Re: Night Riviera Sleeper train - between Paddington and Penzance
Posted by Chris from Nailsea at 21:22, 29th January 2026
I have therefore added 'TG' as one of the expanded definitions in our 'Abbreviation page' - welcome to that, TaplowGreen!
(I am also defined there, lest 'CfN' be confused with the code for Clifton Down station. [Image from here is not available to guests] )
II think that's a good idea. {hint} [Image from here is not available to guests]
Point taken: you have now been added as an honourable member of our club, II. [Image from here is not available to guests]
Posted by TaplowGreen at 15:56, 29th January 2026
Edit: Just spotted TG's earlier message.
With thanks for your post, TonyK, I noted your use of 'TG' as an abbreviation. There is absolutely no problem with that - other than that it might puzzle a new reader of the Coffee Shop forum.
An honour indeed. I will try not to let it go to my head.
Posted by IndustryInsider at 10:46, 29th January 2026
Posted by Chris from Nailsea at 19:09, 28th January 2026
Posted by TonyK at 16:34, 28th January 2026
From the Mirror via MSN today:
A train line in Devon is set to close for emergency repairs after a giant sinkhole appeared near the railway.
The sinkhole, measuring around eight by three-and-a-half metres, opened up near the line between Dawlish and Teignmouth on Saturday evening following Storm Ingrid.
The railway line will be closed between Exeter St Davids and Newton Abbot from 7pm on Wednesday to allow repair work to take place, with services due to resume at 7am on Thursday.
Network Rail are looking into it, but no Night Sleeper tonight.
Posted by 1st fan at 13:57, 28th January 2026
The Penzance bound sleeper was somewhat understandably 75 minutes late into Penzance. The London bound was at one point in the journey that late but made up a lot of the time to arrive 30 mins late.
Posted by Timmer at 20:01, 27th January 2026
21:45 Penzance to London Paddington due 05:04
21:45 Penzance to London Paddington due 05:04 will be cancelled.
This is due to severe weather
So this changed?
Time stamp on Journey check for the revised 21.15 service as posted above was 15.58.
Posted by ChrisB at 19:50, 27th January 2026
So this changed?
Posted by Timmer at 19:39, 27th January 2026
The up sleeper is running, just earlier:
21:15 Penzance to London Paddington due 04:34
Additional 21:15 Penzance to London Paddington due 04:34 will be diverted between Exeter St Davids and Castle Cary.
It will no longer call at Taunton.
It will be delayed due to the diversion and is expected to be 25 minutes late.
This is due to flooding.
Posted by ChrisB at 18:50, 27th January 2026
So tonight's down servce will need to return ECS to provide the same service on Thursday?
Posted by TaplowGreen at 18:23, 27th January 2026
23:45 London Paddington to Penzance due 07:55
23:45 London Paddington to Penzance due 07:55 will be diverted between Castle Cary and Exeter St Davids.
Wed, 28 January 21:45 Penzance to London Paddington due 05:04
28/01/26 21:45 Penzance to London Paddington due 05:04 will be cancelled.
This is due to severe weather.
Wed, 28 January 23:45 London Paddington to Penzance due 07:55
28/01/26 23:45 London Paddington to Penzance due 07:55 will be cancelled.
Posted by Sleepy at 16:40, 23rd January 2026
No Sleeper either way tonight due to bad weather forecasted for Dawlish.
21:45 Penzance to London Paddington due 05:09
21:45 Penzance to London Paddington due 05:09 will be cancelled.
This is due to forecasted severe weather.
23:45 London Paddington to Penzance due 07:54
23:45 London Paddington to Penzance due 07:54 will be cancelled.
2345 will now run to Exeter only (no sleeper berths as sleeper hosts probably told to pass back from Paddington this morning instead of lodging)
Posted by Chris from Nailsea at 12:49, 23rd January 2026
I’m still not sure forecasted is an actual word.
Posted by TaplowGreen at 09:46, 23rd January 2026
Posted by Sleepy at 06:22, 23rd January 2026
Posted by TaplowGreen at 04:37, 19th January 2026
Shocking performance - I hope all concerned get a full refund.
23:50 London Paddington to Penzance due 07:55
18/01/26 23:50 London Paddington to Penzance due 07:55 is being delayed between Reading and Exeter St Davids and is now expected to be 1 minute late.
Posted by bobm at 14:50, 9th January 2026
Well that's gotten to the bottom of that then.   [Image from here is not available to guests]
Posted by Chris from Nailsea at 14:49, 9th January 2026
To be fair, I do prefer 'forecast', but I won't refuse to acknowledge 'forecasted' as a word. [Image from here is not available to guests]
Posted by bobm at 14:43, 9th January 2026
SWR use forecast rather than forecasted in their Journeycheck entries.
Posted by matth1j at 11:04, 9th January 2026
I asked AI - forecast or forecasted?
Both are technically correct, but there is a clear preference depending on the context and your location.
In British English, and particularly when referring to an institution like the Met Office, "forecast" is generally the preferred past tense.
Why "forecast"?
The verb is based on "to cast" (just like broadcast or typecast). Historically, these are irregular verbs that do not change their form in the past tense.
  • Past tense: "The Met Office forecast a storm yesterday."
  • Past participle: "A storm was forecast for yesterday."
Why "forecasted"?
"Forecasted" is a regularised version of the word. While it was once considered incorrect by traditionalists, it is now widely accepted and listed in most modern dictionaries as a valid alternative. It is slightly more common in American English than British English, and it is often used when the word acts as an adjective (e.g., "the forecasted results").
Which one should you use?
Since you are in the UK, "forecast" will sound more natural and "standard" to most people.
Posted by Witham Bobby at 10:54, 9th January 2026
Past Participle of "To Forecast", surely?
"The Met Office forecasted a plague of frogs yesterday"
Posted by Chris from Nailsea at 13:24, 8th January 2026
Grammarist says it is. [Image from here is not available to guests]
Posted by bobm at 12:59, 8th January 2026
Posted by TaplowGreen at 12:52, 8th January 2026
Posted by Sleepy at 16:10, 15th December 2025
 [Image from here is not available to guests] Anybody know why GWR have chosen not to operate the sleeper 21st /22nd /23rd December this year ?
Posted by GBM at 07:46, 12th December 2025
21:45 Penzance to London Paddington due 05:04 will be started from Plymouth.
It will no longer call at Penzance, St Erth, Camborne, Redruth, Truro, St Austell, Par, Bodmin Parkway and Liskeard.
Owing to a signalling fault we are unable to operate this evenings Sleeper service between Penzance and London Paddington.
We have arranged for this service to be operated by one of our regular Intercity Express Trains, starting from Truro, which will offer a Standard and First Class seating service only. There will be no accommodation facilities.
Facilities on the 23:45 London Paddington to Penzance due 07:55.
Will be formed of 5 coaches.
Posted by TaplowGreen at 02:14, 12th December 2025
Posted by TaplowGreen at 21:14, 10th December 2025
23:45 London Paddington to Penzance due 07:55 will be terminated at Plymouth.
It will no longer call at Liskeard, Bodmin Parkway, Lostwithiel, Par, St Austell, Truro, Redruth, Camborne, Hayle, St Erth and Penzance.
Posted by GBM at 07:55, 10th December 2025
09/12/25 23:45 London Paddington to Penzance due 07:55 was terminated at Truro.
It will no longer call at Redruth, Camborne, Hayle, St Erth and Penzance.
Flooding at Marazion has resulted in cancelled and delayed services to/from Penzance.
Has taken out the St Ives branch, and one of the two Falmouth branch trains.
Newquay branch also suspended by flooding (not connected to thee Penzance issue).
Posted by TaplowGreen at 07:41, 10th December 2025
Posted by TaplowGreen at 16:13, 8th December 2025
Where possible customers are advised to travel to Plymouth on an earlier service, where the over night train to Reading and London Paddington will be waiting.
Posted by a-driver at 11:58, 8th December 2025
Loco issues, or carriage issues?
Wheel flats on the loco.
Posted by GBM at 08:21, 8th December 2025
Posted by TaplowGreen at 05:45, 8th December 2025
Posted by TaplowGreen at 04:52, 3rd September 2025
21:45 Penzance to London Paddington due 05:04 will be starting late from Penzance.
This is due to the train driver being taken ill.
Due to a resourcing issue we are unable to operate this evenings Sleeper service between London Paddington and Penzance / Penzance and London Paddington.
We have arranged for this service to be operated by one of our regular Intercity Express Trains which will offer a Standard and First Class seating service only. There will be no accommodation facilities.
Posted by bobm at 11:48, 2nd September 2025
One of the sleeper sets is now on its way from Reading to Penzance ready for tonight's up service.
Posted by GBM at 05:59, 2nd September 2025
In addition to TG post.
01/09/25 23:45 London Paddington to Penzance due 07:55 is now running as scheduled.
Will be formed of 9 coaches.
The train for Night Riviera has broken down so we have arranged for one of our Intercity Express Trains to run instead which has Standard and First Class seating. There will be no accommodation facilities.
Posted by TaplowGreen at 04:42, 2nd September 2025
A rude awakening!
01/09/25 21:45 Penzance to London Paddington due 05:04 will be terminated at Reading.
It will no longer call at London Paddington.
It has been previously delayed and is now 11 minutes late from Totnes.
Posted by grahame at 08:08, 27th August 2025
26/08/25 23:45 London Paddington to Penzance due 07:55 has been delayed at Bristol Temple Meads and is now 126 minutes late.
This is due to an obstruction on the track.
Efficient station work at Taunton and Exeter St Davids has reduced the delay to just under 40 minutes, on what (it must be said) is a generously slack set of timings that would lead to all sorts of questions if they were applied daytime.  Imagine the Day Riviera train leaving Paddington at 11:45 and arriving into Penzance at 19:55.
Posted by TaplowGreen at 04:55, 27th August 2025
Posted by TaplowGreen at 17:29, 25th August 2025
Officially it shouldn’t pick up anyone at Reading.
......I thought it was "pick up only" at Reading?
Either way, if you are correct I can't imagine trying to enforce that would have been a particularly bright move, given that it was most likely the last option for many to get home following the end of the Reading festival, may have got a bit unpleasant on the platform!
Posted by bobm at 12:29, 25th August 2025
Posted by grahame at 12:27, 25th August 2025
Unusual entry on Journeycheck (seen 09:32 this bank holiday Monday morning):
This train is no longer full and standing.
The slightly earlier entry stated that it WAS full and standing from Reading.............did everyone sit down?
I would imagine that a full-and-standing train from Reading at that time of day would drop off far more people than in picked up at intermediate stations ... so that by the time it got into deepest Cornwall it would not be as crammed.
"And standing" ... I suspect that people who found themselves standing off Reading might have bedded   /sat down in doorways and corridors and no longer been standing?
Did the Reading Festival or something end last night causing this major westward flow late in the evening?
Posted by TaplowGreen at 09:56, 25th August 2025
Posted by Trowres at 09:36, 25th August 2025
Posted by TaplowGreen at 13:45, 16th August 2025
With apologies for all the ads/popups, an account of a travel writers experience on the Sleeper......
https://www.plymouthherald.co.uk/whats-on/whats-on-news/mans-overnight-train-journey-cornwall-10428076?utm_medium=Social&utm_source=Facebook&fbclid=IwQ0xDSwMNXKFleHRuA2FlbQIxMAABHuLJ0-8sOex9Dbin-TChxbXuWWCpdWzF7FLm51CAZQnJnPLsHFYbnfuggofs_aem_GFbO_JEQe2C5RZzhZdQfzQ#Echobox=1755272458
Posted by TaplowGreen at 16:04, 25th July 2025
Personally, I don't have a spare £199 lying around.  [Image from here is not available to guests]
Those very cost conscious have the option of travelling in the seated coaches of course.
Having spoken to someone who has endured that experience (all the way to Penzance), those cost conscious people will be spending the following day feeling somewhat akin to your Forum name.
Posted by Sleepy at 10:20, 25th July 2025
Perfectly understandable - would imagine 98% of people that plan to use a Friday night Sleeper to Cornwall in August have booked weeks ago at a much lower price. Those very cost conscious have the option of travelling in the seated coaches of course.
Posted by TaplowGreen at 12:51, 24th July 2025
And to be clear that £199 is just for the cabin.  There is the travel ticket to pay for on top of that.
Like so many things, over the years quality and expectations have risen and so have prices.
.......and so has subsidy presumably.
Posted by grahame at 05:50, 24th July 2025
Like so many things, over the years quality and expectations have risen and so have prices.  Some of the continental sleepers remain at six beds per cabin.  And part of the financial model is (or should be) the cost of replacement of the rolling stock every "n" years.
Posted by bobm at 05:21, 24th July 2025
Posted by Chris from Nailsea at 23:35, 23rd July 2025
Posted by Sleepy at 23:32, 23rd July 2025
Friday night's (25th July) down sleeper still has vacant berths (as does Friday night next week) - do you think GWR pricing has reduced demand ? Or is it lower holiday demand in Cornwall this year ? The price for a single cabin is £199
Posted by a-driver at 18:29, 17th July 2025
Would the sleeper fit (including the inwards loco)?
Platform 3 at Reading is 125m, how long is the sleeper nowadays?
Depends on what they use to assist it after it’s failed!!!   [Image from here is not available to guests] [Image from here is not available to guests]
Posted by 1st fan at 23:17, 16th July 2025
Much longer than that!
Thought so  [Image from here is not available to guests].
Posted by IndustryInsider at 10:47, 16th July 2025
Posted by 1st fan at 23:07, 15th July 2025
Posted by ChrisB at 20:56, 15th July 2025
Posted by grahame at 20:54, 15th July 2025
How long is platform 3 in terms of coach-lengths?
6.35
Posted by ChrisB at 20:03, 15th July 2025
Posted by grahame at 17:59, 15th July 2025
In the case of the Up sleeper I'm not sure being dumped off at Reading at 0430 and having to wait for services to start up in order to get to Paddington would really be a very attractive prospect?
That's not quite what I was suggesting though ... the suggestion was for the sleeper services to terminate and stay resident in a quieter platform for a number of hours ... platform 3 may not be needed for reversal of Cross County trains until (?) what time for example, and in the evening to start from there.
Posted by bobm at 17:08, 15th July 2025
Unless you are a very dedicated Janner, you might say the same about Plymouth on the down!
Posted by TaplowGreen at 17:06, 15th July 2025
23:45 London Paddington to Penzance due 07:55 will be started from Reading.
This is due to a problem currently under investigation.
There is no loco at Reading to work the empty sleeper set into Paddington, the same reason the sleeper terminated at Reading in the morning.
Last nights up sleeper from Penzance has a 57 on the rear to resolve that issue
In various other bits of research I'm doing, it's not unheard of for a sleeper service to terminate / start somewhere on the outskirts of a city, with passengers transferring in or out via other public transport in the area. Most notable is Halkali which is a ride of about 45 minutes into / out from Istanbul.    Perhaps it allows rather more space to be provided for / and for a longer load / unload time at a station that's out of town rather that resource hogging in the centre at the start / end of each day?  I am very tempted - and awaiting howls of protest - to suggest that Stirling might be an excellent hub for the Scottish sleepers, though still providing through carriages that call there during the night to/from far flung places such as Fort William, Inverness, Oban and Aberdeen.
Posted by grahame at 11:12, 15th July 2025
Posted by bobm at 08:26, 15th July 2025
Given the above and the reason given on Journeycheck as “a problem under investigation” I have visions of someone walking round Reading Traincare Depot scratching their head and saying “I’m sure there was a class 57 here somewhere.”
Posted by a-driver at 03:40, 15th July 2025
Posted by TaplowGreen at 19:52, 14th July 2025
Posted by bobm at 07:39, 14th July 2025
It was a late night too.  Service started behind schedule from Penzance as crew were delayed getting to the train due to yesterday’s problems.
Posted by TaplowGreen at 06:31, 14th July 2025
Up sleeper terminated at Reading this morning, a rude awakening for all concerned.
Reports suggest the loco failed.
Posted by grahame at 06:38, 7th July 2025
True, but that's not much consolation for those hanging around at intermediate stations in Cornwall and Devon for a couple of hours at that time of night waiting for it to arrive - remember the customers Graham?
Totally agree.
Posted by TaplowGreen at 06:31, 7th July 2025
21:15 Penzance to London Paddington due 05:04
21:15 Penzance to London Paddington due 05:04 will be starting late from Penzance and is expected to be 60 minutes late.
This is due to the train making extra stops because of service disruption.
It started 111 minutes late ... on such an easy schedule that it has just passed Slough only 16 minutes late.  It's now around 05:00 in the UK, due in to Paddington in 4 minutes. Journeycheck is still forecasting an 06:58 arrival, and real time trains 05:18
Posted by grahame at 05:00, 7th July 2025
Posted by a-driver at 23:10, 6th July 2025
The crew travelling down to Penzance were heavily delayed because the lines outside Plymouth were shut because a driver reported striking two individuals on the track.
https://www.plymouthherald.co.uk/news/plymouth-news/emergency-services-respond-railway-incident-10323460
Posted by TaplowGreen at 22:19, 6th July 2025
Posted by TaplowGreen at 06:42, 28th June 2025
27/06/25 23:45 London Paddington to Penzance due 07:54 was terminated at Plymouth.
Posted by a-driver at 07:54, 20th June 2025
21:45 Penzance to London Paddington due 05:07
19/06/25 21:45 Penzance to London Paddington due 05:07 has been delayed at Penzance and is now 130 minutes late.
This is due to a fault on this train
Currently left Reading 84 minutes late (having left Newton Abbot 143 minutes down)
It failed the night before as well, I believe it was terminated at Plymouth
https://www.realtimetrains.co.uk/service/gb-nr:P08204/2025-06-18#allox_id=0
Posted by GBM at 05:50, 20th June 2025
Posted by TaplowGreen at 07:20, 5th June 2025
23:45 London Paddington to Penzance due 07:55 will be terminated at Bodmin Parkway.
It will no longer call at Lostwithiel, Par, St Austell, Truro, Redruth, Camborne, Hayle, St Erth and Penzance.
Posted by bobm at 13:44, 28th May 2025
Sleeper loco suffered a fuel leak.   Now been rescued by a Castle Class set and on its way, empty, to Long Rock in Penzance.
In the end it went to Laira, Plymouth, for repairs.   Due to head to Penzance this afternoon.
Posted by RobT at 09:07, 28th May 2025
Looks like set GW08 43156/43186 was used for the rescue, as 2C00 was cancelled and 2E06 was partially cancelled.
Posted by GBM at 08:51, 28th May 2025
27/05/25 23:45 London Paddington to Penzance due 07:55 was terminated at Exeter St Davids.
It will no longer call at Newton Abbot, Plymouth, Liskeard, Bodmin Parkway, Lostwithiel, Par, St Austell, Truro, Redruth, Camborne, Hayle, St Erth and Penzance.
.....all lines currently blocked at Exeter St Davids as a result.
Looking at RTT, it was a 3 carriage train from London to Exeter!
Posted by grahame at 08:37, 28th May 2025
What are they going to do without "Thunderbird" Castles??
Posted by bobm at 07:22, 28th May 2025
Posted by TaplowGreen at 06:08, 28th May 2025
Posted by grahame at 08:09, 20th May 2025
Passengers who do not need to travel this evening can attempt to travel tomorrow. Tickets will be honoured.
Road transport has not been organised. Transport in the area is extremely limited at this time of the evening.
My highlighting. Oh dear ... the use of the words "attempt to" doesn't fill one with confidence!
Posted by TaplowGreen at 06:43, 20th May 2025
Looks like a 5 car IET left Penzance around midnight and arrived in Paddington 0515
Must have been a pretty unpleasant experience all round...........and I suspect is responsible for this......
07:10 Penzance to London Paddington due 12:29
07:10 Penzance to London Paddington due 12:29 will be started from Plymouth.
It will no longer call at Penzance, St Erth, Camborne, Redruth, Truro, St Austell, Par, Lostwithiel, Bodmin Parkway, Liskeard, St Germans and Saltash.
Will be formed of 5 coaches instead of 10.
Posted by old original at 05:23, 20th May 2025
Posted by TaplowGreen at 03:29, 20th May 2025
21:45 Penzance to London Paddington due 05:07 has been cancelled.
Sadly, the 21.45 Penzance to London Paddington service is broken down near Penzance. Maintenance are on route to attempt to fix this train. ETA 23.00 at Penzance.
Posted by PhilWakely at 06:17, 17th May 2025
Not a good week for the Up sleeper.
21:45 Penzance to London Paddington due 05:08
21:45 Penzance to London Paddington due 05:08 has been delayed at Penzance and is now 61 minutes late.
Can't complain too much as it was only 8 minutes late arriving at London Paddington!
Posted by TaplowGreen at 04:43, 17th May 2025
Posted by Mark A at 09:21, 13th May 2025
Silly question - how many customers actually want to arrive in London before 07:00 anyway?
Not many.
In fact with delay repay I expect most would be pretty happy.
Not ideal for passengers joining at stations enroute of course, but hopefully they would all be understanding of the reason.
Given the economics of sleeper services would it be justified to modify their delay repay conditions?
It's awkward as some may be heading for onward connections and need that early arrival time - but their needs may be better met by them having travel insurance to cover disruption, which might meet the actual costs they may incur.
The Paddington arrival being ~05:04 and cabins to be vacated by 06:45, if GWR honours delay repay on the basis of that 5:04 arrival there must be many many travellers who'd regard anything before a 6:45 arrival as meeting their needs (and quite a few who'd be fine with 8am but of course Paddington needs the platform...) If, on the occasion that the service arrives an hour down, GWR are meeting a lot of delay repay claims on the basis of that 5:04 arrival it might be that they're compensating some for the hour or more that they'd have spent snoozing anyway.
More relaxed arrangements for delay repay on sleeper services might be for the general good as long as the railway doesn't then regard itself as deincentivised to run the services to time - but again, the avoidable costs involved in tying up a platform in the morning peak should address that.
Posted by IndustryInsider at 08:51, 13th May 2025
Not many.
Posted by grahame at 08:31, 13th May 2025
And didn't make any time up enroute, odd.
Such a slack scheduled running time to boot.
* Longer time at EXD than it should have been.
* Via Honiton which probably makes it less slack
* Relief line most of the way from Reading to Paddington and at a time when Liz Line service running
Posted by GBM at 08:00, 13th May 2025
12/05/25 21:45 Penzance to London Paddington due 05:04 has been delayed at Camborne and is now 126 minutes late.
Posted by TaplowGreen at 05:43, 13th May 2025
Posted by LiskeardRich at 11:32, 12th May 2025
I’d assume as it changed route at Exeter, and they’re citing a train fault, that the fault may have been in the Taunton end cab of the 57. The delay whilst they waited for the honiton route to reopen?
Posted by grahame at 08:45, 12th May 2025
Paddington 175 late. It ran through platform 1 at Castle Cary according to RTT, which is only available from Taunton. So the booked route via Honiton was not taken. Likewise it seems to have gone via the B&H, with not the booked call at Swindon
https://www.realtimetrains.co.uk/service/gb-nr:G45618/2025-05-11/detailed
Ah - thanks for that - I misread Real Time Trains in my earlier report.
Posted by bradshaw at 08:41, 12th May 2025
Posted by GBM at 07:27, 12th May 2025
It left Exeter St Davids 200 minutes late, having arrived there on time, and travelled via Honiton and back onto planned route at Castle Cary.  It was planned to run via Melksham and Swindon but as far as I can tell diverted via Newbury and arrived reading at 06:30 - 145 minutes late as stated.  I suspect it will be cancelled in from there.
Left Reading 179 minutes down, but heading for Paddington.
Posted by grahame at 07:23, 12th May 2025
21:45 Penzance to London Paddington due 05:04 will be diverted between Exeter St Davids and Reading.
It will be delayed between Exeter St Davids and Reading and is expected to be 120 minutes late.
Diverted via Melksham perhaps?
A long lie-in this morning for passengers.
Arrived Reading 0630 (145 minutes late), but still there as I type!
