Posted by TaplowGreen at 17:40, 21st June 2026
Due to damage to the overhead electric wires between Slough and London Paddington fewer trains are able to run on some lines.
Posted by TaplowGreen at 08:54, 21st June 2026
Delays to services at London Paddington
Due to damage to the overhead electric wires at London Paddington trains have to run at reduced speed on the line.
Train services running to and from this station may be delayed. Disruption is expected until 10:00 21/06.
Posted by TaplowGreen at 17:09, 19th June 2026
At Didcot apparently.......feels almost inevitable doesn't it?
Cancellations to services between Reading and Swindon
Due to a fault with the signalling system between Reading and Swindon all lines are blocked.
Train services running to and from these stations may be cancelled, delayed or diverted between Reading and Bath Spa. Didcot Parkway, Swindon and Chippenham will not be served. Disruption is expected until 17:30 19/06.
Posted by Electric train at 11:27, 17th June 2026
Blimey what was it? An albatross?
Delays to services between Newbury and Bedwyn
Following a broken down train earlier today at Kintbury all lines towards Taunton have now reopened. Disruption is expected until 16:15 15/06.
Train services between Newbury and Bedwyn are returning to normal.
A train had broken down near Kintbury, after striking a bird.
Birds have always been an issue with overhead line electrification.   The first generation (Mk1) used on the WCML and GE had places that allowed birds to build nest, the dropping caused corrosion also the blighters shorted the system.
Large birds such as swans and geese will occasionally fly into the OLE insulators etc, they are also know to fly into pantographs even on moving trains which causes a short usually with a big bang, a dead bird and lots of singed feathers.
Posted by Chris from Nailsea at 21:18, 16th June 2026
To be fair, geese can take down an aircraft: see https://en.wikipedia.org/wiki/US_Airways_Flight_1549
Posted by TaplowGreen at 15:39, 15th June 2026
Posted by grahame at 06:42, 15th June 2026
......another week begins.....
Due to damage to the overhead electric wires between London Paddington and Reading the line towards London Paddington bound local stopping is closed.
Train services running to and from these stations may be cancelled or revised. Disruption is expected until 13:00 15/06.
At 06:03 (that's the update time) JourneyCheck is telling us
Due to some damage to the overhead wires in the Southall / Ealing area one of the lines has had to be closed. As a result, fewer trains are able to operate over the section of line between London Paddington and Reading.
Trains will still operate between those points but to a reduced frequency so they will be much busier than normal. Please accept our apologies for any inconvenience this may cause to your journey today.
Train services between London Paddington / Reading / Swindon and Bristol Parkway / Newport / Cardiff Central will operate to a reduced frequency.
Train services between London Paddington - Reading - Oxford will operate to a reduced frequency. Those services which operate to / from Worcester stations via Oxford will continue to do so. Customers at Oxford requiring London where there is no immediate service may utilise Chiltern Railways services at no additional cost between Oxford and London Marylebone and London Underground services Marylebone to Paddington. Similarly, customers in London wishing to travel to Oxford may utilise Chiltern railways services, at no additional cost, between London Marylebone and Oxford. In addition, GWR ticket holders may utilise CrossCountry services, at no additional cost, between Reading and Oxford (in both directions) in order to assist with their journeys.
Train services which normally operate between Didcot Parkway and London Paddington (calling at local stations via Pangbourne) will only operate between Didcot Parkway and Reading in both directions. Passengers to or from stations to London Paddington will be required to change trains at Reading.
Train services which normally operate between Newbury and London Paddington (calling at local stations via Thatcham) will only operate between Newbury and Reading in both directions. Passengers to or from stations to London Paddington will be required to change trains at Reading.
In addition to the reduced Great Western Railway service operating between Reading and London Paddington customers may use, at no additional cost, Elizabeth line services between Reading and London Paddington but kindly note that these services will also be operating to a reduced frequency and likely to very busy. Kindly note that at Paddington the Elizabeth line services call at platforms A and B which may be accessed via the entrances alongside platform 1 of the main terminal station. Great Western Railway ticket holders may also utilise, at no additional cost, South Western Railway services between Reading and Waterloo (in both directions) and London Underground services across London between Waterloo and Paddington.
Good information - and everyone can travel if a bit delayed, congested, and perhaps with an extra change ...  What a pity that this feels so routine!
Posted by TaplowGreen at 04:28, 15th June 2026
Posted by TaplowGreen at 15:53, 9th June 2026
Second of the day..................
Due to a fault with the signalling system at West Ealing fewer trains are able to run on some lines. Disruption is expected until 18:15 09/06.
Train services between Reading and London Paddington may be cancelled or delayed.
Due to a fault with the signal system in the West Ealing area, we are amending our train service between Reading and London Paddington this afternoon.
Posted by TaplowGreen at 06:46, 9th June 2026
From National Rail - causing a lot of cancellations
Between Abbey Wood and Heathrow Terminal 4 / Maidenhead / Reading, between Gidea Park and Heathrow Terminal 4, between London Paddington and Heathrow Terminal 4 / Heathrow Terminal 5 / Reading, and also between Shenfield and Heathrow Terminal 5
An earlier fault with the signalling system at London Paddington is causing disruption to Elizabeth line services through London Paddington. Trains running through this station may still be cancelled or revised whilst service recovers.
Disruption is expected until 08:00.
Posted by charles_uk at 17:48, 2nd June 2026
And just like London buses...
Train services running to and from these stations may be delayed by up to 20 minutes. Disruption is expected until 19:15 02/06.
Some axle counters, part of the signalling system, have stopped working in the Ruscombe area. Axle counters tell the signalling system if a section of track has a train on it. If an axle counter stops working, trains need to stop at the affected signal so that the Driver can speak to the Signaller to confirm if the track ahead is clear.
Posted by TaplowGreen at 10:48, 2nd June 2026
And in a bit of comedy timing, whilst all the disruption continues, the regulator ORR has decided to issue a letter to Network Rail Western saying ORR is satisfied with their performance and improvement.
Even includes :
A major area of focus has been the Thames Valley and Network Rail has carried out a high volume of asset interventions concentrating on track, overhead line equipment, axle counters and points.
https://www.orr.gov.uk/sites/default/files/2026-06/2026-06-01-nr-wales-and-western-compliance.pdf
So apparently ORR thinks the interventions are good enough, even though failures are continuing.  Words fail me.
Genuinely couldn't make it up
https://www.railmagazine.com/news/network-rail-improvements-lead-to-end-of-enforcement-action-on-poor-performance
Posted by John D at 10:36, 2nd June 2026
Even includes :
Posted by TaplowGreen at 10:25, 2nd June 2026
Disruption pushed out till midday now - last couple of weeks have been shambolic on this line - with so many people relying on the Elizabeth Line thanks to the RMT Tube strike today it makes the situation even worse.
Posted by charles_uk at 09:54, 2nd June 2026
Due to a fault with the signalling system between London Paddington and Reading some lines are closed.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 10:15 02/06.
There is a fault with the signalling system between Slough and Acton. The signalling system is how trains are kept a safe distance apart and directed onto the various lines along their journey. When there is a fault with the signalling system trains may need to stop at the affected signals so that the Driver can speak to the Signaller to confirm if the track ahead is clear.
The problem affects 2 of the four lines between London Paddington and Reading, so we are having to reduce the train service through the area to avoid congestion.
Some services between London Paddington and Oxford, and between London Paddington and Cardiff Central, will not run, in either direction.
Local stopping services between London Paddington and Didcot Parkway/Newbury will only run between Reading and Didcot Parkway/Newbury.
Most longer distance Intercity services will continue to run between London Paddington and Reading, but may be subject to delay.
We are working with Network Rail to be able to return to running our normal timetable as soon as possible.
Posted by bobm at 20:28, 1st June 2026
Network Rail are saying on X that today’s problems were caused by cable theft.
Posted by bobm at 16:11, 1st June 2026
Edward Burnett was formerly at the Swindon Advertiser and became noted for his restaurant reviews.
He is now at the Oxford Mail and I suspect filling in at fellow Newsquest title, the Reading Chronicle.
Posted by Marlburian at 15:16, 1st June 2026
A new reporter has joined the Reading Chronicle team, though this article does not make for a happy start: "Several trains to London trains and vice versa pass through Reading."
Posted by bobm at 09:16, 1st June 2026
Electrical failure affecting the points at Dolphin Junction near Slough and one signal in the area.
Hope to be resolved in the next hour.
Posted by TaplowGreen at 08:42, 1st June 2026
Normal weather - normal service
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 08:01 01/06.
Now going to take extra 7 hours to fix disruption
Disruption is expected until 15:00 01/06.
Now been expanded to "all routes".
Cancellations to services on all routes
Due to a points failure between Reading and London Paddington fewer trains are able to run on some lines.
Train services running across the whole Great Western Railway network may be cancelled, delayed or revised. Disruption is expected until 15:00 01/06.
There has been a points failure between Reading and London Paddington. A points failure is a fault with the movable pieces of track that enable trains to change tracks.
................I got to Taplow at around 0540 to find everything being cancelled in both directions, hung around for half an hour, advised to go to Maidenhead although there was very little moving from there either and no taxis available for at least half an hour, so am working from home - fortunately I am able to although there were other customers arriving at the station who clearly weren't, and were extremely concerned/frustrated about how they were going to get to work.
What a (woeful) mess.
Posted by John D at 08:10, 1st June 2026
Posted by Mark A at 08:07, 1st June 2026
Coffeeshop map's a mess, or rather, reflecting a mess, and a lot of cancellations from the likes of Oxford.
Posted by TaplowGreen at 05:20, 1st June 2026
Posted by TaplowGreen at 20:13, 27th May 2026
Due to a speed restriction because of high track temperatures between Reading and London Paddington fewer trains are able to run on all lines.
Train services running to and from these stations may be running non stop between Reading and London Paddington. Twyford, Maidenhead and Slough will not be served.
Posted by a-driver at 18:37, 26th May 2026
Still, we haven’t got long to wait and it’ll be nationalised and all the infrastructure faults will magically disappear overnight!
Isn't the infrastructure in public ownership already?
Yes,  but many people don’t realise that!  Many still think all the failings of the railway are down to the private companies….. and the DfT don’t want to change that thinking!
Previously, any franchised operator had to display its owning company, be it First, Stagecoach etc pretty much from day one.  The nationalised operations don’t.  I wonder why?!
Posted by IndustryInsider at 10:36, 26th May 2026
Seems to apply to the majority of the London - Didcot services today
09:08 London Paddington to Didcot Parkway due 10:22
09:08 London Paddington to Didcot Parkway due 10:22 will no longer call at Slough, Maidenhead and Twyford.
This is due to a speed restriction because of high track temperatures.
To avoid using the crossovers at Dolphin Junction and Stockley Bridge.  They are pretty much the only trains that use them and they are a higher risk point of failure during a heat wave, and if they stay set to the straight ahead route they can’t fail.
Posted by TaplowGreen at 06:44, 26th May 2026
Posted by TaplowGreen at 18:02, 25th May 2026
Posted by a-driver at 17:19, 25th May 2026
Posted by TaplowGreen at 10:48, 25th May 2026
................here we go again
Due to a fault with the signalling system between London Paddington and Reading trains have to run at reduced speed on some lines.
Train services running to and from these stations may be cancelled, delayed or revised. Disruption is expected until 15:00 25/05.
Posted by TaplowGreen at 16:49, 24th May 2026
Due to a fault with the signalling system between Reading and Newbury some lines are blocked.
Train services running to and from these stations will be cancelled or delayed.
Posted by TaplowGreen at 19:16, 23rd May 2026
Due to a fault with the signalling system between London Paddington and Reading fewer trains are able to run on some lines.
Posted by TaplowGreen at 15:11, 22nd May 2026
........and also the second one of the day a little further West in the Thames Valley.....I guess now it's a little warmer we have to expect the infrastructure/service to start melting down.......literally as well as figuratively
Still, cracking BBQ weather! Just in time for the Bank Holiday weekend!
Train services running to and from these stations may be cancelled, delayed or revised. Disruption is expected until 19:00 22/05.
Posted by NickB at 13:34, 22nd May 2026
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 15:15 22/05.
Posted by TaplowGreen at 09:11, 22nd May 2026
Due to a fault with the signalling system between Newbury and Reading trains have to run at reduced speed on some lines.
Train services running to and from these stations may be cancelled or delayed by up to 25 minutes. Disruption is expected until 11:45 22/05.
Posted by TaplowGreen at 07:31, 22nd May 2026
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 10:15 22/05.
Posted by Chris from Nailsea at 20:55, 17th May 2026
Network Rail have been carrying out planned engineering work in the London Paddington area. They have informed us that this will not be finished on time.
Don't panic: it will all go so much smoother when we have civil servants doing it.
Posted by TaplowGreen at 08:01, 17th May 2026
Cancellations to services at London Paddington
Due to engineering works not being finished on time at London Paddington all lines are blocked.
Train services running to and from this station may be cancelled or delayed. Disruption is expected until 08:30 17/05.
Posted by ChrisB at 16:22, 10th May 2026
Piccadilly Line was already shut owing to Engineering Work.
With no trains to Heathrow, it was Circle/District to Hammersmith & a bus this morning - or out from Waterloo to somewhere with a bus connection.
Posted by TaplowGreen at 09:07, 10th May 2026
Due to the emergency services dealing with an incident near the railway between London Paddington and Reading all lines are closed.
Train services running to and from these stations will be cancelled or delayed. Disruption is expected until 11:00 10/05.
Posted by TaplowGreen at 13:46, 5th May 2026
Due to a broken down train between London Paddington and Reading fewer trains are able to run on the line towards Reading.
Posted by NickB at 20:37, 2nd May 2026
And now, trespassers.
Posted by TaplowGreen at 11:43, 2nd May 2026
Cancellations to services between London and Reading
Due to a broken down train between London Paddington and Reading some lines are blocked.
Train services running to and from these stations may be cancelled, delayed by up to 15 minutes or revised. Disruption is expected until 14:00 02/05.
Posted by TaplowGreen at 14:30, 1st May 2026
There is a fault with the signalling systems between London Paddington to Reading
Posted by TaplowGreen at 14:16, 1st May 2026
From National Rail
Elizabeth line services between London Paddington and Slough
A fault with the signalling system between Langley and Slough means that some lines towards Reading are blocked. As a result, Elizabeth line services running between London Paddington and Slough may be delayed by up to 20 minutes or revised.
Disruption is expected until 16:00.
Posted by TaplowGreen at 17:34, 25th April 2026
From National Rail
Between Abbey Wood and Heathrow Terminal 4 / Maidenhead / Reading, and also between Shenfield and Heathrow Terminal 5
A fault with the signalling system at Hanwell means that all lines are blocked. As a result trains running between West Ealing and Heathrow Airport / Slough may be cancelled, delayed by up to 30 minutes or revised.
Disruption is expected until 18:00.
Posted by TaplowGreen at 07:38, 24th April 2026
Due to a points failure between Reading and Newbury fewer trains are able to run on some lines.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 10:00 24/04.
Posted by TaplowGreen at 10:52, 21st April 2026
..............he's moved further West today!
Cancellations to services at Hungerford
Due to trespassers on the railway at Hungerford trains have to run at reduced speed on all lines.
Train services running through this station may be cancelled or delayed.
Disruption is expected until 11:30 21/04.
Posted by Bob_Blakey at 08:04, 21st April 2026
Taser.
Yes, if necessary. First option should always be physical removal of the miscreant as rapidly as possible by as many trained operatives as required. But if said trespasser resists.....
Negotiation should never be involved.
Posted by TaplowGreen at 21:29, 20th April 2026
Taser.
Trespassers had been reported on the railway in the London Paddington area.
The person has now been removed from the railway. Train services will be reinstated where possible, please check your journey.
Hooray!
Posted by plymothian at 18:42, 20th April 2026
Now there’s a new ‘railway emergency’ that has brought trains to a standstill at Burnham
This is a bridge strike at Langley.
Posted by NickB at 18:04, 20th April 2026
Posted by NickB at 16:36, 20th April 2026
Taser.
Posted by ray951 at 16:29, 20th April 2026
Due to trespassers on the railway between Reading and London Paddington fewer trains are able to run on all lines. Disruption is expected until 13:00 20/04.
Delays now until 6pm
"The person has been on the railway since the early hours, and despite Police negotiation they remain on the railway"
.............surely by now they could have been physically removed?
LNER faced a similar issue last week, reportedly someone climbed a gantry, and the resulting disruption affected train services for two days. I’m not sure what the solution is, but it seems wrong that a single individual can cause such widespread inconvenience to tens of thousands of people.
Posted by NickB at 16:11, 20th April 2026
This does seem to be rather ridiculous.
Posted by TaplowGreen at 15:04, 20th April 2026
Posted by TaplowGreen at 12:42, 20th April 2026
Posted by NickB at 07:11, 20th April 2026
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 09:00 20/04.
Posted by IndustryInsider at 11:42, 18th April 2026
You could also say, it's 'slightly less bad'.
Yes, I like that!
Posted by Chris from Nailsea at 11:33, 18th April 2026
Posted by TaplowGreen at 11:22, 18th April 2026
If it's any comfort, (as we're told above) apparently it's "definitely improving"
Yes, I think that's a fair statement...as long as you include the "Still poor" bit.
Still poor...but definitely improving.
Really, "still poor" goes without saying!
Posted by IndustryInsider at 10:39, 18th April 2026
Posted by TaplowGreen at 08:11, 18th April 2026
Surprise!!!  It’s bust again.
Definitely reaching the point of ‘nope, I won’t bother going in case I can’t come back’ that we had in 2024 (and every other year since 2020 really)
Due to a points failure between Slough and Reading fewer trains are able to run on some lines.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 22:45 17/04.
Posted by NickB at 20:14, 17th April 2026
Posted by TaplowGreen at 16:01, 17th April 2026
Culprit seems to have been the 6V50 Wembley-Merehead.
Moving again after standing for >3 hours. (passed Kintbury 16:52 and Bedwyn 20:22).
What are the barriers to achieving a rescue in less time?
Lack of spare locos and traincrew at depots
Lack of inter-operability between classes of loco
Few places where there are crossovers to enable rescue locos to reach a failed train conveniently
Lack of lay-by loops and refuge sidings where a train can be placed "out of the way"
Apart from that, all good!
Posted by Witham Bobby at 09:45, 17th April 2026
Posted by Trowres at 20:29, 16th April 2026
Posted by TaplowGreen at 18:39, 16th April 2026
Cancellations to services between Bedwyn and Newbury
Due to a broken down train between Hungerford and Pewsey the line towards Westbury is blocked. Disruption is expected until the end of the day.
Train services between Bedwyn and Newbury will be cancelled.
Posted by IndustryInsider at 10:25, 15th April 2026
Notwithstanding a bit of a dip over the last couple of weeks, it seems to have been better generally of late?
I'm hesitant in bringing statistics into the game as it's easy to make them fit whatever narrative you want, but pulling data from https://dataportal.orr.gov.uk/statistics/performance/passenger-rail-performance/table-3181a-delay-minutes-per-1-000-train-miles-total-by-network-rail-region-periodic-1/ the average delay minutes for Wales & Western per 1000 train miles works out at:
75.5 for 2023/24 (the year Sadiq chipped in)
63.5 for 2024/25
60.3 for 2025/26 (one period of data still to be added)
Interestingly, during the main Covid year it was 24.5 proving once again that all these delays are the passengers fault!
Posted by TaplowGreen at 09:45, 15th April 2026
Wasn't there to be a concerted effort from NR and contractors to fix the many long-term infrastructure issues on the Paddington the Reading main line?  What happened to that?  Failures seem to me to be as frequent as they ever were
Yep, even our esteemed Mayor Khan chipped in with his opinions on Network Rail's performance and I believe he also chipped in with some cash, but pretty much to no avail it would seem judging by recent issues......
https://www.cityam.com/network-rail-must-improve-performance-after-elizabeth-line-and-paddington-disruption-says-sadiq-khan/
Posted by Witham Bobby at 08:56, 14th April 2026
Posted by TaplowGreen at 06:46, 14th April 2026
Due to a points failure between Reading and Newbury the line is blocked.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 08:00 14/04.
Posted by TaplowGreen at 15:42, 10th April 2026
Truly dire few days on this line......
Due to a points failure between London Paddington and Reading some lines are closed.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 18:00 10/04.
A train had broken down near West Ealing Station but has now been cleared. Unfortunately there is now a points failure in the Hanwell area.
Posted by TaplowGreen at 14:31, 10th April 2026
Due to a broken down train between London Paddington and Reading fewer trains are able to run on some lines.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 16:15 10/04.
A train has broken down near West Ealing Station.
The train is blocking one of the four lines between London Paddington and Reading, so we are having to reduce the train service through the area to avoid congestion.
Posted by a-driver at 18:10, 9th April 2026
......and it continues into today......
Cancellations to services between Twyford and Slough
Due to a fault with the signalling system between Twyford and Slough fewer trains are able to run on some lines.
Train services running through these stations may be cancelled or delayed. Disruption is expected until 06:45 09/04.
Now pushed out to 1100
"The problem affects 2 of the four lines between London Paddington and Reading, so we are having to reduce the train service through the area to avoid congestion. Local stopping services between London Paddington and Newbury will only run between Reading and Newbury. Most longer distance intercity services will continue to run between London Paddington and Reading, but may be subject to delay.
We are working with Network Rail to be able to return to running our normal timetable as soon as possible".
Confirmed as cable theft.
Posted by TaplowGreen at 09:05, 9th April 2026
Posted by TaplowGreen at 06:35, 9th April 2026
Posted by ray951 at 18:53, 8th April 2026
And even more misery, must be because the weather got a bit warm today.
Due to a fault with the signalling system between Oxford and Didcot Parkway all lines will be blocked.
Impact:
Train services running through these stations will be cancelled or delayed. Disruption is expected until 20:00 08/04.
Customer Advice:
Some axle counters, part of the signalling system, have stopped working in the Oxford area. Axle counters tell the signalling system if a section of track has a train on it. If an axle counter stops working, trains need to stop at the affected signal so that the Driver can speak to the Signaller to confirm if the track ahead is clear.
All lines are blocked for 30 minutes to allow Network Rail to access the site to resolve the issue.
Posted by TaplowGreen at 13:52, 8th April 2026
Due to urgent repairs to the track between London Paddington and Reading fewer trains are able to run on some lines.
We have had a report of a defect with the track in the West Drayton area. Trains may not be able to run over the affected line until it has been inspected or may have to run at reduced speed.
......and to add to the misery......
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 16:15 08/04.
There has been a points failure in the Southall area. A points failure is a fault with the movable pieces of track that enable trains to change tracks.
There is also a defect with the track in the West Drayton area which means trains are having to run at reduced speed on one of the four lines towards London Paddington.
Posted by TaplowGreen at 05:59, 8th April 2026
Posted by Chris from Nailsea at 22:41, 5th April 2026
Person died, sadly: see https://www.london-now.co.uk/news/25996954.paddington-gwr-delays---person-hit-train-dies-swindon/
Posted by TaplowGreen at 22:24, 5th April 2026
Due to the emergency services dealing with an incident between Reading and London Paddington all lines are blocked.
A person has been struck by a train, leading to all lines being blocked. It is necessary to bring all trains in the affected area to an immediate stop.
Posted by NickB at 17:00, 3rd April 2026
.....Does the great western line have a track security problem?
The volume of graffiti, AKA criminal damage, along the railway between Paddington & Acton, indicates the answer to that question is a resounding 'Yes'.
Ah but Bob that graffiti is "art", and yet another benefit of our increasingly progressive, diverse society (....or something!)
You forgot to mention ‘vibrant’
Posted by TaplowGreen at 09:18, 3rd April 2026
Posted by Bob_Blakey at 08:06, 3rd April 2026
Posted by IndustryInsider at 20:49, 2nd April 2026
Not infrastructure per se, unless you count trackside fencing, but…
Extensive disruption this afternoon at paddington with all lines blocked due to a trespasser at Southall.
To my recollection this is the 3rd such incident in the past fortnight.  Does the great western line have a track security problem?
Lines open again now but still extensive delays until 1800 according to National Rail on one of the busiest days of the year - also affecting local Elizabeth Line services.
This sort of moronic behaviour does indeed seem to be on the rise and not just in this area - saw some footage of a couple of people practically tap dancing on the third rail last week, narrowly avoided being turned into charcoal.
Seems to have been an attempted suicide which when a driver saw the person with their head on the track, stopped their train and initiated a Railway Emergency Call to stop all other trains in the vicinity.
So the suicide was prevented…but then of course it became a trespass incident.
Mind you, general moronic behaviour as a whole is on the increase, yes.
Posted by JohnM at 17:16, 2nd April 2026
It meant the 1630 Bristol-Paddington was cancelled, then the 1700 was only 5 coaches instead of 9 - possibly twice as many people on a train half the size (plus additional holiday traffic?). I should have been on it, but decided to leave early and return to Melksham via Trowbridge, which was fine despite a scheduled 5 min change.
Posted by TaplowGreen at 16:17, 2nd April 2026
Posted by NickB at 15:17, 2nd April 2026
Posted by TaplowGreen at 19:54, 31st March 2026
Cancellations to services at Oxford
Due to a fault with the signalling system at Oxford some lines are blocked.
Train services running through this station may be cancelled, delayed by up to 30 minutes or diverted. Disruption is expected until 20:45 31/03.
Posted by TaplowGreen at 15:56, 31st March 2026
Delays to services between Hungerford and Newbury
Due to a speed restriction over defective track between Hungerford and Newbury trains have to run at reduced speed on the line towards Newbury.
Posted by TaplowGreen at 11:42, 30th March 2026
Due to a points failure between Reading and Westbury all lines are blocked. Disruption is expected until 12:15 30/03.
Train services between Reading and Newbury may be cancelled or diverted.
Posted by TaplowGreen at 08:06, 29th March 2026
Also impacting services further afield.......
Cancellations to services between Didcot Parkway and Reading
Due to engineering works not being finished on time at Didcot Parkway some lines are blocked. Disruption is expected until 09:45 29/03.
Train services between Didcot Parkway and Reading may be cancelled or delayed.
Posted by TaplowGreen at 17:22, 28th March 2026
Due to trespassers on the railway between Reading and London Paddington trains have to run at reduced speed on all lines.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 17:45 28/03.
Posted by TaplowGreen at 17:27, 26th March 2026
Alterations to services between Newbury and Reading
Due to a fault with the signalling system between Newbury and Reading the line towards Reading is disrupted.
Train services running through these stations may be delayed or diverted between Westbury and Reading.
Disruption is expected until 18:15 26/03.
Posted by TaplowGreen at 10:47, 19th March 2026
From National Rail;
Lines have reopened following an earlier fault with the signalling system at Slough. Trains between London Paddington and Reading are returning to normal but may still be delayed by up to 25 minutes.
Disruption is expected until 12:00.
Posted by TaplowGreen at 08:35, 13th March 2026
Due to a fault on a train at Hayes & Harlington trains have to run at reduced speed on some lines. Disruption is expected until 09:00 13/03.
A safety inspection of the track in the Hayes & Harlington area is causing congestion to trains in and out of London Paddington. In order to reduce delays, some train services have been taken out of the timetable this morning; specifically:
Semi fast services between London Paddington and Reading, that would call at Slough, Maidenhead and Twyford, will not run. Customers can however use their tickets on the Elizabeth Line.
Posted by bobm at 11:29, 1st March 2026
Bit more detail on Journeycheck.
The fire brigade have been responding to a fire at a train depot near London Paddington.
To allow the fire brigade to deal with the incident, power to the overhead electric wires which powers electric trains was switched off.
As a result, major disruption has occurred on this route this morning.
However, the fire has now been safely extinguished, and we are slowly starting to reintroduce the train service. However, delays and short notice cancellations should be expected as continue to restore the train service.
Posted by TaplowGreen at 11:07, 1st March 2026
Following a fire next to the track between London Paddington and Reading all lines will be reopened shortly. Disruption is expected until 11:30 01/03.
Posted by TaplowGreen at 06:10, 23rd February 2026
Due to engineering works not being finished on time between Reading and London Paddington fewer trains are able to run on all lines.
Train services running to and from these stations may be cancelled, delayed or revised. Disruption is expected until 09:00 23/02.
We have been notified that engineering works between Twyford and Maidenhead scheduled to finish at 5am this morning are not going to be completed on time.
The below listed services will be terminating and starting from Reading:
Oxford to London Paddington
Newbury to London Paddington
