Re: HS2 - Government proposals, alternative routes and general discussion
12.7.2025 (Saturday) 20:34 - All running AOK
Posted by matth1j at 15:51, 12th July 2025
Thanks Chris - I should have guessed there was an HS2-related discussion ongoing somewhere.
Posted by Chris from Nailsea at 01:14, 12th July 2025
The government has made the demise of domestic air travel an explicit policy target for the first time by aiming to replace short-haul flights with a new 250mph high-speed rail network.
I was reminded of the original post in our previously merged topic on the subject of HS2 - so I've now merged the latest discussion into this one, in the interest of continuity.
Re: Peter Lord Hendy, rail minister, says HS2 is 'too fast'
Posted by TaplowGreen at 16:15, 11th July 2025
HS2 was conceived to provide extra capacity (sorely needed in many places, not just on the London to Birmingham route) and to be fit for the future
Lord Hendy now saying that it didn't need to be constructed with such high speed limits in mind does not fully explain the tunnels, many of which are for NIMBY reasons, the viaducts instead of earthworks, the slab track, or the bat tunnel, and several other specification extravagances
Judging by Hendy's comments, it would appear that the 225mph running speed was the greatest "specification extravagance" of them all!
Posted by Witham Bobby at 16:06, 10th July 2025
Posted by a-driver at 15:25, 10th July 2025
London to Birmingham is 118 miles
At 225 m.p.h., that's 32 minutes
At 180 m.p.h., it's 40 minutes
At 140 m.p.h., it's 51 minutes
And at 125 m.p.h. its 57 minutes
Of course it will take longer - you have to allow for accelerating and breaking, and allow for the two minutes that you need to be there for closing of the doors, and time to get to and from the stations and platform.  Rather more I would ask about the freqency and how long you'll have to be at the station to check in before your train is called - one hopes not as long as Eurostar.
I find myself remaining of the personal opinion that 140 m.p.h. would have been quite fast enough, with half of the extra money spent to raise the speed limit on good access in and out of that backbone.
Questions - for what proportion of the journey will the trains be running at their top speed or even over 200 m.p.h., and are the ends engineered to a less fast standard - Old Oak Common to Perivale  - 4.5 miles - at 225 m.p.h. would take a minute and 12 seconds.
Utter codswallop!!!!!!  It’s a piece of infrastructure that’s going to be in place for 100s of years, you build it with the future in mind and thus you need to obtain the maximum speed as possible. You’re in competition with road and air.
When it comes to high speed rail around the world, they didn’t get to 125mph and said that’s fast enough. They are still pushing for faster speeds.
Posted by grahame at 13:43, 10th July 2025
Posted by matth1j at 12:55, 10th July 2025
From the Telegraph:
HS2 ran tens of billions of pounds over budget and will open years late because it was designed to be unnecessarily fast, MPs have been told.
Lord Hendy, the rail minister, made the claim as he criticised the decision for the route to be built for trains running at speeds of 225mph, faster than on most high-speed networks overseas.
He said: “It is hard to understand why there was such zealotry about the highest-speed, high-speed railway in a relatively small country when the origination of it was to relieve capacity [problems].
“The case for better connectivity is pretty clear. The West Coast Main Line was predicted to be nearly full, and it is nearly full and under huge pressure.
“But there are two questions that doesn’t answer. One is why we needed an exceptionally fast railway, rather than just a fast railway.
“The other is the speed of delivery. I’m not sure I can make the case that it was desperate. Why it was pursued with such speed – and now we are suffering the cost of it – is hard to say.”
Lord Hendy questioned why HS2 needed to be even faster than the High Speed 1 route that runs between London’s St Pancras International Station and the Channel Tunnel, which at 186mph, he said was “quite fast as it is” and the standard speed for European high-speed lines.
He said about one-third of the HS2 route runs underground or through cuttings in order to keep the line straight and maximise speed, which had created significant engineering challenges.
The former chairman of Network Rail, which manages the UK’s train tracks and major stations, told the House of Commons transport committee that civil engineering work that should have been completed by now was still only about 60pc complete, with just one-third of the wider scheme, including tracks, trains and overhead power lines, finished.
‘Appalling mess’
Last month, the Government said that the opening of HS2 would be delayed beyond 2033 after cost overruns swelled to £37bn, despite the northern half of the project being scrapped to save money.
Heidi Alexander, the Transport Secretary, said the scheme was an “appalling mess” following a “litany of failures” and could end up becoming the most expensive railway line in the world. Some £2bn alone was spent on its now-cancelled second phase to Manchester.
Alan Over, director general for major rail projects at the Department for Transport, told MPs that HS2 was built to such a high specification in part because of a political desire to go one better than Britain’s European rivals.
He said: “If you are going to build a new railway, you might as well make it faster than our historic railways. The speed helps a bit with the capacity as well, because you can get more trains through in the given amount of time.
“The question is, why did the country choose to do it faster than the French or faster than the Germans or faster than the Spanish? There was a bit of ‘we want to join the high-speed revolution’ and be as good as everyone else in that regard.”
Mr Over added: “It’s not bad to have a national ambition. But you have to understand the consequences, that you are then pushing the boundaries and introducing more risk, and that leads to more cost.”
He said that the HS2 was designed for trains faster than all but the speediest Japanese and Chinese models.
Mark Wild, who took over as HS2’s chief executive in December after running London’s Crossrail project, conceded that the project had been too ambitious but said there was now no choice but to persevere with the truncated plans.
He said: “The mistake made here is that the railway is just too fast and too stiff, and that has produced very, very significant civil engineering costs.
“We have clearly got into terrible trouble with the estimate. But the die is cast now and we have to make the best we can of it.”
Posted by TonyK at 17:03, 21st June 2025
In the Times the other day, I saw Morten Morland's cartoon and thought "TG will like this".
Posted by Sixty3Closure at 23:31, 20th June 2025
I was talking to someone who owns a business contracting on HS2. A piece of equipment stopped working so they sent an engineer. The engineer explained that they needed to turn the machine on to see the error code although it was probably a £400 card but the HS2 person refused as it broke safety protocols and there was no one available to manage the change process to allow the machine to be turned on. This went on for a while until HS2 asked if the engineer could install a whole new unit which apparently was allowed and there was a change process for. £20,000 later this was done and as an added bonus the contractor was asked to take the old kit away. He replaced the card for £400 and then sold it for £15K.
I've kept the details vague to avoid identifying anyone but fair to say this was not in a high risk area. It does highlight though that perhaps there's not great financial controls and a culture that doesn't really think about the sums of money being spent or sees spending as an easier way to fix problems than managing them. £20K is probably a tiny part of someone's discretionary spend but repeat this hundreds of times over the course of the project and you can see why costs mount up. Also how dysfunctional is a project if you can swap a machine out but not turn it on to run diagnostics?
Posted by Trowres at 21:57, 19th June 2025
It is interesting to compare HS2 with schemes elsewhere.
Denmark's first high speed line (Copenhagen-Ringsted) had a slight head start on HS2, the idea being considered from 2007 (vs. 2009 for HS2). Again, capacity was a primary motivation. Speed aspirations were more modest, with 250kph being considered.
Much of the route runs parallel with motorways. There is some tunneling in urban areas; also some viaducts; but not on the scale of HS2. The work was planned as multiple contracts in the range of Euro30m to Euro200m.
Construction started in 2012 and it was opened in 2019. Operations had a very gradual start due to problems with the ETCS. The route forms an integral part of the Danish network and will, a few years from now, connect to the European network via the Fehmarn Belt link to Germany.
Outturn cost for the 60km double track electrified line? DKK10bn, or about £1.2bn (give or take a bit on the exchange rates)
(edited to correct the name of the link to Germany)
Posted by TaplowGreen at 12:00, 19th June 2025
........and this is what happened to those who spoke out....
https://www.geplus.co.uk/news/hs2-whistleblower-who-lost-his-job-awarded-319000-13-06-2025/
Posted by Timmer at 17:58, 18th June 2025
All the billions of pounds that have been poured into this massive white elephant that could have been spent elsewhere on the rail network. One project in particular that comes to mind is the bottleneck at Welwyn that would have increased capacity on the ECML.
Posted by TaplowGreen at 16:32, 18th June 2025
Earlier article updated following Commons statements......
BBC News - HS2 line to be delayed again with no new date given - BBC News
https://www.bbc.co.uk/news/articles/cy0wr7nw7wxo
Posted by John D at 14:16, 18th June 2025
Links to some HS2 summer newsletters
Aylesbury area
https://assets.hs2.org.uk/wp-content/uploads/2025/06/NC2A-North-Newsletter-Summer-2025-v2.pdf
North Chilterns area
https://assets.hs2.org.uk/wp-content/uploads/2025/06/NCA-Summer-Newsletter-2025-to-publish-2.pdf
Calvert area
https://assets.hs2.org.uk/wp-content/uploads/2025/06/HS2-Calvert-Area-Summer-Newsletter-2025.pdf
Twyford-Greatworth (Brackley) area
https://assets.hs2.org.uk/wp-content/uploads/2025/06/T2G-HS2-Newsletter-Summer-2025.pdf
Greatwoth-Southam area
https://assets.hs2.org.uk/wp-content/uploads/2025/06/Greatworth-to-Southam-HS2-Newsletter-Summer-2025.pdf
Lots of updates, photos, and expected work in next few months.
Posted by John D at 12:10, 18th June 2025
The rescheduling and re specifying things has not only pushed up costs by billions, it has made complete mockery of timescale.
There are you tube videos showing some sections have finished the earthworks and structures and are being landscaped.   Only one TBM is now working (at Bromford), all the others have finished.  But they have disbanded the crews rather than start the 2 Euston TBMs which are ready to go.  Politicians don't understand basic continuity to save money.
There are set of newsletters, and these suggest in next few months many more new bridges will be in use, and the earthworks completed where there are currently old roads and deviations blocking the way.
Of course, big question is what has been gained by having some sections built (ready for fit out ) by mid 2026 if other parts have been deliberately/carelessly delayed upto 5 years
Posted by JayMac at 11:58, 18th June 2025
An additional £25bn is being thrown into this money pit. Quietly slipped into the Spending Review. Rachel Reeves decided not to mention this massive contribution to infrastructure spending when she gave her speech to the house. I wonder why?
https://www.theguardian.com/commentisfree/2025/jun/13/labour-hs2-money-rachel-reeves-spending-review
The Chancellor should've cancelled the entire project rather than throw more money at it. The assessment was probably that it's too far gone, not physically but politically, to cancel.
What's the scientific name for HS2?
album elephanto pretiosa
Posted by Witham Bobby at 11:22, 18th June 2025
A couple of days a week I drive up the M42 and back for work.  Sometimes also travel around the Hams Hall area, on the A446.
This area is where the HS2 line will have junctions to take trains into Birmingham Curzon Street and out again, on towards Lichfield, where there will be a junction onto the WCML
I've watched progress for months and months, building (so far) one overbridge, and mile upon mile of piers for what will be viaducts.  I can't help thinking that the job has been specified to include all the "nice to haves", and not kept to the basics.  I'm not a civil engineer, but I suspect that viaducts are multiple times more costly than embankments
I just wonder who (if anyone) is in charge of what and how much is being spent on what
The whole thing smacks of politicos not wanting to get themselves a bad reputation on spending or specification grounds, so they've handed it over to an arms length contracting system, without proper oversight.  There is no one to carry the can for when things go wrong.  everyone concerned can point at everyone else.  The story of modern government in the UK
Posted by ellendune at 08:34, 18th June 2025
More delay, more cost............
Yes and we know who to blame now politicians who didn't know how to govern.  Clearing up their mess seems a good description here.
Posted by TaplowGreen at 07:44, 18th June 2025
Posted by Chris from Nailsea at 19:35, 15th June 2025
HS2 reports subcontractor over alleged fraud
The company building the HS2 rail line between London and Birmingham has reported one of its subcontractors to the tax authorities over possible fraud.
Whistleblowers made allegations over the way pay was handled for some construction staff on the high-speed line.
HS2 Ltd said last month it was conducting its own investigation, looking into two firms who supplied it with workers. The company has now also referred the matter to HMRC.
The firms in question were providing workers to Balfour Beatty Vinci (BBV), a contractor for HS2.
Transport Secretary Heidi Alexander is expected to raise the issue in Parliament this week. It is the latest difficulty to beset the troubled giant rail infrastructure project.
HS2 has faced myriad challenges and spiralling costs since it was first announced in 2009.
It was originally designed to boost capacity on the railways between the north and south of England but the last, Conservative, government decided to scrap the second phase of the project, which included building lines to Manchester and Leeds.
Earlier this year whistleblowers flagged concerns over the way some subcontracted staff were being paid. They said self-employed workers had been falsely declared as salaried staff, with "fake" payslips submitted at a higher payrate. The allegations were first published in the i newspaper in May.
One of the labour suppliers is understood to remain suspended from new contracts while inquiries continue.
An HS2 spokesperson said: "We treat all whistleblower allegations seriously and are continuing to conduct our own investigation."
The firm said it encouraged anyone with relevant information to report it via confidential internal channels.
The Department for Transport said last month it had "a zero-tolerance attitude towards fraud, bribery, and corruption" and would ensure any claims of wrongdoing were thoroughly investigated.
Posted by Chris from Nailsea at 11:45, 14th June 2025
From Rail Advent:
Significant progress in excavating 8.4-mile-long HS2 tunnel under London - June 2025
Further significant progress in excavating the 8.4-mile-long Northolt Tunnel for HS2 was made when the third of four tunnel boring machines completed its work in the tunnel last Friday, 6th June.
Emily made the breakthrough after completing a 3.4-mile drive at Green Park Way in Greenford, west London, and the fourth TBM, Anne, is due to finish its boring this summer.
The second bore was completed by TBM Caroline in April this year.
Emily was named after Emily Sophia Taylor, who helped establish the Perivale Maternity Hospital in 1937 before becoming Ealing’s first female mayor in 1938.
It was launched in February 2024 and worked on one bore of the eastern section of the tunnel, from where it removed 775,000 tonnes of London Clay and installed 17,514 tunnel segments.
Four TBMs are being used to construct the Northolt Tunnel, with two TBMs building the eastern section from Victoria Road in North Acton and two TBMs building the western section from West Ruislip. Each TBM will finish its task at Green Park Way, from where it will be lifted out from its underground shaft.
Because of high water pressure in the ground at the Green Park Way site, the TBMs are finishing their drives in a reception can in the shaft, which allows pressure to be maintained while sealant is applied from the tunnel lining to prevent water ingress.
Emily was designed specifically for the soft London Clay of the tunnel. Built by Herrenknecht in Germany, it weighs 1,700 tonnes and has a 9.11m diameter cutterhead.
Three teams of 48 employed by HS2’s London Tunnels contractor, Skanska Costain STRABAG JV, worked around the clock to bore the tunnel, with Emily advancing at around 38 metres per day at peak production.
Excavated clay was removed from the tunnel on a conveyor system to the London Logistics Hub at Willesden Euro Terminal, then transported by rail and reused at sites in Cambridgeshire, Kent and Warwickshire.
The excavated tunnel shaft was lined with concrete segments, each weighing up to 7 tonnes, and made at Hartlepool in County Durham by STRABAG.
Posted by Witham Bobby at 10:55, 19th May 2025
The only HS2 train running in this decade is an enormous gravy train
This nation has "complianced" herself into an incapability to run infrastructure projects.  See also Hinckley Point, etc.
A nation, once full of energy and zeal, that built railway lines all over the globe, is now unable to build a 140 mile railway between two of her great cities
Posted by TaplowGreen at 16:26, 16th May 2025
Further delays and costs..................
https://www.msn.com/en-gb/news/newsbirmingham/fears-birmingham-hs2-station-could-be-delayed-amid-new-2039-finish-date/ar-AA1ERgS1?ocid=socialshare
Posted by Chris from Nailsea at 20:30, 9th May 2025
HS2 tunnel machine breaks through for milestone
A giant HS2 boring machine has broken through to complete the first section of a three and-a-half mile (5.6km) tunnel on the route's approach into Birmingham.
The 125m (137yd) long, 1,600-tonne machine emerged on Friday morning after 652 days and nights of construction work.
The device was named Mary Ann by the local community in a nod to the Warwickshire-born writer George Eliot, which was the pen name of Mary Ann Evans.
The tunnel is the first of two bores of the Bromford Tunnel, running from Water Orton in north Warwickshire to Washwood Heath in Birmingham, passing under the area's motorway network and the River Tame. The breakthrough - HS2's first in Birmingham - was described by officials as a "significant milestone" for the line.
About 31,000 people are employed on the programme across the 140-mile (225km) route.
An HS2 spokesperson estimated that the second bore of the Bromford Tunnel would be completed later this year by another tunnel boring machine, this one named Elizabeth, after the social reformer and activist Dame Elizabeth Cadbury.
Following the excavation, teams will begin fitting out the tunnel with cross passages, concrete finishing works, base slabs and emergency and maintenance walkways.
At peak production, Mary Ann advanced at about 30m (98ft) each day, with teams reinforcing the tunnel with more than 20,000 pieces of concrete.
"Today's breakthrough is a significant milestone for the project and I'm immensely proud of the men and women who have worked day and night to bring Mary Ann and her crew home safely," said Mark Wild, HS2 Ltd's chief executive. "Washwood Heath is set to become one of the most important sites on the entire HS2 network - the point at which the railway will be operated, controlled and maintained using the very latest digital technology."
Mary Ann dug out about a million tonnes of soil to create the structure, which will become the longest railway tunnel in the West Midlands. The earth which was excavated will be reused to support construction of a nearby network of 13 viaducts, officials added.
Posted by Mark A at 21:23, 29th April 2025
An on-the-ground account on this Substack blog. The conflict really is dismal.
https://martinrobbins.substack.com/p/i-visit-britains-most-expensive-farm
Posted by TaplowGreen at 08:22, 26th April 2025
This could prove calamitous for Bucks CC if HS2 appeals and wins.
Calamity and HS2 are never far apart.
Posted by TonyK at 19:58, 25th April 2025
Posted by Bob_Blakey at 13:37, 25th April 2025
The entire built-up area of Wendover is separated from the HS2 route, a chunk of which will be hidden in the Wendover Green Tunnel, by the A413. Planning application 25/00406/APP shows that the chamber was proposed to be located on farmland to the NW of Wendover and it appears that it was the Kings Farm track which could have been extended to provide access.
Personally, given the cost so far, I would have approved a new direct access from the A413 with a bridge over the railway.
Posted by TaplowGreen at 08:50, 25th April 2025
More money required for the Acton-Solihull line................
https://www.bbc.co.uk/news/articles/ce3qk6g4692o
Posted by ChrisB at 20:06, 26th March 2025
I'm not sure that this is within the GWR remit is it? If the DfT want them to stop, they'll errr....stop.
Posted by TaplowGreen at 14:09, 26th March 2025
Claire Young is MP for Thornbury and Yate, in a constituency which includes a section of the main London to South Wales line on it with a single station which at present does not have a regular scheduled local service to London, being served by only by trains from Cardiff running to and through Bristol toward the West Country - indeed as far as Penzance.
Are the 26 trains mentioned a fresh announcement or are they the class 175 units which will be very welcome.
Is Claire the LibDem Transport spokesman? That would explain why it was her that mentioned these?
I reckon it's the 175s (correct number of units).
Paul Kohler - MP for Wimbledon - in the Commons
Baroness Pidgeon - in the Lords
So she isn't the transport spokesperson, doesn't have a station in her constituency which will be affected either way, and has started announcing things that are already under way, something traditionally done by the government rather than the opposition. The news that trains will not be stopping at a station that hasn't been built yet is unlikely to have champagne corks popping amongst even her more fervent supporters, and will only be true for as long as the various bodies involved think that trains stopping at OOC is not a good idea.
https://www.devonlive.com/news/devon-news/big-u-turn-controversial-railway-10039622?utm_source=linkCopy&utm_medium=social&utm_campaign=sharebar
Posted by TonyK at 17:32, 24th March 2025
Posted by grahame at 16:40, 17th March 2025
Posted by ChrisB at 16:21, 17th March 2025
Posted by Western Pathfinder at 16:03, 17th March 2025
 Requiring of a rather hefty pinch of salt thinks me.
Posted by stuving at 15:11, 17th March 2025
Then either none do & the current timetable would still work on the main lines, OR this will mean that there will be fewer paths available per hour as some stop (so the more 'locals' - Cotswolds, Bristol (poss not, as XC direct would be quicker than via OOC), Cardiffs, WSMs) while others don't....
Or else it is a very easy promise to make, since by the time Old Oak Common station opens there won't be any Great Western Railway. And as an operational timetabling matter, I would doubt any promise so far into the future, even from the provisional GBR, was worth much.
Posted by grahame at 14:49, 17th March 2025
Bluesky post from an MP, an update on Old Oak Common services.
"After much lobbying from @libdems.org.uk MPs, I am glad to confirm Great Western Railway trains travelling from the South West to London Paddington will not stop at Old Oak Common as standard - as had been proposed - and that there will be an additional 26 trains added to the fleet."
Are the 26 trains mentioned a fresh announcement or are they the class 175 units which will be very welcome.  The use of the word "additional" suggests to me a net fleet growth, but other reports including from GWR suggest that some of the trains in this transfer are not additional but rather as replacement for other trains being withdrawn.
Posted by ChrisB at 14:31, 17th March 2025
Posted by Mark A at 14:19, 17th March 2025
https://bsky.app/profile/claireyoungmp.bsky.social/post/3lkgyydpypk26
Posted by TonyK at 19:00, 12th March 2025
Well - hopefully both the PAC and vast number of UK-knockers might take some comfort from this take from DW (Germany's answer to BBC) -
https://www.youtube.com/watch?v=VlDChSmyf-0
Seems like it's a universal problem!
Even that's a little simplistic. Yes, the USA laid 2000 miles of track in the 1860s, but they don't have quite the same supply of cheap labour as back then from Ireland and China. Nor do we have the human power available to Brunel back in the olden days. As to "doomed" - depends on which bit of HS2 you mean.
Posted by eightonedee at 21:40, 10th March 2025
Posted by TaplowGreen at 07:35, 28th February 2025
Another roasting for HS2 from the Public Accounts Committee........
https://www.constructionnews.co.uk/civils/hs2/hs2-civils-contracts-slammed-as-extremely-poor-value-for-money-28-02-2025/
Posted by ChrisB at 13:41, 26th December 2024
Added 75mins and a reversal
Posted by PhilWakely at 22:28, 25th December 2024
I think hourly 9/10-car IET diversions into Waterloo, in addition to the Euston ones, would make more sense but were ruled out, this Christmas at least, for a few reasons.   As well as the Westbury blockade there's nothing running between Woking and Basingstoke until 5th January so diversions from Exeter via Yeovil/Salisbury weren't possible.
I presume that diverting into Waterloo via Kensington Olympia and Clapham Junction was ruled out early?
Posted by IndustryInsider at 20:24, 25th December 2024
Posted by Mark A at 18:31, 25th December 2024
What real difference would a short DMU running a handful of services a day through to Waterloo actually make in the grand scheme of things?  Not much I would suspect.
Thinking of passenger flows + an Old Oak Common blockade, if people did take to a Waterloo - Bristol route in numbers, that's a good point. From the passenger's point of view, unless swamped, it's an opportunity to provide a functional and more accessible alternative though.
The other qualities offered by the route are for another (extant and already well-filled) thread though. If it had not been for the pandemic, they'd still be in the timetable and we'd be grumbling about the Salisbury-Trowbridge blockade suspending them for much of January.
PS Seasons greetings, all.
Posted by grahame at 12:33, 25th December 2024
Indeed - but then an hourly through service all stations Bristol Temple Meads to Salisbury ... and onwards all stations to Basigntoke, Farnbourough, Woking, Clapham Junction and Waterloo ... would make a difference.
"Where would the trains and crews come from?".   Well - the Bristol to Westbury is already there. In many hours that extends to Salisbury already, and in many of those it doesn't it carries on to Salisbury.   Salisbury to Waterloo is already there.  So it's a bit of joining up that's needed and NOT a handful of (extra) services that need to be found from somewhere.
I do accept that at times that the line into Paddington is not available, but Westbury IS, the though Bristol to London (Waterloo) service would be distinctly busy.   I'm not sure where we're going with 158s, 159s, 165s, 166s and 175s next year - but it's not beyond imagination to suggest that 158s could be replaced on Cardiff - Exeter services by IETs not headed to London on those days, with the 158s used to make the Bristol - Salisbury services up to 5 carriages, with 8 onwards to Waterloo.
Posted by IndustryInsider at 11:40, 25th December 2024
Posted by grahame at 21:44, 24th December 2024
Indeed, and seven-days-a-week well-timed through trains between Bristol and Waterloo would give some passengers the alternative that's needed.
There used be the Maesteg to Waterloo service in the early hours.
Posted by Mark A at 17:13, 24th December 2024
Posted by ChrisB at 16:34, 24th December 2024
Paddington passengers face '180 days of station disruption' due to HS2 work at Old Oak Common
From The Standard
Passengers heading in and out of Paddington face more than 180 days of disruption due to HS2 works – including 43 days when the station is shut entirely, MPs have been told.
This includes a three-day shutdown immediately after Christmas when the Great Western main line is closed for three days between December 27-29 to enable work to be carried out at Old Oak Common station.
The full extent of the likely disruption to journeys in and out of Paddington emerged during a parliamentary debate.
Max Wilkinson, the Lib Dem MP for Cheltenham, said there would be five years of “widespread disruption” – followed by “every train between the west and south Wales and London” being slower once Old Oak Common station opens around 2030.
He said there would be 29 days of disruption in 2024/25, 30 in 2025-26, 41 in 2026-27, including 14 days when no trains run at all, 34 days in 2027-28, including 11 days when no trains run at all, and 47 days of disruption in 2028-29, including 18 days when no trains run at all.
This totals 181 days of disruption – including 43 days of full closures – and excludes any disruption in 2029/30, as the impact of works that year is not yet known.
Mr Wilkinson told a Westminster Hall debate that most of the disruption would fall “on Sundays and at Christmas”.
He said: “The number of constituencies that will be impacted by the work is absolutely huge. It will be every constituency in Cornwall and Devon, most of Somerset, Bristol, parts of Herefordshire and Worcestershire, south Wales, Gloucestershire—my own area of the country—Wiltshire, Berkshire and Oxfordshire.
“That is a lot of people whose journeys will be slower for a long time, and a lot of people who will have to make alternative arrangements when trains are cancelled.”
Tessa Munt, the Lib-Dem MP for Wells and Mendip Hills, said the closures could have a huge impact on the Glastonbury festival.
“The Glastonbury festival finishes on a Sunday, and many people travel in and out of Glastonbury on a Sunday, so this will be incredibly damaging to that event,” she said.
Mr Wilkinson said that it was “no exaggeration to say that weekends are a nightmare” and demanded improvements to Great Western Railway services on Sundays.
The 14-platform Old Oak Common station, which is costing about £2bn to build, will be used as HS2’s southern terminus until the new HS2 station at Euston is built. There is no opening date but it is likely to be around 2040.
Old Oak Common will also act as an interchange with HS2 for the Elizabeth line, Great Western Railway services and the Heathrow Express.
Mainline trains that stop at Old Oak Common will have four to seven minutes added to their journey times.
Even “fast” trains that run through the new station without stopping – the exact stopping pattern is yet to be determined - will have up to 90 seconds added to their journey times because the mainline track is being realigned and will curve through the new station.
During the Paddington closures, some Great Western Railway services will divert to Euston.
Transport minister Lilian Greenwood said it was impossible to build Old Oak Common “without some disruption to existing services”.
She told MPs: “The next significant blockade had been due to take place in December 2026, but this is now being re-planned to a later date by HS2 Ltd. Further detail on the future works plan will be shared as soon as it is available in the spring.”
Rail minister Lord Hendy is in discussions with HS2, Network Rail and the train operating companies in a bid to reduce the impact of the work at Old Oak Common.
He said in a written parliamentary answer: “Old Oak Common is estimated to be operational between 2029-2033.
“The large Christmas possessions that enable services to run on the new track layout, through Old Oak Common station, are currently being re-planned and further information will be available from Spring 2025.”
A Network Rail spokesman said: “Most of the work will take place without customers noticing, at weekends or overnight.
“However, where this isn’t possible, the industry is working together to comprehensively plan the work to reduce the impact to passengers as much as possible, as well as include any changes into timetables well in advance so customers can still travel by train.”
Posted by CyclingSid at 11:53, 23rd December 2024
Not quite sure whether this is an attempt to sugar the pill of the holiday disruption https://www.bbc.co.uk/news/articles/c1j05d296r1o
Posted by ChrisB at 21:13, 18th December 2024
From The Telegraph
HS2 chairman quits in wake of £100m ‘bat shed’ comments
The chairman of HS2 is to step down after the Government said that the estimated £66 billion cost of the rail project was not an “accurate or reliable” figure.
Sir Jon Thompson, who said last month that a “bat shed” covering 900 metres of HS2 tracks near Aylesbury would cost £100 million to build, announced he will leave his role in the spring.
It came as Heidi Alexander, the Transport Secretary, said in a progress report published on Tuesday that there was doubt over forecasts that the cost had spiralled to between £54 billion and £66 billion – up to double the original estimate of £33 billion.
The report warned that the estimate included parts of the since-cancelled Euston station project. It added: “As it doesn’t take into account this work, or factor in private financing for Euston – which this government is committed to securing – we do not think these figures are accurate or reliable.
“It remains highly uncertain and subject to further assurance and has not been approved by the HS2 Ltd Board or [The Department for Transport] ... but has been included here for transparency.”
The £66 billion estimate, which does not take inflation into account, is based on costings from 2019.
The report said the project’s spiralling budget had been caused by factors including “environmental and planning compliance, as well as the disruption caused by external factors, primarily Covid and the Ukraine conflict.”
So far, £32.8 billion has been spent on HS2 since it was approved in 2012, and the latest estimates come following years of warnings that its spending was out of control.
In 2020 the Public Accounts Committee said the Department for Transport (DfT) had “failed to provide Parliament with clear warning that the programme was going off-course and value for money was at risk”.
Rachel Reeves, the Chancellor, said in October that HS2 would be built to Euston, ending uncertainty brought about by Rishi Sunak axing public funding for the line’s final 4.5-mile stretch into central London.
Instead, both the required tunnels and the extension to Euston station necessary to serve HS2 would have to be privately funded, the Conservative former prime minister said last year.
Sir Jon’s departure from HS2 comes after a new chief executive was appointed to the beleaguered rail project in May.
Mark Wild, a former boss of Crossrail, took up the post this month. The report said: “We have made it the number one priority of the new chief executive, after safety, to drive costs down.”
Sir Jon is expected to become the new chairman of the company behind Sports Direct, businessman Mike Ashley’s Frasers Group, Sky News reported in November.
A spokesman for HS2 Ltd said that “clearly changes in delivery are needed” for the project to “realise its full potential”.
They added: “Mark Wild joined as our new chief executive this month and clearly recognises the programme’s serious cost challenges.
“He is now leading a comprehensive review of HS2’s cost and schedule which will report into government next year and lead to a full reset of the project.”
A DfT spokesman said of the £66 billion costings: “These estimates are out of date and don’t take into account the urgent measures this government took to get the project back under control or the previous government’s decision to cancel Phase 2 and attempt to secure private funding for Euston.
“The Transport Secretary has asked HS2 to urgently provide updated and clearer estimates of the project as soon as possible and we have made it the number one priority of the new chief executive to drive costs down.”
Posted by ChrisB at 21:09, 18th December 2024
From Evening Standard
Euston HS2 station: New twist in saga as Government says £5bn terminus will only have six platforms
The new HS2 station at Euston will have just six platforms, the Government has confirmed.
Rail commentators fear this could result in a lack of capacity should HS2 ever be extended north of Birmingham.
Details about the Labour government’s plans emerged on Tuesday via a parliamentary written answer from rail minister Lord Hendy.
He had been asked by Lord Berkeley, a Labour peer who has taken a close interest in the cost of HS2, how many HS2 trains per hour were planned at Euston, and how many station platforms they were expected to occupy.
Lord Hendy replied: “The new HS2 station will consist of six platforms, which can support up to 10 HS2 trains per hour.
“No decisions have been made on the train services that will run when HS2 opens, and this will be subject to future consultation.”
Gareth Dennis, the rail engineer, author and commentator, told The Standard: “Unless there is a clear plan that integrates both station sites into one shared station with appropriate adjustments, this will kneecap the GB rail network for a generation or more.
“The idea that a future high speed rail network of 17 trains per hour or more is not being planned for is extremely worrying.
“To lose the opportunity to build a large, spacious and resilient station in London will have massive impacts on the ability to run local services in the Midlands and the North for decades.”
William Barter, a rail consultant, said that having only six platforms at Euston would mean that HS2 would never be able to fulfil its full potential. He described the situation as “lunacy”.
Steve Coe, a former assistant general secretary at the rail union TSSA, said building only six platforms was “incredibly shortsighted”.
He added: “Unless Euston is rebuilt with 11 platforms, HS2 will never be able to provide the increased capacity that our railways desperately need. A huge amount of money spent for relatively little gain.”
There will also be six HS2 platforms at Old Oak Common station in north-west London, which will be used as the line’s southern terminus when HS2 trains start running around 2030.
However the Old Oak Common HS2 platforms will be 400m long - meaning each can accommodate two HS2 trains at a time.
There is no opening date for the HS2 station at Euston.
Lord Hendy recently told the transport select committee that his aim was for the HS2 station at Euston to share a concourse with a renovated mainline station.
The original 2015 plan was for the HS2 station at Euston to be built in two phases, adjacent to the mainline station, and have 11 platforms.
But following the Oakervee review in 2020, the Department for Transport switched in 2021 to a “simpler design” for Euston, of 10 platforms that were all to be built in a single phase.
Then in 2023, as HS2’s costs continued to escalate, the Tory government switched to a six-platform design then ordered the work at Euston to be mothballed for two years.
Several months later, in October 2023, the then Prime Minister Rishi Sunak told the Tory party conference that he had decided to axe HS2’s northern leg.
Mr Sunak also confirmed that private sector investment would be needed to deliver the HS2 station at Euston.
It was also reported on Tuesday that the cost of completing the first phase of HS2 between London and Birmingham had increased by £9bn, to £80bn at current prices.
When work at Euston was paused in 2023, the cost of the HS2 station was estimated to have increased from its original £2.6bn budget to £4.8bn (both at 2019 prices).
In a 2022/23 report, the public accounts committee said the £2.6bn budget for Euston was “completely unrealistic” and said that, eight years after the scheme was devised, the DfT “still does not know what it is trying to achieve with the station and what sort of regeneration it will support”.
Switching from an 11-platform to a 10-platform design meant that £106m of work was wasted, according to the National Audit Office.
Posted by johnneyw at 19:23, 19th November 2024
The Beeb reports today's discussions between Louise Haigh and the Metro Mayors for Manchester and the West Midlands.
Apparently resurrection of HS2 Birmingham to Crewe remains a dead duck but a slower line along the route was included in the options discussed along with upgrading the WCML.
Here's the link:
https://www.bbc.com/news/articles/c4gz832149eo
Posted by stuving at 23:44, 18th November 2024
The maps.nls site has an early 1:500 OS map from those times - it's a series of sheets covering London and they're selective in what they shows (and gives the impression that the surveyers were more than a little overwhelmed at the rate of the changes they saw.)
The map  catches both main lines and the West London line in course of construction. It's a map that (eventually) made my scalp prickle as I imagined what the surveyors saw as they went about their work. Here's the place where the two lines (almost) converge.
That was the "skeleton survey", and was only meant to show roads, including frequent spot heights, for the Metropolitan Commissioners of Sewers. NLS have more about the rather complicated history of this set of maps. The published sheets had been reduced to 1:5,280 (12") scale, but the limited amount of fine detail conceals that.
When the survey started in 1848, both railways were already operating, though parts of Euston station were still not finished. There was only a temporary structure at Paddington, and the first permanent one was not started for several years. NLS don't have the map sheets for the Euston area, and at Paddington (sheet VI.SE) there is an empty space with "Paddington Ry Stn (Great Western Terms)" written next to Bishop's Road.
Posted by Mark A at 11:59, 18th November 2024
Thanks for this.
https://maps.nls.uk/geo/explore/#zoom=15.1&lat=51.52979&lon=-0.23174&layers=250&b=OSLeisure&o=100
Posted by stuving at 23:37, 17th November 2024
Is it the case that in the very early days, Euston was to be the terminus for the GWR and then there was a change of plan, and it's that that brings the two lines relatively close?
Yes, in the sense that the 1834 bill, and the 1835 Great Western Railway Act, only provided for that. At the London end the railway was described as "terminating by a junction with the London and Birmingham Railway in a certain field lying between the Paddington Canal and the turnpike road leading from London to Harrow on the western side of the general cemetery in the parish or township of Hammersmith". However, building started with Paddington as the future terminus, as authorised by the 1837 Great Western Railway Paddington Extension Act.
The route of the LBR was determined before the GWR as a project got going, mainly by topography and who owned the land. So I think that first GWR bill was done that way for speed, since there was competition to get acts for these major railway routes. A western route from Paddington had already been proposed by the London and Windsor Railway in 1833, though nothing came of that. However, the LBR being very close to the line of the extension Brunel had in mind would have suggested this short-cut to getting their bill ready for Parliament
Posted by Mark A at 19:47, 17th November 2024
Posted by stuving at 19:23, 17th November 2024
Off to Acton, round the North London Line until it reaches the line into Euston
Sort of - though only 300 m of the distance is on the NLL itself. The route leaves the GWML at the entrance to Acton Yard, and runs up the goods lines (the Poplars) to Acton Wells Jn. Having crossed the Central Line, it leaves the NLL for a parallel goods line through the South West Sidings to join the WCML at Kensal Green Jn, where the West London line also joins from the other direction.
Work has started to electrify the Poplars, but that's not for the IETs which can use diesel power. There is also a need for Cl 345s to be moved between the two ends of the Elizabeth Line when it is split at Old Oak Common.
Posted by ChrisB at 18:02, 17th November 2024
Posted by RailCornwall at 17:42, 17th November 2024
Could anyone detail the route being taken from Reading to Euston and vv. during the Old Oak Common blockades?
Posted by ChrisB at 21:24, 7th November 2024
From the BBC
Bat safety shed will cost £100m, says HS2 chairman
A special barrier that will be built to protect rare bats will cost £100m, according to the chairman of HS2 Ltd.
Sir Jon Thompson told a rail industry conference the bat protection structure in Buckinghamshire was needed to appease Natural England, as bats are legally protected in the UK.
The 1km (0.6 mile) curved barrier will cover the tracks alongside Sheephouse Wood near Calvert in Buckinghamshire, to prevent bats being disturbed by high-speed trains.
Sir Jon said there was "no evidence that high-speed trains interfere with bats".
"We call it a shed," he said. "This shed, you're not going to believe this, cost more than £100m to protect the bats in this wood."
Natural England said it had not required HS2 to "adopt this structure", but its role had been to "comment on whether the proposed mitigations will work".
Other more expensive options, including a bored tunnel and re-routing the railway, were considered.
After receiving the green light from Natural England for the design, HS2 Ltd was forced to spend "hundreds of thousands of pounds" on lawyers and environmental specialists because the local council did not approve the work, Sir Jon said.
"In the end, I won the planning permission by going above Buckinghamshire Council's head," he explained.
Buckinghamshire Council opposes HS2 and has previously criticised the project, external for "unnecessarily damaging Sheephouse Wood".
The deputy cabinet member for HS2, Peter Martin, said: "Whilst the council wishes to protect species such as Bechstein's bats, one of the country’s rarest species, it was never supportive of what seemed like extremely excessive costs for a single structure.
"HS2 Ltd has always been adamant that the bat tunnel structure, which has been designed and built by HS2 Ltd’s own contractor, and the associated costs, were necessary, but it is not something we insisted on."
'Trite'
Sir Jon claimed the issue was an example of the UK's "genuine problem" with completing major infrastructure projects.
He told the Rail Industry Association's annual conference that HS2 Ltd had been required to obtain 8,276 consents from other public bodies in order to build phase one of the railway between London and Birmingham.
He said: "People say you've gone over the budget, but did people think about the bats [when setting the budget]?
"I'm being trite about it, but I'm trying to illustrate one example of the 8,276 of these [consents]."
Natural England Chief Operating Officer Oliver Harmar said: "Development and nature must go hand in hand".
"HS2 Ltd is required by legislation to avoid harm to the environment, and it is for them to make choices, consider risks, and factor in costs when deciding how to do this, whether by avoiding species and sites protected for nature or by investing in mitigation to limit harm where the route passes through sensitive sites."
Sir Jon, who has led the project since Mark Thurston left his role as chief executive in September 2023, warned in January that the estimated cost for phase one had soared to as much as £66.6bn - compared to the £37.5bn forecast in 2013
Posted by Mark A at 17:32, 30th October 2024
Mark, thank you for the long response. Might we both agree that one of HS2's weaknesses is its poor integration with the "classic" network?
Not at all, thankyou for posting that. I certainly agree with your point if HS2, as built, is London to Birmingham + its link to the classic WCML at Handsacre as in that form it doesn't effectively transfer load from the classic railway.
Sunak's decision crippled the product of many years planning and much physical work - a stark reminder of the perils of bad governance.
Stop-start fashion, it's now being taken to Euston, but the terminus must be at great risk of being boxed in with space constraints and hence lack of futureproofing.
There will be several ghosts in the resulting machine, people attracted to unrealised infrastructure will wonder at Curzon Street's unused platforms, others may find themselves on canal boats passing the already built stub that will carry phase 2a - and which currently comes to an abrupt end at one side of the Trent and Mersey canal, the bridge that was intended to carry the line across the water unbuilt.
Brindley's spirit, when not dreaming of rolling his canals around the contours, or of the days when everyone was wrestling with the principle of a staircase lock on UK soil, would be shaking his head in wonder.
Posted by Chris from Nailsea at 15:12, 30th October 2024
Some good news from the Chancellor's Budget - from the BBC:
https://www.bbc.co.uk/news/articles/cdxl1zd07l1o
Transport
£2 cap on single bus fares in England to rise to £3 from January
5p cut to fuel duty on petrol and diesel, due to end in April 2025, kept for another year
Commitment to fund tunnelling work to take HS2 high-speed rail line to Euston station in central London
Commitment to deliver upgrade to trans-Pennine rail line between York and Manchester, running via Leeds and Huddersfield
Posted by eightonedee at 13:59, 30th October 2024
Under normal circumstances, I might sniff at Mr Gilligan's pedigree, but on the four flaws, I feel he may have some good points. As for "Green Signals"...
But - Gilligan's transport experience seems largely as Cycling Czar under Boris Johnson when the letter was Mayor or London, a political appointee on TfL's board under Shapps as Johnson's transport minister. As a journalist his career (as per his Wikipedia profile) included twice costing his newspaper employers substantial libel damages. So - limited experience, none of running any kind of substantial infrastructure project or transport operation outside the M25
Messrs Bowker and Harris of Green Signals are respectively experienced senior manager from major infrastructure projects and transport undertakings and a very experienced senior rail journalist. I think I know which I'd be inclined to take seriously.
Posted by Electric train at 07:42, 30th October 2024
There is integration with the classic network North of Birmingham, the integration at the London end, the link to HS1 was scrapped many years ago, although the OOC - EUS tunnels will have passive provision; however Old Oak Common Station will provide a major interchange.  The major integration that were scrapped, the links to Leeds and Derby etc.
HS2 main purpose is capacity release on the WCML South of Crewe
Posted by Trowres at 23:45, 29th October 2024
Posted by Mark A at 22:20, 29th October 2024
This may be my first post on HS2; a subject I have previously chosen to avoid.
Mr Gilligan, a former advisor to Boris Johnson and Rishi Sunak, blamed four “foundational flaws” – the wrong route, wrong speed, bad connections and “ratchet” project management – for the current state of the line.
Under normal circumstances, I might sniff at Mr Gilligan's pedigree, but on the four flaws, I feel he may have some good points. As for "Green Signals"... could we have some more objective commentary, please?
Every sympathy with people who avoid the subject of HS2...  but...
Ah, Mr Gilligan. To pull a few phrases from that piece:
He said that HS2 should have chosen a “better route” along the M40 corridor. - That's the M40 that crosses several sensitive landscapes and after protest had to be routed to take a big bight around Otmoor.
"slicing through ancient woodland" - HS2 has actually done very little slicing of ancient woodland, the impact on ancient woodland has been much overstated by the Woodland Trust among others.
"lowered speed aspirations from 250mph to avoid costlier tracks" - HS2 is about capacity and HS2's speed maximises capacity - but yes, involves more energy to shift trains and also demands more of alignments, so, yes, the balance may perhaps not have been right, with an element of 'Our trains will be faster than your trains'. Slab track is expensive but does though offer big maintenance savings. Is one aspect of HS2 that responsibility for the maintenance has been pushed onto the builders for many years, one of the factors that has pushed up the quotes?
"Former HS2 plans to connect via a “15-minute walk through the streets of Birmingham"" - that's a bit naughty. Onward HS2 trains will not touch Curzon Street, and Birmingham's metro will connect Curzon Street and New Street. (it would have been good if they'd been one big station though).
According to the transport advisor, almost half of the benefits of HS2 will be felt in London and the southeast even if the full scheme is delivered – degrading links from smaller cities such as Stockport, Stoke and Coventry on the main lines. - On to the naughty step with that one too. A principle of HS2 is to free up capacity on the classic network. The likes of Stockport, Stoke and Coventry can then have the opportunity to benefit from the additional capacity released.
He also called proposals for ‘HS2 light’ a “delusion and a trap”. - Hang on, that's one of his foundational flaws. He's just alleged 'Wrong speed' but when a 186mph alternative is floated, he doesn't like that either. What's Andrew's idea for addressing the WCML issues at Colwich, Stafford? Given that one option is shovel ready to Crewe, it might be a good idea to build that, as the legislation is already in place.
"the wrong route" - Concerning the London to Birmingham section - HS2 phase 1 - while we're well into sunk cost territory on that, HS2 phase 1 as a freestanding railway isn't viable - add the length to Crewe and the position improves greatly, with a big win for the classic network too.
Posted by Trowres at 21:27, 29th October 2024
Posted by Electric train at 19:07, 29th October 2024
Gilligan again....
The self proclaimed rail expert ................. Green Signals gave him a glowing endorsement  ............ NOT
Posted by TaplowGreen at 17:27, 28th October 2024
Gilligan again....
There's a song there somewhere..........
Posted by ChrisB at 17:25, 28th October 2024
Gilligan again....
Posted by TaplowGreen at 16:11, 28th October 2024
"Doomed from the start"
https://www.independent.co.uk/travel/news-and-advice/hs2-doomed-andrew-gilligan-government-b2636742.html
Posted by TaplowGreen at 10:27, 20th October 2024
I'm not sure that this ministerial oversight will make much difference, that ship sailed some time ago*
https://www.bbc.co.uk/news/articles/cr54gv99dz1o
*obviously not a P & O ship!!!
Posted by Sixty3Closure at 17:12, 19th October 2024
Posted by ChrisB at 10:34, 17th October 2024
From the i paper
HS2 ‘will run from London Euston to Crewe’ as Government prepares to reverse cut
The Department for Transport has pushed back on reports that the Government is preparing to announce that HS2 will run from London Euston to Crewe.
Rishi Sunak’s government cancelled the northern leg of the line to Crewe and Manchester last year, meaning that trains are currently expected to stop at Birmingham. However, LBC reported today that the Government was considering reviving Phase 2A of the project, which would extend the line from Birmingham to Crewe.
A Department for Transport spokesperson said: “We have always said we won’t be taking plans for HS2 Phase 2 [between Birmingham and Manchester] back off the shelf after the Conservatives took a wrecking ball to the project and allowed costs to spiral completely out of control.
“But we are committed to delivering better rail connectivity across the north, as set out in our manifesto.
“Transport is an essential part of the Government’s mission to rebuild Britain and grow our economy.”
later
Department for Transport dismisses reports of plans for Birmingham-Crewe HS2 link
No announcement on a link between Birmingham to Crewe is being planned, the department has said.
Wonder where LBC got their info?
Posted by TaplowGreen at 05:39, 10th October 2024
HS2 "could go to Euston" HMG announce
https://www.bbc.co.uk/news/articles/crm2843glmjo
Sensible IMHO.
Was any indication given as to how much it'll cost and.........Oooooooooo's gonna pay for it?
Privately funded or taxpayer?
If as UK PLC we look at HS2 as a 100 to 120 year investment over that time it will more than pay for itself.
A comparison is Crossrail all the naysayers said leading up to and during its construction that no one would ever use it ant would be a white elephant.
In the UK we worry too much about the cost of something and not the value of it
Cost is objective, value is subjective.
Posted by anthony215 at 17:05, 9th October 2024
I think Labour are changing the rules with borrowing for large scale infrastructure projects so I think hs2 to Euston and hs2 lite to Crewe at least will benefit.  To Euston it's⁸ a no brainer and it's a cheap time to do it as everything is in place ready.
I do hope provisions are made toa allow a hs2  eastern leg to Leeds to be resurrected in the future as the east coast mainline and midland are fast filling up.
A future GWML HS line we need to start planning for especially with some many new services proposed etc
Posted by bradshaw at 08:35, 9th October 2024
The Times reporting that HS2 lite may built.
https://www.bbc.co.uk/news/articles/c78dxlvqy25o
BBC News showing all the national newspaper front pages. For the Times you have to scroll down to read it, the fourth from the top.
Posted by Electric train at 08:06, 9th October 2024
Sensible IMHO.
Posted by Chris from Nailsea at 22:32, 8th October 2024
Exactly.
Posted by JayMac at 22:27, 8th October 2024
No indication given.
It could all be covered by our Prime Minister's personal wardrobe budget.
Which wasn't funded from the public purse.
Posted by Chris from Nailsea at 22:23, 8th October 2024
Posted by ChrisB at 21:03, 8th October 2024
From the Guardian
Building HS2 to Euston and Crewe could pay for itself, analysis finds
Extending high-speed line at both ends would let government charge more for rights to run it, rail leaders say
Building HS2 all the way to London Euston and Crewe could save the government money by enabling it to lease the line out for much more, rail industry leaders have told ministers, as the Treasury weighs up whether to fund tunnels to central London.
The High Speed Rail Group proposes selling the rights to run the line as a long-term concession – on a similar basis to the HS1 rail route linking the capital to the Channel tunnel.
Such a concession would be worth about £20bn if fully developed from central London and joining lines to northern cities, but just a fraction of that under current plans to terminate at Old Oak Common and Birmingham, according to an analysis for HSRG.
The coalition of rail and engineering companies, whose members include Hitachi, Alstom, Siemens and Avanti West Coast, argues that spending billions more now to reach Euston and Crewe would still save the Treasury £3.5bn in the long run.
The claims come as the government decides whether to reinstate tunnelling work to Euston, at a critical juncture in construction. Two giant tunnel-boring machines from Germany are still being installed at Old Oak Common despite the last government suspending wider works, after construction contractors warned that it would be hugely more costly and difficult to contemplate tunnelling once the west London station was completed.
While the transport secretary, Louise Haigh, has indicated the government wants to ensure HS2 reaches into central London, the chancellor, Rachel Reeves, has also asked ministers to draw up billions of pounds’ worth of infrastructure cuts.
According to some reports, Reeves is nonetheless planning to announce guarantees for HS2 to Euston in the 30 October budget. However, the funding mechanism is not clear, with Labour having said it would not overturn Rishi Sunak’s shock axing of HS2’s construction into central London and north of Birmingham last October.
Although Labour has pledged to nationalise train operating companies, it has also wooed private investors to potentially build more infrastructure.
HS1 was sold by the government in 2010 for £2.1bn as a 30-year concession to two Canadian pension funds, which resold the rights to other private equity investors in 2017 for £3bn. Concession owners recoup the investment through track access charges to operators such as Eurostar and income from St Pancras station.
In the analysis by HSRG and the policy group Greengauge 21, the current line from Old Oak Common to Birmingham Curzon Street will cost £47bn, but its limitations mean the railway would have a potential concession value of only £5bn. However, building on to Euston and Crewe, while costing another £11.5bn, could make it worth £20bn.
The National Audit Office, among others, has warned that the truncated HS2 risks worsening current services north of Birmingham owing to a lack of capacity when high-speed trains join the overcrowded west coast line.
Dyan Perry, the chair of HSRG and a former chief executive of HS1, said she “appreciates that the forthcoming budget will involve ministers making tough choices. However, short-term decisions to cut investment into infrastructure would be deeply damaging to the UK, creating uncertainty and jeopardising investor confidence.
“We strongly urge Treasury officials to carefully consider our recommendations and take action to ensure the UK can fully realise the benefits of a connected rail network.”
The wider fate of Euston station is still to be decided, with uncertainty over HS2 putting full rebuilding on hold. The Department for Transport and Network Rail last week announced a short-term plan to urgently improve the overcrowded and unappealing terminus, including immediately turning off the much-criticised enormous advertising screen.
Re: HS2 - Government proposals, alternative routes and general discussion
Posted by Timmer at 19:21, 8th October 2024
Slightly off topic but I've heard go ahead will be given for a new bakerloo line fleet
Really hope so as the Bakerloo line is desperately in need of new stock. Good for jobs too that an add on order to the Piccadilly line order goes ahead.
Posted by ChrisB at 16:22, 8th October 2024
Posted by TaplowGreen at 15:52, 8th October 2024
Sensible IMHO.
Posted by IndustryInsider at 14:45, 8th October 2024
That had to happen at some point soon!
Posted by anthony215 at 13:56, 8th October 2024
Posted by TonyK at 12:47, 8th October 2024
Sensible IMHO.
IMHO too. Other reports have a stronger "will go" slant to them.
Posted by broadgage at 11:54, 8th October 2024
Sensible IMHO.
Posted by Electric train at 09:52, 23rd September 2024
Not sure if this is covered elsewhere but a report in The Times today (12/09/24). Probably sounds familiar to anyone who's worked in Project Management.
"The absence of a guiding mind, a single accountable individual in Westminster or Whitehall taking ownership of HS2, led to runaway costs and ultimately the cancellation of the second leg of the high-speed railway project north of ­Birmingham to Manchester.
That is a key conclusion of a report by the Institution of Civil Engineers into one of the great national debacles of recent times, which says that the lack of ­a multi-decade commitment to such a large-scale infrastructure scheme left HS2 open to cancellation by a prime minister able to overturn predecessors’ decisions without recourse to parliament."
That ICE report is ICE Briefing Paper: The cancellation of HS2’s northern leg – learning lessons
I didn't get a clear idea from it of what might or could have been possible if the whole project had been better done from the start. Maybe that's too much to ask for! This commentary has no named author, so presumably it is an institutional opinion.
Two other ICE reports are relevant here. Civil engineering insights on HS2 and alternative proposals is a narrative of the project's evolution to 2022, with limited discussion of some of the cost-reducing alternatives proposed. And Reducing the gap between cost estimates and outturns for major infrastructure projects and programmes does pretty much what its title says. It has rather more about managing risk, unforeseen changes, and expectations than getting estimates that predict outturns.
HS2 has always been cursed by a bad client .......... the UK Government which from its inception has been a vanity project for various Government Sectaries of State, Ministers and Prime Ministers the need to build it as one of fastest in Europe 360 km/h (225 mph) and not at a more sedate speed of HS1 300 km/h (190 mph) or even just a 225 km/h (140mph) with more emphasise on the capacity and not the 15 mins off of the journey London / Birmingham.
Posted by stuving at 18:38, 22nd September 2024
Posted by TonyK at 18:15, 14th September 2024
It is not just about shaving time off of passenger journey time to Manchester and even Glasgow, the key thing it will do is leverage the capacity for freight that phase 1 of HS2 will creates South of Midlands
Exactly so. So long as it is built to take the planned HS2 trains, the speed is not vital. And if it transpires in years to come that speed is vital after all, track can be replaced using slab as it wears out. Tunnels and viaducts will surely use slab track anyway.
Posted by Electric train at 07:28, 14th September 2024
Analysis of this on the WNXX forum if anyone is interested - https://wnxxforum.co.uk/viewtopic.php?f=2&t=37546&start=425
In short, it's almost exactly the same route, a little more expensive in the long-run with ballasted track, a bit slower but still 85 minutes Euston to Manchester which seems pretty reasonable to me.
Posted by Noggin at 09:29, 13th September 2024
Posted by ChrisB at 08:08, 13th September 2024
The i paper appears to have picked up on this too
https://www.msn.com/en-gb/news/world/labour-will-look-at-hs2-north-replacement-as-mayors-point-to-70bn-growth/ar-AA1qu1uY?ocid=msedgdhp&pc=U531&cvid=8b95985b869f4d468b1e59c010bdd4de&ei=10
Posted by TaplowGreen at 07:13, 13th September 2024
Interesting alternative proposal?
https://www.msn.com/en-gb/news/uknews/plan-to-build-cheaper-version-of-scrapped-hs2-northern-leg-unveiled-and-journeys-would-only-be-15-minutes-longer/ar-AA1qu8Wq?ocid=msedgdhp&pc=U531&cvid=b541e92022844906803719db12943552&ei=11
A little ominously;
The report did not provide an estimated cost of the new project.....
However;
...."said financing should be "maximised from the private sector", with central and local governments "partnering to fund the balance".
Posted by Sixty3Closure at 12:24, 12th September 2024
