome to Chippenham due 17:29
16:43 Frome to Chippenham due 17:29 will be started from Westbury.
Posted by grahame at 08:01, 30th March 2025
11:04 Westbury to Chippenham due 11:29
11:45 Chippenham to Westbury due 12:12
11:45 Chippenham to Westbury due 12:12 will be cancelled.
Posted by grahame at 19:40, 28th March 2025
Posted by TaplowGreen at 19:09, 28th March 2025
18:37 Westbury to Swindon due 19:21 will be diverted between Trowbridge and Chippenham.
It will no longer call at Melksham.
It will be delayed due to the diversion and is expected to be 9 minutes late.
Posted by grahame at 19:14, 24th March 2025
Looks like it's reinstated...along with several others!
Is that the plan "B"?  Take anything from JourneyCheck more than a few hours in advance with a huge pinch of salt?
No - "Plan B" was to stay over.  Today was planned at January sale time - but then in February I got an invite for tomorrow that I could not refuse and I was going to be pretty tired.  Plan B was "if return train cancelled, stay over" and button pressed to implement that.  I have emergency supplies anyway.
Posted by grahame at 18:50, 24th March 2025
Both now reinstated.
... and I have checked in to stay in Lambeth ...
Posted by bobm at 15:35, 24th March 2025
Posted by IndustryInsider at 15:28, 24th March 2025
There goes my train home ... advance ticket on the 21:31 off Paddington .... it always pays to have a plan "B" ... think I have one somewhere  ...
Posted by grahame at 14:00, 24th March 2025
Posted by TaplowGreen at 05:55, 24th March 2025
Posted by ChrisB at 14:31, 23rd March 2025
It does - as a part cancellation.
Posted by Mark A at 10:03, 23rd March 2025
In a way, if a service is even announced as cancelled (or part-run), for a portion of passengers it *is* cancelled - it ought to go into the cancellation stats whatever happens subsequently. If it doesn't, the industry's running for its own benefit rather than for its customers.
Posted by froome at 09:56, 23rd March 2025
is it just me?
No - it's very annoying when you change your plans to take a less convenient (or, based on recent experience, more inconvenient ) form of commute and then find out you needn't have bothered.
Thank you for that confirmation.
There are times I feel that I am reflecting the needs / concerns of members and and the many people I talk with who are not Coffee Shop members - and that's good.    There are also time that I find myself wondering if I am the only one concerned at something - in which case I should probably move on from that issue.
Have just seen this. Yes this is definitely an issue which needs resolving. I have often gone to an unmanned station and been confronted with a screen just saying the service I am aiming to catch is cancelled. It has often meant that I have had to cancel a trip I was intending to make, or if possible to very hurriedly find another way of making the trip (for me this has often been to cycle very quickly from Oldfield Park to Bath Spa). It is exceptionally annoying to find that the service did run after all (at Oldfield Park it has often been that the train was running but late and was missing out our station). Screens, announcements and websites need to have much more information given in these circumstances.
Posted by TaplowGreen at 08:05, 23rd March 2025
13:04 Westbury to Chippenham due 13:30
19:45 Chippenham to Westbury due 20:12
20:54 Westbury to Chippenham due 21:19
20:54 Westbury to Chippenham due 21:19 will be cancelled.
13:47 Chippenham to Weymouth due 15:46
13:47 Chippenham to Weymouth due 15:46 will be started from Westbury.
It will no longer call at Chippenham, Melksham and Trowbridge.
18:11 Castle Cary to Chippenham due 19:19
18:11 Castle Cary to Chippenham due 19:19 will be terminated at Westbury.
It will no longer call at Trowbridge, Melksham and Chippenham.
21:50 Chippenham to Westbury due 22:16
21:50 Chippenham to Westbury due 22:16 will be cancelled.
Posted by grahame at 06:15, 23rd March 2025
Posted by grahame at 20:41, 21st March 2025
Just gotta get home now
How it should work (timing wise) - 17:53 from Taunton to Bristol, 18:30 on to Chippenham and 19:00 to Melksham arrived 1 minute down at 19:09 - 76 minute journey.
Posted by grahame at 15:05, 21st March 2025
Problems had started this morning ... I walked to the station and saw the dreaded word "delayed" against the 09:10 to Westbury. Checking Open Trains Times and Real Time Trains and another regular checked on her phone other sources, and on principle asking on the help point too, we were told 09:31 and that the connection at Trowbridge to Bath and Bristol would make, and a couple of minutes later Open Train Times map showed it coming.  Display changed to 09:34 which was going to be really tight at TRO.   No clues as to why ...
Good TM when it rolled in / explained about a point or track failure at Swindon and apologised - "I realise you don't have much information available at Melksham" which shows an excellent understanding.  Connection to Bath and Bristol made.  Connection to Warminster was lost / 30 minute delay to there. I'm not aware of where others were connecting to.
Posted by TaplowGreen at 12:45, 21st March 2025
12:17 Westbury to Swindon due 12:59 will be cancelled.
14:18 Westbury to Swindon due 15:00 will be terminated at Chippenham.
Posted by TaplowGreen at 12:43, 21st March 2025
Due to a points failure at Swindon some lines are blocked. Disruption is expected until 15:00 21/03.
Train services between Swindon and Westbury via Melksham may be cancelled or delayed.
Apologies for the disruption to your journey today.
Network Rail advise that a set of points has failed just outside Swindon station; this is affecting journeys in both directions as local services are caught up in the congestion on the Main Lines.
Posted by grahame at 21:28, 18th March 2025
18:37 Westbury to Swindon due 19:21 will be starting late from Westbury and is expected to be 5 minutes late.
Posted by grahame at 09:41, 18th March 2025
is it just me?
Posted by matth1j at 09:13, 18th March 2025
is it just me?
Posted by grahame at 16:16, 17th March 2025
This is due to a problem currently under investigation.
Both re-instated half an hour later.
Oh dear - I think.
I have written before of how difficult it must be for the decision makers as a situation arises as to when to say something in public.  - but, really, broadcasting in public will be cancelled is a very definitive statement and to my gives no room for doubt - it's a statement that the train in question won't run.
I would (personally - is it just me?) like to see an option where a train service could be reported as being at  [low/some/high] risk of cancellation and with a note of a time by which the record will be updated.
Posted by bobm at 16:06, 17th March 2025
Posted by brooklea at 16:04, 17th March 2025
Ah hmm. Point of order m'lud
I’ll concede the Twyford points failure didn’t help matters, but maintain that had the 05:03 Penzance to Paddington not lost over half an hour in Cornwall this morning due to a points failure, the train’s next working (1C77, with the TM for the TransWilts on board), would probably not have been late enough into Westbury to have knocked-on to the 12:17 to Swindon.
Posted by GBM at 15:29, 17th March 2025
12:17 Westbury to Swindon due 12:59 will be starting late from Westbury and is expected to be 12 minutes late.
Have to love this - NOT a points failure anywhere near us but a knock on delay from
10:35 London Paddington to Exeter St Davids due 13:07
10:35 London Paddington to Exeter St Davids due 13:07 has been delayed at London Paddington and is now 26 minutes late.
Indeed not anywhere near Wiltshire - actually this points failure mentioned by GBM elsewhere on the forum [url=https://www.firstgreatwestern.info/coffeeshop/index.php?topic=28556.msg359538#msg359538]https://www.firstgreatwestern.info/coffeeshop/index.php?topic=28556.msg359538#msg359538[/url], which was in Cornwall.[/i]
Ah hmm. Point of order m'lud https://www.firstgreatwestern.info/coffeeshop/index.php?topic=29650.msg359540#msg359540
Posted by grahame at 15:27, 17th March 2025
Posted by brooklea at 12:50, 17th March 2025
Indeed not anywhere near Wiltshire - actually this points failure mentioned by GBM elsewhere on the forum https://www.firstgreatwestern.info/coffeeshop/index.php?topic=28556.msg359538#msg359538, which was in Cornwall.
Posted by grahame at 12:15, 17th March 2025
Posted by grahame at 10:17, 17th March 2025
09:46 Westbury to Swindon due 10:29
09:46 Westbury to Swindon due 10:29 will be starting late from Westbury and is expected to be 10 minutes late.
Looks like a 'false' report - just 1 minute late off Westbury in the end
Posted by grahame at 10:13, 17th March 2025
Posted by grahame at 08:50, 17th March 2025
Just back from a week in Lanzarote, and was pleasantly surprised to find my 0721 Melksham-Chippenham train on time this morning. But it didn't last - the Paddington service that precedes it into Chippenham was running a bit late, so mine was delayed and I just missed the (unofficial) connection with the 0734 Chippenham-Bristol service. Then the next 0809 was cancelled (train fault). And now the 0832 is showing as 'running late' by 11 mins.
Good to be back
Welcome home ... what more can I say?
Posted by matth1j at 08:30, 17th March 2025
Good to be back
Posted by grahame at 07:47, 14th March 2025
14/03/25 06:35 Salisbury to Worcester Foregate Street due 09:47 will be started from Westbury.
Posted by brooklea at 13:56, 13th March 2025
Hold it!
Toilets are available in coaches X.
Accessible toilet and wheelchair facilities in coach X.
We apologise for the inconvenience this may cause.
Coincidentally(??), the same train as was on the 17:50 Gloucester to Salisbury yesterday (165132 according to RTT).
Swapping units at Westbury this morning caused an eleven minute delay to the TransWilts train, but presumably there were working toilets on the substitute train (and an extra carriage), so not all bad news (unless you were on the Castle Cary to Filton train without a working loo from Westbury….)
Posted by grahame at 08:56, 13th March 2025
Hold it!
Posted by grahame at 20:47, 12th March 2025
This service is partially cancelled
This service was cancelled between Westbury and Salisbury due to the train operator's request (TB).
Posted by grahame at 12:39, 12th March 2025
Posted by grahame at 07:16, 11th March 2025
No problem ... and will reduce (over)crowding at the very end of that journey
No problem ... and will reduce (over)crowding from Swindon to Stroud
