| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by broadgage at 10:39, 14th May 2026 | ![]() ![]() ![]() |
With the current sleeper stock nearing the end of a refurbishment programme I doubt they would want to start re-wiring them at this point.
Surely it is not beyond the wit of man to produce a conversion lead to convert the electrical supply wiring from an HST power car to that at the other end to match the electrical supply wiring from a class 57.
I am old enough to remember when "square" pin plugs were introduced. My dad produced conversion leads with a round pin plug at one end and a "square" plug at the other when we moved from a council prefab to a new house.
I hope that you mean "a square pin plug at one end and round pin SOCKET at the other end" or possibly the other way around. A lead with a PLUG at each end is very dangerous and known with good reason as a suicide lead.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 06:23, 7th May 2026 | ![]() ![]() ![]() |
......and again tonight......
23:45 London Paddington to Penzance due 07:55
Will be formed of 5 coaches instead of 8.
Due to a train fault we are unable to operate this evenings Sleeper service between London Paddington and Penzance.
We have arranged for this service to be operated by one of our regular Intercity Express Trains which will offer a Standard and First Class seating service only.
Not many more months and GWR will be back under public ownership and I reckon thr government will get its way and scrap the sleeper service.
You have to remember it’s FirstGroup paying out of its own pocket to keep it going.
I believe both the Up & Down "sleepers" were IETs last night.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by a-driver at 23:00, 6th May 2026 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by Clan Line at 19:02, 6th May 2026 | ![]() ![]() ![]() |
https://www.youtube.com/watch?v=ftmcFzAwkqU
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 16:46, 6th May 2026 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by bobm at 21:42, 5th May 2026 | ![]() ![]() ![]() |
Given the scarcity of 57s, if they are sending one to Highbridge there won’t be one available to couple to the back of the up sleeper to bring it back to Reading Traincare Depot from London Paddington. Hence why it is terminating at Reading.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by a-driver at 21:29, 5th May 2026 | ![]() ![]() ![]() |
The failed sleeper from last night has now failed on its way up to Reading. Currently dumped in Highbridge loop.
Tonight’s down sleeper likely to be cancelled.
23:45 London Paddington to Penzance due 07:55 will be cancelled.
This is due to a shortage of trains because of extra safety inspections.
Due to a unit failure we are unable to operate this evenings Sleeper service between London Paddington and Penzance.
We have arranged for this service to be operated by one of our regular Intercity Express Trains which will offer a Standard and First Class seating service only. There will be no accommodation facilities.
And a rude awakening for those on the Up sleeper tonight.....
21:45 Penzance to London Paddington due 05:09
21:45 Penzance to London Paddington due 05:09 will be terminated at Reading.
It will no longer call at London Paddington.
A shortage of train crew….. or a shortage of a 57 to work it from Reading to Paddington.
I believe they are planning to send a 57 light engine from Reading to Highbridge in the early hours of the morning and triple head the failed sleeper set back to Long Rock via Bristol TM.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 17:17, 5th May 2026 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 16:34, 5th May 2026 | ![]() ![]() ![]() |
Trigger's broom strikes again!
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by a-driver at 15:54, 5th May 2026 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by grahame at 07:38, 5th May 2026 | ![]() ![]() ![]() |
Reading elsewhere that the "Up" sleeper broke down last night and was replaced by a 5 car IET?
Believe so .... here's where the IET has come from
05:03 Penzance to London Paddington due 09:54
05:03 Penzance to London Paddington due 09:54 will be started from Plymouth.
It will no longer call at Penzance, Redruth, Truro, St Austell, Bodmin Parkway, Liskeard and Saltash.
This is due to a fault on a train.
Will be formed of 5 coaches instead of 10.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 07:06, 5th May 2026 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by PhilWakely at 23:29, 21st April 2026 | ![]() ![]() ![]() |
An interesting article in RAIL Magazine regarding Rail Operations Group Class 93's contains a paragraph regarding the Night Riviera.....
Apologies if the whole article is behind a paywall.....
: RAIL Magazine
ROG also confirmed that tentative talks have been held with Great Western Railway, with a view to testing the Class 93s on the ‘Night Riviera’ Sleeper between Paddington and Penzance.
However, given this would need two locomotives which would have to run off the 1,070hp of battery and 1,205hp of diesel power west of Wootton Bassett or Bristol Parkway, as well as being expected to lift the seven- or eight-coach trains over Dainton, Rattery and Hemerdon banks, it’s hard to see how a ‘93’ could be a realistic cost-effective alternative to the Class 57/6s.
I understand that ROG also wants the test to include a couple of runs Up and Down The Mule between Exeter and Castle Cary as the bank between Exeter St David's and Exeter Central would provide a major test for a pair of 93's (Here's hoping for a wet night!).
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by grahame at 11:54, 23rd March 2026 | ![]() ![]() ![]() |
Shock, horror
- 9 minutes late into Penzance - 08:04 versus 07:55. All that remains is for anyone who's told their lift to pick them up at the JourneyCheck expected time of 08:54 to twiddle their thumbs for 50 minutes.
- 9 minutes late into Penzance - 08:04 versus 07:55. All that remains is for anyone who's told their lift to pick them up at the JourneyCheck expected time of 08:54 to twiddle their thumbs for 50 minutes.Do you think that perhaps, assuming a reasonable amount of common sense (risky I know), that someone on the train in question expecting to be picked up would ring ahead and confirm any revised arrival time, especially given yesterday's events at Newton Abbot?
You give Jo Public a great deal of credit ... we are informed here on the Coffee Shop, but remember that the rail systems tell people that ballast is "stones on the track" and points are things which "allow the movement of trains from one line to another".
Friends coming the the WWRUG meeting last Wednesday, with successive trains 110 minutes late, cancelled, and 55 minutes late kept me message / informed. However, the are well informed ... and there are two sides to the story and I was so busy with meeting setup that there was a distinct delay in me hearing.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 11:21, 23rd March 2026 | ![]() ![]() ![]() |
Shock, horror
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by bobm at 09:23, 23rd March 2026 | ![]() ![]() ![]() |
There was a time in the not too distant past when the Monday morning sleeper arrived in Penzance an hour later than the other days.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by grahame at 08:12, 23rd March 2026 | ![]() ![]() ![]() |
Shock, horror
- 9 minutes late into Penzance - 08:04 versus 07:55. All that remains is for anyone who's told their lift to pick them up at the JourneyCheck expected time of 08:54 to twiddle their thumbs for 50 minutes.| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by bobm at 07:51, 23rd March 2026 | ![]() ![]() ![]() |
Looks like with the late start it may have been forced to go around scheduled engineering work.
After Reading it took the Berks & Hants as far as Westbury before going up the Avon Valley to rejoin its booked route at Bath Spa.
Thanks to the generous layover at Exeter St David’s it was all but on time going forward.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by grahame at 06:40, 23rd March 2026 | ![]() ![]() ![]() |
23:50 London Paddington to Penzance due 07:55
22/03/26 23:50 London Paddington to Penzance due 07:55 will be diverted between Reading and Exeter St Davids.
It has been delayed at London Paddington and is now 59 minutes late.
This is due to train crew being delayed.
Probably due to the closure due to a fire on a train between Totnes and Newton Abbot last night.
It's interesting to compare what the official "JourneyCheck" and Real Time Trains are telling me now - at about 06:30 - as to how this train is doing.
A good example of how some of the AI systems spew out - err - false suggestions. Even at 2 O'Clock this morning, it might have been a good bet to suggest that the train would make up most of the delay. As the sleeper is set down only once it gets west, JourneyCheck is not in this instance going to mislead people into missing their train, but it might mean that someone getting off the train in Liskeard and being picked up by taxis finds they have nearly an hour to wait if the taxi has looked at this information feed.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by grahame at 08:20, 17th March 2026 | ![]() ![]() ![]() |
21:45 Penzance to London Paddington due 05:04
16/03/26 21:45 Penzance to London Paddington due 05:04 will be diverted between Taunton and Reading.
It is being delayed between Taunton and Reading and is now expected to be 110 minutes late.
This is due to an obstruction on the track
Trowbridge at 02:29 on time.
No report at Melksham.
Chippenham at 04:39, 110 minutes late.
Paddington arrival 06:35, 90 minutes late.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 06:48, 17th March 2026 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by bobm at 14:17, 14th February 2026 | ![]() ![]() ![]() |
Part of the apparent discrepancy may be down to a change of route. After leaving Taunton it was scheduled to go via Box and Swindon but instead went up the Berks & Hants line.
When it passed Cogload Junction it was 194 minutes late. By the time it got back on route west of Reading it had reigned that in to 157 minutes late.
As the service was replaced by a five car IET at Taunton, it also saved 20 minutes with the Reading stop as it didn't pause to attach the second loco to the rear.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 11:24, 14th February 2026 | ![]() ![]() ![]() |
I hope that they were all l;eft in their cabins until the IET was ready & waiting at TAU?
A rude awakening indeed!
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by ChrisB at 10:47, 14th February 2026 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by Andy E at 10:27, 14th February 2026 | ![]() ![]() ![]() |
It seems that the train was declared a failure at Taunton where it had arrived at 01.38. An 802 IET was sent from Exeter to continue the service leaving Taunton at 05.05.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by ChrisB at 09:36, 14th February 2026 | ![]() ![]() ![]() |
21:45 Penzance to London Paddington due 05:07
13/02/26 21:45 Penzance to London Paddington due 05:07 is being delayed at Taunton and is now expected to be 200 minutes late.
Goodness - how the information system is so wonderful at getting it wrong. Due into Paddington at 05:07, actually in at 07:04 - only 117 late
That's a result of timing the run at a sedate pace to allow sleep. Of course, once late, the train can & does go faster & catch up.
I'm sure it was 200 late when that warning was posted - why would it not be?
Lumo even post that their delays can be caught up further down/up the line.....
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 08:35, 14th February 2026 | ![]() ![]() ![]() |
Goodness - how the information system is so wonderful at getting it wrong. Due into Paddington at 05:07, actually in at 07:04 - only 117 late - and for many passengers, I suspect that's a far better arrival time anyway. And - question - how does delay/repay work with the sleeper - fare, berth fees, ...
"Only" 2 hours late
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by grahame at 08:31, 14th February 2026 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 08:13, 14th February 2026 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by Chris from Nailsea at 21:22, 29th January 2026 | ![]() ![]() ![]() |
I have therefore added 'TG' as one of the expanded definitions in our 'Abbreviation page' - welcome to that, TaplowGreen!
(I am also defined there, lest 'CfN' be confused with the code for Clifton Down station.
)II think that's a good idea. {hint}
Point taken: you have now been added as an honourable member of our club, II.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 15:56, 29th January 2026 | ![]() ![]() ![]() |
Edit: Just spotted TG's earlier message.
With thanks for your post, TonyK, I noted your use of 'TG' as an abbreviation. There is absolutely no problem with that - other than that it might puzzle a new reader of the Coffee Shop forum.
)An honour indeed. I will try not to let it go to my head.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by IndustryInsider at 10:46, 29th January 2026 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by Chris from Nailsea at 19:09, 28th January 2026 | ![]() ![]() ![]() |
)| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TonyK at 16:34, 28th January 2026 | ![]() ![]() ![]() |
From the Mirror via MSN today:
A train line in Devon is set to close for emergency repairs after a giant sinkhole appeared near the railway.
The sinkhole, measuring around eight by three-and-a-half metres, opened up near the line between Dawlish and Teignmouth on Saturday evening following Storm Ingrid.
The railway line will be closed between Exeter St Davids and Newton Abbot from 7pm on Wednesday to allow repair work to take place, with services due to resume at 7am on Thursday.
Network Rail are looking into it, but no Night Sleeper tonight.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by 1st fan at 13:57, 28th January 2026 | ![]() ![]() ![]() |
The Penzance bound sleeper was somewhat understandably 75 minutes late into Penzance. The London bound was at one point in the journey that late but made up a lot of the time to arrive 30 mins late.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by Timmer at 20:01, 27th January 2026 | ![]() ![]() ![]() |
21:45 Penzance to London Paddington due 05:04 will be cancelled.
This is due to severe weather
So this changed?
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by ChrisB at 19:50, 27th January 2026 | ![]() ![]() ![]() |
So this changed?
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by Timmer at 19:39, 27th January 2026 | ![]() ![]() ![]() |
The up sleeper is running, just earlier:
21:15 Penzance to London Paddington due 04:34
Additional 21:15 Penzance to London Paddington due 04:34 will be diverted between Exeter St Davids and Castle Cary.
It will no longer call at Taunton.
It will be delayed due to the diversion and is expected to be 25 minutes late.
This is due to flooding.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by ChrisB at 18:50, 27th January 2026 | ![]() ![]() ![]() |
So tonight's down servce will need to return ECS to provide the same service on Thursday?
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 18:23, 27th January 2026 | ![]() ![]() ![]() |
23:45 London Paddington to Penzance due 07:55 will be diverted between Castle Cary and Exeter St Davids.
Wed, 28 January 21:45 Penzance to London Paddington due 05:04
28/01/26 21:45 Penzance to London Paddington due 05:04 will be cancelled.
This is due to severe weather.
Wed, 28 January 23:45 London Paddington to Penzance due 07:55
28/01/26 23:45 London Paddington to Penzance due 07:55 will be cancelled.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by Sleepy at 16:40, 23rd January 2026 | ![]() ![]() ![]() |
No Sleeper either way tonight due to bad weather forecasted for Dawlish.
21:45 Penzance to London Paddington due 05:09 will be cancelled.
This is due to forecasted severe weather.
23:45 London Paddington to Penzance due 07:54
23:45 London Paddington to Penzance due 07:54 will be cancelled.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by Chris from Nailsea at 12:49, 23rd January 2026 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 09:46, 23rd January 2026 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by Sleepy at 06:22, 23rd January 2026 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 04:37, 19th January 2026 | ![]() ![]() ![]() |
Shocking performance - I hope all concerned get a full refund.
18/01/26 23:50 London Paddington to Penzance due 07:55 is being delayed between Reading and Exeter St Davids and is now expected to be 1 minute late.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by bobm at 14:50, 9th January 2026 | ![]() ![]() ![]() |
Well that's gotten to the bottom of that then.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by Chris from Nailsea at 14:49, 9th January 2026 | ![]() ![]() ![]() |
To be fair, I do prefer 'forecast', but I won't refuse to acknowledge 'forecasted' as a word.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by bobm at 14:43, 9th January 2026 | ![]() ![]() ![]() |
SWR use forecast rather than forecasted in their Journeycheck entries.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by JohnM at 11:04, 9th January 2026 | ![]() ![]() ![]() |
I asked AI - forecast or forecasted?
Both are technically correct, but there is a clear preference depending on the context and your location.
In British English, and particularly when referring to an institution like the Met Office, "forecast" is generally the preferred past tense.
Why "forecast"?
The verb is based on "to cast" (just like broadcast or typecast). Historically, these are irregular verbs that do not change their form in the past tense.
Why "forecasted"?
"Forecasted" is a regularised version of the word. While it was once considered incorrect by traditionalists, it is now widely accepted and listed in most modern dictionaries as a valid alternative. It is slightly more common in American English than British English, and it is often used when the word acts as an adjective (e.g., "the forecasted results").
Which one should you use?
Since you are in the UK, "forecast" will sound more natural and "standard" to most people.
Why "forecast"?
- Past tense: "The Met Office forecast a storm yesterday."
- Past participle: "A storm was forecast for yesterday."
Why "forecasted"?
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by Witham Bobby at 10:54, 9th January 2026 | ![]() ![]() ![]() |
I’m still not sure forecasted is an actual word.
Past Participle of "To Forecast", surely?
"The Met Office forecasted a plague of frogs yesterday"
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by Chris from Nailsea at 13:24, 8th January 2026 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by bobm at 12:59, 8th January 2026 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 12:52, 8th January 2026 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by Sleepy at 16:10, 15th December 2025 | ![]() ![]() ![]() |
Anybody know why GWR have chosen not to operate the sleeper 21st /22nd /23rd December this year ?| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by GBM at 07:46, 12th December 2025 | ![]() ![]() ![]() |
21:45 Penzance to London Paddington due 05:04 will be started from Plymouth.
It will no longer call at Penzance, St Erth, Camborne, Redruth, Truro, St Austell, Par, Bodmin Parkway and Liskeard.
Owing to a signalling fault we are unable to operate this evenings Sleeper service between Penzance and London Paddington.
We have arranged for this service to be operated by one of our regular Intercity Express Trains, starting from Truro, which will offer a Standard and First Class seating service only. There will be no accommodation facilities.
Facilities on the 23:45 London Paddington to Penzance due 07:55.
Will be formed of 5 coaches.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 02:14, 12th December 2025 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 21:14, 10th December 2025 | ![]() ![]() ![]() |
23:45 London Paddington to Penzance due 07:55 will be terminated at Plymouth.
It will no longer call at Liskeard, Bodmin Parkway, Lostwithiel, Par, St Austell, Truro, Redruth, Camborne, Hayle, St Erth and Penzance.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by GBM at 07:55, 10th December 2025 | ![]() ![]() ![]() |
09/12/25 23:45 London Paddington to Penzance due 07:55 was terminated at Truro.
It will no longer call at Redruth, Camborne, Hayle, St Erth and Penzance.
Flooding at Marazion has resulted in cancelled and delayed services to/from Penzance.
Has taken out the St Ives branch, and one of the two Falmouth branch trains.
Newquay branch also suspended by flooding (not connected to thee Penzance issue).
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 07:41, 10th December 2025 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 16:13, 8th December 2025 | ![]() ![]() ![]() |
Where possible customers are advised to travel to Plymouth on an earlier service, where the over night train to Reading and London Paddington will be waiting.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by a-driver at 11:58, 8th December 2025 | ![]() ![]() ![]() |
Loco issues, or carriage issues?23:45 London Paddington to Penzance due 07:55 will be terminated at Plymouth.
Wheel flats on the loco.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by GBM at 08:21, 8th December 2025 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 05:45, 8th December 2025 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 04:52, 3rd September 2025 | ![]() ![]() ![]() |
21:45 Penzance to London Paddington due 05:04 will be starting late from Penzance.
This is due to the train driver being taken ill.
Due to a resourcing issue we are unable to operate this evenings Sleeper service between London Paddington and Penzance / Penzance and London Paddington.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by bobm at 11:48, 2nd September 2025 | ![]() ![]() ![]() |
One of the sleeper sets is now on its way from Reading to Penzance ready for tonight's up service.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by GBM at 05:59, 2nd September 2025 | ![]() ![]() ![]() |
In addition to TG post.
01/09/25 23:45 London Paddington to Penzance due 07:55 is now running as scheduled.
Will be formed of 9 coaches.
The train for Night Riviera has broken down so we have arranged for one of our Intercity Express Trains to run instead which has Standard and First Class seating. There will be no accommodation facilities.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 04:42, 2nd September 2025 | ![]() ![]() ![]() |
A rude awakening!
01/09/25 21:45 Penzance to London Paddington due 05:04 will be terminated at Reading.
It has been previously delayed and is now 11 minutes late from Totnes.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by grahame at 08:08, 27th August 2025 | ![]() ![]() ![]() |
26/08/25 23:45 London Paddington to Penzance due 07:55 has been delayed at Bristol Temple Meads and is now 126 minutes late.
This is due to an obstruction on the track.
Efficient station work at Taunton and Exeter St Davids has reduced the delay to just under 40 minutes, on what (it must be said) is a generously slack set of timings that would lead to all sorts of questions if they were applied daytime. Imagine the Day Riviera train leaving Paddington at 11:45 and arriving into Penzance at 19:55.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 04:55, 27th August 2025 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 17:29, 25th August 2025 | ![]() ![]() ![]() |
Officially it shouldn’t pick up anyone at Reading.
......I thought it was "pick up only" at Reading?
Either way, if you are correct I can't imagine trying to enforce that would have been a particularly bright move, given that it was most likely the last option for many to get home following the end of the Reading festival, may have got a bit unpleasant on the platform!
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by bobm at 12:29, 25th August 2025 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by grahame at 12:27, 25th August 2025 | ![]() ![]() ![]() |
Unusual entry on Journeycheck (seen 09:32 this bank holiday Monday morning):
This train is no longer full and standing.
The slightly earlier entry stated that it WAS full and standing from Reading.............did everyone sit down?
I would imagine that a full-and-standing train from Reading at that time of day would drop off far more people than in picked up at intermediate stations ... so that by the time it got into deepest Cornwall it would not be as crammed.
"And standing" ... I suspect that people who found themselves standing off Reading might have bedded /sat down in doorways and corridors and no longer been standing?
Did the Reading Festival or something end last night causing this major westward flow late in the evening?
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 09:56, 25th August 2025 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by Trowres at 09:36, 25th August 2025 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 13:45, 16th August 2025 | ![]() ![]() ![]() |
With apologies for all the ads/popups, an account of a travel writers experience on the Sleeper......
https://www.plymouthherald.co.uk/whats-on/whats-on-news/mans-overnight-train-journey-cornwall-10428076?utm_medium=Social&utm_source=Facebook&fbclid=IwQ0xDSwMNXKFleHRuA2FlbQIxMAABHuLJ0-8sOex9Dbin-TChxbXuWWCpdWzF7FLm51CAZQnJnPLsHFYbnfuggofs_aem_GFbO_JEQe2C5RZzhZdQfzQ#Echobox=1755272458
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 16:04, 25th July 2025 | ![]() ![]() ![]() |
Personally, I don't have a spare £199 lying around.
Those very cost conscious have the option of travelling in the seated coaches of course.
Having spoken to someone who has endured that experience (all the way to Penzance), those cost conscious people will be spending the following day feeling somewhat akin to your Forum name.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by Sleepy at 10:20, 25th July 2025 | ![]() ![]() ![]() |
Perfectly understandable - would imagine 98% of people that plan to use a Friday night Sleeper to Cornwall in August have booked weeks ago at a much lower price. Those very cost conscious have the option of travelling in the seated coaches of course.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 12:51, 24th July 2025 | ![]() ![]() ![]() |
And to be clear that £199 is just for the cabin. There is the travel ticket to pay for on top of that.
Like so many things, over the years quality and expectations have risen and so have prices.
.......and so has subsidy presumably.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by grahame at 05:50, 24th July 2025 | ![]() ![]() ![]() |
Like so many things, over the years quality and expectations have risen and so have prices. Some of the continental sleepers remain at six beds per cabin. And part of the financial model is (or should be) the cost of replacement of the rolling stock every "n" years.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by bobm at 05:21, 24th July 2025 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by Chris from Nailsea at 23:35, 23rd July 2025 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by Sleepy at 23:32, 23rd July 2025 | ![]() ![]() ![]() |
Friday night's (25th July) down sleeper still has vacant berths (as does Friday night next week) - do you think GWR pricing has reduced demand ? Or is it lower holiday demand in Cornwall this year ? The price for a single cabin is £199
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by a-driver at 18:29, 17th July 2025 | ![]() ![]() ![]() |
Would the sleeper fit (including the inwards loco)?
Platform 3 at Reading is 125m, how long is the sleeper nowadays?Depends on what they use to assist it after it’s failed!!!
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by 1st fan at 23:17, 16th July 2025 | ![]() ![]() ![]() |
Platform 3 at Reading is 125m, how long is the sleeper nowadays?Much longer than that!
.| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by IndustryInsider at 10:47, 16th July 2025 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by 1st fan at 23:07, 15th July 2025 | ![]() ![]() ![]() |
Platform 3 at Reading is 125m, how long is the sleeper nowadays?| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by ChrisB at 20:56, 15th July 2025 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by grahame at 20:54, 15th July 2025 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by ChrisB at 20:03, 15th July 2025 | ![]() ![]() ![]() |
How long is platform 3 in terms of coach-lengths?
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by grahame at 17:59, 15th July 2025 | ![]() ![]() ![]() |
In the case of the Up sleeper I'm not sure being dumped off at Reading at 0430 and having to wait for services to start up in order to get to Paddington would really be a very attractive prospect?
That's not quite what I was suggesting though ... the suggestion was for the sleeper services to terminate and stay resident in a quieter platform for a number of hours ... platform 3 may not be needed for reversal of Cross County trains until (?) what time for example, and in the evening to start from there.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by bobm at 17:08, 15th July 2025 | ![]() ![]() ![]() |
Unless you are a very dedicated Janner, you might say the same about Plymouth on the down!
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 17:06, 15th July 2025 | ![]() ![]() ![]() |
23:45 London Paddington to Penzance due 07:55 will be started from Reading.
This is due to a problem currently under investigation.
There is no loco at Reading to work the empty sleeper set into Paddington, the same reason the sleeper terminated at Reading in the morning.
Last nights up sleeper from Penzance has a 57 on the rear to resolve that issue
In various other bits of research I'm doing, it's not unheard of for a sleeper service to terminate / start somewhere on the outskirts of a city, with passengers transferring in or out via other public transport in the area. Most notable is Halkali which is a ride of about 45 minutes into / out from Istanbul. Perhaps it allows rather more space to be provided for / and for a longer load / unload time at a station that's out of town rather that resource hogging in the centre at the start / end of each day? I am very tempted - and awaiting howls of protest - to suggest that Stirling might be an excellent hub for the Scottish sleepers, though still providing through carriages that call there during the night to/from far flung places such as Fort William, Inverness, Oban and Aberdeen.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by grahame at 11:12, 15th July 2025 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by bobm at 08:26, 15th July 2025 | ![]() ![]() ![]() |
Given the above and the reason given on Journeycheck as “a problem under investigation” I have visions of someone walking round Reading Traincare Depot scratching their head and saying “I’m sure there was a class 57 here somewhere.”
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by a-driver at 03:40, 15th July 2025 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 19:52, 14th July 2025 | ![]() ![]() ![]() |
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by bobm at 07:39, 14th July 2025 | ![]() ![]() ![]() |
It was a late night too. Service started behind schedule from Penzance as crew were delayed getting to the train due to yesterday’s problems.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 06:31, 14th July 2025 | ![]() ![]() ![]() |
Up sleeper terminated at Reading this morning, a rude awakening for all concerned.
Reports suggest the loco failed.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by grahame at 06:38, 7th July 2025 | ![]() ![]() ![]() |
True, but that's not much consolation for those hanging around at intermediate stations in Cornwall and Devon for a couple of hours at that time of night waiting for it to arrive - remember the customers Graham?
Totally agree.
| Re: Night Riviera Sleeper train - between Paddington and Penzance - ongoing discussion Posted by TaplowGreen at 06:31, 7th July 2025 | ![]() ![]() ![]() |
21:15 Penzance to London Paddington due 05:04
21:15 Penzance to London Paddington due 05:04 will be starting late from Penzance and is expected to be 60 minutes late.
This is due to the train making extra stops because of service disruption.
It started 111 minutes late ... on such an easy schedule that it has just passed Slough only 16 minutes late. It's now around 05:00 in the UK, due in to Paddington in 4 minutes. Journeycheck is still forecasting an 06:58 arrival, and real time trains 05:18
