Posted by grahame at 19:14, 1st March 2026
18:10 Castle Cary to Swindon due 19:34
19:43 Swindon to Westbury due 20:25
Facilities on the 21:34 Swindon to Westbury due 22:16.
Posted by grahame at 14:35, 1st March 2026
14:05 Frome to Swindon due 14:58
16:43 Frome to Swindon due 17:34
17:44 Swindon to Salisbury due 18:55
Facilities on the 17:44 Swindon to Salisbury due 18:55.
Posted by grahame at 08:17, 27th February 2026
06:35 Salisbury to Worcester Foregate Street due 09:47 will be terminated at Gloucester.
It will no longer call at Cheltenham Spa, Ashchurch For Tewkesbury, Worcester Shrub Hill and Worcester Foregate Street.
Posted by grahame at 15:50, 26th February 2026
15:15 Swindon to Westbury due 15:58
15:15 Swindon to Westbury due 15:58 will be delayed between Trowbridge and Westbury and is expected to be 10 minutes late.
Posted by TaplowGreen at 22:00, 25th February 2026
21:16 Westbury to Swindon due 21:58 has been cancelled.
Posted by grahame at 10:43, 25th February 2026
Frustrating this morning. The Gloucester-Southampton service that I catch at Melksham 06:29 to Trowbridge 06:38 left Melksham on time, but then had to wait before joining the line down from Bath outside Trowbridge due to the delayed Portsmouth Harbour service - not unusual. However after it got going again it crawled along, eventually arriving at Trowbridge just in time to wave goodbye to the 06:46 Bristol service I was supposed to be connecting with departing the other platform.
Not a disaster - the next Bristol service was 07:05. But RealtimeTrains shows the Portsmouth Harbour service left Trowbridge at 06:42, while my Southampton one departed at 06:47. That 5 minute gap seems longer than it needed to be - is it the minimum allowed between consecutive trains?
Also, at one point the National Rail app was giving estimated times at Trowbridge for both the Southampton and Portsmouth trains as 06:42. Obviously it's using a simple algorithm to calculate those times - a potential use for AI? Earlier it had also been showing the Southampton service as being in front of the delayed Portsmouth one, whereas I knew from experience we would have to wait - again, something AI would be able to work out.
I - suspect - that the Portsmouth train "has to" go first because of a lack of platforms available at Westbury at that time of the morning.  Platform 2 is occupied by the train that's about to start its day on the way to Weymouth, and Platform 3 by the Frome to Cardiff train that stops in Westbury for around 10 minutes.  Leaving only platform 1.   This morning, the two trains seem to have approached Bradford Junction at about the same time anyway.  Yes, there are limited signals between Trowbridge and Westbury - and the 5 minute headway is probably correct.
AI in the customer and industry information systems feel like AU sometimes - Automate Unintelligence, where data is extrapolated in isolation from other factors that are known.  "Hideously simplified" at times, to the extent that you and I can often do far better ...
Posted by matth1j at 10:05, 25th February 2026
Posted by grahame at 07:38, 24th February 2026
06:35 Salisbury to Worcester Foregate Street due 09:47 has been delayed at Warminster and is now 10 minutes late.
Posted by grahame at 16:38, 21st February 2026
17:35 Swindon to Westbury due 18:18
17:35 Swindon to Westbury due 18:18 will be cancelled.
Edit to add ...
Customers are advised to travel to Chippenham on the 17:46 service to Bristol Temple Meads, and change at Chippenham for road transport.
Posted by bobm at 16:38, 20th February 2026
I wonder why that reason was picked and not "waiting for a member of traincrew".
Posted by grahame at 15:51, 20th February 2026
Well sort of.   The London to Exeter St David's train which brings the conductor was 30 minutes late.   Swindon train left 13 minutes late.
Yep, standard reason for that  Swindon service to be delayed  ... or cancelled.
Posted by bobm at 12:59, 20th February 2026
Posted by grahame at 12:51, 20th February 2026
12:17 Westbury to Swindon due 12:59 has been delayed at Westbury and is now 13 minutes late.
Posted by grahame at 06:12, 19th February 2026
Facilities on the 05:11 Gloucester to Southampton Central due 08:09.
Posted by bobm at 18:28, 17th February 2026
Left on time….
Posted by grahame at 17:46, 17th February 2026
17:50 Gloucester to Salisbury due 20:06 will be starting late from Gloucester.
Posted by grahame at 17:48, 15th February 2026
18:10 Castle Cary to Swindon due 19:34 will be started from Frome.
It will no longer call at Castle Cary and Bruton.
Posted by bobm at 07:18, 11th February 2026
Left five minutes late in the end.
Real Time Trains suggests it, and earlier services, were formed of six coaches.  However it also says they used platform 2 at Swindon.  The truth is out there somewhere.
Posted by grahame at 22:24, 10th February 2026
22:31 Swindon to Westbury due 23:12 will be starting late from Swindon.
This is due to the train departing late to maintain customer connections.
Usually a sensible hold.
Posted by matth1j at 13:33, 10th February 2026
I've been called up for jury service in Swindon in April; it's about a 10 min walk from the station to the court. Just wondering whether it'll be safe to catch the 8:02 Melksham-Swindon service (scheduled arrival time 8:34), or whether to take the 7:21 (7:47)...
There's a good chance the 8:02 will be fine. But if there is a problem, it'll be very stressful, so I'll probably end up taking the 7:21 to give me a Plan B. There's a Spoons not far from the court
Posted by grahame at 06:50, 10th February 2026
07:45 Westbury to Swindon due 08:34
08:44 Swindon to Westbury due 09:26
09:46 Westbury to Swindon due 10:28
20:12 Swindon to Westbury due 20:56
Facilities on the 22:31 Swindon to Westbury due 23:12
AOK ... though there are likely to have been seats for everyone in a 2 car train even on the 07:45, 09:46, 15:15 and 17:35 which are the busiest trains.
Posted by grahame at 09:41, 9th February 2026
Reinstated by 7pm; unfortunate for would-be passengers who had already altered their plans, and for the taxi drivers who weren’t ultimately engaged to cover The Railway’s staff shortage.
Indeed ...
I can understand that there are times of uncertainty when operational and other issues add doubt as to whether a train can run ... and a difficult call to know whether to declare a problem to alert people as early as possible, or to proceed in trying to find a solution and keep mum about it until it's blindingly obvious that a train won't run / will skip stops, etc.
As a passenger, I stand by my wish that it wasn't just a "red/green" system but a "red/amber/green" system of information such that yesterday's might have flagged up as amber - "we may have to run buses / taxis in place of this train" rather than "this train is cancelled" - at least earlier in the day until it's known which way it's going.
I should add that we are seeing fewer cancellations as a whole on Swindon <-> Westbury services this year, bringing us much more into line - measured on percentage of trains cancelled - with other stations in the region.  Thank You to those who have helped with this - it makes the service much more attractive, marketable, growable - and analysis suggests that across Wiltshire the two current stations where there are latent opportunities are Melksham and Dilton Marsh.    Being able to rely on a service is key ... though I would point out that having a booked passenger service at all at roughly the right time is even more important to its use that the occasional cancellation.
Posted by brooklea at 08:43, 9th February 2026
Posted by grahame at 20:35, 8th February 2026
19:43 Swindon to Westbury due 20:25 has been delayed at Swindon and is now 5 minutes late.
Posted by grahame at 16:04, 8th February 2026
Posted by Mark A at 20:31, 5th February 2026
The absolute *joy* of waiting at Kemble in the 80s, when the single track section to Swindon would tend to provoke fun and games.
But also the *joy* after walking four miles to the station in the '82 snow and within a day or five of the thermometer hitting minus 18C up there, when it was necessary to leave the lane as that was choked to hedgerow-depth with snow, and make ones way through the fields alongside - to Kemble Station, and in swept the London-bound HST from the Sapperton direction, with a decent collection of sticky snow on the front end and also between the carriages, passengers... ok, me...  once aboard, rocking up to the buffet for something to thaw them out.
Posted by grahame at 17:51, 5th February 2026
17:35 Swindon to Westbury due 18:19 will be starting late from Swindon.
9 minutes late off Swindon (17:44), maintaining connection from the 16:33 Paddington to Cheltenham Spa train.   Had it set off on time at 17:35, it would have got in the way of the Bristol and Taunton train due to leave Swindon at 17:22, but didn't leave today until 17:36.   The delay looks like a sensible call.
Posted by Chris from Nailsea at 15:05, 5th February 2026
I, too, was caught up in the knock-on effects of that earlier failure of a train this morning, somewhere around Stroud apparently.
My own train towards home, from Kemble to Swindon, was initially reported as 'cancelled', then 'reinstated but 11 minutes late'.  I arrived at Kemble station, where to add insult to injury the booking office and waiting room were closed all day 'due to staffing issues'. There were many passengers, effectively out in the open, conferring about the delay to their arrival in London - a few of which, I overheard, were time-critical, for business meeting reasons, for example.
The information boards and announcements were then updated fairly frequently, with the delay increasing steadily from 11 minutes to, eventually, 29 minutes.
The other two trains involved in my journey home (Swindon to Temple Meads and Temple Meads to Nailsea) were spot on time throughout.
Posted by Mark A at 10:28, 5th February 2026
That is... really very poor. Sorry that people including you were on the receiving end of it.
Posted by grahame at 08:59, 5th February 2026
06:35 Salisbury to Worcester Foregate Street due 09:47 was terminated at Swindon.
It will no longer call at Kemble, Stroud, Stonehouse, Gloucester, Cheltenham Spa, Ashchurch For Tewkesbury, Worcester Shrub Hill and Worcester Foregate Street.
Posted by grahame at 08:58, 5th February 2026
What the lack of services means to an evening meeting in Trowbridge
From home at 16:05 ... at ASDA, Trowbridge, 16:55 - 50 minute journey for 17:00 meeting (bus)
The plan was 20:00 start homeward, 20:12 train, 20:22 Melksham Station, 20:50 home.
But turned into ... 19:00 from ASDA ... home at 22:20 - 200 minute journey.
We finished in good time, and I was quite happy to sit and do various writing up and things on my laptop in the "Rose end Crown" up to 20:00.  But - from "on time" the train switched to "Delayed" and eventually to 21:12 - a 60 minute delay.  At 21:12, it switched to being a few minutes later than that, the 21:25, and then it went "Cancelled".  And at 21:25, 165101 went through without stopping - I suspected it was the delayed 20:12, moving the empty train back up to Gloucester - turned out to be in service, but skipping all intermediate stations except Swindon.
The 21:22 - next train as far as Swindon - was shown as "on time", then 21:26, then 21:30. And it arrived and left at that time - 8 minutes late. It came to a halt just to the north of Trowbridge - waiting at a red signal - and we eventually go to Melksham Station at 21:45 - 13 minutes late.  Would have been home at 22:05, but stopped to get a takeaway for Lisa and me and that added time - far too late to start cooking at home.
Information at Trowbridge - appalling. Departure board "Delayed" not informative.  Impossible suggestions being made about 2 trains within a minute of each other which was clearly not able to happen. Announcemnets advising people to wait for the "next fastest train" which, however, was (yet) shown as delayed but was very cleraly going to be.   Help point when I asked about alternatives to get to Melksham offered to give me the travelline phone number to call about buses.  Train manager dispatched train at Trowbridge and disappeared into rear cab, not seen again until door opened at Melksham.  No other rail staff seen the whole evening.
Lisa suggested I was too principled sticking it out and should have looked for a taxi, though they can be sparse in the evening in Trowbridge. and with others waiting too, and five of us off the train eventually at Melksham, that might of been an idea.  It was not offered by the help point person, nor were there any indications of the train running screen or in announcements to help / mask that suggestion..  At one point I was considering D1 bus to Bath and 273 bus to Melksham with a midnight arrival home!
Posted by grahame at 07:19, 5th February 2026
Chaos this evening ...  WWRUG Committee meeting finished around 19:15 in Trowbridge and I have just got home at 22:30.       Particularly galling to see trains going through Trowbridge without stopping ... the young lady waiting for the 20:12 there and headed home to Stroud will still not be there.
I have updated my "logging" page to strike through trains that are supposed to stop at Melksham, but run through without calling.  From a passenger viewpoint, I consider them to be cancellations.
Posted by grahame at 22:40, 4th February 2026
20:06 Westbury to Cheltenham Spa due 22:06 will no longer call at Trowbridge, Melksham, Chippenham, Kemble, Stroud and Stonehouse.
It has been delayed at Westbury and is now 75 minutes late.
Posted by TaplowGreen at 22:24, 4th February 2026
Posted by grahame at 19:40, 4th February 2026
17:50 Gloucester to Salisbury due 20:06 will be terminated at Warminster.
It will no longer call at Salisbury.
It is being delayed at Swindon.
Posted by TaplowGreen at 13:18, 31st January 2026
12:17 Westbury to Swindon due 13:01
12:17 Westbury to Swindon due 13:01 has been delayed at Chippenham and is now 18 minutes late.
This is due to passengers causing a disturbance on a train earlier today.
13:13 Swindon to Westbury due 13:55
13:13 Swindon to Westbury due 13:55 will no longer call at Melksham and Trowbridge.
Posted by grahame at 19:53, 30th January 2026
20:06 Westbury to Cheltenham Spa due 22:06 will be starting late from Westbury and is expected to be 20 minutes late.
Will be formed of 9 coaches instead of 3 to Swindon.
Wow!
Not sure of that ...
20 minutes late confirmed - 3 carriages will be plenty, but I like the idea of an IET that terminates at Westbury and normally runs empty to Stoke Gifford running via Swindon and standing in for s broken local train.   Sounds sensible.
How are they going to have a train calling at Melksham at 20:39 southbound then one at 20:41 northbound - I suspect the AI part of the system is AU (Artificial Unintelligence)
Posted by grahame at 19:35, 30th January 2026
Wow!
Posted by grahame at 18:03, 30th January 2026
17:50 Gloucester to Salisbury due 20:06 has been cancelled.
Last Updated:30/01/2026 17:54
Posted by grahame at 09:59, 29th January 2026
19 minutes late from Melksham ....
And made up ...
11 minutes late from Swindon
1 minute late from Gloucester
3 minutes early into Worcester Shrub Hill where it sat for 16 minutes
on time into Worcester Foregate Street
... an interesting example with slack in the timing of this train.
Posted by grahame at 08:57, 29th January 2026
06:35 Salisbury to Worcester Foregate Street due 09:47 will be started from Westbury.
It will be delayed at Westbury.
19 minutes late from Melksham .... no chance of a quick change at Chippenham for Bristol today then ...
Posted by grahame at 07:31, 27th January 2026
05:11 Gloucester to Southampton Central due 08:09 is being delayed at Gloucester.
Last Updated:27/01/2026 05:13
Stilll showing at 07:30 ... it was 1 minute late off Gloucester.   Mountain out of what turned out to be a molehill.
Posted by bobm at 20:45, 26th January 2026
The Leeds train, incidentally, left 26 minutes late but surpisingly left New St on time. No idea what held it up for so long at Temple Meads.
Official reason was "overcrowding/not enough wheelchair spaces".
Posted by grahame at 19:06, 26th January 2026
Might be very useful to you in terms of charting performance/timings over an extended period?
Please don't encourage him, IndustryInsider.
I am rather suspecting that performance records stretching back to the last decade would set me off on a tangent I can do without.
Posted by Red Squirrel at 16:43, 26th January 2026
Not 100% a propos, but I was amused last evening when I got on the 18.46 from Temple Meads to Montpelier.
This train - and you will see the tenuous connection to the topic, -  is often cancelled when I try to catch it due to lack of crew. I had come off the Plymouth - Leeds train on Platform 3, so it should have been a simple matter of stay put while the Leeds train shuffles off, and catch the Severn Beach train from the same platform. The minutes ticked by, ramps were obtained, a chap in a wheelchair got off and then the ramp was installed in a door at the other end of the train. Then, suddenly! Nothing happened. People shrugged. Someone cleared his throat. No-one went and no-one came. And then, over the wheezing rattle of the Vogager, the inevitable platform change was announced. So I joined the crowd hotfooting it to Platform 7, and just a few minutes later we were on our way.
The odd bit was the conductor's announcement. He apologised for the confusion. I thought he was going to explain why the Leeds train had delayed us and led to a platform change. What he actually told us was that our train had been cancelled and then uncancelled because he had been reallocated to another train but then another guard had come in on a later, delayed train thus allowing him to work our train. So that puts us in our place then!
Posted by Chris from Nailsea at 14:52, 26th January 2026
Posted by IndustryInsider at 14:19, 26th January 2026
A year ago, yes, it was 07:34 departure from Chippenham in the public timetable, with the 07:31 departure to Worcester unchanged and I would assume (data no longer easily to hand) that the arrival from Salisbury was at 07:30.  So 4 minutes has indeed become 3.
A realtimetrains+ subscription gives you the option to search back 5 years (or right back to 2012 with the 'Extended History' upgrade).
Posted by grahame at 10:32, 26th January 2026
I am delighted that the 07:21 in the mornings has consistently been on time, so (Thingley Junction traffic allowing) will allow a good connection into Bristol.
I wish you hadn't said that - I'm going to be testing it out later...
BTW the (unofficial) connection at Chippenham is even tighter than it used to be, isn't it? Has the Paddington Weston-super-Mare service crept forward a minute?
07:30 - 07:31 Salisbury to Worcester train calls at Chippenham
07:31 - 07:33 London to Weston-super-mare train calls at Chippenham
I am - disappointed - that this has just slipped in, bearing in mind requests to move it to 07:35 as GWR have been known to do for their own convenience when engineering works have been taking place. At the least, I would have hoped to have received a notification of changes as has happened with so many changes in the past.  However, the GWR team could be characterised at present by being operational rather than customer responsive. Ask passengers who used to finish work at Salisbury at the end of a conventional 9-to-5 day and catch the 17:42 home to Dilton Marsh, and suddenly found on 15th December that the train that had called at Dilton Marsh was now running empty, and their alternative didn't leave Salisbury until 19:13.
Conversations are being had, but in reality the passengers and the regulators are pretty toothless.  There are times that changes make sense and occasionally that will inconvenience some people - we have accepted a number of such changes in the past - but at present changes are being put in more, it seems, with a view to improving performance stats than to serving the customer.   Frustrating, as there are ways of doing both at the same time.
Posted by matth1j at 06:10, 26th January 2026
Posted by grahame at 15:56, 25th January 2026
A good week - how it should be, and here's hoping it can continue like this.
The late running by a few minutes of the final train of the day is encouraged and expected, as it's scheduled as a 5 minute connection off the express from London and little delays to connect make it work.  I was on this train last Tuesday, and a noticeable number of people joined us off the London to Cheltenham Spa express before we set off from Swindon.    And there are no onward connections at Trowbridge or Westbury that are compromised by a few minutes late running, so it's AOK on this train.
Posted by grahame at 20:36, 23rd January 2026
20:06 Westbury to Cheltenham Spa due 22:06 has been cancelled.
Posted by grahame at 17:22, 23rd January 2026
Posted by grahame at 16:16, 19th January 2026
Reporting systems for Melksham are from equipment a little way from the station; whilst we have had occasions where a train has left early, in practise most train manager and drivers do wait until the due time; the lines showing early departures above are in most cases accounted for by a train that's ready to leave early, but in fact hung around.
For those trains fitted with working GPS, the reports should be totally accurate.  For those that don't it does rely upon a guesstimate from when the train passes the previous signal berth at the junction either end - usually pretty accurate, but not so if there's a delay at the station or a long speed restriction etc.
Interesting.  I can be at Melksham Station and it tells me my train has arrived when it hasn't!
Posted by IndustryInsider at 15:58, 19th January 2026
Posted by grahame at 11:03, 18th January 2026
Here's a clearer table  ... removing the pedantic detail for trains that are virtually on time
Posted by grahame at 10:50, 18th January 2026
To help quantify / analyse the issues in particular for passengers who are departing and arriving at Melksham Station, I am recording the logged performance of each train timetabled to call at present, from industry feeds.
I have taken the delay/repay cutoffs of 15 and 30 minutes as my colour change points, with an extra short "within 2 minutes" note in particular to watch the 07:21 train which has a tight unofficial connection at Chippenham for Bristol Temple Meads.
Northbound and Southbound are separate reports - this is an analysis for customers and if someone's headed for Westbury, the next train isn't much use to them if it's going to Swindon.
Posted by grahame at 07:27, 16th January 2026
06:35 Salisbury to Worcester Foregate Street due 09:47 is being delayed between Salisbury and Warminster and is now expected to be 18 minutes late.
Posted by matth1j at 06:34, 15th January 2026
Just buying my ticket for tomorrow morning's Melksham-Bristol commute, and spotted that what is usually the 06:29 Melksham-Trowbridge is scheduled for 06:31 (it was 06:29 on Monday). Anyone know why?
Same again this morning, although it arrived at 06:27. It's also scheduled for 06:31 tomorrow, but back to normal on Monday.
Posted by grahame at 19:43, 14th January 2026
From the Wiltshire Times
GWR trains cancelled in Wiltshire amid travel chaos
A freight train has broken down at Melksham, blocking the line between Swindon and Westbury and forcing GWR to cancel services between the two towns.
Disruption on the line is expected until at least midday on Wednesday, January 14, with customers being advised to take alternative routes during that time.
This comes after a train broke down on the line between Westbury and Reading on Wednesday morning.
Posted by grahame at 10:22, 14th January 2026
Due to a broken down train at Melksham the line is blocked. Disruption is expected until 12:00 14/01.
Train services between Swindon and Westbury via Melksham will be cancelled.
A freight train has broken down on the line between Westbury and Swindon; as a result we are unable to operate our service.
Oops
11:05 Swindon to Westbury due 11:47
11:05 Swindon to Westbury due 11:47 will be cancelled.
Last Updated:14/01/2026 09:30
"we are unable to operate our service".  With no suggestion about what customers - that first one (the 10:02 at Melksham) is the busiest northbound of the day - should do.    This is where a volunteer presence at the station would be so helpful ... but that is a subject for a fresh thread.
Posted by TaplowGreen at 10:18, 14th January 2026
Posted by Andy E at 10:10, 14th January 2026
Looks like chaos on the Trans Wilts this morning. A failed freight near Kintbury on the Berks and Hants has meant that up West Country trains have been diverted over the Trans Wilts. Now though it looks as though infrastructure train 6M50 has failed somewhere south of Melksham blocking that line. 1A73 and 1J74 up passenger trains from the West Country have diverted from Westbury up to Bath/Bathampton Junction and reversed there to continue to London.
Posted by bobm at 08:36, 14th January 2026
A bit of both - but the end result is the same.
The 07:45 is normally formed from an incoming service from Bristol Parkway.   This morning that train started from Temple Meads and arrived at Westbury 14 minutes late at 07:43.   For some reason the decision was taken not to run the TransWilts service, even with a late start.
Posted by grahame at 07:54, 14th January 2026
And now ...
08:44 Swindon to Westbury due 09:26 will be cancelled.
of if you prefer ...
This service is cancelled.
This service was cancelled due to late arrival of an inbound service (YI).
Posted by grahame at 07:52, 14th January 2026
And now ...
Posted by grahame at 07:42, 14th January 2026
Well an IET just passed through towards Chippenham (at 06:28), might be related...
Don't think 06:31 is likely
The IET was 1K71 - the 05:10 Bristol Temple Meads to Paddington that usually calls at Kennet Valley stations.  Got to Westbury on time (actually a couple of minutes early at 05:48, but say there until 06:14 and left headed back (16 minutes late) up whence it came, passing Bradford Junction ar 06:22 for the second time and headed, though untracked on my system, via Chippenham and Swindon - it has appeared on the trackers again at 07:28 - 21 minutes late - into Reading.
Oh for increased capacity, Bradford Junction to Thingley Junction.
Posted by grahame at 07:17, 14th January 2026
This could be why an unexpected IET was around and delayed the [06:29/06:31].    That won't account for the scheduled change to 06:31 today ...
Cancellations to services between Reading and Westbury
Due to a broken down train between Reading and Westbury all lines are blocked.
Train services running to and from these stations may be cancelled, delayed or diverted. Disruption is expected until 08:30 14/01.
Due to a broken down train at Kintbury, all lines between Reading and Westbury is currently blocked.
Our local Newbury to Bedwyn service is also suspended until further notice.
Where possible, long distance services will divert.
Posted by matth1j at 06:56, 14th January 2026
Actually the 06:46 is delayed, showing as 07:01. But that's probably going to be busier than usual, might wait for the 07:05 anyway.
Posted by matth1j at 06:45, 14th January 2026
Departed Melksham at 06:43 - will miss the 06:46 Trowbridge-Bristol, but at least the 07:05 has 3 carriages
Posted by matth1j at 06:33, 14th January 2026
Posted by grahame at 22:26, 13th January 2026
There is a 2 minute "Pathing Allowance" at Thingley Junction - a "special" tomorrow; I looked at Wednesday next week and it's back to normal.  Nothing showing on Real Time Trains to need that allowance though.
Posted by matth1j at 22:14, 13th January 2026
Posted by grahame at 05:58, 13th January 2026
Will be formed of 3 coaches instead of 2 from Westbury.
Posted by grahame at 20:03, 12th January 2026
Posted by grahame at 08:07, 12th January 2026
06:35 Salisbury to Worcester Foregate Street due 09:47 is being delayed at Salisbury.
Is it just me or... or are the old crocks put on our line?   Feels like that sometimes!
Congratulations to the crew for getting it running just 10 minutes late.   The above message still being issued three quarters of an hour after the train had left Salisbury - even though it implies it's still there - and it still suggests it's stuck at Salisbury at 08:07 as I write.
Posted by grahame at 07:29, 12th January 2026
Posted by grahame at 17:49, 11th January 2026
16:53 Frome to Chippenham due 17:30
16:53 Frome to Chippenham due 17:30 is being delayed at Westbury and is now expected to be 25 minutes late.
And there was a false alarm cancellation on this one ...
17:59 Chippenham to Salisbury due 18:55
17:59 Chippenham to Salisbury due 18:55 will now run as scheduled.
Last Updated:11/01/2026 17:41
Posted by grahame at 17:14, 11th January 2026
13:54 Chippenham to Weymouth due 15:45
13:54 Chippenham to Weymouth due 15:45 will no longer call at Frome.
This is due to a short-notice change to the timetable.
... which means ... exactly what, GWR ?
Your text is just random words, selected from the Oxford Dictionary.
It's a piece of text that's used when a "whoopsie" is found in the temporary timetable around engineering.
In this case, 5M11 ECS arrived as normal at Frome at 13:43.  It normally sets off at 14:05 for Swindon, clearing in good time for the 14:28 call of the (Swindon, but today Chippenham) to Weymouth train.  However, the trains from Frome can't go as far as Swindon today - only to Chippenham - and so it didn't leave until 14:38.    Frome has just one platform ...
Posted by ChrisB at 17:03, 11th January 2026
Today, we have removed the Frome stop from this service.
Posted by Chris from Nailsea at 16:54, 11th January 2026
Posted by grahame at 14:11, 11th January 2026
Posted by grahame at 08:40, 10th January 2026
07:45 Westbury to Chippenham due 08:11
07:45 Westbury to Chippenham due 08:11 will be cancelled.
Last Updated:10/01/2026 07:05
Here is that same train 4 weeks ago - 14th December.  At that date, it was running to both Chippenham and Swindon.  For today, it had been cut back to Chippenham because of planned engineering, and then less than an hour before it was due, it was cancelled.
Image © 2026 by Graham Ellis is licensed under CC BY-NC-ND 4.0. I am taking this opportunity to post / remind readers of the copyright on my photographs shared / used on the Coffee Shop - it's been a recent subject of discussion (here) and it's worthy of occasional reminder.
Posted by grahame at 07:49, 10th January 2026
08:44 Chippenham to Westbury due 09:19
08:44 Chippenham to Westbury due 09:19 will be cancelled.
Last Updated:10/01/2026 07:20
Posted by grahame at 07:41, 9th January 2026
With Storm Goretti ranging, it's amazing that the only change on trains that run via the Westbury - Swindon line is:
06:35 Salisbury to Worcester Foregate Street due 09:47 will be terminated at Worcester Shrub Hill.
It will no longer call at Worcester Foregate Street.
This is due to severe weather.
To some extent, a technical report as far as the TransWilts is concerned - through passengers from South of Swindon to Foregate Street are few and far between, and the 12 minute scheduled wait at Shrub Hill on this train means that it's not attractive anyway.
Posted by matth1j at 10:10, 6th January 2026
A bit OTT but the central waiting room at Chippenham was flippin cold yesterday evening while waiting for the 1735 Swindon-Westbury. I can understand the heating having trouble keeping it warm in sub-zero temperatures, but the blowers weren't even blowing - something was broken. I reported it to the staff on the main exit barrier (across the bridge) who said they would investigate.
Posted by grahame at 08:45, 6th January 2026
07:45 Westbury to Swindon due 08:34 has been delayed at Westbury and is now 10 minutes late.
In amongst all the other - chaos - on GWR this is minor
Posted by Trowres at 22:10, 2nd January 2026
Transwilts to the rescue!
22:31 Swindon to Westbury due 23:16 will be cancelled.
Posted by Timmer at 17:15, 2nd January 2026
I suspect the 16.23 to Swindon, a 2 car 158, was rather cozy as it would have had passengers off 13.55 Paignton to London. This train terminated at Westbury because of the track issue between Westbury and Pewsey. See:
https://www.firstgreatwestern.info/coffeeshop/index.php?topic=31378.msg370461#new
Posted by ChrisB at 15:46, 2nd January 2026
I guess that drivers are able to volunteer to do that - as long as their mileage claim to the TOC isn't fraudulent - but the way you posed the question Mark A - it read as though you thought there was a duty on the driver if you so asked? There definitely isn't.
Posted by Mark A at 14:09, 2nd January 2026
Yes, near-midnight Yorkshire taxi person on a railway contract working on a dirty night took me to the door rather than to the... awkwardly situated station some distance from the village.
Posted by matth1j at 13:59, 2nd January 2026
Is that a taxi dropping its sole occupant down at the station rather than at their preferred destination?
They are averse to letting you off early
On the Chippenham-Melksham route they've been kind enough to drop me off at the bottom of Westlands Lane a couple of times (home is in Whitley). Once I was the only passenger so it potentially saved them about 2 x 1.5-2 miles of driving, but there was a couple of us on the most recent occasion.
Posted by grahame at 13:28, 2nd January 2026
Errr......your ticket is to the *station* - not your 'preferred destination'. Taxi drivers are usually required to meter to the station & won't be paid any additional mileage incurred - so don't be surprised if your taxi will only go to the station. This is definitely the case when carrying more than 1 passenger - each passenger can not insist that they are dropped at their 'preferred destination' - but at the station concerned.
I would agree with that.  And in this case he had to do a drop off and perhaps a pick up too.   They are averse to letting you off early - "you're driving past the end of my street - can I get off here?" either - but then so are buses, and have you ever asked a train not due to call at Dilton Marsh to make a stop there, even if the local train that should call is cancelled?
Posted by grahame at 13:25, 2nd January 2026
Posted by ChrisB at 11:16, 2nd January 2026
Posted by grahame at 07:25, 2nd January 2026
Here is a summary of yesterday:
1 planned cancellation because (?) it was a public holiday
2 cancellations described as "staff shortage"
6 cancellations described as "fault on this train"
9 services ran
50% cancellation rate
Of note from personal experience
* the 13 minute delay to the 07:21 (2M81) was due to 6M50 (Westbury to Bescot) which passed through Melksham at 07:09 (35 minutes early - it was due at 07:43) but then got held on the single line approaching Thingley, blocking 2M81 on the line approaching Bradford Junction.   At the time the train was due, the display on the platform at Melksham said:
* I was returning to Melksham on 2M30, and arrived into Chippehnam from Bristol (separate story) at 17:34.  I knew to go over to the gateline and ask staff for help.   The announcement system was advising people that the train was cancelled and "The next fastest train will be the 19:00 to Salisbury" - correct advice, but not telling people who didn't want to wait for nearly an hour and a half that they could seek further assistance if they did not want to wait for the train.
Capacity was also limited between Bristol and Bath yesterday afternoon, with single line working on one line while a safety check was made.  Altenate London <-> Bristol trains routed via Bristol Parkway, and just one an hour not 3 running from Westbury to Bristol. One has to wonder as a passenger why one of the trains stuck at Westbury could not have been used in place of the faulty one on the Swindon service.  My taxi driver from Chippehnam was metering his run, and GWR will be invoiced just shy of £45 - not a cheap ride at Bank Holiday rates!
Final thought - why when a train is cancelled does it say "Calling at" on the boards - the whole point is that it is NOT calling at and really it should say "not calling as planned at" should it not?
Posted by grahame at 04:08, 2nd January 2026
No - that is a taxi dropping three occupants at the station.   On the cusp of a delay-repay claim - 15 minutes late. The taxi was also charged with picking any passenger from Melksham to Trowbridge, so there was logic in him going there. Fuller reports to follow - a very interesting "state of the nation" set of learning journeys!
Posted by Mark A at 22:19, 1st January 2026
Posted by grahame at 20:49, 1st January 2026
A ... wonderful day ...
... four bus journeys, and supposed to be four journeys by train but one turned into this ...
Posted by TaplowGreen at 20:20, 1st January 2026
Posted by grahame at 17:02, 1st January 2026
and
Last Updated:01/01/2026 16:15
No alternative offered
